  3. Off Topic
  4. Grafana stürzt mehrfach täglich ab
22 Beiträge 5 Kommentatoren 1.4k Aufrufe 4 Beobachtet
    @timov sagte in Grafana stürzt mehrfach täglich ab:
    Hatte das Problem schon mal jemand oder weiß, wie es zu lösen ist?
    Was steht denn im Log?
    TimoV
    @haus-automatisierung
     grafana-server.service - Grafana instance
         Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Mon 2022-07-18 11:02:36 CEST; 11min ago
           Docs: http://docs.grafana.org
        Process: 23924 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packagi>
       Main PID: 23924 (code=exited, status=1/FAILURE)
            CPU: 93ms
    Jul 18 11:02:36 iobroker systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
    Jul 18 11:02:36 iobroker systemd[1]: Stopped Grafana instance.
    Jul 18 11:02:36 iobroker systemd[1]: grafana-server.service: Start request repeated too quickly.
    Jul 18 11:02:36 iobroker systemd[1]: grafana-server.service: Failed with result 'exit-code'.
    Jul 18 11:02:36 iobroker systemd[1]: Failed to start Grafana instance.
    • T TimoV
              CPU: 93ms
      @timov
      sudo apt update
      apt policy grafana
      sagt?
        @timov
        sudo apt update
        apt policy grafana
        sagt?
        TimoV
        pi@iobroker:~ $ sudo apt update
        Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
        Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
        Get:3 https://repos.influxdata.com/debian bullseye InRelease [4,739 B]
        Get:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
        Get:5 http://raspbian.raspberrypi.org/raspbian bullseye/non-free Sources [141 kB]
        Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/contrib Sources [82.2 kB]
        Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [289 kB]
        Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/main Sources [12.2 MB]
        Get:9 https://repos.influxdata.com/debian bullseye/stable armhf Packages [780 B]
        Get:10 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [784 B]
        Get:11 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
        Get:12 http://raspbian.raspberrypi.org/raspbian bullseye/non-free armhf Packages [106 kB]
        Fetched 26.1 MB in 12s (2,135 kB/s)
        Reading package lists... Done
        105 packages can be upgraded. Run 'apt list --upgradable' to see them.
        pi@iobroker:~ $ apt policy grafana
        grafana:
          Installed: (none)
          Candidate: (none)
          Version table:
        • T TimoV
          grafana:
            Installed: (none)
            Candidate: (none)
            Version table:
          räusper
          Und wie hast du grafana bitte installiert?
          Das macht man richtig auch über apt, ist bei dir aber nicht so gemacht worden.
            räusper
            TimoV
            @thomas-braun danke erstmal für deine Unterstützung!
            Ich hab Grafana über dieses Tutorial installiert: https://www.verdrahtet.info/2020/02/14/installation-von-influxdb-grafana-inkl-verbindung-zu-iobroker/
            Soll ich sudo apt-get upgrade ausführen?
            • T TimoV
              @timov
              Ja, bitte unbedingt das System auf Stand halten.
              iobroker stop
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              Die Anleitung ist auch Quark. Jedenfalls was grafana anbelangt.
              dpkg -l '*grafana*'
              sagt?
              • T TimoV
                ich habe neben ioBroker auch Grafana und eine InfluxDB laufen. Leider stürzt Grafana mehrfach täglich ab, sodass ich es erst per SSH neustarten muss, bis es wieder funktioniert.
                Abstürzen heißt, dass die Grafana-Seite über Port 3000 nicht mehr erreichbar ist und "die Verbindung abgelehnt" wird.
                Über Hilfe würde ich mich sehr freuen.
                VG Timo
                crunchipC Abwesend
                crunchipC Abwesend
                @timov dir fehlt folgendes, damit der service dauerhaft läuft. Allerdings wie schon geschrieben wurde, installier es per apt und dann hast auch die passende neuste version
                sudo /bin/systemctl enable grafana-server
                  @crunchip
                  Da fehlt zuerst mal eine 'ordentliche' Installation via Paketmanager.
