  4. Probleme mit Installation von ESP Home@0.2.4
109 Beiträge 6 Kommentatoren 12.9k Aufrufe 5 Beobachtet
  • T Tontechniker
    pi@raspberrypi:/opt/iobroker $ npm install iobroker.esphome
    > iobroker.esphome@0.2.4 install /opt/iobroker/node_modules/iobroker.esphome
    > npip install
    No python_modules directory; installing pip locally if needed.
      Cache entry deserialization failed, entry ignored
    Successfully completed pip check.
    Collecting esphome>=2021.8
      Using cached esphome-2022.5.1-py2.py3-none-any.whl (2.3 MB)
    Collecting tornado>=3.2
      Using cached tornado-6.1.tar.gz (497 kB)
      Preparing metadata (setup.py) ... done
    Collecting pyserial==3.5
      Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
    Collecting PyYAML==6.0
      Using cached PyYAML-6.0.tar.gz (124 kB)
      Installing build dependencies ... done
      Getting requirements to build wheel ... done
      Preparing metadata (pyproject.toml) ... done
    Collecting tzlocal==4.2
      Using cached tzlocal-4.2-py3-none-any.whl (19 kB)
    Collecting click==8.1.3
      Using cached click-8.1.3-py3-none-any.whl (96 kB)
    Collecting tzdata>=2021.1
      Using cached tzdata-2022.1-py2.py3-none-any.whl (339 kB)
    Collecting voluptuous==0.13.1
      Using cached voluptuous-0.13.1-py3-none-any.whl (29 kB)
    Collecting aioesphomeapi==10.8.2
      Using cached aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
    Collecting colorama==0.4.4
      Using cached colorama-0.4.4-py2.py3-none-any.whl (16 kB)
    Collecting paho-mqtt==1.6.1
      Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
    Collecting esptool==3.3
      Using cached esptool-3.3.tar.gz (213 kB)
    Collecting esphome-dashboard==20220508.0
      Using cached esphome_dashboard-20220508.0-py3-none-any.whl (601 kB)
    Collecting kconfiglib==13.7.1
      Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
    Collecting platformio==5.2.5
      Using cached platformio-5.2.5.tar.gz (218 kB)
    Collecting zeroconf==0.38.4
      Using cached zeroconf-0.38.4-py3-none-any.whl (106 kB)
    Collecting protobuf<4.0,>=3.12.2
      Using cached protobuf-3.20.1-py2.py3-none-any.whl (162 kB)
    Collecting noiseprotocol<1.0,>=0.3.1
      Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
    Collecting bitstring>=3.1.6
      Using cached bitstring-3.1.9-py3-none-any.whl (38 kB)
    Collecting cryptography>=2.1.4
      Using cached cryptography-37.0.2.tar.gz (585 kB)
      Installing build dependencies ... error
      error: subprocess-exited-with-error
      × pip subprocess to install build dependencies did not run successfully.
      │ exit code: 1
      ╰─> [126 lines of output]
          Collecting setuptools!=60.9.0,>=40.6.0
            Using cached setuptools-62.3.3-py3-none-any.whl (1.2 MB)
          Collecting wheel
            Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB)
          Collecting cffi>=1.12
            Using cached cffi-1.15.0.tar.gz (484 kB)
            Preparing metadata (setup.py): started
            Preparing metadata (setup.py): finished with status 'done'
          Collecting setuptools-rust>=0.11.4
            Using cached setuptools_rust-1.3.0-py3-none-any.whl (21 kB)
          Collecting pycparser
            Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
          Collecting semantic-version<3,>=2.8.2
            Using cached semantic_version-2.10.0-py2.py3-none-any.whl (15 kB)
          Collecting typing-extensions>=3.7.4.3
            Using cached typing_extensions-4.2.0-py3-none-any.whl (24 kB)
          Building wheels for collected packages: cffi
            Building wheel for cffi (setup.py): started
            Building wheel for cffi (setup.py): finished with status 'error'
            × python setup.py bdist_wheel did not run successfully.
            │ exit code: 1
            ╰─> [38 lines of output]
                /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/setuptools/config/setupcfg.py:459: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
                  warnings.warn(msg, warning_class)
                running bdist_wheel
                running build
                running build_py
                creating build
                creating build/lib.linux-armv7l-cpython-39
                creating build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/lock.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/vengine_gen.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/error.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/model.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/__init__.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/ffiplatform.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/api.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/cparser.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/commontypes.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/verifier.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/pkgconfig.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/recompiler.py -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/_cffi_include.h -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/parse_c_type.h -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/_embedding.h -> build/lib.linux-armv7l-cpython-39/cffi
                copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-cpython-39/cffi
                running build_ext
                building '_cffi_backend' extension
                creating build/temp.linux-armv7l-cpython-39
                creating build/temp.linux-armv7l-cpython-39/c
                arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-cpython-39/c/_cffi_backend.o
                c/_cffi_backend.c:2:10: fatal error: Python.h: Datei oder Verzeichnis nicht gefunden
                    2 | #include <Python.h>
                compilation terminated.
                error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                [end of output]
            note: This error originates from a subprocess, and is likely not a problem with pip.
            ERROR: Failed building wheel for cffi
            Running setup.py clean for cffi
          Failed to build cffi
          Installing collected packages: wheel, typing-extensions, setuptools, semantic-version, pycparser, setuptools-rust, cffi
            Running setup.py install for cffi: started
            Running setup.py install for cffi: finished with status 'error'
            × Running setup.py install for cffi did not run successfully.
            │ exit code: 1
            ╰─> [40 lines of output]
                running install
                /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
                  warnings.warn(
                running build
                running build_py
                creating build
                running build_ext
                [end of output]
          error: legacy-install-failure
          × Encountered error while trying to install package.
