  4. Alexa2 Adapter 3.18.x (BETA)
    apollon77A
449 Beiträge 38 Kommentatoren 134.7k Aufrufe 42 Beobachtet
  • padrinoP padrino
    @apollon77 sagte in Alexa2 Adapter 3.18.x (BETA):
    @padrino mach mal Debug log an ... aber ja ... so "heftig" wie der Debug beim Start ist wäre es nicht zu verwunderlich
    Das ganze Log?
    Komme nimmer rein...
    2022-07-19 12:35:21.311  - info: alexa2.0 (4259) Initialization Done ...
    2022-07-19 12:35:28.778  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    2022-07-19 12:35:28.784  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Close: 1005:
    2022-07-19 12:35:28.785  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Retry Connection in 20s
    2022-07-19 12:35:28.786  - info: alexa2.0 (4259) Alexa-Push-Connection disconnected - retry: Retry Connection in 20s
    2022-07-19 12:35:49.251  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    2022-07-19 12:35:49.255  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Close: 1005:
    2022-07-19 12:35:49.257  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Retry Connection in 25s
    2022-07-19 12:35:49.259  - info: alexa2.0 (4259) Alexa-Push-Connection disconnected - retry: Retry Connection in 25s
    2022-07-19 12:36:14.772  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    2022-07-19 12:36:14.780  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Close: 1005:
    2022-07-19 12:36:14.781  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Retry Connection in 30s
    2022-07-19 12:36:14.781  - info: alexa2.0 (4259) Alexa-Push-Connection disconnected - retry: Retry Connection in 30s
    2022-07-19 12:36:45.281  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    2022-07-19 12:36:45.289  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Close: 1005:
    2022-07-19 12:36:45.291  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Retry Connection in 35s
    2022-07-19 12:36:45.292  - info: alexa2.0 (4259) Alexa-Push-Connection disconnected - retry: Retry Connection in 35s
    2022-07-19 12:37:20.787  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    2022-07-19 12:37:20.795  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Close: 1005:
    2022-07-19 12:37:20.796  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Retry Connection in 40s
    2022-07-19 12:37:20.798  - info: alexa2.0 (4259) Alexa-Push-Connection disconnected - retry: Retry Connection in 40s
    2022-07-19 12:38:01.282  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    2022-07-19 12:38:01.289  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Close: 1005:
    2022-07-19 12:38:01.290  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Retry Connection in 45s
    2022-07-19 12:38:01.291  - info: alexa2.0 (4259) Alexa-Push-Connection disconnected - retry: Retry Connection in 45s
    2022-07-19 12:38:46.793  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    2022-07-19 12:38:46.801  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Close: 1005:
    2022-07-19 12:38:46.803  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Retry Connection in 50s
    2022-07-19 12:38:46.804  - info: alexa2.0 (4259) Alexa-Push-Connection disconnected - retry: Retry Connection in 50s
    2022-07-19 12:39:37.300  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    2022-07-19 12:39:37.307  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Close: 1005:
    2022-07-19 12:39:37.309  - debug: alexa2.0 (4259) Alexa-Remote WS-MQTT: Retry Connection in 55s
    2022-07-19 12:39:37.311  - info: alexa2.0 (4259) Alexa-Push-Connection disconnected - retry: Retry Connection in 55s
    2022-07-19 12:40:00.361  - debug: alexa2.0 (4259) Alexa-Remote: No authentication check needed (time elapsed 372354)
    2022-07-19 12:40:00.364  - debug: alexa2.0 (4259) Alexa-Remote: Sending Request with {"host":"www.amazon.de","p
    liv-in-skyL
    liv-in-skyL
    #80
    @padrino genau das selbe ist bei mir auch :-(
    • liv-in-skyL liv-in-sky
      apollon77A
      apollon77A
      #81
      @liv-in-sky Dann schalte vllt (wenn du nicht adptet stoppen lassen kannst) die Push-Connection bis morgen früh oder so aus in den Settings)
      • apollon77A apollon77
        liv-in-skyL
        liv-in-skyL
        #82
        @apollon77 habe ich gestern abend schon deaktiviert :-)
        • MalleRalleM
          MalleRalleM
          MalleRalle
          #83
          @apollon77
          Mit 3.18.6 funktioniert Device Stop wieder.