                    @crunchip
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @thomas-braun siehe Ergänzung
                      @timov
                      iobroker stop
                      sudo apt update
                      sudo reboot
                      dpkg -l '*grafana*'
                      sagt?
                      TimoV
                      schrieb am zuletzt editiert von TimoV
                      @thomas-braun Upgrade lief jetzt. Momentan startet Grafana gar nicht mehr.
                      pi@iobroker:~ $ dpkg -l '*grafana*'
                      Desired=Unknown/Install/Remove/Purge/Hold
                      | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                      |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                      ||/ Name           Version      Architecture Description
                      un  grafana        <none>       <none>       (no description available)
                      ii  grafana-rpi    7.4.3        armhf        Grafana
                      • T TimoV
                        grafana-rpi
                        sudo dpkg -P grafana-rpi
                        Dann das grafana-Repo anlegen:
                        sudo apt-get install -y apt-transport-https
                        sudo apt-get install -y software-properties-common wget
                        wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                        echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
                        sudo apt update
                        sudo apt install grafana
                        T crunchipC 2 Antworten Letzte Antwort
                          grafana-rpi
                          sudo apt update
                          TimoV
                          @thomas-braun Vielen Dank!
                          Grafana läuft jetzt erstmal wieder und ich werde beobachten, wie es sich verhält.
                          • T TimoV
                            @timov
                            sudo apt update
                            apt policy grafana
                            sagt nun?
                              @timov
                              sudo apt update
                              apt policy grafana
                              sagt nun?
                              TimoV
                              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
                              Hit:4 https://repos.influxdata.com/debian bullseye InRelease
                              Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                              All packages are up to date.
                              grafana:
                                Installed: 9.0.3
                                Candidate: 9.0.3
                                Version table:
                               *** 9.0.3 500
                                      500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                                   9.0.2 500
                                   9.0.1 500
                                   9.0.0 500
                                   8.5.9 500
                                   8.5.6 500
                                   8.5.5 500
                                   8.5.4 500
                                   8.5.3 500
                                   8.5.2 500
                                   8.5.1 500
                                   8.5.0 500
                                   8.4.10 500
                                   8.4.7 500
                                   8.4.6 500
                                   8.4.5 500
                                   8.4.4 500
                                   8.4.3 500
                                   8.4.2 500
                                   8.4.1 500
                                   8.4.0 500
                                   8.3.10 500
                                   8.3.7 500
                                   8.3.6 500
                                   8.3.5 500
                                   8.3.4 500
                                   8.3.3 500
                                   8.3.2 500
                                   8.3.1 500
                                   8.3.0 500
                                   8.2.7 500
                                   8.2.6 500
                                   8.2.5 500
                                   8.2.4 500
                                   8.2.3 500
                                   8.2.2 500
                                   8.2.1 500
                                   8.2.0 500
                                   8.1.8 500
                                   8.1.7 500
                                   8.1.6 500
                                   8.1.5 500
                                   8.1.4 500
                                   8.1.3 500
                                   8.1.2 500
                                   8.1.1 500
                                   8.1.0 500
                                   8.0.7 500
                                   8.0.6 500
                                   8.0.5 500
                                   8.0.4 500
                                   8.0.3 500
                                   8.0.2 500
                                   8.0.1 500
                                   8.0.0 500
                                   7.5.16 500
                                   7.5.15 500
                                   7.5.13 500
                                   7.5.12 500
                                   7.5.11 500
                                   7.5.10 500
                                   7.5.9 500
                                   7.5.8 500
                                   7.5.7 500
                                   7.5.6 500
                                   7.5.5 500
                                   7.5.4 500
                                   7.5.3 500
                                   7.5.2 500
                                   7.5.1 500
                                   7.5.0 500
                                   7.4.5 500
                                   7.4.3 500
                                   7.4.2 500
                                   7.4.1 500
                                   7.4.0 500
                                   7.3.10 500
                                   7.3.7 500
                                   7.3.6 500
                                   7.3.5 500
                                   7.3.4 500
                                   7.3.3 500
                                   7.3.2 500
                                   7.3.1 500
                                   7.3.0 500
                                   7.2.2 500
