  4. ZigBee neue Version 1.7.x
    5.9k
1.7backupiconszigbee
217 Beiträge 40 Kommentatoren 48.0k Aufrufe 47 Beobachtet
  • David G.D David G.
    @arteck
    Hab es doch schon geschafft.
    So sieht der Start vom Adapter aus:
    zigbee.0
    2022-07-31 09:25:14.969	warn	DeviceAvailability:Failed to ping 0xf0d1b8000013d3a8 Panel TW Z3
    zigbee.0
    2022-07-31 09:25:14.939	warn	DeviceAvailability:Failed to ping 0xbc33acfffeb20bf5 TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:14.704	warn	DeviceAvailability:Failed to ping 0x84fd27fffed0858b TRADFRI bulb GU10 WS 400lm
    zigbee.0
    2022-07-31 09:25:14.451	warn	DeviceAvailability:Failed to ping 0x60a423fffeed446c TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:14.403	warn	DeviceAvailability:Failed to ping 0x60a423fffef0ff05 TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:14.317	warn	DeviceAvailability:Failed to ping 0x804b50fffea8bebd TRADFRI bulb GU10 WS 400lm
    zigbee.0
    2022-07-31 09:25:14.254	warn	DeviceAvailability:Failed to ping 0xcc86ecfffe952a0e TRADFRI bulb GU10 WS 400lm
    zigbee.0
    2022-07-31 09:25:14.243	warn	DeviceAvailability:Failed to ping 0xbc33acfffec026df TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:14.174	warn	DeviceAvailability:Failed to ping 0xbc33acfffe5f8ea0 TRADFRI bulb E14 WS opal 600lm
    zigbee.0
    2022-07-31 09:25:13.981	warn	DeviceAvailability:Failed to ping 0xbc33acfffea94381 TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:13.941	warn	DeviceAvailability:Failed to ping 0xd0cf5efffeeedcb2 TRADFRI bulb GU10 WS 400lm
    zigbee.0
    2022-07-31 09:25:13.771	warn	DeviceAvailability:Failed to ping 0x2c1165fffe17366c TRADFRIbulbE27WWclear250lm
    zigbee.0
    2022-07-31 09:25:13.649	warn	DeviceAvailability:Failed to ping 0x7cb03eaa00afc5ce Plug 01
    zigbee.0
    2022-07-31 09:25:13.536	warn	DeviceAvailability:Failed to ping 0xbc33acfffe9b50d6 TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:24:50.227	info	Zigbee started
    zigbee.0
    2022-07-31 09:24:50.222	info	0x00124b002519401e (addr 5935): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    zigbee.0
    2022-07-31 09:24:50.220	info	0x00124b002513bb34 (addr 37306): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    zigbee.0
    2022-07-31 09:24:50.217	info	0xf0d1b8000013d3a8 (addr 23290): 4058075181472 - LEDVANCE SMART+ panel 60 x 60cm tunable white (Router)
    zigbee.0
    2022-07-31 09:24:50.214	info	0x842e14fffe78cb20 (addr 46126): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
    zigbee.0
    2022-07-31 09:24:50.213	info	0xbc33acfffec026df (addr 64479): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.181	info	0xbc33acfffe9b50d6 (addr 48925): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.179	info	0xbc33acfffea94381 (addr 47468): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.176	info	0x804b50fffefb471f (addr 29106): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
    zigbee.0
    2022-07-31 09:24:50.173	info	0xbc33acfffeb20bf5 (addr 22639): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.171	info	0x60a423fffef0ff05 (addr 49702): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.168	info	0x60a423fffeed446c (addr 19589): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.166	info	0xbc33acfffe5f8ea0 (addr 57424): LED1733G7 - IKEA TRADFRI LED bulb E14 600 lumen, dimmable, white spectrum, opal white (Router)
    zigbee.0
    2022-07-31 09:24:50.163	info	0xcc86ecfffe952a0e (addr 41784): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    zigbee.0
    2022-07-31 09:24:50.161	info	0x84fd27fffed0858b (addr 32917): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    zigbee.0
    2022-07-31 09:24:50.157	info	0x804b50fffea8bebd (addr 25499): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    zigbee.0
    2022-07-31 09:24:50.155	info	0xd0cf5efffeeedcb2 (addr 21634): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    zigbee.0
    2022-07-31 09:24:50.152	info	0x2c1165fffe17366c (addr 16013): LED1934G3_E27 - IKEA TRADFRI LED bulb E27 WW clear 250 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.143	info	0x7cb03eaa00afc5ce (addr 13786): AB3257001NJ - OSRAM Smart+ plug (Router)
    zigbee.0
    2022-07-31 09:24:50.093	info	Currently 18 devices are joined:
    zigbee.0
    2022-07-31 09:24:50.079	info	--> transmitPower : high
    zigbee.0
    2022-07-31 09:24:50.052	info	Unable to disable LED, unsupported function.
