  4. IoBroker läuft nicht mehr
    5.8k
56 Beiträge 4 Kommentatoren 6.6k Aufrufe 4 Beobachtet
    @yoshi
    iobroker start admin
    Y Offline
    Y Offline
    Yoshi
    @thomas-braun said in IoBroker läuft nicht mehr:
    gestartet aber per web immer noch nicht erreichbar
    pi@raspberrypi4-iob:~ $ iobroker start admin
    The adapter "admin.0" was started.
    pi@raspberrypi4-iob:~ $ iobroker list instances
      system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iob                         -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
    + system.adapter.ble.0                    : ble                   : raspberrypi4-iob                         -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi4-iob                         -  enabled, port: 80
    + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
      system.adapter.esphome.0                : esphome               : raspberrypi4-iob                         - disabled
      system.adapter.hass.0                   : hass                  : raspberrypi4-iob                         -  enabled, port: 8123
    + system.adapter.hmip.0                   : hmip                  : raspberrypi4-iob                         -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi4-iob                         -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi4-iob                         -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi4-iob                         - disabled
      system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
    + system.adapter.milight.0                : milight               : raspberrypi4-iob                         -  enabled, port: 5987
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iob                         -  enabled, port: 1945, bind: 0.0.0.0
    + system.adapter.sayit.0                  : sayit                 : raspberrypi4-iob                         -  enabled, port: 0
    + system.adapter.shelly.0                 : shelly                : raspberrypi4-iob                         -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi4-iob                         -  enabled
      system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi4-iob                         - disabled
    + system.adapter.telegram.0               : telegram              : raspberrypi4-iob                         -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4-iob                         -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4-iob                         -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4-iob                         -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : raspberrypi4-iob                         -  enabled
    + instance is alive
    • Y Yoshi
      + instance is alive
      @yoshi
      iobroker logs --watch
      sagt was zu einem Neustart (zweite Konsoleninstanz).
      Y 1 Antwort Letzte Antwort
        @yoshi
        Y Offline
        Y Offline
        Yoshi
        Nachdem ich den Pi nochmal neugestartet habe, komme ich wieder drauf. Vielen Dank schon mal.
        Aber VIS will irgendwie nicht. Das kommt als Fehlermeldung im Protokoll
        vis.0
        2022-07-24 17:05:11.082	error	Not exists
        vis.0
        2022-07-24 17:05:11.081	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:466:21)
        vis.0
        2022-07-24 17:05:11.079	error	unhandled promise rejection: Not exists
        vis.0
        2022-07-24 17:05:11.078	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        Das spuckt er aus wenn ich VIS nachinstalieren möchte
        $ iobroker upgrade vis@1.4.15 --debug
        Update vis from @1.4.15 to @1.4.15
        NPM version: 6.14.17Installing iobroker.vis@1.4.15... (System call)
        > iobroker.vis@1.4.15 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
        npm ERR! code ELIFECYCLE
        npm ERR! errno 6
        npm ERR! iobroker.vis@1.4.15 install: `node main.js --install`
        npm ERR! Exit status 6npm ERR! npm ERR! Failed at the iobroker.vis@1.4.15 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-24T15_05_17_209Z-debug.log
        host.raspberrypi4-iob Cannot install iobroker.vis@1.4.15: 6
        ERROR: Process exited with code 25
        • Y Yoshi
          vis.0
          vis.0
          vis.0
          vis.0
          npm ERR! errno 6
          @yoshi
          cd /opt/iobroker
          npm ls | grep -E 'github|ERR'
          • Y Offline
            Y Offline
            Yoshi
            pi@raspberrypi4-iob:~ $ cd /opt/iobroker
            │ │ │ ├── github-from-package@0.0.0
            npm ERR! missing: iobroker.vis@1.4.15, required by iobroker.inst@2.0.3
            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis@1.4.15
            npm ERR! missing: axios@0.26.1, required by iobroker.vis@1.4.15
            npm ERR! missing: @types/iobroker@4.0.2, required by @iobroker/adapter-core@2.6.0
            npm ERR! missing: follow-redirects@1.14.9, required by axios@0.26.1
            pi@raspberrypi4-iob:/opt/iobroker $
            • Y Yoshi
              @yoshi
              Installier mal eine Vorversion von vis
              • Y Offline
                Y Offline
                Yoshi
                Mehrere probiert. Immer wieder Fehlermeldungen.
