  4. ZigBee neue Version 1.7.x
    5.9k
1.7backupiconszigbee
217 Beiträge 40 Kommentatoren 48.0k Aufrufe 47 Beobachtet
  • arteckA arteck
    @david-g hast du das LOG noch.. vom Adapterstart
    David G.D Online
    David G.D Online
    David G.
    #91
    @arteck
    Hab es doch schon geschafft.
    So sieht der Start vom Adapter aus:
    zigbee.0
    2022-07-31 09:25:14.969	warn	DeviceAvailability:Failed to ping 0xf0d1b8000013d3a8 Panel TW Z3
    zigbee.0
    2022-07-31 09:25:14.939	warn	DeviceAvailability:Failed to ping 0xbc33acfffeb20bf5 TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:14.704	warn	DeviceAvailability:Failed to ping 0x84fd27fffed0858b TRADFRI bulb GU10 WS 400lm
    zigbee.0
    2022-07-31 09:25:14.451	warn	DeviceAvailability:Failed to ping 0x60a423fffeed446c TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:14.403	warn	DeviceAvailability:Failed to ping 0x60a423fffef0ff05 TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:14.317	warn	DeviceAvailability:Failed to ping 0x804b50fffea8bebd TRADFRI bulb GU10 WS 400lm
    zigbee.0
    2022-07-31 09:25:14.254	warn	DeviceAvailability:Failed to ping 0xcc86ecfffe952a0e TRADFRI bulb GU10 WS 400lm
    zigbee.0
    2022-07-31 09:25:14.243	warn	DeviceAvailability:Failed to ping 0xbc33acfffec026df TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:14.174	warn	DeviceAvailability:Failed to ping 0xbc33acfffe5f8ea0 TRADFRI bulb E14 WS opal 600lm
    zigbee.0
    2022-07-31 09:25:13.981	warn	DeviceAvailability:Failed to ping 0xbc33acfffea94381 TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:25:13.941	warn	DeviceAvailability:Failed to ping 0xd0cf5efffeeedcb2 TRADFRI bulb GU10 WS 400lm
    zigbee.0
    2022-07-31 09:25:13.771	warn	DeviceAvailability:Failed to ping 0x2c1165fffe17366c TRADFRIbulbE27WWclear250lm
    zigbee.0
    2022-07-31 09:25:13.649	warn	DeviceAvailability:Failed to ping 0x7cb03eaa00afc5ce Plug 01
    zigbee.0
    2022-07-31 09:25:13.536	warn	DeviceAvailability:Failed to ping 0xbc33acfffe9b50d6 TRADFRI bulb GU10 WW 400lm
    zigbee.0
    2022-07-31 09:24:50.227	info	Zigbee started
    zigbee.0
    2022-07-31 09:24:50.222	info	0x00124b002519401e (addr 5935): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    zigbee.0
    2022-07-31 09:24:50.220	info	0x00124b002513bb34 (addr 37306): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    zigbee.0
    2022-07-31 09:24:50.217	info	0xf0d1b8000013d3a8 (addr 23290): 4058075181472 - LEDVANCE SMART+ panel 60 x 60cm tunable white (Router)
    zigbee.0
    2022-07-31 09:24:50.214	info	0x842e14fffe78cb20 (addr 46126): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
    zigbee.0
    2022-07-31 09:24:50.213	info	0xbc33acfffec026df (addr 64479): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.181	info	0xbc33acfffe9b50d6 (addr 48925): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.179	info	0xbc33acfffea94381 (addr 47468): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.176	info	0x804b50fffefb471f (addr 29106): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
    zigbee.0
    2022-07-31 09:24:50.173	info	0xbc33acfffeb20bf5 (addr 22639): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.171	info	0x60a423fffef0ff05 (addr 49702): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.168	info	0x60a423fffeed446c (addr 19589): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.166	info	0xbc33acfffe5f8ea0 (addr 57424): LED1733G7 - IKEA TRADFRI LED bulb E14 600 lumen, dimmable, white spectrum, opal white (Router)
    zigbee.0
    2022-07-31 09:24:50.163	info	0xcc86ecfffe952a0e (addr 41784): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    zigbee.0
    2022-07-31 09:24:50.161	info	0x84fd27fffed0858b (addr 32917): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    zigbee.0
    2022-07-31 09:24:50.157	info	0x804b50fffea8bebd (addr 25499): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    zigbee.0
    2022-07-31 09:24:50.155	info	0xd0cf5efffeeedcb2 (addr 21634): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
    zigbee.0
    2022-07-31 09:24:50.152	info	0x2c1165fffe17366c (addr 16013): LED1934G3_E27 - IKEA TRADFRI LED bulb E27 WW clear 250 lumen, dimmable (Router)
    zigbee.0
    2022-07-31 09:24:50.143	info	0x7cb03eaa00afc5ce (addr 13786): AB3257001NJ - OSRAM Smart+ plug (Router)
    zigbee.0
    2022-07-31 09:24:50.093	info	Currently 18 devices are joined:
    zigbee.0
    2022-07-31 09:24:50.079	info	--> transmitPower : high
    zigbee.0
    2022-07-31 09:24:50.052	info	Unable to disable LED, unsupported function.
