  4. IoBroker läuft nicht mehr
    5.8k
56 Beiträge 4 Kommentatoren 6.6k Aufrufe 4 Beobachtet
    @yoshi
    Oder hau es auf die Ausgabe:
    cat /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
    Y Offline
    Y Offline
    Yoshi
    Ja das hat geklappt. Aber das Log ist Mega groß. Ich versuche mal das ein oder andere rauszukopieren. Den ich verstehe nur Bahnhof :-)
    pi@raspberrypi4-iob:~ $ cat /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   '--save-exact',
    1 verbose cli   'iobroker.vis@1.4.14'
    1 verbose cli ]
    2 info using npm@6.14.17
    3 info using node@v14.20.0
    4 verbose npm-session d9b13fc63301aec3
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.vis 373ms (from cache)
    8 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.14.tgz 744ms
    9 silly pacote version manifest for iobroker.vis@1.4.14 fetched in 1167ms
    10 timing stage:loadCurrentTree Completed in 9183ms
    11 silly install loadIdealTree
    12 silly install cloneCurrentTreeToIdealTree
    13 timing stage:loadIdealTree:cloneCurrentTree Completed in 58ms
    14 silly install loadShrinkwrap
    15 timing stage:loadIdealTree:loadShrinkwrap Completed in 4956ms
    16 silly install loadAllDepsIntoIdealTree
    17 silly resolveWithNewModule iobroker.vis@1.4.14 checking installable status
    18 silly removeObsoleteDep removing iobroker.vis@1.4.15 from the tree as its been replaced by a newer version or is no longer required
    19 silly removeObsoleteDep removing @iobroker/adapter-core@2.6.0 from the tree as its been replaced by a newer version or is no longer required
    20 silly removeObsoleteDep removing @types/iobroker@4.0.2 from the tree as its been replaced by a newer version or is no longer required
    21 silly removeObsoleteDep removing axios@0.26.1 from the tree as its been replaced by a newer version or is no longer required
    22 silly removeObsoleteDep removing follow-redirects@1.14.9 from the tree as its been replaced by a newer version or is no longer required
    23 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 65ms (from cache)
    24 silly pacote range manifest for @iobroker/adapter-core@^2.6.0 fetched in 78ms
    25 silly resolveWithNewModule @iobroker/adapter-core@2.6.0 checking installable status
    26 http fetch GET 304 https://registry.npmjs.org/axios 146ms (from cache)
    27 silly pacote range manifest for axios@^0.26.1 fetched in 161ms
    28 silly resolveWithNewModule axios@0.26.1 checking installable status
    29 http fetch GET 200 https://registry.npmjs.org/@types%2fiobroker 9ms (from cache)
    30 silly pacote range manifest for @types/iobroker@^4.0.1 fetched in 14ms
    31 silly resolveWithNewModule @types/iobroker@4.0.4 checking installable status
    32 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 8723ms
    33 timing stage:loadIdealTree Completed in 16007ms
    34 silly currentTree iobroker.inst@2.0.3
    34 silly currentTree ├─┬ @abandonware/bluetooth-hci-socket@0.5.3-8
    34 silly currentTree │ ├── debug@4.3.4
    34 silly currentTree │ └── ms@2.1.2
    34 silly currentTree ├─┬ @abandonware/noble@1.9.2-15
    35 silly idealTree ├── yeast@0.1.2
    35 silly idealTree └── zrender@4.3.2
    36 silly install generateActionsToTake
    37 timing stage:generateActionsToTake Completed in 457ms
    38 silly diffTrees action count 4
    39 silly diffTrees add @types/iobroker@4.0.4
    40 silly diffTrees add @iobroker/adapter-core@2.6.0
    41 silly diffTrees add axios@0.26.1
    42 silly diffTrees add iobroker.vis@1.4.14
    43 silly decomposeActions action count 32
    44 silly decomposeActions fetch @types/iobroker@4.0.4
    45 silly decomposeActions extract @types/iobroker@4.0.4
    46 silly decomposeActions preinstall @types/iobroker@4.0.4
    47 silly decomposeActions build @types/iobroker@4.0.4
    48 silly decomposeActions install @types/iobroker@4.0.4
    49 silly decomposeActions postinstall @types/iobroker@4.0.4
    50 silly decomposeActions finalize @types/iobroker@4.0.4
    51 silly decomposeActions refresh-package-json @types/iobroker@4.0.4
    52 silly decomposeActions fetch @iobroker/adapter-core@2.6.0
