  5. Warnungen im Blockly Script (GELÖST)
blocklyjavascript
21 Beiträge 4 Kommentatoren 2.7k Aufrufe 3 Beobachtet
  • Elektroniker86E Offline
    Elektroniker86
      <block type="create" id="K=+:F0(CILzbfZ=5@+*h" x="-1037" y="-712">
        <field name="NAME">Kameras.Parkplatz Alarm EIN_AUS</field>
        <next>
          <block type="on" id="lcGz5d3oWQ85C^Ed(uK9">
            <field name="OID">javascript.0.Kameras.Parkplatz Alarm EIN_AUS</field>
            <statement name="STATEMENT">
              <block type="controls_if" id="H.E00`#rWS:Lm*8)@bsV">
                <value name="IF0">
                  <block type="logic_compare" id="4PlP3`5X47Pj^VP2NY0`">
                    <field name="OP">EQ</field>
                    <value name="A">
                      <block type="on_source" id="`9M2a0T:AOs`2F2+oWl?">
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_boolean" id="]SbtrJ#s3aohU9?_V%70">
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="control" id="^xUkyDRAC1k$+/vG1_p_">
                    <field name="OID">mqtt.1.instar.Stellplatz.alarm.area1.enable.raw</field>
                    <value name="VALUE">
                      <block type="math_number" id="[@iG:fmz]~.Fg*te10P1">
                        <field name="NUM">1</field>
                      </block>
                    </value>
                    <next>
                      <block type="control" id="oz(,y@bD6sDOq6IJggS.">
                        <field name="OID">mqtt.1.instar.Stellplatz.alarm.area2.enable.raw</field>
                          <block type="math_number" id="KKpZDBd}Yl*bQ5y*.]IB">
                          </block>
                        </value>
                        <next>
                          <block type="control" id="h0]QC:%:-%^`v~`0W8g.">
                            <field name="OID">mqtt.1.instar.Stellplatz.alarm.area3.enable.raw</field>
                              <block type="math_number" id="@=a*_-/4peR%wrq}{LS1">
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
                <statement name="ELSE">
                  <block type="control" id="KtYae/7|mz.tPsTw8U9x">
                      <block type="math_number" id="[.|8iya1~Q3ZcV_+S-S1">
                        <field name="NUM">0</field>
                      </block>
                    </value>
                    <next>
                      <block type="control" id="TCJ|kafArO5#CXm+Ka!$">
                          <block type="math_number" id="($|yNNB|[u{v|Q*YpGO*">
                          </block>
                        </value>
                        <next>
                          <block type="control" id="pWKDt*4bv]){(hQO8M%+">
                              <block type="math_number" id="]xJ!8ymGFthjzAgZZvWm">
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
    • Elektroniker86E Elektroniker86
          <next>
                  <value name="IF0">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </next>
        </block>
      </xml>
      TT-Tom
      @elektroniker86
      Dein Fehler liegt im anlegen des Datenpunkt. Nimm mal die Leerzeichen raus.
      Wo soll der den angelegt werden?
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      Elektroniker86E 1 Antwort Letzte Antwort
      • T TT-Tom
        @elektroniker86
        Elektroniker86
        @tt-tom
        Ok, Leerzeichen durch Unterstriche ersetzen?
        Hier ist und soll er auch angelegt sein:
          @tt-tom
          TT-Tom
          @elektroniker86 und?
          Gruß Tom
          Public Transport
          • T TT-Tom
            Elektroniker86
            @tt-tom
            Nein, immer noch das gleiche. Habe die Leerzeichen jetzt durch Unterstriche ersetzt.
            DJMarc75D T 2 Antworten Letzte Antwort
              @tt-tom
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @elektroniker86
              Poste mal bitte die Eigenschaften von einem der angesteuerten DP.
              Lehrling seit 1975 !!!
                @tt-tom
                TT-Tom
                @elektroniker86
                erste mal die Zahlen durch wahr und falsch.
                Edit: @DJMarc75 hat den selben Gedanken
                Gruß Tom
                Public Transport
                • T TT-Tom
                  @elektroniker86
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @tt-tom sagte in Warnungen im Blockly Script:
                  Ähnlich, ich denke dass da 1 oder 0 schon korrekt ist aber nicht als Zahl sondern als String (Text) verwendet werden sollte.
                  • DJMarc75D DJMarc75
                    TT-Tom
                    @djmarc75 sagte in Warnungen im Blockly Script:
                    ja, das ist glaube ich die richtige Richtung.
                    Gruß Tom
                    Public Transport
                      @elektroniker86
                      Elektroniker86
                      @djmarc75
                        "common": {
                          "name": "instar/Stellplatz/alarm/area1/enable/raw",
                          "write": true,
                          "read": true,
                          "role": "variable",
                          "desc": "mqtt server variable",
                          "type": "string"
                        "native": {
                          "topic": "instar/Stellplatz/alarm/area1/enable/raw"
                        "type": "state",
                        "from": "system.adapter.mqtt.1",
                        "user": "system.user.admin",
                        "ts": 1659642195982,
                        "_id": "mqtt.1.instar.Stellplatz.alarm.area1.enable.raw",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                          "owner": "system.user.admin",
                        @djmarc75
                          "common": {
                            "write": true,
                            "read": true,
                            "role": "variable",
                            "type": "string"
                          "native": {
                          "type": "state",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @elektroniker86 sagte in Warnungen im Blockly Script:
                        "type": "string"
                        dann wäre es des Rätsels Lösung:
                        Müsste aber im LOG(nicht im Skriptlog) auch drinstehen wenn du per Skript schaltest.
                        Elektroniker86E 2 Antworten Letzte Antwort
                          "type": "string"
                          Elektroniker86
                          @djmarc75
                          Ahh, leuchtet irgendwie ein. Das probiere ich gleich aus.
                            "type": "string"
                            Elektroniker86
                            @djmarc75
                            TIP TOP ! Läuft!
                            Das war der Fehler. Vielen Dank für deine Hilfe.
                              Elektroniker86
                              Natürlich Danke an alle !