    zigbee.0
    2022-07-31 09:24:50.040	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    zigbee.0
    2022-07-31 09:24:46.983	info	Installed Version: iobroker.zigbee@1.7.5
    zigbee.0
    2022-07-31 09:24:45.958	info	Starting Zigbee npm ...
    zigbee.0
    2022-07-31 09:24:45.955	info	delete old Backup files. keep only last 10
    zigbee.0
    2022-07-31 09:24:45.624	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
    Wenn ich eine Gruppe oder ein einzelnes Gerät schalten möchte:
    zigbee.0
    2022-07-31 09:29:15.864	warn	Send command to 0xbc33acfffe5f8ea0 failed with: Code 205 (No network route)
    zigbee.0
    2022-07-31 09:28:55.040	warn	unread state change for group members ["0x60a423fffef0ff05","0xbc33acfffeb20bf5"]
    P. S.:
    3 Gu10 sind wirklich Stromlos.
    #92
    @david-g
    Setz den Port auf den Link aus /dev/serial/by-id
    nicht auf /dev/ttyUSBx
    • David G.D Online
      David G.D Online
      David G.
      #93
      Ist abgeändert.
      Problem bleibt 1 zu 1 bestehen.
      EDIT:
      Hab grade folgendes festgestellt. Kann das sein?
      Habe eine einzelne Birne Stromlos gemacht. Danach hat sich der Adapter selber neugestartet.
      Nun kann ich alle Birnen steuern.
      Wenn ich den Adapter jetzt nochmal neustarte bekommt er die Geräte auch nicht angepingt. Lassen sich dann jedoch nach kurzer Zeit schalten.
      EDIT2
      Wenn ich die Geräte vom Strom nehme, scheinen sie sich danach zu verbinden.
      Den Absturz vom Adapter hatte ich, weil noch nicht die aktuelle git Version installiert war (das ikea Problem).
      Beobachte es mal
        Ist abgeändert.
        EDIT:
        EDIT2
        Beobachte es mal
        arteckA Offline
        arteckA Offline
        arteck
        #94
        @david-g sagte in ZigBee neue Version 1.7.x:
        in offi 1.7.5 ist es beoben.. da brauchst du nicht von GIT installieren
          @arteck das geht dann wohl nur mit dem originalen Gateway. Weil da hab ich ein Video dazu gesehen: https://youtu.be/gTZ4C4_iD6k ab ca. 3:00 Aber die originalen 30sec sind auch schon besser.
          Tassos
          #95
          Hallo ,Ich bin neu hier und weiß nicht wie ich ein thema eröffne.
          Ich habe ein Problem und bin am verzweifeln. Ich möchte einen Gateway für bewesserung verbinden mit meinem w-lan und es geht nicht,ich habe den Rainpoint gateway und habe alles richtig gemacht,ich habe auch einen zweiten vewrsucht ,immer wieder das gleiche,er sucht und sucht 2 minuten und nichts
          • T Tassos
            #96
            @tassos Dann ist das Hier wahrscheinlich der Falsche Thread. Dein Bewässerungscomputer hat kein Zigbee, sondern WIFI.
              Tassos
              #97
              @typ1er Sorry,wo muss ich hin?
              • T Tassos
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #98
                @tassos Du solltest einen eigenen Thread aufmachen - mit passendem Thema.
                A.
                • arteckA arteck
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #99
                  @arteck
                  weißt du was das bedeuten könnte:
                  zigbee.0
                  	2022-08-06 15:53:26.839	warn	Failed to read state '"power_on_behavior"'of '0x588e81fffef0543f' after query with '{"code":134}'
                  zigbee.0
                  	2022-08-06 15:51:53.353	warn	Failed to read state '"power_on_behavior"'of '0x588e81fffef0543f' after query with '{"code":134}'
                  zigbee.0
                  	2022-08-06 15:39:07.879	warn	Failed to read state '"power_on_behavior"'of '0x588e81fffef0543f' after query with '{"code":134}'
                  • liv-in-skyL liv-in-sky
                    @arteck
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #100
                    @liv-in-sky
                    Die Meldungen kommen wenn das System versucht das Attribute "power_on_behavior" von einem Gerät zu lesen welches dieses Attribut nicht unterstützt (code:134 ist "unsupported attribute")
                    Es ist davon auszugehen das das Gerät nicht 100% sauber in den Herdsman-converters implementiert ist.
                    A.
                    • AsgothianA Asgothian
                      @liv-in-sky
                      A.
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #101
                      @asgothian danke dir - dann kann ich wohl nichts machen, außer den query dp nicht zu nutzen :-(
                      • nukleuzN Offline
                        nukleuzN Offline
                        nukleuz
                        schrieb am zuletzt editiert von nukleuz
                        #102
                        ich wage gerade den Umstieg von DeConz zu ioBroker Zigbee…
                        Klappt alles sehr gut.
                        Bisher habe ich ein Gerät was sich nicht pairen lassen will.
                        Von Dresden Elektronik der Dimmer Switch hat ein Fragezeichen. Wird der unterstützt?
                        Wie gehe ich hier nun vor?
                        Danke für Info und weiter so 👍
                        E19F36AB-072B-4CEE-A2E6-78B6D47286DC.jpeg DA6AC4B8-5073-4F84-B52D-0566AF05D9D8.png
                        Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                        • nukleuzN nukleuz
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #103
                          da muss ein Blaues I sein.. drauf klicken..die Kachel posten
                          nukleuzN 1 Antwort Letzte Antwort
                          • arteckA arteck
                            nukleuzN Offline
                            nukleuzN Offline
                            nukleuz
                            #104
                            @arteck
                            Hier der Screenshot - danke:
                            modelZigbee:Kobold
                            type:Router
                            nwk:32959
                            manuf id:4405
                            manufacturer:dresden elektronik
                            power:Mains (single phase)
                            app version:0
                            hard version:1
                            zcl version:8
                            stack version:0
                            date code:20211119
                            build:0103.10000026
                            interviewed:true
                            configured:false
                            endpoint:1
                            profile:260
                            input clusters:genBasic (0)
                            genIdentify (3)
                            genGroups (4)
                            genScenes (5)
                            genOnOff (6)
                            genLevelCtrl (8)
                            output clusters:genOta (25)
                            endpoint:2
                            profile:260
                            genIdentify (3)
                            output clusters:genIdentify (3)
                            genOnOff (6)
                            genLevelCtrl (8)
                            endpoint:242
                            profile:41440
                            output clusters:greenPower (33)
                            • JackDanielJ Offline
                              JackDanielJ Offline
                              JackDaniel
                              schrieb am zuletzt editiert von JackDaniel
                              #105
                              kommt die anzeige vom verbindungsstatus in den objekten eigentlich vom adapter, oder vom admin, oder von wo ganz anders?
                              ich finde die anzeige spitze, bzw. sollte das zum standard für alle geräte werden :)
                              Carpe diem
                              • JackDanielJ JackDaniel
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #106
                                @jackdaniel wird vom adapter geliefert und admin setzt es um
                                • nukleuzN nukleuz
                                  @arteck
                                  modelZigbee:Kobold
                                  type:Router
                                  nwk:32959
                                  manuf id:4405
                                  app version:0
                                  hard version:1
                                  zcl version:8
                                  stack version:0
                                  date code:20211119
                                  build:0103.10000026
                                  interviewed:true
                                  configured:false
                                  endpoint:1
                                  profile:260
                                  genIdentify (3)
                                  genGroups (4)
                                  genScenes (5)
                                  genOnOff (6)
                                  genLevelCtrl (8)
                                  endpoint:2
                                  profile:260
                                  genIdentify (3)
                                  genOnOff (6)
                                  genLevelCtrl (8)
                                  endpoint:242
                                  profile:41440
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #107
                                  @nukleuz der ist da.. installier mal die GIT version
                                  https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                                  nukleuzN 3 Antworten Letzte Antwort
                                  • arteckA arteck
                                    nukleuzN Offline
                                    nukleuzN Offline
                                    nukleuz
                                    #108
                                    @arteck
                                    Danke vorab!
                                    Adapter ist aktualisiert - leider komme ich morgen erst zum neu pairen… Oder müsste er nach Update angezeigt werden?
                                    Greets
                                    • arteckA arteck
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #109
                                      @arteck sagte in ZigBee neue Version 1.7.x:
                                      sowas find ich klasse - wünschte mir das in anderen adaptern :-)
                                      • arteckA arteck
                                        nukleuzN Offline
                                        nukleuzN Offline
                                        nukleuz
                                        #110
                                        @arteck
                                        Habe das Gerät neu gepaired:
                                        Pairing time left: 20
                                        Pairing time left: 21
                                        New device joined '0x00212effff0a6524' model Kobold
                                        Interview successful: [object Object]
                                        Pairing time left: 22
                                        Pairing time left: 23
                                        Error: Device 0x00212effff0a6524 "Kobold" not described in statesMapping.. undefined
                                        Pairing time left: 24
                                        Interview started: 0x00212effff0a6524
                                        Pairing time left: 25
                                        Pairing time left: 26
                                        Pairing time left: 27
                                        Pairing time left: 28
                                        So sieht die Kachel aus:
                                        Und so die DP:
                                        Was kann ich noch tun?