    zigbee.0
    2022-07-31 09:24:50.040	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    zigbee.0
    2022-07-31 09:24:46.983	info	Installed Version: iobroker.zigbee@1.7.5
    zigbee.0
    2022-07-31 09:24:45.958	info	Starting Zigbee npm ...
    zigbee.0
    2022-07-31 09:24:45.955	info	delete old Backup files. keep only last 10
    zigbee.0
    2022-07-31 09:24:45.624	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
    Wenn ich eine Gruppe oder ein einzelnes Gerät schalten möchte:
    zigbee.0
    2022-07-31 09:29:15.864	warn	Send command to 0xbc33acfffe5f8ea0 failed with: Code 205 (No network route)
    zigbee.0
    2022-07-31 09:28:55.040	warn	unread state change for group members ["0x60a423fffef0ff05","0xbc33acfffeb20bf5"]
    P. S.:
    3 Gu10 sind wirklich Stromlos.
    • David G.D David G.
      @arteck
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      P. S.:
      #92
      @david-g
      Setz den Port auf den Link aus /dev/serial/by-id
      nicht auf /dev/ttyUSBx
      • David G.D Online
        David G.D Online
        David G.
        #93
        Ist abgeändert.
        Problem bleibt 1 zu 1 bestehen.
        EDIT:
        Hab grade folgendes festgestellt. Kann das sein?
        Habe eine einzelne Birne Stromlos gemacht. Danach hat sich der Adapter selber neugestartet.
        Nun kann ich alle Birnen steuern.
        Wenn ich den Adapter jetzt nochmal neustarte bekommt er die Geräte auch nicht angepingt. Lassen sich dann jedoch nach kurzer Zeit schalten.
        EDIT2
        Wenn ich die Geräte vom Strom nehme, scheinen sie sich danach zu verbinden.
        Den Absturz vom Adapter hatte ich, weil noch nicht die aktuelle git Version installiert war (das ikea Problem).
        Beobachte es mal
          Ist abgeändert.
          EDIT:
          EDIT2
          Beobachte es mal
          arteckA Offline
          arteckA Offline
          arteck
          #94
          @david-g sagte in ZigBee neue Version 1.7.x:
          in offi 1.7.5 ist es beoben.. da brauchst du nicht von GIT installieren
            @arteck das geht dann wohl nur mit dem originalen Gateway. Weil da hab ich ein Video dazu gesehen: https://youtu.be/gTZ4C4_iD6k ab ca. 3:00 Aber die originalen 30sec sind auch schon besser.
            Tassos
            #95
            Hallo ,Ich bin neu hier und weiß nicht wie ich ein thema eröffne.
            Ich habe ein Problem und bin am verzweifeln. Ich möchte einen Gateway für bewesserung verbinden mit meinem w-lan und es geht nicht,ich habe den Rainpoint gateway und habe alles richtig gemacht,ich habe auch einen zweiten vewrsucht ,immer wieder das gleiche,er sucht und sucht 2 minuten und nichts
            • T Tassos
              #96
              @tassos Dann ist das Hier wahrscheinlich der Falsche Thread. Dein Bewässerungscomputer hat kein Zigbee, sondern WIFI.
                Tassos
                #97
                @typ1er Sorry,wo muss ich hin?
                • T Tassos
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #98
                  @tassos Du solltest einen eigenen Thread aufmachen - mit passendem Thema.
                  A.
                  • arteckA arteck
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #99
                    @arteck
                    weißt du was das bedeuten könnte:
                    zigbee.0
                    	2022-08-06 15:53:26.839	warn	Failed to read state '"power_on_behavior"'of '0x588e81fffef0543f' after query with '{"code":134}'
                    zigbee.0
                    	2022-08-06 15:51:53.353	warn	Failed to read state '"power_on_behavior"'of '0x588e81fffef0543f' after query with '{"code":134}'
                    zigbee.0
                    	2022-08-06 15:39:07.879	warn	Failed to read state '"power_on_behavior"'of '0x588e81fffef0543f' after query with '{"code":134}'
                    • liv-in-skyL liv-in-sky
                      @arteck
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #100
                      @liv-in-sky
                      Die Meldungen kommen wenn das System versucht das Attribute "power_on_behavior" von einem Gerät zu lesen welches dieses Attribut nicht unterstützt (code:134 ist "unsupported attribute")
                      Es ist davon auszugehen das das Gerät nicht 100% sauber in den Herdsman-converters implementiert ist.
                      A.
                      • AsgothianA Asgothian
                        @liv-in-sky
                        A.