    53 silly decomposeActions extract @iobroker/adapter-core@2.6.0
    54 silly decomposeActions preinstall @iobroker/adapter-core@2.6.0
    55 silly decomposeActions build @iobroker/adapter-core@2.6.0
    56 silly decomposeActions install @iobroker/adapter-core@2.6.0
    57 silly decomposeActions postinstall @iobroker/adapter-core@2.6.0
    58 silly decomposeActions finalize @iobroker/adapter-core@2.6.0
    59 silly decomposeActions refresh-package-json @iobroker/adapter-core@2.6.0
    60 silly decomposeActions fetch axios@0.26.1
    61 silly decomposeActions extract axios@0.26.1
    62 silly decomposeActions preinstall axios@0.26.1
    63 silly decomposeActions build axios@0.26.1
    64 silly decomposeActions install axios@0.26.1
    65 silly decomposeActions postinstall axios@0.26.1
    66 silly decomposeActions finalize axios@0.26.1
    67 silly decomposeActions refresh-package-json axios@0.26.1
    68 silly decomposeActions fetch iobroker.vis@1.4.14
    69 silly decomposeActions extract iobroker.vis@1.4.14
    70 silly decomposeActions preinstall iobroker.vis@1.4.14
    71 silly decomposeActions build iobroker.vis@1.4.14
    72 silly decomposeActions install iobroker.vis@1.4.14
    73 silly decomposeActions postinstall iobroker.vis@1.4.14
    74 silly decomposeActions finalize iobroker.vis@1.4.14
    75 silly decomposeActions refresh-package-json iobroker.vis@1.4.14
    76 silly install executeActions
    77 silly doSerial global-install 32
    78 verbose correctMkdir /home/iobroker/.npm/_locks correctMkdir not in flight; initializing
    79 verbose lock using /home/iobroker/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging
    80 silly doParallel extract 4
    81 silly extract @types/iobroker@4.0.4
    82 silly extract @iobroker/adapter-core@2.6.0
    83 silly extract axios@0.26.1
    84 silly extract iobroker.vis@1.4.14
    85 silly tarball trying axios@^0.26.1 by hash: sha512-fPwcX4EvnSHuInCMItEhAGnaSEXRBjtzh9fOtsE6E1G6p7vl7edEeZe11QHf18+6+9gR5PbKV/sGKNaD8YaMeA==
    86 silly tarball trying iobroker.vis@1.4.14 by hash: sha512-KY+HIWjbwd24O7N8ViPD9WxJ9E/+ntPV7xZi93Z9mf85NKaLP6ZkGwW7AJCvnUZTkoAcCCBe5FhNrsxutEQoSw==
    87 silly tarball trying @types/iobroker@^4.0.1 by hash: sha512-hioI0Cf73pd0i5QGdJptj4AS+6zpWjBSZ4Vz80VyU/oLO7qgU/UiyO79o/ajAWbNREEVlhCJg8sHCoEAe0Bbaw==
    88 silly tarball trying @iobroker/adapter-core@^2.6.0 by hash: sha512-J5Cgy0NK8GWjN1th3yvWCG3tnK8iJJcPaHIoVR8PfpEsz4hffuVGi660vNXqXdiqR5Br09XSJ5h1Pn9af0/taw==
    89 silly extract @types/iobroker@^4.0.1 extracted to /opt/iobroker/node_modules/.staging/@types/iobroker-e6a8269f (179ms)
    90 silly extract @iobroker/adapter-core@^2.6.0 extracted to /opt/iobroker/node_modules/.staging/@iobroker/adapter-core-29bacaba (201ms)
    91 silly extract axios@^0.26.1 extracted to /opt/iobroker/node_modules/.staging/axios-e9689e9f (365ms)
    92 silly extract iobroker.vis@1.4.14 extracted to /opt/iobroker/node_modules/.staging/iobroker.vis-c6a771c0 (947ms)
    93 timing action:extract Completed in 956ms
    94 silly doReverseSerial unbuild 32
    95 silly doSerial remove 32
    96 silly doSerial move 32
    97 silly doSerial finalize 32
    98 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/@types/iobroker
    99 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/@iobroker/adapter-core
    100 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/axios
    101 silly finalize /opt/iobroker/node_modules/iobroker.vis
    102 timing action:finalize Completed in 23ms
    103 silly doParallel refresh-package-json 4
    104 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/@types/iobroker
    105 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/@iobroker/adapter-core
    106 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/axios
    107 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis
    108 timing action:refresh-package-json Completed in 38ms
    109 silly doParallel preinstall 4
    110 silly preinstall @types/iobroker@4.0.4
    111 info lifecycle @types/iobroker@4.0.4~preinstall: @types/iobroker@4.0.4
    112 silly preinstall @iobroker/adapter-core@2.6.0
