  3. Off Topic
  4. InfluxDB
  5. Benötige Hilfe bei Influx DB
    apollon77A
Geplant Angeheftet Gesperrt Verschoben InfluxDB
109 Beiträge 7 Kommentatoren 29.2k Aufrufe 5 Beobachtet
    @altersrentner
    Sag ich doch. Kein Repository angelegt.
    Und dein Influxdata-Repository ist auch falsch. Du hast kein 'stretch' laufen sondern offenbar 'bullseye'. Dann muss das auch auf bullseye lauten.
    A
    A
    Altersrentner
    #86
    @thomas-braun sagte in Benötige Hilfe bei Influx DB:
    Das habe ich gemacht:
    pi@raspberrypiioBroker:~ $ sudo apt-get install -y adduser libfontconfig1
    Reading package lists... Done
    adduser is already the newest version (3.118).
    libfontconfig1 is already the newest version (2.13.1-4.2).
    libfontconfig1 set to manually installed.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    pi@raspberrypiioBroker:~ $ wget https://dl.grafana.com/enterprise/release/grafana-enterprise_6.6.1_amd64.deb
    --2022-08-05 14:59:11--  https://dl.grafana.com/enterprise/release/grafana-enterprise_6.6.1_amd64.deb
    Resolving dl.grafana.com (dl.grafana.com)... 2a04:4e42:1b::729, 151.101.114.217
    Connecting to dl.grafana.com (dl.grafana.com)|2a04:4e42:1b::729|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 63940356 (61M) [application/x-debian-package]
    Saving to: ‘grafana-enterprise_6.6.1_amd64.deb’
    grafana-enterprise_6.6.1_amd64.d 100%[=========================================================>]  60.98M  6.83MB/s    in 8.9s
    2022-08-05 14:59:20 (6.81 MB/s) - ‘grafana-enterprise_6.6.1_amd64.deb’ saved [63940356/63940356]
    pi@raspberrypiioBroker:~ $ sudo dpkg -i grafana-enterprise_6.6.1_amd64.deb
    dpkg: error processing archive grafana-enterprise_6.6.1_amd64.deb (--install):
     package architecture (amd64) does not match system (arm64)
    Errors were encountered while processing:
    pi@raspberrypiioBroker:~ $ sudo apt install grafana=6.6.1
    E: Unable to locate package grafana
    Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
    • A Altersrentner
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #87
      @altersrentner
      Damit dübelst du dir 'irgendwas' am Paketmanager vorbei ins System.
      Finger weg von so einem Blödsinn.
      amd64 passt auch nicht zu deinem Raspberry Pi, der hat eine andere Prozessorarchitektur. Deswegen auch:
      • A Altersrentner
        DJMarc75D
        DJMarc75D
        DJMarc75
        #88
        @altersrentner
        wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
        echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
        dann
        sudo apt update
        Lehrling seit 1975 !!!
        • DJMarc75D DJMarc75
          @altersrentner
          dann
          sudo apt update
          A
          A
          Altersrentner
          #89
          @djmarc75
          pi@raspberrypiioBroker:~ $ sudo apt update
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://repos.influxdata.com/debian stretch InRelease
          Get:4 https://packages.grafana.com/oss/deb stable InRelease [12.1 kB]
          Get:5 https://packages.grafana.com/oss/deb stable/main arm64 Packages [26.6 kB]
          Get:6 https://packages.grafana.com/oss/deb stable/main armhf Packages [36.1 kB]
          Hit:7 http://deb.debian.org/debian bullseye InRelease
          Hit:8 http://deb.debian.org/debian bullseye-updates InRelease
          Fetched 74.9 kB in 6s (13.1 kB/s)
          All packages are up to date.
          • A Altersrentner
            @djmarc75
            Thomas BraunT
            Thomas BraunT
            #90
            @altersrentner
            Auch wenn ich das absolut nicht für eine gute Idee halte:
            sudo apt-mark hold grafana
            DJMarc75D A 2 Antworten Letzte Antwort
              @altersrentner
              DJMarc75D
              DJMarc75D
              DJMarc75
              #91
              Da gibts dann halt ein H-Kennzeichen 😀
              @Altersrentner bist Du schon weitergekommen ?
                @altersrentner
                A
                A
                Altersrentner
                #92
                Warum?
                @djmarc75 sagte in Benötige Hilfe bei Influx DB:
                Was meinst Du damit?
                Ja, Eben das erste Board erstellt👍 👍 👍 😊 😊 😊
                Die Version ist super einfach zu bedienen
                Ich denke, das soll es dann gewesen sein.
                Ich möchte mich bei alle die mir mit Engelsgeduld geholfen haben bedanken.
                Mit freundlichen Grüßen
                Michael
                • A Altersrentner
                  Warum?