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #101
                        @asgothian danke dir - dann kann ich wohl nichts machen, außer den query dp nicht zu nutzen :-(
                        • nukleuzN Offline
                          nukleuzN Offline
                          nukleuz
                          schrieb am zuletzt editiert von nukleuz
                          #102
                          ich wage gerade den Umstieg von DeConz zu ioBroker Zigbee…
                          Klappt alles sehr gut.
                          Bisher habe ich ein Gerät was sich nicht pairen lassen will.
                          Von Dresden Elektronik der Dimmer Switch hat ein Fragezeichen. Wird der unterstützt?
                          Wie gehe ich hier nun vor?
                          Danke für Info und weiter so 👍
                          E19F36AB-072B-4CEE-A2E6-78B6D47286DC.jpeg DA6AC4B8-5073-4F84-B52D-0566AF05D9D8.png
                          Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                          • nukleuzN nukleuz
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #103
                            da muss ein Blaues I sein.. drauf klicken..die Kachel posten
                            nukleuzN 1 Antwort Letzte Antwort
                            • arteckA arteck
                              nukleuzN Offline
                              nukleuzN Offline
                              nukleuz
                              #104
                              @arteck
                              Hier der Screenshot - danke:
                              modelZigbee:Kobold
                              type:Router
                              nwk:32959
                              manuf id:4405
                              manufacturer:dresden elektronik
                              power:Mains (single phase)
                              app version:0
                              hard version:1
                              zcl version:8
                              stack version:0
                              date code:20211119
                              build:0103.10000026
                              interviewed:true
                              configured:false
                              endpoint:1
                              profile:260
                              input clusters:genBasic (0)
                              genIdentify (3)
                              genGroups (4)
                              genScenes (5)
                              genOnOff (6)
                              genLevelCtrl (8)
                              output clusters:genOta (25)
                              endpoint:2
                              profile:260
                              genIdentify (3)
                              output clusters:genIdentify (3)
                              genOnOff (6)
                              genLevelCtrl (8)
                              endpoint:242
                              profile:41440
                              output clusters:greenPower (33)
                              • JackDanielJ Offline
                                JackDanielJ Offline
                                JackDaniel
                                schrieb am zuletzt editiert von JackDaniel
                                #105
                                kommt die anzeige vom verbindungsstatus in den objekten eigentlich vom adapter, oder vom admin, oder von wo ganz anders?
                                ich finde die anzeige spitze, bzw. sollte das zum standard für alle geräte werden :)
                                Carpe diem
                                • JackDanielJ JackDaniel
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #106
                                  @jackdaniel wird vom adapter geliefert und admin setzt es um
                                  • nukleuzN nukleuz
                                    @arteck
                                    modelZigbee:Kobold
                                    type:Router
                                    nwk:32959
                                    manuf id:4405
                                    app version:0
                                    hard version:1
                                    zcl version:8
                                    stack version:0
                                    date code:20211119
                                    build:0103.10000026
                                    interviewed:true
                                    configured:false
                                    endpoint:1
                                    profile:260
                                    genIdentify (3)
                                    genGroups (4)
                                    genScenes (5)
                                    genOnOff (6)
                                    genLevelCtrl (8)
                                    endpoint:2
                                    profile:260
                                    genIdentify (3)
                                    genOnOff (6)
                                    genLevelCtrl (8)
                                    endpoint:242
                                    profile:41440
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #107
                                    @nukleuz der ist da.. installier mal die GIT version
                                    https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                                    nukleuzN 3 Antworten Letzte Antwort
                                    • arteckA arteck
                                      nukleuzN Offline
                                      nukleuzN Offline
                                      nukleuz
                                      #108
                                      @arteck
                                      Danke vorab!
                                      Adapter ist aktualisiert - leider komme ich morgen erst zum neu pairen… Oder müsste er nach Update angezeigt werden?
                                      Greets
                                      • arteckA arteck
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #109
                                        @arteck sagte in ZigBee neue Version 1.7.x:
                                        sowas find ich klasse - wünschte mir das in anderen adaptern :-)
                                        • arteckA arteck
                                          nukleuzN Offline
                                          nukleuzN Offline
                                          nukleuz
                                          #110
                                          @arteck
                                          Habe das Gerät neu gepaired:
                                          Pairing time left: 20
                                          Pairing time left: 21
                                          New device joined '0x00212effff0a6524' model Kobold
                                          Interview successful: [object Object]
                                          Pairing time left: 22
                                          Pairing time left: 23
                                          Error: Device 0x00212effff0a6524 "Kobold" not described in statesMapping.. undefined
                                          Pairing time left: 24
                                          Interview started: 0x00212effff0a6524
                                          Pairing time left: 25
                                          Pairing time left: 26
                                          Pairing time left: 27
                                          Pairing time left: 28
                                          So sieht die Kachel aus:
                                          Und so die DP:
                                          Was kann ich noch tun?
                                          Danke.
                                          Edit:
