  4. IoBroker läuft nicht mehr
    5.8k
56 Beiträge 4 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • Y Yoshi
    @thomas-braun said in IoBroker läuft nicht mehr:
    iobroker logs --watch
    Nachdem ich den Pi nochmal neugestartet habe, komme ich wieder drauf. Vielen Dank schon mal.
    Aber VIS will irgendwie nicht. Das kommt als Fehlermeldung im Protokoll
    vis.0
    2022-07-24 17:05:11.082	error	Not exists
    vis.0
    2022-07-24 17:05:11.081	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:466:21)
    vis.0
    2022-07-24 17:05:11.079	error	unhandled promise rejection: Not exists
    vis.0
    2022-07-24 17:05:11.078	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Das spuckt er aus wenn ich VIS nachinstalieren möchte
    $ iobroker upgrade vis@1.4.15 --debug
    Update vis from @1.4.15 to @1.4.15
    NPM version: 6.14.17Installing iobroker.vis@1.4.15... (System call)
    > iobroker.vis@1.4.15 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
    npm ERR! code ELIFECYCLE
    npm ERR! errno 6
    npm ERR! iobroker.vis@1.4.15 install: `node main.js --install`
    npm ERR! Exit status 6npm ERR! npm ERR! Failed at the iobroker.vis@1.4.15 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-24T15_05_17_209Z-debug.log
    host.raspberrypi4-iob Cannot install iobroker.vis@1.4.15: 6
    ERROR: Process exited with code 25
    @yoshi
    cd /opt/iobroker
    npm ls | grep -E 'github|ERR'
    • Y Offline
      Y Offline
      Yoshi
      pi@raspberrypi4-iob:~ $ cd /opt/iobroker
      │ │ │ ├── github-from-package@0.0.0
      npm ERR! missing: iobroker.vis@1.4.15, required by iobroker.inst@2.0.3
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis@1.4.15
      npm ERR! missing: axios@0.26.1, required by iobroker.vis@1.4.15
      npm ERR! missing: @types/iobroker@4.0.2, required by @iobroker/adapter-core@2.6.0
      npm ERR! missing: follow-redirects@1.14.9, required by axios@0.26.1
      pi@raspberrypi4-iob:/opt/iobroker $
      • Y Yoshi
        @yoshi
        Installier mal eine Vorversion von vis
        • Y Offline
          Y Offline
          Yoshi
          Mehrere probiert. Immer wieder Fehlermeldungen.
          Zudem habe ich gerade festgestellt, dass der ioBroker die Instanzen nicht lesen kann.
          $ iobroker upgrade vis@1.4.8 --debug
          Update vis from @0.0.0 to @1.4.8
          Installing iobroker.vis@1.4.8... (System call)
          > iobroker.vis@1.4.8 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
          host.raspberrypi4-iob Cannot install iobroker.vis@1.4.8: 6
          weniger
          mehr
          $ iobroker upgrade vis@1.4.14 --debug
          Update vis from @0.0.0 to @1.4.14
          Installing iobroker.vis@1.4.14... (System call)
          > iobroker.vis@1.4.14 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
          npm ERR! errno 6
          npm ERR! Exit status 6npm ERR! npm ERR! Failed at the iobroker.vis@1.4.14 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
          host.raspberrypi4-iob Cannot install iobroker.vis@1.4.14: 6
          • Y Yoshi
            weniger
            mehr
            npm ERR! errno 6
            @yoshi sagte in IoBroker läuft nicht mehr:
            Dann schau in das Log
            less -R /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
            Y 1 Antwort Letzte Antwort
              Y Offline
              Y Offline
              Yoshi
              Wie kann ich das log hier reinkopieren. Irgendwie bin ich zu doof dafür
              • Y Yoshi
                @yoshi
                Ich versteh das Problem nicht.
                Kopieren? Wie oben auch?
                  @yoshi
                  Y Offline
                  Y Offline
                  Yoshi
                  Ich müsste es irgendwo abspeichern. Ich kann in der Console nur irgendwie das Kopieren was ich gerade sehe.
                  • Y Yoshi
                    Mit Bild runter / Leertaste blättert man in less.
