  4. Ersatz für vcgencmd nach Raspberry Kernel Update
42 Beiträge 9 Kommentatoren 10.7k Aufrufe 7 Beobachtet
    @mickym
    Versuch mal
    vcgencmd display_power 0 0
    echad@chet:~ $ vcgencmd display_power 0 0
    display_power=0
    display_power [0 | 1 | -1] [display]
    Show current display power state, or set the display power state. vcgencmd display_power 0 will turn off power to the current display. vcgencmd display_power 1 will turn on power to the display. If no parameter is set, this will display the current power state. The final parameter is an optional display ID, as returned by tvservice -l or from the table below, which allows a specific display to be turned on or off.
    Note that for the 7" Raspberry Pi Touch Display this simply turns the backlight on and off. The touch functionality continues to operate as normal.
    vcgencmd display_power 0 7 will turn off power to display ID 7, which is HDMI 1 on a Raspberry Pi 4.
    Display         | ID
    > Main LCD      | 0
    > Secondary LCD | 1
    > HDMI 0        | 2
    > Composite     | 3
    > HDMI 1        | 7
    To determine if a specific display ID is on or off, use -1 as the first parameter.
    vcgencmd display_power -1 7 will return 0 if display ID 7 is off, 1 if display ID 7 is on, or -1 if display ID 7 is in an unknown state, for example undetected.
    mickymM Online
    mickymM Online
    mickym
    @thomas-braun sagte in Raspberry Kernel Update:
    @mickym
    Versuch mal
    display_power=0
    Ja das hat ich schon probiert - auch mit
    pi@MWHome2:~ $ vcgencmd display_power = 0
    display_power=0
    pi@MWHome2:~ $ vcgencmd display_power 0 0
    display_power=0
    Das meldet zwar display_power=0 zurück, der HDMI Port bleibt aber weiter aktiv.
    • mickymM mickym
      @mickym
      Versuch mal
      display_power=0
      display_power=0
      display_power=0
      @mickym
      Und mit 2 oder 7? Das sind die HDMI-Ports.
        @mickym
        mickymM Online
        mickymM Online
        mickym
        @thomas-braun Also Du meinst
        vcgencmd display_power 2 0
        bzw.
        vcgencmd display_power 7 0
        btw: Das mit dem Zurückhalten der Pakete hat aber schon mal geklappt und Ursache ist definitiv das Kernel Update.
        • mickymM mickym
          bzw.
          @mickym Anders herum.
          Die ID steht hinten.
            mickymM Online
            mickymM Online
            mickym
            @thomas-braun Kein Effekt.
            Ich hab alles von -2 bis +7 ausprobiert, es kommt mal display_power=-1 oder display_power=0 zurück, aber es schaltet nichts ab.
            • mickymM mickym
              @mickym
              Hast du xrandr installiert?
              xrandr --output HDMI-1 --off
              Wobei ich da die genaue Syntax nicht kenne. Mein RPI läuft ja headless...
                @mickym
                mickymM Online
                mickymM Online
                mickym
                @thomas-braun Das Kommando habe ich zwar aber es kommt immer zurück, dass er kein Display öffnen konnte.
                Can't open display
                pi@MWHome2:~ $ xrandr --listmonitors
                Can't open display
                pi@MWHome2:~ $ xrandr --listproviders
                Can't open display
                Wie gesagt das mit dem Kernel auf hold setzen hat geklappt. Es war halt sehr elegant - weil der Bildschirm über Bewegungsmelder gesteuert wurde und nicht über starre Zeiten der Inaktivität - aber noch viel besser - er ist halt automatisch angegangen sobald man das Zimmer betreten hat. Ich finde solche Updates einfach beschi...en. Dann soll man es halt sicher machen oder man nutzt es auf eigenes Risiko.
                Entweder nehm ich halt den blöden Bildschirmschoner - dann muss man halt immer ne Maus bewegen oder ich hab auch noch einen Shelly über und hänge den Monitor ganz hin - dann wird gar kein Strom mehr gebraucht - wenn niemand im Zimmer ist.
                • mickymM mickym
                  Can't open display
                  Can't open display
                  Can't open display
                  @mickym sagte in Raspberry Kernel Update:
                  Can't open display
                  Möglich das man dafür in der Gruppe 'video' sein muss. Sollte aber eh der Fall sein.
                  xrandr
                  oder
                  sudo xrandr
                  sagt?
                    Can't open display
                    xrandr
                    oder
                    sudo xrandr
                    sagt?
                    mickymM Online
                    mickymM Online
                    mickym
                    Can't open display
                    pi@MWHome2:~ $ sudo xrandr
                    Can't open display
                    pi@MWHome2:~ $
                    pi ist in Gruppe video.
