  4. Problem beim Löschen von Node Red
    5.8k
56 Beiträge 6 Kommentatoren 7.2k Aufrufe 9 Beobachtet
  • G guitardoc
    pi@raspberrypi:~ $ iobroker update
    Used repository: Latest
    Adapter    "admin"        : 6.2.17   , installed 6.2.17
    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
    Adapter    "cloud"        : 4.2.1    , installed 4.2.1
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "eusec"        : 0.9.4    , installed 0.9.4
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.0.0    , installed 6.0.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "logparser"    : 1.1.0    , installed 1.1.0
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "socketio"     : 6.1.8    , installed 6.1.8
    Adapter    "sql"          : 2.1.8    , installed 2.1.8
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
    Adapter    "web"          : 5.2.4    , installed 5.2.4
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 2.1.3    , installed 2.1.3
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    pi@raspberrypi:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v6.2.17
    system.adapter.backitup                : backitup       - v2.4.12
    system.adapter.cloud                   : cloud          - v4.2.1
    system.adapter.deconz                  : deconz         - v1.3.21
    system.adapter.discovery               : discovery      - v3.0.5
    system.adapter.email                   : email          - v1.1.3
    system.adapter.eusec                   : eusec          - v0.9.4
    system.adapter.feiertage               : feiertage      - v1.1.0
    system.adapter.flot                    : flot           - v1.11.0
    system.adapter.info                    : info           - v1.9.19
    system.adapter.javascript              : javascript     - v6.0.0
    system.adapter.logparser               : logparser      - v1.1.0
    system.adapter.nanoleaf-lightpanels    : nanoleaf-lightpanels - v1.2.0
    system.adapter.ping                    : ping           - v1.4.12
    system.adapter.scenes                  : scenes         - v2.3.9
    system.adapter.shelly                  : shelly         - v6.0.0
    system.adapter.shuttercontrol          : shuttercontrol - v1.4.14
    system.adapter.simple-api              : simple-api     - v2.7.0
    system.adapter.socketio                : socketio       - v6.1.8
    system.adapter.sql                     : sql            - v2.1.8
    system.adapter.telegram                : telegram       - v1.14.1
    system.adapter.terminal                : terminal       - v0.1.2
    system.adapter.vis                     : vis            - v1.4.15
    system.adapter.vis-map                 : vis-map        - v1.0.4
    system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
    system.adapter.vw-connect              : vw-connect     - v0.0.51
    system.adapter.web                     : web            - v5.2.4
    system.adapter.wiffi-wz                : wiffi-wz       - v2.2.1
    system.adapter.ws                      : ws             - v2.1.3
    system.adapter.yahka                   : yahka          - v0.13.1
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.email.0                  : email                 : raspberrypi                              - disabled
      system.adapter.eusec.0                  : eusec                 : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.javascript.1             : javascript            : raspberrypi                              - disabled
      system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
      system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
      system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
      system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wiffi-wz.0               : wiffi-wz              : raspberrypi                              -  enabled
      system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + instance is alive
    pi@raspberrypi:~ $
    @guitardoc
    iobroker start admin
    G 1 Antwort Letzte Antwort
      @guitardoc
      guitardoc
      @thomas-braun Das brachte nichts - AAAAABER… Reboot tut gut!!! Jetzt läuft alles wieder!! Adapter ist weg, ich komme überall drauf und alle Instanzen die laufen sollen sind grün!!
      Vielen Vielen Vielen lieben Dank euch für die kompetente Hilfe!!! Leider kann ich überall nur ein Sternchen vergeben…
      • G guitardoc
        GlasfaserG Offline
        GlasfaserG Offline
        @guitardoc
        Frage am Rande ... warum bist du komplett im BETA Zweig !?
        • GlasfaserG Glasfaser
          @guitardoc
          guitardoc
          @glasfaser Der Shuttercontrol-Adapter wird immer mal upgedated und ich finde da immer wieder mal Fehler drin und teste dann das Verhalten.
          Oder kann man das auch für einzelne Adapter festlegen?
            @guitardoc sagte in Problem beim Löschen von Node Red:
            Ich vermute, die Verzeichnisse müssen wieder gelöscht werden?
            Ja. Wo auch immer die jetzt wieder herkommen.
            Aber mit dem Einzeiler ist das nicht mehr viel arbeit.
            rewenode
            @thomas-braun Ja, aber der Einzeiler muss jedesmal in dem Verzeichnis abgesetzt werden, wo die Verzeichnisse sind, weil der nicht rekursiv arbeitet.
            Hab bei mir mal so gelöscht:
            cd /opt/iobroker/node_modules
            for i in $(ls -dR */.[^.]*-*/); do rm -rf ${i%%/}; done
            Hab's vorher mit :
            ls -dR */.[^.]*-*/
            getestet und hat auch nur die relevanten Verzeichnisse rausgeworfen.