                    • Y Yoshi
                      @yoshi
                      Oder hau es auf die Ausgabe:
                      cat /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
                        @yoshi
                        Y Offline
                        Y Offline
                        Yoshi
                        Ja das hat geklappt. Aber das Log ist Mega groß. Ich versuche mal das ein oder andere rauszukopieren. Den ich verstehe nur Bahnhof :-)
                        pi@raspberrypi4-iob:~ $ cat /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
                        0 info it worked if it ends with ok
                        1 verbose cli [
                        1 verbose cli   '/usr/bin/node',
                        1 verbose cli   '/usr/bin/npm',
                        1 verbose cli   'install',
                        1 verbose cli   '--save-exact',
                        1 verbose cli   'iobroker.vis@1.4.14'
                        1 verbose cli ]
                        2 info using npm@6.14.17
                        3 info using node@v14.20.0
                        4 verbose npm-session d9b13fc63301aec3
                        5 silly install loadCurrentTree
                        6 silly install readLocalPackageData
                        7 http fetch GET 304 https://registry.npmjs.org/iobroker.vis 373ms (from cache)
                        8 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.14.tgz 744ms
                        9 silly pacote version manifest for iobroker.vis@1.4.14 fetched in 1167ms
                        10 timing stage:loadCurrentTree Completed in 9183ms
                        11 silly install loadIdealTree
                        12 silly install cloneCurrentTreeToIdealTree
                        13 timing stage:loadIdealTree:cloneCurrentTree Completed in 58ms
                        14 silly install loadShrinkwrap
                        15 timing stage:loadIdealTree:loadShrinkwrap Completed in 4956ms
                        16 silly install loadAllDepsIntoIdealTree
                        17 silly resolveWithNewModule iobroker.vis@1.4.14 checking installable status
                        18 silly removeObsoleteDep removing iobroker.vis@1.4.15 from the tree as its been replaced by a newer version or is no longer required
                        19 silly removeObsoleteDep removing @iobroker/adapter-core@2.6.0 from the tree as its been replaced by a newer version or is no longer required
                        20 silly removeObsoleteDep removing @types/iobroker@4.0.2 from the tree as its been replaced by a newer version or is no longer required
                        21 silly removeObsoleteDep removing axios@0.26.1 from the tree as its been replaced by a newer version or is no longer required
                        22 silly removeObsoleteDep removing follow-redirects@1.14.9 from the tree as its been replaced by a newer version or is no longer required
                        23 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 65ms (from cache)
                        24 silly pacote range manifest for @iobroker/adapter-core@^2.6.0 fetched in 78ms
                        25 silly resolveWithNewModule @iobroker/adapter-core@2.6.0 checking installable status
                        26 http fetch GET 304 https://registry.npmjs.org/axios 146ms (from cache)
                        27 silly pacote range manifest for axios@^0.26.1 fetched in 161ms
                        28 silly resolveWithNewModule axios@0.26.1 checking installable status
                        29 http fetch GET 200 https://registry.npmjs.org/@types%2fiobroker 9ms (from cache)
                        30 silly pacote range manifest for @types/iobroker@^4.0.1 fetched in 14ms
                        31 silly resolveWithNewModule @types/iobroker@4.0.4 checking installable status
                        32 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 8723ms
                        33 timing stage:loadIdealTree Completed in 16007ms
                        34 silly currentTree iobroker.inst@2.0.3
                        34 silly currentTree ├─┬ @abandonware/bluetooth-hci-socket@0.5.3-8
                        34 silly currentTree │ ├── debug@4.3.4
                        34 silly currentTree │ └── ms@2.1.2
                        34 silly currentTree ├─┬ @abandonware/noble@1.9.2-15
                        35 silly idealTree ├── yeast@0.1.2
                        35 silly idealTree └── zrender@4.3.2
                        36 silly install generateActionsToTake
                        37 timing stage:generateActionsToTake Completed in 457ms
                        38 silly diffTrees action count 4
                        39 silly diffTrees add @types/iobroker@4.0.4
                        40 silly diffTrees add @iobroker/adapter-core@2.6.0
                        41 silly diffTrees add axios@0.26.1
                        42 silly diffTrees add iobroker.vis@1.4.14
                        43 silly decomposeActions action count 32
                        44 silly decomposeActions fetch @types/iobroker@4.0.4
                        45 silly decomposeActions extract @types/iobroker@4.0.4
                        46 silly decomposeActions preinstall @types/iobroker@4.0.4
                        47 silly decomposeActions build @types/iobroker@4.0.4
                        48 silly decomposeActions install @types/iobroker@4.0.4
                        49 silly decomposeActions postinstall @types/iobroker@4.0.4