          Vielen Dank für den schnellen Fix!
          ESP8266E 1 Antwort Letzte Antwort
          • MalleRalleM MalleRalle
            @apollon77
            ESP8266E
            ESP8266E
            ESP8266
            schrieb am zuletzt editiert von ESP8266
            #84
            @apollon77 , ich habe festgestellt, dass das Tablet Fire HD in Überall nicht unterstützt wird. Speak und announcement funktionieren nur mit Echo Dot und Echo Show. Das war schon im alten Adapter so. Ist es Möglich das zu implemtieren?
            • ESP8266E ESP8266
              apollon77A
              apollon77A
              #85
              @esp8266 was heißt „tut in überall nicht“?
              Was heißt speak tut nicht? Es ist da aber passiert nix?falls ja: kannst du in der Alexa App eine Routine anlegen die eine Ausgabe darauf tut? Wenn nein dann kann das device das halt nicht. Da kann ich auch nix tun ;-)
                ESP8266E
                ESP8266E
                ESP8266
                #86
                @apollon77 , wenn ich im device Tablet in speak ein Hallo eingebe, wird auch Hallo über das Tablet wieder gegeben. So auch via Script wenn ich explizit das Tablet angebe....nur nicht in überall. Das gleiche verhalten mit announcement....
                • ESP8266E ESP8266
                  apollon77A
                  apollon77A
                  #87
                  @esp8266 überall ist die gruppe korrekt? Dann bitte einmal loglevel auf debug und log von der Platte unter /opt/iobroker/log/… vom ganzen Start und danach einer solchen Einzel speak und einem überall speak zu mir per email an iobroker@fischer-ka.de
                    padrinoP
                    padrinoP
                    padrino
                    #88
                    @apollon77
                    So, habe jetzt hier mal den Router neu gestartet, den Cookie neu gezogen und 3.18.6 installiert.
                    Bekomme aber keine Push Verbindung zu amazon. :(
                    Bringt es was Dir das komplette Startup Log per Mail zu schicken?
                    • padrinoP padrino
                      @apollon77
                      apollon77A
                      apollon77A
                      #89
                      @padrino Ich fürchte hilft nicht. Keine Ahnung warum das nicht geht. Lass die Push connection ggf wirklich mal einen tag aus ... oder zwei. Wenn es eine Art "zu oft connected" ist dann sollte es nach ner Zeit wieder gehen.
                      padrinoP ESP8266E 2 Antworten Letzte Antwort
                        padrinoP
                        padrinoP
                        padrino
                        #90
                        @apollon77
                        Dann muss ich mir wohl einen Button anlegen, der nach der Anfrage, die es benötigt, die History triggert. 😌
                          ESP8266E
                          ESP8266E
                          ESP8266
                          #91
                          @apollon77 , überall ist korrekt. Mir ist aufgefallen, das im device Tablet unter Info isMultiroomMember auf false steht. Dot und Show stehen dort auf true.
                          Beim Fire HD Cube dort das selbige wie beim Tablet. Nur will ich dort keine Ansagen haben.
                          Es müsste irgendwie möglich sein, Devices zu einer Gruppe hinzuzufügen und auch wieder entfernen zu können.
                          • ESP8266E ESP8266
                            Thomas BraunT
                            Thomas BraunT
                            #92
                            @esp8266
                            Das dürfte damit zusammen hängen, dass man in der Regel diese Geräte mit den scheppernden Quäkern nicht in einem Multiroom-Audio-Setup haben will.
                              @esp8266
                              ESP8266E
                              ESP8266E
                              ESP8266
                              #93
                              @thomas-braun , naja der Cube scheppert nicht. Ich spiele eh keine Musik über die Devices ab. Dafür steht eine hochwertige Anlage im Wohnzimmer. Bei weitem besser....
                              • apollon77A
                                apollon77A
                                #94
                                Naja am End eist die Frage - was ist denn "Überall"? ne selbst erstellte Gruppe? Dann hake die Geräte an. Wenn es eine Standardgruppe von Amazon ist die Du nicht editieren kannst dann leg ne eigene an :-) Wobei ich nicht weiss ob man Apps o.ä. da überhaupt anhaken kann bzw sieht.
                                Wenn Amazon bestimmte gerätetypen per Default da nicht reinpackt kann der Adapter dafür nix.