          ╰─> cffi
          note: This is an issue with the package mentioned above, not pip.
          hint: See above for output from the failure.
          [end of output]
    │ exit code: 1
    ╰─> See above for output.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.esphome@0.2.4 install: `npip install`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-11T12_14_44_232Z-debug.log
    Benötige ich für Python 3 eine Lizenz?
    #94
    @tontechniker sagte in Probleme mit Installation von ESP Home@0.2.4:
    Nein, aber ggf. dev-Files und ein buildenvironment
    apt policy python-dev-is-python3 build-essential
      Tontechniker
      #95
      pi@raspberrypi:/opt/iobroker $ apt policy python-dev-is-python3 build-essential
      python-dev-is-python3:
        Installiert:           (keine)
        Installationskandidat: 3.9.2-1
        Versionstabelle:
           3.9.2-1 500
      build-essential:
        Installiert:           12.9
        Installationskandidat: 12.9
        Versionstabelle:
       *** 12.9 500
      • T Tontechniker
          Versionstabelle:
             3.9.2-1 500
        build-essential:
          Installiert:           12.9
          Versionstabelle:
         *** 12.9 500
        #96
        Dann installier das nach:
        sudo apt install python-dev-is-python3
          Tontechniker
          #97
          Nach der Installation:
            Installiert:           3.9.2-1
            Versionstabelle:
           *** 3.9.2-1 500
          build-essential:
            Installiert:           12.9
            Versionstabelle:
           *** 12.9 500
          Soll ich nochmal rebooten und versuchen ESP zu installieren?
          • T Tontechniker
              Versionstabelle:
             *** 3.9.2-1 500
            build-essential:
              Installiert:           12.9
              Versionstabelle:
             *** 12.9 500
            #98
            @tontechniker
            Ich vermute die Installation von esphome funktioniert nun.
            Ansonsten wüsste ich auch nicht weiter.
              @tontechniker
              Tontechniker
              #99
              Hatte immernoch Fehlermeldung. Dann in Console Install nochmal gestartet und am Ende Fehlermeldung, dass Rust-Compiler >=1.41.0 sein muß. Habe dann "Pip" installiert und mit
              pip install --upgrade Rust
              den Upgrade durchgeführt. Danach von Admin aus Install ESP gestartet und - siehe da! Es Funktioniert!
              Vielen Dank für Deine/Eure Hilfe!!
              Hans
              • T Tontechniker
                Hans
                Jan1
                #100
                @tontechniker
                Da frag ich mich warum dass nur bei Dir so ein Umstand war den Adapter ans laufen zu bekommen?
                Das Buster nach Bullseye upzugraden funktioniert zwar, aber ne Neuinstallation dauert nicht wirklich länger und ist definitiv sauber. Könnte ne mögliche Ursache sein, oder bei mir wurde das bei Dir nun manuell installierte Zeug im Zuge einer anderen Installation schon unbemerkt von mir bereits installiert. Hatte einfach mal den Adapter von GIT zum Testen geladen und lief sofort ohne Fehler durch.
                • J Jan1
                  @tontechniker
                  Tontechniker
                  schrieb am zuletzt editiert von Tontechniker
                  #101
                  @jan1 Ich kann Dir nicht sagen, wie das passiert ist. Ich habe vor einigen Monaten Bullseye auf einer SSD installiert, eingestellt und dann IoBroker installiert und dann mein IoBroker-Backup eingespielt.
                  Dir auch nochmal ein herzliches "DANKESCHÖN"!
                  • T Tontechniker
                    Jan1
                    #102
                    @tontechniker
                    Ok, hattes Du nicht geschrieben, dass Du das Bullseye von Buster hochgezogen hast? Wenn nicht, dann ist es ja ne Neuinstallation, wobei man das eigentlich nicht von ner CD macht beim PI, sondern mit dem dafür vorgesehenen Tool ;)
                    Edit:
                    ok das mit dem Upgrade war der Kamerad aus dem anderen Thread.
                    Scheiß Konzentration Probleme nach Corna, LOL
                      Sushibomba
                      #103
                      Ich bekomme es leider auch nicht hin den espHome Adapter zu installieren.
                      Kann mir wer helfen :( ?
                      NPM version: 8.11.0
                      Installing iobroker.esphome@0.2.4... (System call)
                      host.Pi4ioBroker Cannot install iobroker.esphome@0.2.4: 1
                      ERROR: Process exited with code 25
                      • S Sushibomba
                        NPM version: 8.11.0
                        #104
                        @sushibomba
                        Installier den Adapter mit --debug-Option.
                        Dann sieht man wo es da klemmen könnte.
                          @sushibomba
                          Sushibomba
                          #105
                          Könntest du mir schreiben welche Befehle ich dafür verwenden muss in Putty :-/
                          • S Sushibomba
                            HomoranH Offline
                            HomoranH Offline
                            #106
                            @sushibomba Tanzen wir jetzt auf zwei Hochzeiten?
                              Sushibomba
                              #107
                              Nein war nicht meine Absicht. Hatte nur in beiden geschrieben weil ich nicht wusste wo die Leute häufiger rein schauen :(
                              • S Sushibomba
                                HomoranH Offline
                                HomoranH Offline
                                #108
                                @sushibomba sagte in Probleme mit Installation von ESP Home@0.2.4:
                                also doch eine Absicht dahinter
                                  Sushibomba
                                  schrieb am zuletzt editiert von Sushibomba
                                  #109
                                  Ja wenn man es so nimmt schon. Aber keine böse :D
