  4. Test Adapter Growatt v3.3.1
adaptergrowattpv-anlageshinesolartesttester
808 Beiträge 72 Kommentatoren 434.0k Aufrufe 63 Beobachtet
  • W Online
    W Online
    Wildbill
    #177
    @PLCHome-0 Ich hatte heute mehrfach mit der neuesten Version folgende Meldungen im Log, die ich so glaub noch nie hatte. Adapter hat sich dann jedesmal nach einem automatischen Neustart wieder gefangen und für 1-2 Stunden keine Meldungen geworfen, bis es wieder kam. Insgesamt drei oder viermal. Kannst Du damit was anfangen?
    host.iobroker-vlan100
    2022-08-11 13:02:13.074	error	instance system.adapter.growatt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-08-11 13:02:13.074	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-08-11 13:02:13.073	error	Caught by controller[1]: at runMicrotasks (<anonymous>)
    2022-08-11 13:02:13.073	error	Caught by controller[1]: at /opt/iobroker/node_modules/growatt/lib/growatt.js:252:45
    2022-08-11 13:02:13.073	error	Caught by controller[1]: at JSON.stringify (<anonymous>)
    2022-08-11 13:02:13.073	error	Caught by controller[1]: --- property 'socket' closes the circle
    2022-08-11 13:02:13.073	error	Caught by controller[1]: | property '_httpMessage' -> object with constructor 'ClientRequest'
    2022-08-11 13:02:13.073	error	Caught by controller[1]: --> starting at object with constructor 'TLSSocket'
    2022-08-11 13:02:13.073	error	Caught by controller[1]: TypeError: Converting circular structure to JSON
    2022-08-11 13:02:13.072	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    growatt.0
    2022-08-11 13:02:12.454	error	Converting circular structure to JSON --> starting at object with constructor 'TLSSocket' | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'socket' closes the circle
    growatt.0
    2022-08-11 13:02:12.453	error	TypeError: Converting circular structure to JSON --> starting at object with constructor 'TLSSocket' | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'socket' closes the circle at JSON.stringify (<anonymous>) at /opt/iobroker/node_modules/growatt/lib/growatt.js:252:45 at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
    growatt.0
    2022-08-11 13:02:12.451	error	unhandled promise rejection: Converting circular structure to JSON --> starting at object with constructor 'TLSSocket' | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'socket' closes the circle
    growatt.0
    2022-08-11 13:02:12.446	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Bin nach wie vor auf dem chinesischen Server.
    Gruss, Jürgen
    PLCHome 0P 1 Antwort Letzte Antwort
    • PLCHome 0P PLCHome 0
      Das mit dem KEY war es nicht. Ich hab gerade einen Testadapter gepostet. Der läuft jetzt bei mir seit 10:50 Uhr stabil
      Garf
      #178
      @plchome-0
      Bei mir sieht es ebenfalls stabil und fehlerfrei aus.
      • W Offline
        W Offline
        warp735
        #179
        @plchome-0
        hab mich grad an Rechner gesetzt und hatte diese Meldung auf m Schirm. Adapter war rot, wurde also gestoppt.
        • W Wildbill
          growatt.0
          growatt.0
          growatt.0
          growatt.0
          Gruss, Jürgen
          PLCHome 0P Offline
          PLCHome 0P Offline
          PLCHome 0
          schrieb am zuletzt editiert von PLCHome 0
          #180
          @wildbill said in Test Adapter Growatt v1.0.0:
          252:45
          circular structure to JSON --> ... ist gefixed
          Kannst du auf Unstable testen?
          G W 2 Antworten Letzte Antwort
            252:45
            Garf
            #181
            @plchome-0
            Den oben beschreibenen Fehler hatte ich auch. Jetzt läuft es wieder fehlerfrei.
              252:45
              W Online
              W Online
              Wildbill
              #182
              @plchome-0 sagte in Test Adapter Growatt v1.0.0:
              252:45
              Bin auf 1.1.17 hoch und schaue mal, ob bis morgen noch Meldungen auftauchen. Danke schonmal. 👍
              Gruss, Jürgen
              • W Online
                W Online
                Wildbill
                #183
                @PLCHome-0 So, seit gestern mit der 1.1.17 bleibt das Log endlich ruhig.
                Einzig heute Nacht gab es eine Meldung vom Adapter:
                growatt.0
                2022-08-13 03:57:31.230	error	Growatt exception: AxiosError: Request failed with status code 500
                Da ich mich aber meine zu erinnern, dass ich sowas immer wieder mal nachs zwischen 3 und 4 hatte wird das wohl der China-Server sein, der neu gebootet und kurz nicht erreichbar ist. 😊
                Also von meiner Seite sieht es jetzt sehr gut aus. Danke
                Gruss, Jürgen
                • W Wildbill
                  growatt.0
                  Gruss, Jürgen
                  PLCHome 0P Offline
                  PLCHome 0P Offline
                  PLCHome 0
                  #184
                  @wildbill Zwischen 3 und 4 trennen auch manche DSL-Router, vielleicht kommt die Meldung bei dir daher.