    113 info lifecycle @iobroker/adapter-core@2.6.0~preinstall: @iobroker/adapter-core@2.6.0
    114 silly preinstall axios@0.26.1
    115 info lifecycle axios@0.26.1~preinstall: axios@0.26.1
    116 silly preinstall iobroker.vis@1.4.14
    117 info lifecycle iobroker.vis@1.4.14~preinstall: iobroker.vis@1.4.14
    118 timing action:preinstall Completed in 3ms
    119 silly doSerial build 32
    120 silly build @types/iobroker@4.0.4
    121 info linkStuff @types/iobroker@4.0.4
    122 silly linkStuff @types/iobroker@4.0.4 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
    123 silly build @iobroker/adapter-core@2.6.0
    124 info linkStuff @iobroker/adapter-core@2.6.0
    125 silly linkStuff @iobroker/adapter-core@2.6.0 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
    126 silly build axios@0.26.1
    127 info linkStuff axios@0.26.1
    128 silly linkStuff axios@0.26.1 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
    129 silly build iobroker.vis@1.4.14
    130 info linkStuff iobroker.vis@1.4.14
    131 silly linkStuff iobroker.vis@1.4.14 has /opt/iobroker/node_modules as its parent node_modules
    132 timing action:build Completed in 15ms
    133 silly doSerial global-link 32
    134 silly doParallel update-linked 0
    135 silly doSerial install 32
    136 silly install @types/iobroker@4.0.4
    137 info lifecycle @types/iobroker@4.0.4~install: @types/iobroker@4.0.4
    138 silly install @iobroker/adapter-core@2.6.0
    139 info lifecycle @iobroker/adapter-core@2.6.0~install: @iobroker/adapter-core@2.6.0
    140 silly install axios@0.26.1
    141 info lifecycle axios@0.26.1~install: axios@0.26.1
    142 silly install iobroker.vis@1.4.14
    143 info lifecycle iobroker.vis@1.4.14~install: iobroker.vis@1.4.14
    144 verbose lifecycle iobroker.vis@1.4.14~install: unsafe-perm in lifecycle true
    145 verbose lifecycle iobroker.vis@1.4.14~install: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/iobroker/node_modules/iobroker.vis/node_modules/.bin:/opt/iobroker/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
    146 verbose lifecycle iobroker.vis@1.4.14~install: CWD: /opt/iobroker/node_modules/iobroker.vis
    147 silly lifecycle iobroker.vis@1.4.14~install: Args: [ '-c', 'node main.js --install' ]
    148 silly lifecycle iobroker.vis@1.4.14~install: Returned: code: 6  signal: null
    149 info lifecycle iobroker.vis@1.4.14~install: Failed to exec install script
    150 timing action:install Completed in 3586ms
    151 verbose unlock done using /home/iobroker/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging
    152 timing stage:rollbackFailedOptional Completed in 266ms
    153 timing stage:runTopLevelLifecycles Completed in 30652ms
    154 silly saveTree iobroker.inst@2.0.3
    154 silly saveTree ├── colors@1.4.0
    154 silly saveTree ├─┬ fs-extra@7.0.1
    154 silly saveTree │ ├── graceful-fs@4.2.3
    154 silly saveTree │ ├── jsonfile@4.0.0
    154 silly saveTree │ └── universalify@0.1.2
    154 silly saveTree ├─┬ iobroker.admin@6.2.4
    154 silly saveTree ├── semver@5.7.1
    154 silly saveTree └── yargs@7.1.0
    155 verbose stack Error: iobroker.vis@1.4.14 install: `node main.js --install`
    155 verbose stack Exit status 6
    155 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
    155 verbose stack     at EventEmitter.emit (events.js:400:28)
    155 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
    155 verbose stack     at ChildProcess.emit (events.js:400:28)
    155 verbose stack     at maybeClose (internal/child_process.js:1088:16)
    155 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:296:5)
    156 verbose pkgid iobroker.vis@1.4.14
    157 verbose cwd /opt/iobroker
    158 verbose Linux 5.15.32-v7l+
    159 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--save-exact" "iobroker.vis@1.4.14"
    160 verbose node v14.20.0
    161 verbose npm  v6.14.17
    162 error code ELIFECYCLE
    163 error errno 6
    164 error iobroker.vis@1.4.14 install: `node main.js --install`
    164 error Exit status 6
    165 error Failed at the iobroker.vis@1.4.14 install script.