                Zudem habe ich gerade festgestellt, dass der ioBroker die Instanzen nicht lesen kann.
                $ iobroker upgrade vis@1.4.8 --debug
                Update vis from @0.0.0 to @1.4.8
                Installing iobroker.vis@1.4.8... (System call)
                > iobroker.vis@1.4.8 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
                host.raspberrypi4-iob Cannot install iobroker.vis@1.4.8: 6
                weniger
                mehr
                $ iobroker upgrade vis@1.4.14 --debug
                Update vis from @0.0.0 to @1.4.14
                Installing iobroker.vis@1.4.14... (System call)
                > iobroker.vis@1.4.14 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
                npm ERR! errno 6
                npm ERR! Exit status 6npm ERR! npm ERR! Failed at the iobroker.vis@1.4.14 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
                host.raspberrypi4-iob Cannot install iobroker.vis@1.4.14: 6
                • Y Yoshi
                  weniger
                  mehr
                  npm ERR! errno 6
                  @yoshi sagte in IoBroker läuft nicht mehr:
                  Dann schau in das Log
                  less -R /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
                    Y Offline
                    Y Offline
                    Yoshi
                    Wie kann ich das log hier reinkopieren. Irgendwie bin ich zu doof dafür
                    • Y Yoshi
                      @yoshi
                      Ich versteh das Problem nicht.
                      Kopieren? Wie oben auch?
                        @yoshi
                        Y Offline
                        Y Offline
                        Yoshi
                        Ich müsste es irgendwo abspeichern. Ich kann in der Console nur irgendwie das Kopieren was ich gerade sehe.
                        • Y Yoshi
                          Mit Bild runter / Leertaste blättert man in less.
                          • Y Yoshi
                            @yoshi
                            Oder hau es auf die Ausgabe:
                            cat /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
                              @yoshi
                              Y Offline
                              Y Offline
                              Yoshi
                              Ja das hat geklappt. Aber das Log ist Mega groß. Ich versuche mal das ein oder andere rauszukopieren. Den ich verstehe nur Bahnhof :-)
                              pi@raspberrypi4-iob:~ $ cat /home/iobroker/.npm/_logs/2022-07-24T15_31_30_481Z-debug.log
                              0 info it worked if it ends with ok
                              1 verbose cli [
                              1 verbose cli   '/usr/bin/node',
                              1 verbose cli   '/usr/bin/npm',
                              1 verbose cli   'install',
                              1 verbose cli   '--save-exact',
                              1 verbose cli   'iobroker.vis@1.4.14'
                              1 verbose cli ]
                              2 info using npm@6.14.17
                              3 info using node@v14.20.0
                              4 verbose npm-session d9b13fc63301aec3
                              5 silly install loadCurrentTree
                              6 silly install readLocalPackageData
                              7 http fetch GET 304 https://registry.npmjs.org/iobroker.vis 373ms (from cache)
                              8 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.14.tgz 744ms
                              9 silly pacote version manifest for iobroker.vis@1.4.14 fetched in 1167ms
                              10 timing stage:loadCurrentTree Completed in 9183ms
                              11 silly install loadIdealTree
                              12 silly install cloneCurrentTreeToIdealTree
                              13 timing stage:loadIdealTree:cloneCurrentTree Completed in 58ms
                              14 silly install loadShrinkwrap
                              15 timing stage:loadIdealTree:loadShrinkwrap Completed in 4956ms
                              16 silly install loadAllDepsIntoIdealTree
                              17 silly resolveWithNewModule iobroker.vis@1.4.14 checking installable status
                              18 silly removeObsoleteDep removing iobroker.vis@1.4.15 from the tree as its been replaced by a newer version or is no longer required
                              19 silly removeObsoleteDep removing @iobroker/adapter-core@2.6.0 from the tree as its been replaced by a newer version or is no longer required
                              20 silly removeObsoleteDep removing @types/iobroker@4.0.2 from the tree as its been replaced by a newer version or is no longer required