                                        Danke.
                                        Edit:
                                        • H Offline
                                          haumichel
                                          #111
                                          ich habe heute meinen ZigBee Adapter auf Version 1.7.5 aktualisiert.
                                          Leider geht jetzt fast gar nichts mehr und ich brauche mal ein wenig Hilfe. Bei mir werden einige Ikea Glühlampen und 3 Sensoren damit gesteuert. Das hat bis zum Update auch gut funktioniert.
                                          Die ganzen Lampen werden im Adapter mit Signalstärke 0 angezeigt. Generell scheint es aber zu funktionieren, der Lichtsensor funktioniert nach wie vor.
                                          Ein Neustart des Raspberrys, mit und ohne Conbee II Stick hat keine Besserung gebracht.
                                          Habe ebenfalls versucht eine Lampe komplett neu anzulernen, ohne Erfolg.
                                          Hier mal ein Auszug aus dem Log
                                          zigbee.0
                                          	2022-11-08 16:09:48.846	error	Send command to 0x94deb8fffecaf033 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:09:32.842	error	Send command to 0x94deb8fffecaf033 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:09:03.843	warn	DeviceConfigure:DeviceConfigure failed 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01, attempt 5 (Error: Bind 0x04cf8cdf3c7b5365/1 genPowerCfg from '0x00212effff05e492/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:765:19) at Endpoint.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:567:13) at Object.bind (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/reporting.js:40:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/xiaomi.js:1546:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:145:9) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:124:17))
                                          zigbee.0
                                          	2022-11-08 16:08:03.523	info	Configuring 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01
                                          zigbee.0
                                          	2022-11-08 16:06:55.836	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:54.830	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:53.830	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:51.830	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:47.831	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:46.841	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:44.831	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:42.830	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:41.829	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:06:39.831	error	Send command to 0x94deb8fffecc6895 failed with no error code (no response received)
                                          zigbee.0
                                          	2022-11-08 16:05:29.822	warn	DeviceConfigure:DeviceConfigure failed 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01, attempt 4 (Error: Bind 0x04cf8cdf3c7b5365/1 genPowerCfg from '0x00212effff05e492/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:765:19) at runNextTicks (node:internal/process/task_queues:61:5) at processTimers (node:internal/timers:499:9) at Endpoint.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:567:13) at Object.bind (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/reporting.js:40:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/xiaomi.js:1546:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:145:9) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:124:17))
                                          zigbee.0
                                          	2022-11-08 16:04:28.949	info	Configuring 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01
                                          zigbee.0
                                          	2022-11-08 16:04:09.810	warn	DeviceConfigure:DeviceConfigure failed 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01, attempt 3 (Error: Bind 0x04cf8cdf3c7b5365/1 genPowerCfg from '0x00212effff05e492/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:765:19) at Endpoint.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:567:13) at Object.bind (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/reporting.js:40:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/xiaomi.js:1546:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:145:9) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:124:17))
                                          zigbee.0
                                          	2022-11-08 16:03:09.107	info	Configuring 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01
                                          zigbee.0
                                          	2022-11-08 16:02:09.796	warn	DeviceConfigure:DeviceConfigure failed 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01, attempt 2 (Error: Bind 0x04cf8cdf3c7b5365/1 genPowerCfg from '0x00212effff05e492/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:765:19) at Endpoint.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:567:13) at Object.bind (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/reporting.js:40:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/xiaomi.js:1546:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:145:9) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:124:17))
                                          zigbee.0
                                          	2022-11-08 16:01:09.367	info	Configuring 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01
                                          zigbee.0
                                          	2022-11-08 16:01:04.781	warn	DeviceAvailability:Failed to ping 0x94deb8fffed33d36 TRADFRI bulb GU10 CWS 345lm
                                          zigbee.0
                                          	2022-11-08 16:01:04.780	warn	DeviceAvailability:Failed to ping 0x94deb8fffecaf033 TRADFRI bulb GU10 CWS 345lm