                    • mickymM mickym
                      Can't open display
                      Can't open display
                      pi@MWHome2:~ $
                      M Online
                      M Online
                      mrjeschke
                      @mickym
                      Musste gerade feststellen das ich das gleiche Problem habe.
                      Ausschalten kann ich den Monitor über
                      pi@DietPi:~$ export DISPLAY=:0.0
                      pi@DietPi:~$ xrandr --output HDMI-1 --off
                      Einschalten geht über
                      pi@DietPi:~$ xrandr --output HDMI-1 --auto
                      • M mrjeschke
                        @mickym
                        mickymM Online
                        mickymM Online
                        mickym
                        @maik-0
                        @Thomas-Braun
                        Ja und ich bin soooo blöd.😬 😬 😬
                        Man muss das Kommando tatsächlich auf der Maschine eingeben, an der der Bildschirm hängt. Das war bei dem vcgencmd nicht so, da ging das auch über ssh.
                        Das Ausschalten geht so. - Ich muss nun schauen, ob ich es via NodeRed steuern kann.
                        • mickymM mickym
                          @maik-0
                          @Thomas-Braun
                          Das ist klar, X wird nicht (ohne weiteres) über ssh geroutet.
                          Hier kämpfen auch einige damit:
                          https://www.linuxquestions.org/questions/linux-general-1/xrandr-from-remote-through-ssh-869084/
                            mickymM Online
                            mickymM Online
                            mickym
                            @thomas-braun Das Ausschalten ging, aber ich habe nun das Problem wie ich das wieder anbekomme.
                            • M mrjeschke
                              @mickym
                              mickymM Online
                              mickymM Online
                              mickym
                              @mrjeschke
                              @Thomas-Braun
                              So vielen Dank an Euch beide. Wichtig war noch der Export dieser Umgebungsvariable DISPLAY=0.0 - damit ist es dann auch möglich remote und über SSH den Bildschirm wieder zu schalten. Außerdem muss man noch Berechtigungen vergeben, damit das ganze auch für andere Benutzer funktioniert. Für NodeRed muss man dann noch ein paar Verrenkungen machen. Da muss ich wohl @apollon77 bitten wieder eine Variable für die settings.js bereitzustellen, damit man in der Laufzeitumgebung des NodeRed Prozesses Umgebungsvariablen definieren kann.
                              Als erstes damit der Benutzer iobroker das Ganze auch ausführen darf, muss man die Zugriffsrechte anpassen und zwar muss das wohl bei jedem Neustart des Systems neu erfolgen, kann man wohl nicht konfigurieren. Ich habe diesen Zugriffscheck abgeschaltet mit xhost +.
                              Es langt wenn man es für den Benutzer pi ins Anmeldeprofil schreibt, da sich dieser ja eh automatisch anmeldet.
                              Die beiden Befehle habe ich also in die .profile im Homeverzeichnis des pi angehängt:
                              export DISPLAY=:0.0
                              xhost +
                              Dann war die Herausforderung diese DISPLAY Umgebungsvariable in dem Prozess, in dem node-red läuft zugänglich zu machen, wie oben bereits erwähnt.
                              Man kann folgendenen Eintrag in die settings.js machen bevor die module.export section beginnt - also entweder ganz am Anfang oder ganz am Ende.
                              process.env.DISPLAY=':0.0';
                              Wenn man es nicht macht - dann bekommt man immer als RC=1 zurück, wenn man die xrandr Befehle ausführen will.
                              Ansonsten kann man dann prüfen, dass der Returncode 0 ist - also alles in Ordnung ist. Und kann dann an bzw. true in auto und false bzw, aus in off übersetzen und an den Befehlsrumpf angehängt.
                              xrandr --output HDMI-1 <--off|--auto>
                              Danke an alle die mir geholfen haben. :)
                              mickymM SminterS 2 Antworten Letzte Antwort
                              • mickymM mickym
                                @mrjeschke
                                @Thomas-Braun
                                export DISPLAY=:0.0
                                xhost +
                                mickymM Online
                                mickymM Online
                                mickym
                                Das Einzige - was etwas offen ist - das ich bisher nichts gefunden habe, wie bei dem vcgencmd Befehl, das mir den aktuellen Status zurückliefert. Das ist nicht ganz so schlimm, wenn man eh nur an einer Stelle schaltet und halt sobald die Maschine hochgefahren ist, einen definierten Status schaltet.
                                • mickymM mickym
                                  @mrjeschke
                                  @Thomas-Braun
                                  export DISPLAY=:0.0
                                  xhost +
                                  SminterS Offline
                                  SminterS Offline
                                  Sminter
                                  @mickym Danke, genau das habe ich gesucht: Die Steuerung des Bildschirms per NodeRed. Kannst du mir noch den Export deines Flows zukommen lassen?
