  4. Test Adapter Philips-TV v0.2.x
    6.6k
philipsphilips tv
550 Beiträge 84 Kommentatoren 185.6k Aufrufe 48 Beobachtet
  • WszeneW Wszene
    @foxriver76
    Das log
    philips-tv-android.0
    2022-08-08 21:43:34.815	error	Could not launch TV channel "ntv": {"statusCode":400,"body":"<html>\n<head>\n <title>Status page</title>\n</head>\n<body style=\"font-family: sans-serif;\">\n<p style=\"font-size: 1.2em;font-weight: bold;margin: 1em 0px;\">Bad Request</p>\n<p>The request could not be understood by the server due to malformed syntax</p>\n<p>You can get technical details <a href=\"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.4.1\">here</a>.<br>\nPlease continue your visit at our <a href=\"/\">home page</a>.\n</p>\n</body>\n</html>\n","headers":{"date":"Mon, 08 Aug 2022 19:43:31 GMT","accept-ranges":"bytes","server":"Restlet-Framework/2.3.12","access-control-allow-origin":"*","content-length":"456","content-type":"text/html; charset=UTF-8"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.20.200:1926","port":"1926","hostname":"192.168.20.200","hash":null,"search":null,"query":null,"pathname":"/6/activities/launch","path":"/6/activities/launch","href":"https://192.168.20.200:1926/6/activities/launch"},"method":"POST","headers":{"content-length":138,"authorization":"Digest username=\"3nfKjgd4LL885dmV\", realm=\"XTV\", nonce=\"MTY1OTk4NzgxMTY0NDo2NzRjYmY4ZTg4OGIxODA0MTY2ZjFlMjQ1Y2JhNzUzNg==\", uri=\"/6/activities/launch\", qop=auth, response=\"630e934c534d9bd014b497e4edbabc0c\", nc=00000001, cnonce=\"6dbea975523444b0ba665a83d439ff3a\", algorithm=MD5","referer":"https://192.168.20.200:1926/6/activities/launch"}}}
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #325
    @wszene Nächster Versuch bitte
    Videotutorials & mehr
    WszeneW 1 Antwort Letzte Antwort
    • foxriver76F foxriver76
      WszeneW Offline
      WszeneW Offline
      Wszene
      #326
      @foxriver76
      Leider hat das auch nicht geklappt
      2022-08-08 22:31:49.684	error	Could not launch TV channel "NITRO": socket hang up
      2022-08-08 22:31:49.657	warn	{"channel":{"ccid":905,"preset":"1","name":"1-2-3.tv HD"},"channelList":{"id":"allcab","version":"6"}}
      2022-08-08 22:31:49.657	warn	Notify developer:
      2022-08-08 22:31:19.198	info	Starting with ip "192.168.20.200"
      2022-08-08 22:31:19.174	info	starting. Version 0.0.1 (non-npm: foxriver76/ioBroker.philips-tv-android#d9933451e224975ac76ebaa240360aa5df66cd78) in /opt/iobroker/node_modules/iobroker.philips-tv-android, node: v16.16.0, js-controller: 4.0.23
      2022-08-08 22:31:13.018	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-08-08 22:31:13.017	info	terminating
      2022-08-08 22:31:12.915	info	Got terminate signal TERMINATE_YOURSELF
      Meine Hard- & Software:
      • CC2652P Zigbee Stick
      • Lichtschalter mit Tasmota
      • IKEA TRÅDFRI Glühbirnen
      • Aqara Sensoren
      • WszeneW Wszene
        @foxriver76
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        #327
        @wszene Danke fürs Posten. Next try.. jetzt sollte es gehen ;-)
        WszeneW 2 Antworten Letzte Antwort
          WszeneW Offline
          WszeneW Offline
          Wszene
          #328
          @foxriver76
          Guten Morgen,
          Jetzt funktioniert es perfekt
          Vielen Dank für deine Arbeit
          Wieder 2 Geräte weg von der Harmony
          • Aqara Sensoren
            WszeneW Offline
            WszeneW Offline
            Wszene
            #329
            @foxriver76
            Hast du schon eine Idee wann deine Version des Adapters in die Repo kommt
            • Aqara Sensoren
            • WszeneW Wszene
              @foxriver76
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              #330
              @wszene Ich möchte gerne mindestens einen Tester mit einer API Version v5/v1 haben. Und im Optimalfall, ersetzt der Adapter den von @AlCalzone falls das für ihn i. O. ist, ich möchte für diesen Fall allerdings für die User älterer APIs nichts kaputt machen. Dann können wir sehr gerne die Schritte in die Wege leiten und den Adapter auf npm schieben.
