  4. Nach Update starten Adapter nicht mehr
    5.8k
120 Beiträge 9 Kommentatoren 10.6k Aufrufe 6 Beobachtet
    @tobiasp sagte in Nach Update starten Adapter nicht mehr:
    gulp-replace
    Such mal nach dem Ding.
    cd /opt/iobroker
    npm ls gulp-replace
    tobiasp
    #72
    ok scheint weg zu sein abbbber jetzt habe ich gleich wieder etliche andere nachdem ich Canvas neu installieren musste.
    |   +-- new-github-release-url@1.0.0
    npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
    npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: @alcalzone/release-script@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
    npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
    npm ERR! extraneous: @alcalzone/release-script-plugin-license@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
    npm ERR! extraneous: gulp-replace /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
    npm ERR! error in /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace/package.json'
    npm ERR! extraneous: bindings@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bindings
    npm ERR! extraneous: chai@4.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
    npm ERR! extraneous: del@6.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/del
    npm ERR! extraneous: eslint@7.32.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
    npm ERR! extraneous: gulp@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
    npm ERR! extraneous: gulp-rename@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
    npm ERR! extraneous: mocha@9.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
    npm ERR! extraneous: nan@2.16.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nan
    npm ERR! extraneous: timekeeper@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
    pi@raspberrypi:/opt/iobroker $
    • T tobiasp
      #73
      scheint weg zu sein
      sicher?
        scheint weg zu sein
        sicher?
        tobiasp
        #74
        ne hast recht auch gerade gesehen der scheis
        • T tobiasp
          tobiasp
          #75
          @tobiasp
          So hab wieder auf den JS 14 zurückgesielt. Sobald ich das Update durchführe funktionieren die Updates nicht mehr oder der Javascript bleibt "rot"
          • T tobiasp
            @tobiasp
            GlasfaserG Offline
            GlasfaserG Offline
            #76
            @tobiasp
            Vorschlag ... dein Pi neu aufsetzen mit NodeJS 16 und dann ein Backup einspielen.
            Wenn man vom Thread Start bis hier unten liest ,ist dein ioBroker verkorkst.
            • T tobiasp
              @thomas-braun said in Nach Update starten Adapter nicht mehr:
              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.16.0
              v16.16.0
              8.11.0
              pi
              /home/pi
              OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              OK:2 http://archive.raspberrypi.org/debian buster InRelease
              OK:3 https://deb.nodesource.com/node_16.x buster InRelease
              OK:4 https://www.pivccu.de/piVCCU stable InRelease
              Alle Pakete sind aktuell.
              nodejs:
                Installiert:           16.16.0-deb-1nodesource1
                Installationskandidat: 16.16.0-deb-1nodesource1
                Versionstabelle:
               *** 16.16.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                   10.24.0~dfsg-1~deb10u1 500
              pi@raspberrypi:~ $
              GlasfaserG Offline
              GlasfaserG Offline
              #77
              Wie kommst du dazu !?
                tobiasp
                #78
                @glasfaser
                @ wie meinst du Backup einspielen ?
                Welches Backup? kann man ein Backup von alles Adaptern usw machen und als Backup laden?
                • T tobiasp
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #79
                  @tobiasp
                  Ja über den Backitup Adatper ... hast du den nicht , . bzw. nutzt du den nicht !?
                  https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md
                  Das ist das A und O
                    tobiasp
                    #80
                    @glasfaser
                    Hatte ich nicht eingerichtet, da ich immer die SD KArte Clone.
                    Jetzt ist halt das Problem das mein letzter Clone zu alt ist. Hmm blöd gelaufe.
                    Heisst wenn ich ein Backup machen damit könnte ich vom jetzigen das auf die neue "jungfreuliche" packen.
                    • T tobiasp
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #81
                      kann man machen ... aber damit werden vorhandenen Fehler immer weiter mitgenommen usw.
                      Kurz und knappp ,ja .
                      Wenn du danach noch Probleme hast , kannst dich ja hier im Thread melden ... wir helfen dir dann gerne weiter .
                      • GlasfaserG Glasfaser
                        tobiasp
                        #82
                        @glasfaser
                        Ok das wäre ja super ich habe etliche Backups unter der Zeit mal gemacht in iobroker. Dann setzt ich mal von Grund auf einen auf. mit Node 16 gleich ab anfang an.
                        danke erstmal
                        GlasfaserG DJMarc75D crunchipC 3 Antworten Letzte Antwort
                          tobiasp
                          #83
                          @glasfaser said in Nach Update starten Adapter nicht mehr:
                          Wie meinst du wie ich dazu komme?
                          • T tobiasp
                            @glasfaser
                            danke erstmal
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #84
                            Zeige mal bitte :
                            iobroker update -i
                            Edit :
                            und
                            iobroker list instances
                            weil du teilweise von Git etwas installiert hast
                            • T tobiasp
                              @glasfaser
                              danke erstmal
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #85
                              leider wohl nicht laut
                              Neu machen bewirkt Wunder und schont die Nerven !
                              Lehrling seit 1975 !!!
                              • T tobiasp
                                @glasfaser
                                danke erstmal
                                crunchipC Offline
                                crunchipC Offline
                                #86
                                Node 16 kommt automatisch mit dem iobroker Install
                                  tobiasp
                                  #87
                                  @crunchip said in Nach Update starten Adapter nicht mehr:
                                  Ich habe ja das UrsprungsImage nur Iobroker da ist schon ein altes Node mit drauf
                                    Zeige mal bitte :
                                    iobroker update -i
                                    Edit :
                                    und
                                    tobiasp
                                    #88
                                    @glasfaser
                                    Hab leider schon neu angefangen weil es mich sehr genert hat.
                                    Zum Backup muss ich alle Adapter erst installieren oder macht Das Backup das gleich mit ?
                                    • T tobiasp
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #89
                                      Jipp ... und bitte WARTEN bist alles läuft ... sieht man auch im Log
                                        tobiasp
                                        #90
                                        @glasfaser
                                        Guten morgen. hergestellt hat er alles wieder. Nach dem Neustart fehlt ihm der JS-Controller leider. Jetzt versuche ich den zu installieren aber er will jetzt etlich DAteinen bzw. Ordner umbeannt. Wahnsinn
                                        DJMarc75D Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                                        • T tobiasp
                                          @glasfaser
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #91
                                          @tobiasp sicher dass Du nicht ein marodes Backup eingespielt hast ??