                        50 silly decomposeActions finalize @types/iobroker@4.0.4
                        51 silly decomposeActions refresh-package-json @types/iobroker@4.0.4
                        52 silly decomposeActions fetch @iobroker/adapter-core@2.6.0
                        53 silly decomposeActions extract @iobroker/adapter-core@2.6.0
                        54 silly decomposeActions preinstall @iobroker/adapter-core@2.6.0
                        55 silly decomposeActions build @iobroker/adapter-core@2.6.0
                        56 silly decomposeActions install @iobroker/adapter-core@2.6.0
                        57 silly decomposeActions postinstall @iobroker/adapter-core@2.6.0
                        58 silly decomposeActions finalize @iobroker/adapter-core@2.6.0
                        59 silly decomposeActions refresh-package-json @iobroker/adapter-core@2.6.0
                        60 silly decomposeActions fetch axios@0.26.1
                        61 silly decomposeActions extract axios@0.26.1
                        62 silly decomposeActions preinstall axios@0.26.1
                        63 silly decomposeActions build axios@0.26.1
                        64 silly decomposeActions install axios@0.26.1
                        65 silly decomposeActions postinstall axios@0.26.1
                        66 silly decomposeActions finalize axios@0.26.1
                        67 silly decomposeActions refresh-package-json axios@0.26.1
                        68 silly decomposeActions fetch iobroker.vis@1.4.14
                        69 silly decomposeActions extract iobroker.vis@1.4.14
                        70 silly decomposeActions preinstall iobroker.vis@1.4.14
                        71 silly decomposeActions build iobroker.vis@1.4.14
                        72 silly decomposeActions install iobroker.vis@1.4.14
                        73 silly decomposeActions postinstall iobroker.vis@1.4.14
                        74 silly decomposeActions finalize iobroker.vis@1.4.14
                        75 silly decomposeActions refresh-package-json iobroker.vis@1.4.14
                        76 silly install executeActions
                        77 silly doSerial global-install 32
                        78 verbose correctMkdir /home/iobroker/.npm/_locks correctMkdir not in flight; initializing
                        79 verbose lock using /home/iobroker/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging
                        80 silly doParallel extract 4
                        81 silly extract @types/iobroker@4.0.4
                        82 silly extract @iobroker/adapter-core@2.6.0
                        83 silly extract axios@0.26.1
                        84 silly extract iobroker.vis@1.4.14
                        85 silly tarball trying axios@^0.26.1 by hash: sha512-fPwcX4EvnSHuInCMItEhAGnaSEXRBjtzh9fOtsE6E1G6p7vl7edEeZe11QHf18+6+9gR5PbKV/sGKNaD8YaMeA==
                        86 silly tarball trying iobroker.vis@1.4.14 by hash: sha512-KY+HIWjbwd24O7N8ViPD9WxJ9E/+ntPV7xZi93Z9mf85NKaLP6ZkGwW7AJCvnUZTkoAcCCBe5FhNrsxutEQoSw==
                        87 silly tarball trying @types/iobroker@^4.0.1 by hash: sha512-hioI0Cf73pd0i5QGdJptj4AS+6zpWjBSZ4Vz80VyU/oLO7qgU/UiyO79o/ajAWbNREEVlhCJg8sHCoEAe0Bbaw==
                        88 silly tarball trying @iobroker/adapter-core@^2.6.0 by hash: sha512-J5Cgy0NK8GWjN1th3yvWCG3tnK8iJJcPaHIoVR8PfpEsz4hffuVGi660vNXqXdiqR5Br09XSJ5h1Pn9af0/taw==
                        89 silly extract @types/iobroker@^4.0.1 extracted to /opt/iobroker/node_modules/.staging/@types/iobroker-e6a8269f (179ms)
                        90 silly extract @iobroker/adapter-core@^2.6.0 extracted to /opt/iobroker/node_modules/.staging/@iobroker/adapter-core-29bacaba (201ms)
                        91 silly extract axios@^0.26.1 extracted to /opt/iobroker/node_modules/.staging/axios-e9689e9f (365ms)
                        92 silly extract iobroker.vis@1.4.14 extracted to /opt/iobroker/node_modules/.staging/iobroker.vis-c6a771c0 (947ms)
                        93 timing action:extract Completed in 956ms
                        94 silly doReverseSerial unbuild 32
                        95 silly doSerial remove 32
                        96 silly doSerial move 32
                        97 silly doSerial finalize 32
                        98 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/@types/iobroker
                        99 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/@iobroker/adapter-core
                        100 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/axios
                        101 silly finalize /opt/iobroker/node_modules/iobroker.vis
                        102 timing action:finalize Completed in 23ms
                        103 silly doParallel refresh-package-json 4
                        104 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/@types/iobroker
                        105 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/@iobroker/adapter-core
                        106 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/axios
                        107 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis
                        108 timing action:refresh-package-json Completed in 38ms
                        109 silly doParallel preinstall 4
                        110 silly preinstall @types/iobroker@4.0.4
                        111 info lifecycle @types/iobroker@4.0.4~preinstall: @types/iobroker@4.0.4