                                  Da ich mich noch nicht lange mit dem Pi beschäftige. Wo finde ich die zwei anzupassenden Dateien auf dem Pi 4?
                                  • SminterS Sminter
                                    mickymM Online
                                    mickymM Online
                                    mickym
                                    @sminter Na wenn du all das gemacht hast, was ich unten beschrieben habe - der Flow ist quasi nur der Aufruf der Befehle:
                                    Mit true und false schalte ich den Monitor an und aus:
                                    Hier der Flow:
                                           "id": "226756a3.c3f79a",
                                           "type": "exec",
                                           "z": "2364426f.ac30ce",
                                           "command": "xrandr --output HDMI-1 ",
                                           "addpay": "payload",
                                           "append": "",
                                           "useSpawn": "true",
                                           "timer": "10",
                                           "winHide": false,
                                           "oldrc": false,
                                           "name": "",
                                           "x": 770,
                                           "y": 1840,
                                           "wires": [
                                                   "7220811b.4bd39"
                                                   "7220811b.4bd39"
                                                   "830e8b336da27104"
                                           "id": "3b699dd31190819f",
                                           "type": "change",
                                           "name": "translate",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "true",
                                                   "fromt": "bool",
                                                   "to": "--auto",
                                                   "tot": "str"
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "false",
                                                   "fromt": "bool",
                                                   "to": "--off",
                                                   "tot": "str"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 560,
                                           "y": 1840,
                                           "wires": [
                                                   "226756a3.c3f79a"
                                    Die anderen Dateien habe ich in dem Post beschrieben. Die .profile im Homeverzeichnis des pi.
                                    Den export der Variablen, wie gesagt in der settings.js - da musst Du das template editieren. Leider - da es nicht in die Adapterkonfiguration übernommen wird, bei jedem Update erneut ändern:
                                    Die template settings.js findest Du unter dem Verzeichnis:
                                    /opt/iobroker/node_modules/iobroker.node-red
                                    SminterS 1 Antwort Letzte Antwort
                                    • mickymM mickym
                                      Hier der Flow:
                                             "type": "exec",
                                             "append": "",
                                             "useSpawn": "true",
                                             "timer": "10",
                                             "winHide": false,
                                             "oldrc": false,
                                             "name": "",
                                             "x": 770,
                                             "y": 1840,
                                             "wires": [
                                                     "7220811b.4bd39"
                                                     "7220811b.4bd39"
                                                     "830e8b336da27104"
                                             "type": "change",
                                             "rules": [
                                                     "t": "change",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "from": "true",
                                                     "fromt": "bool",
                                                     "to": "--auto",
                                                     "tot": "str"
                                                     "t": "change",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "from": "false",
                                                     "fromt": "bool",
                                                     "to": "--off",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 560,
                                             "y": 1840,
                                             "wires": [
                                                     "226756a3.c3f79a"
                                      SminterS Offline
                                      SminterS Offline
                                      Sminter
                                      @mickym Thx, für die Screenshots. Hatte anfänglich Schwierigkeiten. Vielleicht liegt es an der OS-Version oder dem Pi4. Kann es sein, das meine Settings-Datei wo anders liegt?
                                      Und die .profile finde ich auch über die Dateisuche nicht.
                                      Der NodeRed-Befehl ist kein Problem, nur greift er natürlich noch nicht... Weißt du wo ich die Datei noch suchen könnte?
                                      • mickymM Online
                                        mickymM Online
                                        mickym
                                        @sminter die .profile sehe ich ja schon auf deinem Screenshot. 4.letzte Datei, wenn du Deinen User pi in franz umbenannt hast.
                                        Und die settings.js liegt nur im Adapterverzeichnus, das ich gepostet habe. Also hier: /opt/iobroker/node_modules/iobroker.node-red
                                        Natürlich nur, wenn du node-red als Adapter im iobroker betreibst, Ansonsten halt in Deiner stand-alone Settings.js
                                        • mickymM mickym
                                          SminterS Offline
                                          SminterS Offline
                                          Sminter
                                          @mickym Sorry, nach all den versteckten und dann auch nicht suchbaren Dateien war ich wohl etwas verwirrt.
                                          Wenn die Dateien nicht versteckt und der der andere Pfad beachtet wird, lassen sich die Dateien finden und editieren. Nun funktioniert alles. Danke für die detaillierte Anleitung!
                                          Jetzt muss ich nur noch mein Bewegungsmelder dazu bekommen, die ganzen Fehlalarme bleiben zu lassen... :-)
                                          EnduranceE 1 Antwort Letzte Antwort