            Also bei mir hat das ohne Probleme in einem Rutsch funktioniert.
            Bin mir aber nicht sicher, ob da nicht irgendwelche neg. Seiteneffekte auftreten und Verzeichnisse erwischt werden könnten, die nicht gelöscht werden dürfen.
            Aber die Löschung in allen relevanten (Sub)verzeichnissen war sonst auch mir dem Einzeiler eine Qual.
            Reiner
            • R rewenode
              Hab's vorher mit :
              ls -dR */.[^.]*-*/
              Reiner
              @rewenode
              Ich hab den Lösch-Einzeiler geändert. Läuft jetzt auch rekursiv durch den Baum. War mir eigentlich zu heikel. Aber seis drum...
              • NegaleinN Offline
                NegaleinN Offline
                Negalein
                Hallo
                Ich möchte auch den Node-Red Adapter löschen.
                Dann kommt
                nega@ioBroker:~$ iobroker del node-red --custom --debug
                Delete adapter "node-red"
                host.ioBroker object node-red deleted
                host.ioBroker object node-red.admin deleted
                Error deleting adapter node-red from disk: host.ioBroker: Cannot uninstall iobroker.node-red: 217
                You might have to delete it yourself!
                nega@ioBroker:~$ sudo rm -rf /opt/iobroker/node_modules/iobroker.node-red/
                [sudo] password for nega:
                nega@ioBroker:~$
                Lösch ich nun mit sudo rm -rf /opt/iobroker/node_modules/iobroker.node-red/ ist das Verzeichnis weg und der Adapter scheint im Admin unter den Installierten nicht mehr auf.
                Aber spätestens am nächsten Tag ist er wieder da und wird mir als Update angeboten.
                Versuch ich es mit dem Einzeiler von @Thomas-Braun mit for i in $(ls -dR */.[^.]*-*/); do rm -rf ${i%%/}; done in /opt/iobroker/node_modules$ kommt unter anderem (nur ein sehr kurzer Auszug)
                rm: cannot remove '@peter-murray/.hue-bridge-model-c8zoKMkf/src/model/sensors/ZGPSwitch.ts': Permission denied
                rm: cannot remove '@peter-murray/.hue-bridge-model-c8zoKMkf/src/model/Light.ts': Permission denied
                rm: cannot remove '@peter-murray/.hue-bridge-model-c8zoKMkf/src/HueBridgeModelError.ts': Permission denied
                rm: cannot remove '@peter-murray/.hue-bridge-model-c8zoKMkf/src/types/TimePatternType.ts': Permission denied
                rm: cannot remove '@peter-murray/.hue-bridge-model-c8zoKMkf/src/types/Int8Type.ts': Permission denied
                rm: cannot remove '@peter-murray/.hue-bridge-model-c8zoKMkf/src/types/UInt8Type.test.ts': Permission denied
                rm: cannot remove '@peter-murray/.hue-bridge-model-c8zoKMkf/src/types/StringType.test.ts': Permission denied
                Wie bring ich den nun 100%ig weg?
                ° Fixer ---> iob fix
                • NegaleinN Negalein
                  Hallo
                  Dann kommt
                  nega@ioBroker:~$
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @negalein Zu einen hast Du mit diesem Verzeichnis zwar den Adapter aber nicht node-red an sich entfernt. Entweder man macht es erst mal mit
                  npm remove node-red
                  im
                  /opt/iobroker
                  Verzeichnis. Ansonsten - wenn Du das nicht mit npm löschst befindet sich
                  1. Der Adapter von NodeRed /opt/iobroker/node_modules/iobroker.node-red
                  2. NodeRed an sich in /opt/iobroker/node_modules/@nodered, sowie alle Verzeichnisse die mit node-red in /opt/iobroker/node_modules beginnen
                  3. Dann solltest doch noch Deine eigenen Daten mit den entsprechenden Instanzen des Node-Red Adapters in /opt/iobroker/iobroker-data entfernen
                  und zuletzt noch die Verweise auf iobroker.node-red aus der package.json in /opt/iobroker entfernen.
                  Auch wenn ich das nicht verstehe. ;) ,wie man das geilste Programm in Zusammenarbeit mit dem iobroker überhaupt entfernen will.
                  • NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    @mickym sagte in Problem beim Löschen von Node Red:
                    nicht wirklich.
                    Er scheint nach kurzer Zeit wieder in den Adaptern auf.
                    Ich möchte ihn einfach von den Adaptern weg haben.
                    Instanz ist schon ewig gelöscht.
                      nicht wirklich.
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @negalein sagte in Problem beim Löschen von Node Red:
                      nicht wirklich.