                                Ansonsten müsste ich jetzt noch eine simulierte "wirklich Überall" Gruppe nur im Adapter anlegen die es dann aber nicht bei Amazon gibt ... hhhmm
                                  DJMarc75D
                                  DJMarc75D
                                  DJMarc75
                                  #95
                                  Ja, das ist eine Standardgruppe welche automatisch angelegt wird.
                                  @esp8266 sagte in Alexa2 Adapter 3.18.x (BETA):
                                  Bitte diese Einstellungen für die Gruppe "überall" mal über die APP antesten. In der APP siehst Du dann auch sofort, ob das jeweilige Device in die Gruppe mit aufgenommen werden kann.
                                  Lehrling seit 1975 !!!
                                    So, nach den aufregenden letzten tagen mit dem Versionbereich 3.14-3.17 kommt hier noch das Finale der Feature-Parade. Ich habe mich für einen eigenen Thread entscheiden um es nicht mit den Issues des anderen Threads und der Beta Versionen bis einschliesslich 3.17.5 zu vermischen.
                                    Wer also mit einer dier Versionen Issues hat bitte weiterhin https://forum.iobroker.net/topic/56021/alexa2-adapter-3-13-3-14-3-15-3-16-3-17-beta nutzen!!
                                    Die 3.18 bringt nochmal ein paar Features mit die so gewünscht wurden, ändert aber auch eine wichtige Thematik mit Smart Home Devices!! Ab sofort müssen Smart Home Devices die synchroniert werden sollen in Ihren Objekten einmalig aktiviert werden Dazu gibt es dort einen neuen State #includeInIntervalQuery der standardmäßig deaktiviert ist. Ich denke das dies ein sinnvoller Kompromiss ist und sich so jeder nochmal Gedanken macht bevor er es auf true setzt :-)
                                    Bevor wir zum Changelog kommen eine Bitte an die Tester die hier mitlesen:
                                    Bitte lasst den Adapter nach dem Update mal mit Debug Loglevel laufen. Er muß nach einer gewissen Weile, wo er initial alles lädt ,dann ein Info Log melden mit "Initialization Done ...". Damit sollte es im Log ruhiger werden und nur noch dann was tun wenn entweder die konfigurierten Intervalle abgelaufen sind oder Ihr mit einem gerät interagiert oder eine Push-Info von Amazon reinkommt. Bitte prüft da mal das alles passt und nicht doch mit irgendwlechen Konfig-Varianten wieder gespammt wird. DANKE! (PS: Bitte in der Zeit KEINE Musik irgendo laufen lassen sonst wird das Log nicht ruhig weil es immer loggt das sich die Musik-States ändern (was vollkommen normal ist!)
                                    Der sonstige Changelog:
                                    3.18.0 (2022-07-18)
                                    • IMPORTANT: Smart home device values are from now on only synchronized when enabled via #includeInIntervalQuery state. Enable only what's really needed!
                                    • (Apollon77) Allow to query several more smart home device states (incl. the Echo own Temperature-Sensor if available) and more optimizations
                                    • (Apollon77) Optimize querying smart home device states to only request relevant properties
                                    • (Apollon77) Exclude some value types again from requesting from Amazon because they make no sense and will never contain meaningful data
                                    • (Apollon77) Add FireTV commands for FireTV devices
                                    • (Apollon77) Add CommandsAll.deviceStop and CommandsAll.deviceDoNotDisturb commands to be sent to all devices
                                    • (Apollon77) Add Equalizer preferences (if supported by devices)
                                    • (Apollon77) Add Speaker and AUX preferences (if supported by devices)
                                    • (Apollon77) Add Display (enabled, brightness, adaptive brightness) preferences (if supported by devices)
                                    • (Apollon77) Enhance doNotDisturb state to also allow specifying a enable duration or end timepoint
                                    • (Apollon77) Add a fallback to update music player when a new history record mentions music as target for the spoken words. Could help as fallback when push infos are not coming in sometimes with Sonos
                                    • (Apollon77) Delay initialization of push connection to when basic structures are initialized
                                    • (Apollon77) Add some more devices
                                    Ingo
                                    MichaelScM
                                    MichaelScM
                                    MichaelSc
                                    #96
                                    @apollon77 Lieber Ingo: Danke für die Weiterentwicklung.