                                          zigbee.0
                                          	2022-11-08 16:01:04.779	warn	DeviceAvailability:Failed to ping 0x94deb8fffecc6895 TRADFRI bulb GU10 CWS 345lm
                                          zigbee.0
                                          	2022-11-08 16:01:04.778	warn	DeviceAvailability:Failed to ping 0x804b50fffed2a41b TRADFRI bulb E14 WS 470lm
                                          zigbee.0
                                          	2022-11-08 16:01:03.779	warn	DeviceAvailability:Failed to ping 0x588e81fffe7b00f1 TRADFRI bulb E14 WS 470lm
                                          zigbee.0
                                          	2022-11-08 16:01:03.779	warn	DeviceAvailability:Failed to ping 0x842e14fffe61104e TRADFRI bulb E14 WS 470lm
                                          zigbee.0
                                          	2022-11-08 16:01:03.778	warn	DeviceAvailability:Failed to ping 0x94deb8fffed3342e TRADFRI bulb GU10 CWS 345lm
                                          zigbee.0
                                          	2022-11-08 16:00:02.891	warn	DeviceConfigure:DeviceConfigure failed 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01, attempt 1 (Error: Bind 0x04cf8cdf3c7b5365/1 genPowerCfg from '0x00212effff05e492/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:765:19) at runNextTicks (node:internal/process/task_queues:61:5) at processTimers (node:internal/timers:499:9) at Endpoint.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:567:13) at Object.bind (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/reporting.js:40:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/xiaomi.js:1546:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:145:9) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:124:17) at DeviceConfigure.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:60:21) at async Promise.all (index 1))
                                          zigbee.0
                                          	2022-11-08 15:59:02.121	info	Zigbee started
                                          zigbee.0
                                          	2022-11-08 15:59:02.119	info	0x94deb8fffed3342e (addr 11439): LED1923R5 - IKEA TRADFRI LED bulb GU10 345 lumen, dimmable, white spectrum, color spectrum (Router)
                                          zigbee.0
                                          	2022-11-08 15:59:02.102	info	0x94deb8fffed33d36 (addr 38562): LED1923R5 - IKEA TRADFRI LED bulb GU10 345 lumen, dimmable, white spectrum, color spectrum (Router)
                                          zigbee.0
                                          	2022-11-08 15:59:02.100	info	0x94deb8fffecaf033 (addr 58711): LED1923R5 - IKEA TRADFRI LED bulb GU10 345 lumen, dimmable, white spectrum, color spectrum (Router)
                                          zigbee.0
                                          	2022-11-08 15:59:02.097	info	0x94deb8fffecc6895 (addr 32799): LED1923R5 - IKEA TRADFRI LED bulb GU10 345 lumen, dimmable, white spectrum, color spectrum (Router)
                                          zigbee.0
                                          	2022-11-08 15:59:02.094	info	0x00158d00045cd7a9 (addr 29771): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          zigbee.0
                                          	2022-11-08 15:59:02.092	info	0x804b50fffed2a41b (addr 45967): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                          zigbee.0
                                          	2022-11-08 15:59:02.090	info	0x588e81fffe7b00f1 (addr 49350): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                          zigbee.0
                                          	2022-11-08 15:59:02.087	info	0x842e14fffe61104e (addr 59926): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                          zigbee.0
                                          	2022-11-08 15:59:02.084	info	0x00158d00054a9c73 (addr 24915): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.0
                                          	2022-11-08 15:59:02.082	info	0xbc33acfffe8727c5 (addr 34494): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                          zigbee.0
                                          	2022-11-08 15:59:02.070	info	0x04cf8cdf3c7b5365 (addr 47500): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                          zigbee.0
                                          	2022-11-08 15:59:02.065	info	Configuring 0x04cf8cdf3c7b5365 lumi.sen_ill.mgl01
                                          zigbee.0
                                          	2022-11-08 15:59:02.023	info	Currently 11 devices are joined:
                                          zigbee.0
                                          	2022-11-08 15:59:02.018	info	Unable to set transmit power, unsupported function.
                                          zigbee.0
                                          	2022-11-08 15:59:01.850	info	--> transmitPower : normal
                                          zigbee.0
                                          	2022-11-08 15:59:01.828	info	Unable to disable LED, unsupported function.
                                          zigbee.0
                                          	2022-11-08 15:59:01.806	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":101,"maintrel":0,"revision":"0x26650700"}}
                                          zigbee.0
                                          	2022-11-08 15:59:01.770	info	Installed Version: iobroker.zigbee@1.7.5
                                          zigbee.0
                                          	2022-11-08 15:59:01.079	info	Starting Zigbee npm ...
                                          zigbee.0
                                          	2022-11-08 15:59:01.075	info	delete old Backup files. keep only last 10
                                          zigbee.0
                                          	2022-11-08 15:59:00.915	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
                                          So sieht's in den Objekten aus
                                          H 1 Antwort Letzte Antwort