                      Ich habs Dir doch im Detail beschrieben, was man alles wegmachen muss - wenns nicht funktioniert - dann musst halt jemand sachkundigers finden.
                      • mickymM mickym
                        nicht wirklich.
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        Sorry, ich verstehs nicht.
                        Warum muss Node-Red mit npm remove node-red und nicht wie die anderen mit iobroker del node-red?
                        Bei npm remove node-red kommt jetzt
                        nega@ioBroker:/opt/iobroker$ npm remove node-red
                        up to date in 3s
                        193 packages are looking for funding
                          run `npm fund` for details
                          up to date in 3s
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @negalein schau halt sowohl mit
                          npm list node-red
                          npm list iobroker.node-red
                          ob noch Einträge vorhanden sind.
                          Das eine ist der Adapter, das andere ist Node-red an sich.
                          so sieht ungefähr sieht es installiert aus - wobei ich beta im Moment drauf habe:
                          iobroker.inst@3.0.0 /opt/iobroker
                          └── iobroker.node-red@4.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.node-red.git#049d7bdddc747071fc7379551d4bd7a66d690c57)
                          npm list node-red
                          └─┬ iobroker.node-red@4.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.node-red.git#049d7bdddc747071fc7379551d4bd7a66d690c57)
                            └── node-red@3.0.2
                          • mickymM mickym
                            npm list node-red
                            npm list node-red
                              └── node-red@3.0.2
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            nega@ioBroker:/opt/iobroker$ npm list node-red
                            `-- iobroker.node-red@3.3.1
                              `-- node-red@2.2.2
                            nega@ioBroker:/opt/iobroker$ npm list iobroker.node-red
                                `-- node-red@2.2.2
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @negalein Ja dann lösch
                              npm remove iobroker.node-red
                              und schau mit
                              npm list node-red
                              ob NodeRed mit entfernt wurde, ansonsten das auch noch entfernen .
                              npm remove node-red
                              Es dürfen danach keine Einträge mehr vorhanden sien.
                              • mickymM mickym
                                und schau mit
                                npm list node-red
                                npm remove node-red
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                ist entfernt, wenn empty steht?
                                `-- (empty)
                                  `-- (empty)
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @negalein Ja
                                  • mickymM mickym
                                    @negalein Ja
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    Ja
                                    Merci :)
                                    Warum musste Node-Red so deinstalliert werden und nicht wie üblich mit iobroker del node-red?
                                      Ja
                                      Merci :)
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @negalein Nun mit iobroker .... irgendwas - macht das alles der iobroker. Wenn der aus welchem Grund was nicht wegbringt - dann nutzt man halt npm direkt. Du hast ja das Verzeichnis manuell gelöscht, vielleicht steigt dann die iobroker Routine aus, weil sie denkt ist schon alles weg - aber in der package.json etc. sind vielleicht noch Verweise drin - jedenfalls sollten die Verzeichnisse auch weg sein.
                                      Wie gesagt im Moment hat das auch alles nichts mit NodeRed zu tun - sondern prinzipiell können durch die npm 8 Umstellung verschiedene Dinge passierten und irgendwas nicht upgedated, installiert oder deinstalliert werden. Deswegen rate ich ja oft dazu das ganze node_modules Verzeichnis neu aufbauen zu lassen. Ich hatte totales Chaos und konnte zum Beispiel den backit-up adapter nicht updaten. - Im Prinzip ist das Upgrade auf npm 8 meines Erachtens schuld, dass im Moment diverse Sachen nicht mehr so funktionieren, wie sie sollten.
                                      • mickymM mickym
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        Ja, ich muss gefühlt bei jedem 3. 4. Update Verzeichnisse mit dem ~gdfufjz usw. händisch löschen.
                                        Ist erst mit NPM 8 aufgetreten.
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @negalein Deswegen bin ich ja auch für die große Lösung auch wenn die hier von manchen nicht empfohlen wird.
                                          Hier sind beide Vorgehensweisen zusammengefasst:
                                          https://forum.iobroker.net/topic/57278/absturz-beim-update-admin-adapter-6-2-14-auf-6-2-17/4?_=1661097462352
                                          Man sollte halt ein Image haben.
                                          Im Detail:
                                          Meine Radikallösung bevor Neuaufbau und mit entsprechender Datensicherung geht immer noch so:
                                          1. Neuaufbau des /opt/iobroker/node_modules Verzeichnis: https://forum.iobroker.net/topic/56543/nach-nodejs-update-kein-adapter-mehr-updatebar/23?_=1658914381795
                                          2. Um wieder einen sauberen Baum zu erhalten - alle Einträge in der package.json löschen, die nicht mit iobroker beginnen und wie folgt vorgehen: https://forum.iobroker.net/topic/56772/gelöst-kein-adapter-lässt-sich-updaten