                              21 silly removeObsoleteDep removing axios@0.26.1 from the tree as its been replaced by a newer version or is no longer required
                              22 silly removeObsoleteDep removing follow-redirects@1.14.9 from the tree as its been replaced by a newer version or is no longer required
                              23 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 65ms (from cache)
                              24 silly pacote range manifest for @iobroker/adapter-core@^2.6.0 fetched in 78ms
                              25 silly resolveWithNewModule @iobroker/adapter-core@2.6.0 checking installable status
                              26 http fetch GET 304 https://registry.npmjs.org/axios 146ms (from cache)
                              27 silly pacote range manifest for axios@^0.26.1 fetched in 161ms
                              28 silly resolveWithNewModule axios@0.26.1 checking installable status
                              29 http fetch GET 200 https://registry.npmjs.org/@types%2fiobroker 9ms (from cache)
                              30 silly pacote range manifest for @types/iobroker@^4.0.1 fetched in 14ms
                              31 silly resolveWithNewModule @types/iobroker@4.0.4 checking installable status
                              32 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 8723ms
                              33 timing stage:loadIdealTree Completed in 16007ms
                              34 silly currentTree iobroker.inst@2.0.3
                              34 silly currentTree ├─┬ @abandonware/bluetooth-hci-socket@0.5.3-8
                              34 silly currentTree │ ├── debug@4.3.4
                              34 silly currentTree │ └── ms@2.1.2
                              34 silly currentTree ├─┬ @abandonware/noble@1.9.2-15
                              35 silly idealTree ├── yeast@0.1.2
                              35 silly idealTree └── zrender@4.3.2
                              36 silly install generateActionsToTake
                              37 timing stage:generateActionsToTake Completed in 457ms
                              38 silly diffTrees action count 4
                              39 silly diffTrees add @types/iobroker@4.0.4
                              40 silly diffTrees add @iobroker/adapter-core@2.6.0
                              41 silly diffTrees add axios@0.26.1
                              42 silly diffTrees add iobroker.vis@1.4.14
                              43 silly decomposeActions action count 32
                              44 silly decomposeActions fetch @types/iobroker@4.0.4
                              45 silly decomposeActions extract @types/iobroker@4.0.4
                              46 silly decomposeActions preinstall @types/iobroker@4.0.4
                              47 silly decomposeActions build @types/iobroker@4.0.4
                              48 silly decomposeActions install @types/iobroker@4.0.4
                              49 silly decomposeActions postinstall @types/iobroker@4.0.4
                              50 silly decomposeActions finalize @types/iobroker@4.0.4
                              51 silly decomposeActions refresh-package-json @types/iobroker@4.0.4
                              52 silly decomposeActions fetch @iobroker/adapter-core@2.6.0
                              53 silly decomposeActions extract @iobroker/adapter-core@2.6.0
                              54 silly decomposeActions preinstall @iobroker/adapter-core@2.6.0
                              55 silly decomposeActions build @iobroker/adapter-core@2.6.0
                              56 silly decomposeActions install @iobroker/adapter-core@2.6.0
                              57 silly decomposeActions postinstall @iobroker/adapter-core@2.6.0
                              58 silly decomposeActions finalize @iobroker/adapter-core@2.6.0
                              59 silly decomposeActions refresh-package-json @iobroker/adapter-core@2.6.0
                              60 silly decomposeActions fetch axios@0.26.1
                              61 silly decomposeActions extract axios@0.26.1
                              62 silly decomposeActions preinstall axios@0.26.1
                              63 silly decomposeActions build axios@0.26.1
                              64 silly decomposeActions install axios@0.26.1
                              65 silly decomposeActions postinstall axios@0.26.1
                              66 silly decomposeActions finalize axios@0.26.1
                              67 silly decomposeActions refresh-package-json axios@0.26.1
                              68 silly decomposeActions fetch iobroker.vis@1.4.14
                              69 silly decomposeActions extract iobroker.vis@1.4.14