                  Michael
                  Thomas BraunT
                  Thomas BraunT
                  #93
                  @altersrentner
                  Erwartest du da ernsthaft eine Antwort?
                  Schau hier rein:
                  https://grafana.com/tags/security/
                    @altersrentner
                    Schau hier rein:
                    A
                    A
                    Altersrentner
                    #94
                    Schau hier rein:
                    OHA!
                    Aber 😧 ich habe bei der aktuellen V keinen Lichtblick gefunden.
                    Habe doch noch eine Frage
                    Wie kann ich das zurücksetzen / aufheben?
                    MfG Michael
                    • A Altersrentner
                      Schau hier rein:
                      OHA!
                      MfG Michael
                      DJMarc75D
                      DJMarc75D
                      DJMarc75
                      #95
                      @altersrentner sagte in Benötige Hilfe bei Influx DB:
                      sudo atp-mark unhold grafana
                      Suchfunktionen in jeglicher Form wäre da auch mal eine super Idee - nicht hier alles OutOfTheBox erwarten !
                        A
                        A
                        Altersrentner
                        #96
                        @djmarc75
                        Asche auf mein Haupt😖
                        MfG Michael
                        • A Altersrentner
                          @djmarc75
                          MfG Michael
                          DJMarc75D
                          DJMarc75D
                          DJMarc75
                          #97
                          Asche auf mein Haup
                          Na sooo schlimm dann auch nicht. Aber sei mal ehrlich, bissle selber suchen ist nicht grad schädlich 😉
                            Asche auf mein Haup
                            Thomas BraunT
                            Thomas BraunT
                            #98
                            Wenn man gemein wäre:
                            man apt-mark
                              man apt-mark
                              DJMarc75D
                              DJMarc75D
                              DJMarc75
                              #99
                              man apt-mark
                              Mich schreibt man mit C und nicht mit K ... aber gemein bin ich natürlich auch ! 😂
                                man apt-mark
                                A
                                A
                                Altersrentner
                                #100
                                @djmarc75
                                Habe sehr viel gelesen 😧 aber komme jetzt wirklich nicht weiter.
                                Ich möchte ein Plugin zu Grafana hinzu fügen.
                                Installirt sollte das Discrete Plugin sein.
                                Die Fehlermeldung sagt aber:
                                < Paketlisten lesen... Fertig
                                Abhängigkeitsbaum erstellen ... Fertig
                                Zustandsinformationen lesen... Fertig
                                E: Paket natel-discrete-panel kann nicht gefunden werden>
                                Das habe ich bis jetzt versucht,
                                pi@raspberrypiioBroker:~ $ sudo grafana-cli plugins install natel-discrete-panel
                                installing natel-discrete-panel @ 0.1.1
                                from: https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/download
                                into: /var/lib/grafana/plugins
                                ✔ Installed natel-discrete-panel successfully
                                Restart grafana after installing plugins . <service grafana-server restart>
                                pi@raspberrypiioBroker:~ $ sudo apt natel-discrete-panel
                                E: Invalid operation natel-discrete-panel
                                pi@raspberrypiioBroker:~ $ sudo apt install natel-discrete-panel
                                E: Unable to locate package natel-discrete-panel
                                Wie kann ich weiter kommen?
                                Sonst, abgesehen von dem Sicherheitshinweis von Thomas Braun läuft alles prima.
                                MfG Michael
                                E Thomas BraunT 3 Antworten Letzte Antwort
                                • DJMarc75D
                                  DJMarc75D
                                  DJMarc75
                                  #101
                                  @altersrentner Tag,
                                  die Frage ist warum Du das über die Konsole installieren willst ?
                                  Geht bei mir direkt per Grafana.
                                  • A Altersrentner
                                    @djmarc75
                                    MfG Michael
                                    E
                                    E
                                    Einstein67
                                    #102
                                    @altersrentner said in Benötige Hilfe bei Influx DB:
                                    Warum installierst du nicht einfach über die Grafana Oberfläche?
                                    Configuration --> Plugins --> ins Suchfeld Discrete eingeben --> auswählen und install
                                    • A Altersrentner
                                      @djmarc75
                                      MfG Michael
                                      Thomas BraunT
                                      Thomas BraunT
                                      #103
                                      @altersrentner
                                      Das Plugin ist kein Paket das man über den Paketmanager bezieht sondern offenbar direkt aus grafana heraus.
                                      • A Altersrentner
                                        @djmarc75
                                        MfG Michael
                                        E
                                        E
                                        Einstein67
                                        #104
                                        @altersrentner Gerade gesehen. Das Plugin wurde richtig installiert!
                                        Funktioniert es nicht?
                                        • E Einstein67
                                          A
                                          A
                                          Altersrentner
                                          #105
                                          @einstein67 sagte in Benötige Hilfe bei Influx DB:
                                          Nein es taucht unter den Plugins nicht auf.
                                          84.0k