    165 error This is probably not a problem with npm. There is likely additional logging output above.
    166 verbose exit [ 6, true ]
    pi@raspberrypi4-iob:~ $ Last login: Sun Jul 24 16:56:55 on ttys001
    jacekbezler@MacBook-Air-von-Jacek ~ % ssh pi@192.168.0.64
    pi@192.168.0.64's password:
    Linux raspberrypi4-iob 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
    permitted by applicable law.
    Last login: Sun Jul 24 16:58:48 2022 from 192.168.0.120
    1 verbose cli [
    1 verbose cli ]
    166 verbose exit [ 6, true ]ot a problem with npm. There is likely additional lo
    • Y Offline
      Y Offline
      Yoshi
      Warum auch immer, die Instanzen kann ich wieder sehen.
      Nun läuft auch der Adapter HASS nicht und wenn ich ihn nachinstalieren möchte, bekomme ich das gleiche wie bei VIS
      • Y Yoshi
        @yoshi
        Geh mal auf nodejs16 hoch.
        Anleitung in meiner Signatur.
        Y 1 Antwort Letzte Antwort
          @yoshi
          Y Offline
          Y Offline
          Yoshi
          ok...kann ich bei der Ausgabe fortfahren ?
          pi@raspberrypi4-iob:~ $ cd /opt/iobroker
          npm ls | grep -E 'github|ERR'
          │ │ │ ├── github-from-package@0.0.0
          • Y Yoshi
            @yoshi
            Ja, das ist kein Fehler.
              @yoshi
              Y Offline
              Y Offline
              Yoshi
              soweit erledigt.
              pi@raspberrypi4-iob:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.16.0
              v16.16.0
              8.11.0
              pi
              /home/pi
              OK:1 http://phoscon.de/apt/deconz bullseye InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
              OK:4 https://repos.influxdata.com/debian stretch InRelease
              OK:5 https://download.docker.com/linux/debian bullseye InRelease
              OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
              OK:7 https://packages.grafana.com/oss/deb stable InRelease
              OK:8 https://deb.nodesource.com/node_16.x bullseye InRelease
              Alle Pakete sind aktuell.
              nodejs:
                Installiert:           16.16.0-deb-1nodesource1
                Installationskandidat: 16.16.0-deb-1nodesource1
                Versionstabelle:
               *** 16.16.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                   14.20.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                   12.22.12~dfsg-1~deb11u1 500
              pi@raspberrypi4-iob:~ $ iobroker start
              • Y Yoshi
                soweit erledigt.
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.16.0
                v16.16.0
                8.11.0
                pi
                /home/pi
                nodejs:
                  Versionstabelle:
                @yoshi sagte in IoBroker läuft nicht mehr:
                Das muss auf bullseye lauten. Stell es um:
                sudo sed -i 's/stretch/bullseye/g' /etc/apt/sources.list.d/*
                  Y Offline
                  Y Offline
                  Yoshi
                  Ok erledigt.
                  HASS läuft auch wieder.