                              70 silly decomposeActions preinstall iobroker.vis@1.4.14
                              71 silly decomposeActions build iobroker.vis@1.4.14
                              72 silly decomposeActions install iobroker.vis@1.4.14
                              73 silly decomposeActions postinstall iobroker.vis@1.4.14
                              74 silly decomposeActions finalize iobroker.vis@1.4.14
                              75 silly decomposeActions refresh-package-json iobroker.vis@1.4.14
                              76 silly install executeActions
                              77 silly doSerial global-install 32
                              78 verbose correctMkdir /home/iobroker/.npm/_locks correctMkdir not in flight; initializing
                              79 verbose lock using /home/iobroker/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging
                              80 silly doParallel extract 4
                              81 silly extract @types/iobroker@4.0.4
                              82 silly extract @iobroker/adapter-core@2.6.0
                              83 silly extract axios@0.26.1
                              84 silly extract iobroker.vis@1.4.14
                              85 silly tarball trying axios@^0.26.1 by hash: sha512-fPwcX4EvnSHuInCMItEhAGnaSEXRBjtzh9fOtsE6E1G6p7vl7edEeZe11QHf18+6+9gR5PbKV/sGKNaD8YaMeA==
                              86 silly tarball trying iobroker.vis@1.4.14 by hash: sha512-KY+HIWjbwd24O7N8ViPD9WxJ9E/+ntPV7xZi93Z9mf85NKaLP6ZkGwW7AJCvnUZTkoAcCCBe5FhNrsxutEQoSw==
                              87 silly tarball trying @types/iobroker@^4.0.1 by hash: sha512-hioI0Cf73pd0i5QGdJptj4AS+6zpWjBSZ4Vz80VyU/oLO7qgU/UiyO79o/ajAWbNREEVlhCJg8sHCoEAe0Bbaw==
                              88 silly tarball trying @iobroker/adapter-core@^2.6.0 by hash: sha512-J5Cgy0NK8GWjN1th3yvWCG3tnK8iJJcPaHIoVR8PfpEsz4hffuVGi660vNXqXdiqR5Br09XSJ5h1Pn9af0/taw==
                              89 silly extract @types/iobroker@^4.0.1 extracted to /opt/iobroker/node_modules/.staging/@types/iobroker-e6a8269f (179ms)
                              90 silly extract @iobroker/adapter-core@^2.6.0 extracted to /opt/iobroker/node_modules/.staging/@iobroker/adapter-core-29bacaba (201ms)
                              91 silly extract axios@^0.26.1 extracted to /opt/iobroker/node_modules/.staging/axios-e9689e9f (365ms)
                              92 silly extract iobroker.vis@1.4.14 extracted to /opt/iobroker/node_modules/.staging/iobroker.vis-c6a771c0 (947ms)
                              93 timing action:extract Completed in 956ms
                              94 silly doReverseSerial unbuild 32
                              95 silly doSerial remove 32
                              96 silly doSerial move 32
                              97 silly doSerial finalize 32
                              98 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/@types/iobroker
                              99 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/@iobroker/adapter-core
                              100 silly finalize /opt/iobroker/node_modules/iobroker.vis/node_modules/axios
                              101 silly finalize /opt/iobroker/node_modules/iobroker.vis
                              102 timing action:finalize Completed in 23ms
                              103 silly doParallel refresh-package-json 4
                              104 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/@types/iobroker
                              105 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/@iobroker/adapter-core
                              106 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis/node_modules/axios
                              107 silly refresh-package-json /opt/iobroker/node_modules/iobroker.vis
                              108 timing action:refresh-package-json Completed in 38ms
                              109 silly doParallel preinstall 4
                              110 silly preinstall @types/iobroker@4.0.4
                              111 info lifecycle @types/iobroker@4.0.4~preinstall: @types/iobroker@4.0.4
                              112 silly preinstall @iobroker/adapter-core@2.6.0
                              113 info lifecycle @iobroker/adapter-core@2.6.0~preinstall: @iobroker/adapter-core@2.6.0
                              114 silly preinstall axios@0.26.1
                              115 info lifecycle axios@0.26.1~preinstall: axios@0.26.1
                              116 silly preinstall iobroker.vis@1.4.14
                              117 info lifecycle iobroker.vis@1.4.14~preinstall: iobroker.vis@1.4.14
                              118 timing action:preinstall Completed in 3ms
                              119 silly doSerial build 32