                        112 silly preinstall @iobroker/adapter-core@2.6.0
                        113 info lifecycle @iobroker/adapter-core@2.6.0~preinstall: @iobroker/adapter-core@2.6.0
                        114 silly preinstall axios@0.26.1
                        115 info lifecycle axios@0.26.1~preinstall: axios@0.26.1
                        116 silly preinstall iobroker.vis@1.4.14
                        117 info lifecycle iobroker.vis@1.4.14~preinstall: iobroker.vis@1.4.14
                        118 timing action:preinstall Completed in 3ms
                        119 silly doSerial build 32
                        120 silly build @types/iobroker@4.0.4
                        121 info linkStuff @types/iobroker@4.0.4
                        122 silly linkStuff @types/iobroker@4.0.4 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
                        123 silly build @iobroker/adapter-core@2.6.0
                        124 info linkStuff @iobroker/adapter-core@2.6.0
                        125 silly linkStuff @iobroker/adapter-core@2.6.0 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
                        126 silly build axios@0.26.1
                        127 info linkStuff axios@0.26.1
                        128 silly linkStuff axios@0.26.1 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
                        129 silly build iobroker.vis@1.4.14
                        130 info linkStuff iobroker.vis@1.4.14
                        131 silly linkStuff iobroker.vis@1.4.14 has /opt/iobroker/node_modules as its parent node_modules
                        132 timing action:build Completed in 15ms
                        133 silly doSerial global-link 32
                        134 silly doParallel update-linked 0
                        135 silly doSerial install 32
                        136 silly install @types/iobroker@4.0.4
                        137 info lifecycle @types/iobroker@4.0.4~install: @types/iobroker@4.0.4
                        138 silly install @iobroker/adapter-core@2.6.0
                        139 info lifecycle @iobroker/adapter-core@2.6.0~install: @iobroker/adapter-core@2.6.0
                        140 silly install axios@0.26.1
                        141 info lifecycle axios@0.26.1~install: axios@0.26.1
                        142 silly install iobroker.vis@1.4.14
                        143 info lifecycle iobroker.vis@1.4.14~install: iobroker.vis@1.4.14
                        144 verbose lifecycle iobroker.vis@1.4.14~install: unsafe-perm in lifecycle true
                        145 verbose lifecycle iobroker.vis@1.4.14~install: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/iobroker/node_modules/iobroker.vis/node_modules/.bin:/opt/iobroker/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
                        146 verbose lifecycle iobroker.vis@1.4.14~install: CWD: /opt/iobroker/node_modules/iobroker.vis
                        147 silly lifecycle iobroker.vis@1.4.14~install: Args: [ '-c', 'node main.js --install' ]
                        148 silly lifecycle iobroker.vis@1.4.14~install: Returned: code: 6  signal: null
                        149 info lifecycle iobroker.vis@1.4.14~install: Failed to exec install script
                        150 timing action:install Completed in 3586ms
                        151 verbose unlock done using /home/iobroker/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging
                        152 timing stage:rollbackFailedOptional Completed in 266ms
                        153 timing stage:runTopLevelLifecycles Completed in 30652ms
                        154 silly saveTree iobroker.inst@2.0.3
                        154 silly saveTree ├── colors@1.4.0
                        154 silly saveTree ├─┬ fs-extra@7.0.1
                        154 silly saveTree │ ├── graceful-fs@4.2.3
                        154 silly saveTree │ ├── jsonfile@4.0.0
                        154 silly saveTree │ └── universalify@0.1.2
                        154 silly saveTree ├─┬ iobroker.admin@6.2.4
                        154 silly saveTree ├── semver@5.7.1
                        154 silly saveTree └── yargs@7.1.0
                        155 verbose stack Error: iobroker.vis@1.4.14 install: `node main.js --install`
                        155 verbose stack Exit status 6
                        155 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                        155 verbose stack     at EventEmitter.emit (events.js:400:28)
                        155 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                        155 verbose stack     at ChildProcess.emit (events.js:400:28)
                        155 verbose stack     at maybeClose (internal/child_process.js:1088:16)
                        155 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:296:5)
                        156 verbose pkgid iobroker.vis@1.4.14
                        157 verbose cwd /opt/iobroker
                        158 verbose Linux 5.15.32-v7l+
                        159 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--save-exact" "iobroker.vis@1.4.14"
                        160 verbose node v14.20.0
                        161 verbose npm  v6.14.17
                        162 error code ELIFECYCLE
                        163 error errno 6
                        164 error iobroker.vis@1.4.14 install: `node main.js --install`
                        164 error Exit status 6
                        165 error Failed at the iobroker.vis@1.4.14 install script.