                  Aber VIS will einfach nicht
                  $ iobroker upgrade vis@1.4.8 --debug
                  Update vis from @1.4.15 to @1.4.8
                  Installing iobroker.vis@1.4.8... (System call)
                  npm ERR! path /opt/iobroker/node_modules/iobroker.vis
                  host.raspberrypi4-iob Cannot install iobroker.vis@1.4.8: 6
                  ERROR: Process exited with code 25
                  • Y Yoshi
                    Ok erledigt.
                    @yoshi
                    Dann deinstallier vis mal komplett.
                      @yoshi
                      Y Offline
                      Y Offline
                      Yoshi
                      gibts dafür nen Befehl oder einfach Instanz in den Papierkorb ?
                      • Y Yoshi
                        ja und instanz löschen wäre nicht Adapter komplett deinstallieren
                        iobroker del vis
                          iobroker del vis
                          Y Offline
                          Y Offline
                          Yoshi
                          Ja das stimmt, hab auch Adapter gemeint...hab dann den Adapter den Papierkorb benutzt und folgendes kam als Rückmeldung.
                          $ iobroker del vis --debug
                          host.raspberrypi4-iob Counted 1 instances of vis
                          Cannot remove adapter "vis", because instance "vis-fancyswitch.0" depends on it!
                          ERROR: Process exited with code 47
                          • Y Yoshi
                            @yoshi
                            Ich hab kein vis hier laufen, keine Ahnung ob es eine gute Idee ist die ganzen dep auch runterzuwerfen.
                              @yoshi
                              @thomas-braun vielleicht reicht es den npm cache löschen?
                              • Y Offline
                                Y Offline
                                Yoshi
                                Hab nun alle Instanzen von VIS gelöscht und dann konnte ich auch den Adapter Löschen und wieder installieren. Aber natürlich ist mein view weg. Naja egal. Hauptsache alle andere läuft wieder.
                                Besten Dank Thomas
                                • Y Yoshi
                                  Besten Dank Thomas
                                  Backup?
                                    Backup?
                                    Y Offline
                                    Y Offline
                                    Yoshi
                                    Damit bin ich noch nicht so vertraut...hab ein io broker Backup von heute Nacht.
                                    iobroker_2022_07_24-02_40_11_backupiobroker.tar
                                    Würde das reichen ?
                                    • Y Yoshi
                                      Würde das reichen ?
                                      Würde das reichen ?
                                      mach das mal mit einem entpacker (z.B. 7z) auf.
                                      du solltest darin eine vis-views.json finden.
                                      das sind alle deine views
                                        Würde das reichen ?
                                        Y Offline
                                        Y Offline
                                        Yoshi
                                        Ok, schaue ich mir bei Gelegenheit an.
                                        Nochmals herzlichen Dank
                                        • Y Offline
                                          Y Offline
                                          Yoshi
                                          schrieb am zuletzt editiert von Yoshi
                                          Nur noch eine Frage. Dadurch, dass ich so viel zerschossen habe, hat der Deconz Adapter auch alle Teilnehmer verloren.
                                          Kann man da was machen oder alle neu einlesen ?
                                          Es hört nicht auf :-(
                                          Wollte ESPHome installieren und es geht leider nicht. Bevor ich wieder alles zerschiesse frage ich lieber was ich machen kann.
                                          2022-07-24 23:16:04.499	info	iobroker exit 25
                                          2022-07-24 23:16:03.459	error	iobroker host.raspberrypi4-iob Cannot install iobroker.esphome@0.2.4: 126
                                          2022-07-24 23:16:03.420	info	iobroker npm ERR! /home/iobroker/.npm/_logs/2022-07-24T21_15_44_444Z-debug-0.log
                                          2022-07-24 23:16:03.416	info	iobroker npm ERR! A complete log of this run can be found in:
                                          2022-07-24 23:16:03.414	info	iobroker
                                          2022-07-24 23:16:03.408	info	iobroker npm ERR! sh: 1: npip: Permission denied
                                          2022-07-24 23:16:03.407	info	iobroker npm ERR! command sh -c npip install
                                          2022-07-24 23:16:03.401	info	iobroker npm ERR! command failed
                                          2022-07-24 23:16:03.390	info	iobroker npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
                                          2022-07-24 23:16:03.389	info	iobroker npm ERR! code 126
                                          2022-07-24 23:15:43.097	info	iobroker Installing iobroker.esphome@0.2.4... (System call)