                              120 silly build @types/iobroker@4.0.4
                              121 info linkStuff @types/iobroker@4.0.4
                              122 silly linkStuff @types/iobroker@4.0.4 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
                              123 silly build @iobroker/adapter-core@2.6.0
                              124 info linkStuff @iobroker/adapter-core@2.6.0
                              125 silly linkStuff @iobroker/adapter-core@2.6.0 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
                              126 silly build axios@0.26.1
                              127 info linkStuff axios@0.26.1
                              128 silly linkStuff axios@0.26.1 has /opt/iobroker/node_modules/iobroker.vis/node_modules as its parent node_modules
                              129 silly build iobroker.vis@1.4.14
                              130 info linkStuff iobroker.vis@1.4.14
                              131 silly linkStuff iobroker.vis@1.4.14 has /opt/iobroker/node_modules as its parent node_modules
                              132 timing action:build Completed in 15ms
                              133 silly doSerial global-link 32
                              134 silly doParallel update-linked 0
                              135 silly doSerial install 32
                              136 silly install @types/iobroker@4.0.4
                              137 info lifecycle @types/iobroker@4.0.4~install: @types/iobroker@4.0.4
                              138 silly install @iobroker/adapter-core@2.6.0
                              139 info lifecycle @iobroker/adapter-core@2.6.0~install: @iobroker/adapter-core@2.6.0
                              140 silly install axios@0.26.1
                              141 info lifecycle axios@0.26.1~install: axios@0.26.1
                              142 silly install iobroker.vis@1.4.14
                              143 info lifecycle iobroker.vis@1.4.14~install: iobroker.vis@1.4.14
                              144 verbose lifecycle iobroker.vis@1.4.14~install: unsafe-perm in lifecycle true
                              145 verbose lifecycle iobroker.vis@1.4.14~install: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/iobroker/node_modules/iobroker.vis/node_modules/.bin:/opt/iobroker/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
                              146 verbose lifecycle iobroker.vis@1.4.14~install: CWD: /opt/iobroker/node_modules/iobroker.vis
                              147 silly lifecycle iobroker.vis@1.4.14~install: Args: [ '-c', 'node main.js --install' ]
                              148 silly lifecycle iobroker.vis@1.4.14~install: Returned: code: 6  signal: null
                              149 info lifecycle iobroker.vis@1.4.14~install: Failed to exec install script
                              150 timing action:install Completed in 3586ms
                              151 verbose unlock done using /home/iobroker/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging
                              152 timing stage:rollbackFailedOptional Completed in 266ms
                              153 timing stage:runTopLevelLifecycles Completed in 30652ms
                              154 silly saveTree iobroker.inst@2.0.3
                              154 silly saveTree ├── colors@1.4.0
                              154 silly saveTree ├─┬ fs-extra@7.0.1
                              154 silly saveTree │ ├── graceful-fs@4.2.3
                              154 silly saveTree │ ├── jsonfile@4.0.0
                              154 silly saveTree │ └── universalify@0.1.2
                              154 silly saveTree ├─┬ iobroker.admin@6.2.4
                              154 silly saveTree ├── semver@5.7.1
                              154 silly saveTree └── yargs@7.1.0
                              155 verbose stack Error: iobroker.vis@1.4.14 install: `node main.js --install`
                              155 verbose stack Exit status 6
                              155 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                              155 verbose stack     at EventEmitter.emit (events.js:400:28)
                              155 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                              155 verbose stack     at ChildProcess.emit (events.js:400:28)
                              155 verbose stack     at maybeClose (internal/child_process.js:1088:16)
                              155 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:296:5)
                              156 verbose pkgid iobroker.vis@1.4.14
                              157 verbose cwd /opt/iobroker
                              158 verbose Linux 5.15.32-v7l+
                              159 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--save-exact" "iobroker.vis@1.4.14"
