  4. Nach Update starten Adapter nicht mehr
    5.8k
120 Beiträge 9 Kommentatoren 10.6k Aufrufe 6 Beobachtet
  • T tobiasp
    pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
    | +-- github-url-from-git@1.5.0
    | +-- new-github-release-url@1.0.0
    npm ERR! extraneous: gulp-replace /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
    npm ERR! error in /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace/package.json'
    pi@raspberrypi:/opt/iobroker $ npm uninstall gulp-replace
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace/package.json'
    removed 9 packages in 26.348s
    119 packages are looking for funding
    run npm fund for details
    #70
    @tobiasp sagte in Nach Update starten Adapter nicht mehr:
    Bitte in CodeTags posten.
    cd /opt/iobroker/node_modules/iobroker.javascript/node_modules
    Ansonsten schau in die
    rein.
      tobiasp
      #71
      sorrry mein Fehler.
        gulp-replace
        Such mal nach dem Ding.
        cd /opt/iobroker
        npm ls gulp-replace
        tobiasp
        #72
        ok scheint weg zu sein abbbber jetzt habe ich gleich wieder etliche andere nachdem ich Canvas neu installieren musste.
        npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
        npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: @alcalzone/release-script@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
        npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
        npm ERR! extraneous: @alcalzone/release-script-plugin-license@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
        npm ERR! extraneous: bindings@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bindings
        npm ERR! extraneous: chai@4.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
        npm ERR! extraneous: del@6.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/del
        npm ERR! extraneous: eslint@7.32.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
        npm ERR! extraneous: gulp@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
        npm ERR! extraneous: gulp-rename@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
        npm ERR! extraneous: mocha@9.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
        npm ERR! extraneous: nan@2.16.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nan
        npm ERR! extraneous: timekeeper@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
        • T tobiasp
          #73
          scheint weg zu sein
          sicher?
            scheint weg zu sein
            sicher?
            tobiasp
            #74
            ne hast recht auch gerade gesehen der scheis
            • T tobiasp
              tobiasp
              #75
              @tobiasp
              So hab wieder auf den JS 14 zurückgesielt. Sobald ich das Update durchführe funktionieren die Updates nicht mehr oder der Javascript bleibt "rot"
              • T tobiasp
                @tobiasp
                GlasfaserG Offline
                GlasfaserG Offline
                #76
                @tobiasp
                Vorschlag ... dein Pi neu aufsetzen mit NodeJS 16 und dann ein Backup einspielen.
                Wenn man vom Thread Start bis hier unten liest ,ist dein ioBroker verkorkst.
                • T tobiasp
                  @thomas-braun said in Nach Update starten Adapter nicht mehr:
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.16.0
                  v16.16.0
                  8.11.0
                  pi
                  /home/pi
                  OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:2 http://archive.raspberrypi.org/debian buster InRelease
                  OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                  OK:4 https://www.pivccu.de/piVCCU stable InRelease
                  Alle Pakete sind aktuell.
                  nodejs:
                    Installiert:           16.16.0-deb-1nodesource1
                    Installationskandidat: 16.16.0-deb-1nodesource1
                    Versionstabelle:
                   *** 16.16.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                       10.24.0~dfsg-1~deb10u1 500
                  pi@raspberrypi:~ $
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #77
                  Wie kommst du dazu !?
                    tobiasp
                    #78
                    @glasfaser
                    @ wie meinst du Backup einspielen ?
                    Welches Backup? kann man ein Backup von alles Adaptern usw machen und als Backup laden?
                    • T tobiasp
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #79
                      @tobiasp
                      Ja über den Backitup Adatper ... hast du den nicht , . bzw. nutzt du den nicht !?
                      https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md
                      Das ist das A und O
                        tobiasp
                        #80
                        @glasfaser
                        Hatte ich nicht eingerichtet, da ich immer die SD KArte Clone.
                        Jetzt ist halt das Problem das mein letzter Clone zu alt ist. Hmm blöd gelaufe.
                        Heisst wenn ich ein Backup machen damit könnte ich vom jetzigen das auf die neue "jungfreuliche" packen.
                        • T tobiasp
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #81
                          kann man machen ... aber damit werden vorhandenen Fehler immer weiter mitgenommen usw.
                          Kurz und knappp ,ja .
                          Wenn du danach noch Probleme hast , kannst dich ja hier im Thread melden ... wir helfen dir dann gerne weiter .
                          • GlasfaserG Glasfaser
                            tobiasp
                            #82
                            @glasfaser
                            Ok das wäre ja super ich habe etliche Backups unter der Zeit mal gemacht in iobroker. Dann setzt ich mal von Grund auf einen auf. mit Node 16 gleich ab anfang an.
                            danke erstmal
                            GlasfaserG DJMarc75D crunchipC 3 Antworten Letzte Antwort
                              tobiasp
                              #83
                              @glasfaser said in Nach Update starten Adapter nicht mehr:
                              Wie meinst du wie ich dazu komme?
                              • T tobiasp
                                @glasfaser
                                danke erstmal
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #84
                                Zeige mal bitte :
                                iobroker update -i
                                Edit :
                                und
                                iobroker list instances
                                weil du teilweise von Git etwas installiert hast
                                • T tobiasp
                                  @glasfaser
                                  danke erstmal
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  #85
                                  leider wohl nicht laut
                                  Neu machen bewirkt Wunder und schont die Nerven !
                                  Lehrling seit 1975 !!!
                                  • T tobiasp
                                    @glasfaser
                                    danke erstmal
                                    crunchipC Offline
                                    crunchipC Offline
                                    #86
                                    Node 16 kommt automatisch mit dem iobroker Install
                                      tobiasp
                                      #87
                                      @crunchip said in Nach Update starten Adapter nicht mehr:
                                      Ich habe ja das UrsprungsImage nur Iobroker da ist schon ein altes Node mit drauf
                                        Zeige mal bitte :
                                        iobroker update -i
                                        Edit :
                                        und
                                        tobiasp
                                        #88
                                        @glasfaser
                                        Hab leider schon neu angefangen weil es mich sehr genert hat.
                                        Zum Backup muss ich alle Adapter erst installieren oder macht Das Backup das gleich mit ?
                                        • T tobiasp
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #89
                                          Jipp ... und bitte WARTEN bist alles läuft ... sieht man auch im Log