                        165 error This is probably not a problem with npm. There is likely additional logging output above.
                        166 verbose exit [ 6, true ]
                        pi@raspberrypi4-iob:~ $ Last login: Sun Jul 24 16:56:55 on ttys001
                        jacekbezler@MacBook-Air-von-Jacek ~ % ssh pi@192.168.0.64
                        pi@192.168.0.64's password:
                        Linux raspberrypi4-iob 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
                        permitted by applicable law.
                        Last login: Sun Jul 24 16:58:48 2022 from 192.168.0.120
                        1 verbose cli [
                        1 verbose cli ]
                        166 verbose exit [ 6, true ]ot a problem with npm. There is likely additional lo
                        • Y Offline
                          Y Offline
                          Yoshi
                          Warum auch immer, die Instanzen kann ich wieder sehen.
                          Nun läuft auch der Adapter HASS nicht und wenn ich ihn nachinstalieren möchte, bekomme ich das gleiche wie bei VIS
                          • Y Yoshi
                            @yoshi
                            Geh mal auf nodejs16 hoch.
                            Anleitung in meiner Signatur.
                              @yoshi
                              Y Offline
                              Y Offline
                              Yoshi
                              ok...kann ich bei der Ausgabe fortfahren ?
                              • Y Yoshi
                                @yoshi
                                Ja, das ist kein Fehler.
                                  @yoshi
                                  Y Offline
                                  Y Offline
                                  Yoshi
                                  soweit erledigt.
                                  pi@raspberrypi4-iob:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.16.0
                                  v16.16.0
                                  8.11.0
                                  pi
                                  /home/pi
                                  OK:1 http://phoscon.de/apt/deconz bullseye InRelease
                                  OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                  OK:4 https://repos.influxdata.com/debian stretch InRelease
                                  OK:5 https://download.docker.com/linux/debian bullseye InRelease
                                  OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                                  OK:7 https://packages.grafana.com/oss/deb stable InRelease
                                  OK:8 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Alle Pakete sind aktuell.
                                  nodejs:
                                    Installiert:           16.16.0-deb-1nodesource1
                                    Installationskandidat: 16.16.0-deb-1nodesource1
                                    Versionstabelle:
                                   *** 16.16.0-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                       14.20.0-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                       12.22.12~dfsg-1~deb11u1 500
                                  pi@raspberrypi4-iob:~ $ iobroker start
                                  • Y Yoshi
                                    soweit erledigt.
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.16.0
                                    v16.16.0
                                    8.11.0
                                    pi
                                    /home/pi
                                    nodejs:
                                      Versionstabelle:
                                    Das muss auf bullseye lauten. Stell es um:
                                    sudo sed -i 's/stretch/bullseye/g' /etc/apt/sources.list.d/*
                                      Y Offline
                                      Y Offline
                                      Yoshi
                                      Ok erledigt.
                                      HASS läuft auch wieder.
                                      Aber VIS will einfach nicht
                                      Update vis from @1.4.15 to @1.4.8
                                      npm ERR! path /opt/iobroker/node_modules/iobroker.vis
                                      • Y Yoshi
                                        Ok erledigt.
                                        @yoshi
                                        Dann deinstallier vis mal komplett.
                                          @yoshi
                                          Y Offline
                                          Y Offline
                                          Yoshi
                                          gibts dafür nen Befehl oder einfach Instanz in den Papierkorb ?