              Es sind noch einige States hinzu gekommen zum ansteuern von Ambilight. Ebenfalls wird der Endpunkt mit den Systeminfos einmalig abgefragt, was bei mir allerdings in einen Timeout läuft, hier auch gerne Feedback geben ob das Instanzobjekt als Device angelegt wird und im native Teil die Device Informationen aufweist.
              WszeneW AlCalzoneA 2 Antworten Letzte Antwort
                WszeneW Offline
                WszeneW Offline
                Wszene
                #331
                @foxriver76
                OK das kann ich verstehen aber mit den v5/v1 APIs kann ich dir leider nicht helfen
                Ich hab gerade das Update gemacht
                Ich habe nur einen DP dazu bekommen
                "Ambilight On/Off"
                Und was meinst du genau
                "Ebenfalls wird der Endpunkt mit den Systeminfos einmalig abgefragt, was bei mir allerdings in einen Timeout läuft"
                Einen TimeOut konnte ich nicht feststellen
                • Aqara Sensoren
                • WszeneW Wszene
                  @foxriver76
                  "Ambilight On/Off"
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  #332
                  @wszene Hast du ein Stift hinter dem Objekt philips-tv-android.0? Dann zeige mal bitte das Objekt bei dir.
                  Im settings channel sind Ambilight states hinzu gekommen, falls unterstützt vom TV.
                    WszeneW Offline
                    WszeneW Offline
                    Wszene
                    #333
                    @foxriver76 sagte in Test Adapter Philips-TV v0.2.x:
                    Leider nicht
                    Da hat sich bei mir nichts geändert
                    • Aqara Sensoren
                    • WszeneW Wszene
                      Leider nicht
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #334
                      @wszene dann mach mal bitte ein debug run und Zeuge mir das Logfile.
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        #335
                        Gerne!
                        R 1 Antwort Letzte Antwort
                        • AlCalzoneA AlCalzone
                          Gerne!
                          roughestboy
                          #336
                          @foxriver: vielen Dank für die Aktualisierung des Adapters, genauso natürlich auch an AlCalzone für den Vorgänger.
                          Ich habe den Adapter nun installiert, funktioniert auch prinzipiell.
                          Meine Frage: wie kann ich damit den TV starten ?
                          • R roughestboy
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            #337
                            @roughestboy Im TV solltest du WOL aktivieren, versteckt sich in den Netzwerkeinstellungen. Dann die MAC Adresse in die Adapter Config eintragen. Hierbei wird normalerweise die WIFI Mac Adresse benötigt. Dann per settings.power DP den TV einschalten.
                              roughestboy
                              #338
                              @foxriver76 Danke, funktioniert soweit.
                              • R Offline
                                Rushmed
                                schrieb am zuletzt editiert von Rushmed
                                #339
                                Vielen Dank, hab den Adapter auch installiert und verbunden!
                                OLED806er TV
                                • R Rushmed
                                  OLED806er TV
                                  Rushmed
                                  #340
                                  Ich habe bei mir den aktuellen Adapter sowie den Alexa Skill für meinen Philips Fernseher installiert. Leider kann ich den Fernseher mit "Alexa, schalte Fernseher ein." nicht einschalten. Ich vermute weil er über den Skill schalten will und bei dem funktioniert komischerweise das WOL trotz Aktivierung in den TV Einstellungen und in der Alexa App auf dem TV nicht. BTW mit dem Adapter funktioniert WOL. Nun möchte ich aber den TV nicht unter verschiedenen Namen anlegen und benötige dennoch den Skill weil der schon soviele sprachsteuerbare Funktionen mitbringt ohne dass ich für jede DP's anlegen muss.
                                  Hat jemand von euch die gleiche Kombi am Laufen?
                                  Edit, hat sich erledigt.
                                  • C Offline
                                    chrisalex2204
                                    #341
                                    ich wollte den Adapter testen, bekomme aber im Log folgende Fehlermeldung:
                                    Could not poll API: no auth mechanism defined
                                    Was mache ich falsch?
                                    • C chrisalex2204
                                      foxriver76F Offline
                                      foxriver76F Offline
                                      foxriver76
                                      schrieb am zuletzt editiert von foxriver76
                                      #342
                                      @chrisalex2204 welche api version?
                                      Falls nicht v6, bitte nochmal neu installieren, ich habe eine Kleinigkeit gefixt.
                                      C 1 Antwort Letzte Antwort
                                        chrisalex2204
                                        #343
                                        @foxriver76
                                        Es müsste api version 6 sein. Habe neu installiert und nun bekomme ich folgenden Fehler:
                                        Cannot read properties of undefined (reading 'apiVersion')
                                        • C chrisalex2204
                                          @foxriver76
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          #344
                                          @chrisalex2204 Bitte nochmal reinstall