                              160 verbose node v14.20.0
                              161 verbose npm  v6.14.17
                              162 error code ELIFECYCLE
                              163 error errno 6
                              164 error iobroker.vis@1.4.14 install: `node main.js --install`
                              164 error Exit status 6
                              165 error Failed at the iobroker.vis@1.4.14 install script.
                              165 error This is probably not a problem with npm. There is likely additional logging output above.
                              166 verbose exit [ 6, true ]
                              pi@raspberrypi4-iob:~ $ Last login: Sun Jul 24 16:56:55 on ttys001
                              jacekbezler@MacBook-Air-von-Jacek ~ % ssh pi@192.168.0.64
                              pi@192.168.0.64's password:
                              Linux raspberrypi4-iob 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
                              permitted by applicable law.
                              Last login: Sun Jul 24 16:58:48 2022 from 192.168.0.120
                              1 verbose cli [
                              1 verbose cli ]
                              166 verbose exit [ 6, true ]ot a problem with npm. There is likely additional lo
                              • Y Offline
                                Y Offline
                                Yoshi
                                Warum auch immer, die Instanzen kann ich wieder sehen.
                                Nun läuft auch der Adapter HASS nicht und wenn ich ihn nachinstalieren möchte, bekomme ich das gleiche wie bei VIS
                                • Y Yoshi
                                  @yoshi
                                  Geh mal auf nodejs16 hoch.
                                  Anleitung in meiner Signatur.
                                    @yoshi
                                    Y Offline
                                    Y Offline
                                    Yoshi
                                    ok...kann ich bei der Ausgabe fortfahren ?
                                    • Y Yoshi
                                      @yoshi
                                      Ja, das ist kein Fehler.
                                        @yoshi
                                        Y Offline
                                        Y Offline
                                        Yoshi
                                        soweit erledigt.
                                        pi@raspberrypi4-iob:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                        armv7l
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.16.0
                                        v16.16.0
                                        8.11.0
                                        pi
                                        /home/pi
                                        OK:1 http://phoscon.de/apt/deconz bullseye InRelease
                                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                        OK:4 https://repos.influxdata.com/debian stretch InRelease
                                        OK:5 https://download.docker.com/linux/debian bullseye InRelease
                                        OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                                        OK:7 https://packages.grafana.com/oss/deb stable InRelease
                                        OK:8 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        Alle Pakete sind aktuell.
                                        nodejs:
                                          Installiert:           16.16.0-deb-1nodesource1
                                          Installationskandidat: 16.16.0-deb-1nodesource1
                                          Versionstabelle:
                                         *** 16.16.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                             14.20.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                             12.22.12~dfsg-1~deb11u1 500
                                        • Y Yoshi
                                          soweit erledigt.
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.16.0
                                          v16.16.0
                                          8.11.0
                                          pi
                                          /home/pi
                                          nodejs:
                                            Versionstabelle:
                                          Das muss auf bullseye lauten. Stell es um:
                                          sudo sed -i 's/stretch/bullseye/g' /etc/apt/sources.list.d/*