                    W Online
                    W Online
                    Wildbill
                    #185
                    @plchome-0 Nein, bei mir erfolgt die Trennung nur alle paar Monate mal, daran liegt es nicht.
                    Die Meldung kommt aber wirklich täglich exakt um 3:57 Uhr. Skript oder geplanten Adapter-Neustart kann ich ausschliessen.
                    Gruss, Jürgen
                    • W Wildbill
                      Gruss, Jürgen
                      moonsorrox
                      #186
                      Dieser Beitrag wurde gelöscht!
                      • M moonsorrox
                        [[topic:post-is-deleted]]
                        moonsorrox
                        #187
                        W 1 Antwort Letzte Antwort
                        • M moonsorrox
                          W Online
                          W Online
                          Wildbill
                          #188
                          • W Wildbill
                            moonsorrox
                            schrieb am zuletzt editiert von moonsorrox
                            #189
                            • M moonsorrox
                              W Online
                              W Online
                              Wildbill
                              schrieb am zuletzt editiert von Wildbill
                              #190
                                moonsorrox
                                #191
                                meine Frage wäre aber eine andere zu meinem Growatt 1500S der läuft mit diesem Modul bisher super, aber was ich garnicht heraus bekomme ist der Ertrag der Anlage für ein Jahr.
                                Ich bekomme alle Werte die ich brauche Tag, Monat und Gesamt, aber eben für 1Jahr nicht ist das bei allen Growatt so?
                                • M moonsorrox
                                  W Online
                                  W Online
                                  Wildbill
                                  #192
                                  @moonsorrox Bin mir gar nicht sicher, ob Du die Daten des Jahresertrags direkt auf der Growatt-Seite findest. Ich sehe da auch nur maximal den Monatsertrag und dann Total, aber nicht für das gesamte Jahr.
                                  Für derartige Auswertungen würde ich Dir aber eh den Sourceanalytix-Adapter empfehlen. Natürlich nicht nur für den Growatt, sondern für Zähler sämtlicher Art. Damit lässt sich sowas viel besser und granularer auswerten und Du bekommst auch Montas- und Wochendaten im Verlauf, so dass Du die gesamte Vergangenheit jederzeit sehen kannst.
                                  Gruss, Jürgen
                                  • W Wildbill
                                    Gruss, Jürgen
                                    moonsorrox
                                    #193
                                    @wildbill
                                    naja ich sehe bei Growatt eingeloggt schon die Jahre, also die 3 Jahre 2020, 2021, 2022 bis jetzt August jetzt als Balkendiagram, aber im ioBroker gibt es diesen Wert eben nicht.
                                      W Online
                                      W Online
                                      Wildbill
                                      #194
                                      @plchome-0 Da der Adapter heute mal wieder einen Haufen Fehler schmeisst, habe ich mal direkt server.growatt.com aufgerufen. Abgesehen davon, dass die Bedienung auf der Site gerade sehr sehr langsam war, zeigte mir der Browser (Safari) dort soeben auch einen Serverfehler 500 an. Also scheint es doch am Server direkt zu liegen. Warum da wohl manche (wie ich) mehr betroffen sind und andere anscheinend nicht (oder nicht so sehr), ist mir zwar unklar, aber damit muss ich wohl leben.
                                      Gruss, Jürgen
                                      • W Wildbill
                                        Gruss, Jürgen
                                        moonsorrox
                                        #195
                                        @wildbill
                                        ja ich habe es schon bemerkt das einige viele Fehler haben, andere eben nicht - ich habe aktuell keine Fehler
                                        Habe grad mal geschaut, aber ein Fehler habe auch gehabt
                                        2022-08-26 14:14:59.812 error Growatt exception: AxiosError: Request failed with status code 502
                                        W S 2 Antworten Letzte Antwort
                                        • M moonsorrox
                                          @wildbill
                                          W Online
                                          W Online
                                          Wildbill
                                          #196
                                          @moonsorrox Wenn ich schaue, welche Objekte sich im Gowatt-Adapter auswählen lassen, so sehe ich da auch nur eMonth und eTotal. Von Jahren ist da nix, also kommt das wohl auch nicht mit. Aber wie gesagt, mit dem sourceanalytix hast Du alls (und mehr) was Du brauchst.
                                          Gruss, Jürgen
