[How-to] Node.js ioBroker richtig updaten-2021/22 Edition
Also global... Wobei das eigentlich im gleichen Verzeichnis wie aus dem Paket 'nodejs' stammend liegen sollte.
Dann versuch mal
npm uninstall -g npmVielleicht auch noch per root oder sudo installiert?
@thomas-braun sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Dann versuch mal
Bin nicht mehr sicher ob das ohne sudo lief.....der Befehl wirft den gleichen Fehler aus wie "npm ls" zuvor...
pi@raspberrypi:/opt/iobroker $ npm uninstall -g npm /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110 class SocksProxyAgent extends agent_base_1.Agent { ^ TypeError: Class extends value undefined is not a constructor or null at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110:44) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/agent.js:174:25) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/remote.js:7:18) at Module._compile (node:internal/modules/cjs/loader:1105:14) pi@raspberrypi:/opt/iobroker $ -
@apollon77 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Welche node.js version ist da drauf?
16.16.0
16.16.0
type npmliefert?
pi@raspberrypi:/opt/iobroker $ type npm npm ist eine Funktion. npm () { __real_npm=$(which npm); if [[ $(pwd) == "/opt/iobroker"* ]]; then sudo -H -u iobroker $__real_npm $*; else eval $__real_npm $*; fi } pi@raspberrypi:/opt/iobroker $ -
type npmliefert?
pi@raspberrypi:/opt/iobroker $ type npm npm ist eine Funktion. npm () { __real_npm=$(which npm); if [[ $(pwd) == "/opt/iobroker"* ]]; then sudo -H -u iobroker $__real_npm $*; else eval $__real_npm $*; fi } pi@raspberrypi:/opt/iobroker $which npm && type -P npm && ls -l /usr/bin/npm -
which npm && type -P npm && ls -l /usr/bin/npm@thomas-braun sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
which npm && type -P npm && ls -l /usr/bin/npmpi@raspberrypi:/opt/iobroker $ which npm && type -P npm && ls -l /usr/bin/npm /usr/bin/npm /usr/bin/npm lrwxrwxrwx 1 root root 38 7. Jul 18:02 /usr/bin/npm -> ../lib/node_modules/npm/bin/npm-cli.js pi@raspberrypi:/opt/iobroker $ -
@joergh sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
root root
Nein, das ist in Ordnung.
which npm && type -P npm && ls -l /usr/bin/npmpi@raspberrypi:/opt/iobroker $ which npm && type -P npm && ls -l /usr/bin/npm /usr/bin/npm /usr/bin/npm lrwxrwxrwx 1 root root 38 7. Jul 18:02 /usr/bin/npm -> ../lib/node_modules/npm/bin/npm-cli.js pi@raspberrypi:/opt/iobroker $uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejsUnd vielleicht mal den fixer aufrufen und die Kiste neustarten.
iob stop iob fix sudo reboot -
iob stop iob fix sudo reboot@thomas-braun sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
iob stop iob fix sudo rebootAlles gemacht...folgendes kam nach dem ersten Befehl
pi@raspberrypi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.16.0 v16.16.0 /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110 class SocksProxyAgent extends agent_base_1.Agent { ^ TypeError: Class extends value undefined is not a constructor or null at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110:44) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/agent.js:174:25) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/remote.js:7:18) at Module._compile (node:internal/modules/cjs/loader:1105:14)nach dem reboot kam dann auf npm ls unverändert
pi@raspberrypi:~ $ npm ls /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110 class SocksProxyAgent extends agent_base_1.Agent { ^ TypeError: Class extends value undefined is not a constructor or null at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110:44) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/agent.js:174:25) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/remote.js:7:18) at Module._compile (node:internal/modules/cjs/loader:1105:14) pi@raspberrypi:~ $ -
pi@raspberrypi:~ $ npm ls /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110 class SocksProxyAgent extends agent_base_1.Agent { ^ TypeError: Class extends value undefined is not a constructor or null at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110:44) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/agent.js:174:25) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/remote.js:7:18) at Module._compile (node:internal/modules/cjs/loader:1105:14) pi@raspberrypi:~ $iobroker stop apt policy nodejs sudo apt install --reinstall nodejs iobroker start -
iobroker stop apt policy nodejs sudo apt install --reinstall nodejs iobroker start@thomas-braun sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
iobroker stop apt policy nodejs sudo apt install --reinstall nodejs iobroker startpi@raspberrypi:~ $ iobroker stop pi@raspberrypi:~ $ apt policy nodejs nodejs: Installiert: 16.16.0-deb-1nodesource1 Installationskandidat: 16.16.0-deb-1nodesource1 Versionstabelle: *** 16.16.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages pi@raspberrypi:~ $ sudo apt install --reinstall nodejs Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig 0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen 23,6 MB an Archiven heruntergeladen werden. Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt. Holen:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23,6 MB] Es wurden 23,6 MB in 4 s geholt (6.613 kB/s). (Lese Datenbank ... 133291 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ... Entpacken von nodejs (16.16.0-deb-1nodesource1) über (16.16.0-deb-1nodesource1) ... nodejs (16.16.0-deb-1nodesource1) wird eingerichtet ... Trigger für man-db (2.9.4-2) werden verarbeitet ... pi@raspberrypi:~ $Sieht mir ja so aus, als ob er beim reinstall nicht die npm 8 mit installiert, so wie beim upgrade....
Das muss er, denn
dpkg -L nodejs | grep /usr/bin/npm /usr/bin/npmDas zeigt er an...aber warum bleibt die npm Version bei 6.14.17?
pi@raspberrypi:~ $ dpkg -L nodejs | grep /usr/bin/npm /usr/bin/npm pi@raspberrypi:~ $ -
Das muss er, denn
pi@raspberrypi:~ $ dpkg -L nodejs | grep /usr/bin/npm /usr/bin/npm pi@raspberrypi:~ $@joergh sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Wo siehtst du die Versionsnummer? Ich sehe nur mir unbekannte Fehlermeldungen.
Ja, stand noch im Admin von iobroker, aber nach reload ist sie da nun auch weg...
Kann man nicht vielleicht downgraden und dann wieder hoch?
@joergh Ist jetzt wirklich stochern im Nebel, aber installier das nochmal falsch global.
npm install -g npm@6 -
npm install -g npm@6@thomas-braun sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Da lässt sich nichts mehr mit npm installieren, es kommt immer der gleiche Fehler...hab dazu was gefunden im Netz:
"It may happen, that after deinstallation you have to delete the node_modules directory in the nodejs Installation Directory manually. And after that do the installation."
Welches wäre das denn?