                                    Fahre den 3.18.6.
                                    Habe dann mal die Änderung mit "#includeInIntervalQuery state" versucht zu verstehen und zu finden.
                                    Finden: Negativ, finde solche states leider nicht.
                                    Verstehen: Wenn ich beispielsweise über Buttons in der VIS die Wiedergabe eines Radiosenders in Gruppen starten will oder die Lautstärke einer Gruppe oder individuell mehrerer Echos im System einstellen möchte, dann funktioniert das nicht (mehr), weil es nicht synchronisiert wird? Oder verstehe ich das falsch?
                                    Beispiel: Ich setze
                                    wobei ´textCommand´ das Feld in einer Gruppe oder auch in einem einzelnen Echo sein kann.
                                    Zusätzlich dann individuelle Lautstärken mit
                                    Wenn ich den neuen state #includeInIntervalQuery riichtig verstehe, dann funktioniert das nicht, weil man das erst aktivieren muss? Zitat: "Ab sofort müssen Smart Home Devices die synchroniert werden sollen in Ihren Objekten einmalig aktiviert werden"?
                                    Ein kurzer Hinweis, was ich hier tun muss, wäre sehr hilfreich.
                                    Oder ob das schon irgendwo weiter beschrieben ist.
                                    Kuriosum am Schluß: Ich kann sagen, dass die Beispiele wie oben beschrieben, funktionieren
                                    Also muss ja ein Sync stattfinden, sonst würde Alexa diese Settings hier im iObroker ja gar nicht mitbekommen - denke ich.
                                    iOBroker (and the other stuff) on a Proxmox Installation on an Intel NUC10.
                                    IoT: Discarded Zigbee-System and all the hardware related to Zigbee; replaced with HomeMatic IP - very reliable.
                                    • MichaelScM MichaelSc
                                      Fahre den 3.18.6.
                                      Beispiel: Ich setze
                                      apollon77A
                                      apollon77A
                                      #97
                                      @michaelsc Jetzt mal laaaangsam weil ich denke du bringst hier einiges durcheinander.
                                      Das Thema #includeInIntervalQuery betrifft AUSSCHLIESSLICH die Daten der States unter alexa2.0.Smart-Home-Devices.* ... der ganze Rest hat damit nichts zu tun.
                                      Also Volume und Player states und all das ist was ganz anderes.
                                      Die sollten weiterhin tun ganz normal.
                                      Tut jetzt irgendwas nicht oder war es nur die Verwirrung auf was sich dieses neue Stat ebezieht?
                                      MichaelScM 1 Antwort Letzte Antwort
                                        MichaelScM
                                        MichaelScM
                                        MichaelSc
                                        #98
                                        @apollon77 War oder ist wohl nur Verwirrung: Das Play- and Volume-Einstellen scheint zu funzen. Ich hab nur manchmal den Eindruck, dass wenn ich einen Echo in eine Gruppe mit aufnehme, die Gruppe dann nicht mehr funktioniert.
                                        Betr. Verwirrung: Daten der States unter alexa2.0.Smart-Home-Devices... AHHHHHHHHHH, verstanden. Ein Echo ist ja kein Smart-Home-Device.
                                        Mein Lese- oder Denkfehler. So sorry.
                                        Grad geschaut: Ach, habe ja auch Alexa2.0.Smart-home-Devices:
                                        Epson ET-3750 Series, wieso Alexa sich da den Drucker gekrallt hat, versteh ich auch nicht. #includeInIntervalQuery false.
                                        Und angeblich hab ich einen WiGa Echo als Device dort: Mit State enabled und #includeInIntervalQuery auch false. Ach: Wenn ich da grad weiterschaue hab ich 14 Geräte oder Channels dort, da spiegelt sich meine ganze Echo-Devices-Welt wider, incl Fernseher usw usw.
                                        Damit mache ich aber NICHTS.
                                          apollon77A
                                          apollon77A
                                          #99
                                          @michaelsc sagte in Alexa2 Adapter 3.18.x (BETA):
                                          Dann lass es einfach aus oder überlege ob Du das ganze Smart Home Device Sync in den Settings einfach ausschaltest
                                          MichaelScM ESP8266E 2 Antworten Letzte Antwort
                                          83.9k