                                   7.2.1 500
                                   7.2.0 500
                                   7.1.5 500
                                   7.1.4 500
                                   7.1.3 500
                                   7.1.2 500
                                   7.1.1 500
                                   7.1.0 500
                                   7.0.6 500
                                   7.0.5 500
                                   7.0.4 500
                                   7.0.3 500
                                   7.0.2 500
                                   7.0.1 500
                                   7.0.0 500
                                   6.7.6 500
                                   6.7.5 500
                                   6.7.4 500
                                   6.7.3 500
                                   6.7.2 500
                                   6.7.1 500
                                   6.7.0 500
                                   6.6.2 500
                                   6.6.1 500
                                   6.6.0 500
                                   6.5.3 500
                                   6.5.2 500
                                   6.5.1 500
                                   6.5.0 500
                                   6.4.5 500
                                   6.4.4 500
                                   6.4.3 500
                                   6.4.2 500
                                   6.4.1 500
                                   6.4.0 500
                                   6.3.7 500
                                   6.3.6 500
                                   6.3.5 500
                                   6.3.4 500
                                   6.3.3 500
                                   6.3.2 500
                                   6.3.1 500
                                   6.3.0 500
                                   6.2.5 500
                                   6.2.4 500
                                   6.2.3 500
                                   6.2.2 500
                                   6.2.1 500
                                   6.2.0 500
                                   6.1.6 500
                                   6.1.5 500
                                   6.1.4 500
                                   6.1.3 500
                                   6.1.2 500
                                   6.1.1 500
                                   6.1.0 500
                                   6.0.2 500
                                   6.0.1 500
                                   6.0.0 500
                                   5.4.5 500
                                   5.4.4 500
                                   5.4.3 500
                                   5.4.2 500
                                   5.4.1 500
                                   5.4.0 500
                                   5.3.4 500
                                   5.3.3 500
                                   5.3.2 500
                                   5.3.1 500
                                   5.3.0 500
                                   5.2.5 500
                                   5.2.4 500
                                   5.2.3 500
                                   5.2.2 500
                                   5.2.1 500
                                   5.2.0 500
                              • T TimoV
                                grafana:
                                  Installed: 9.0.3
                                  Candidate: 9.0.3
                                  Version table:
                                 *** 9.0.3 500
                                     9.0.2 500
                                     9.0.1 500
                                     9.0.0 500
                                     8.5.9 500
                                     8.5.6 500
                                     8.5.5 500
                                     8.5.4 500
                                     8.5.3 500
                                     8.5.2 500
                                     8.5.1 500
                                     8.5.0 500
                                     8.4.10 500
                                     8.4.7 500
                                     8.4.6 500
                                     8.4.5 500
                                     8.4.4 500
                                     8.4.3 500
                                     8.4.2 500
                                     8.4.1 500
                                     8.4.0 500
                                     8.3.10 500
                                     8.3.7 500
                                     8.3.6 500
                                     8.3.5 500
                                     8.3.4 500
                                     8.3.3 500
                                     8.3.2 500
                                     8.3.1 500
                                     8.3.0 500
                                     8.2.7 500
                                     8.2.6 500
                                     8.2.5 500
                                     8.2.4 500
                                     8.2.3 500
                                     8.2.2 500
                                     8.2.1 500
                                     8.2.0 500
                                     8.1.8 500
                                     8.1.7 500
                                     8.1.6 500
                                     8.1.5 500
                                     8.1.4 500
                                     8.1.3 500
                                     8.1.2 500
                                     8.1.1 500
                                     8.1.0 500
                                     8.0.7 500
                                     8.0.6 500
                                     8.0.5 500
                                     8.0.4 500
                                     8.0.3 500
                                     8.0.2 500
                                     8.0.1 500
                                     8.0.0 500
                                     7.5.16 500
                                     7.5.15 500
                                     7.5.13 500
                                     7.5.12 500
                                     7.5.11 500
                                     7.5.10 500
                                     7.5.9 500
                                     7.5.8 500
                                     7.5.7 500
                                     7.5.6 500
                                     7.5.5 500
                                     7.5.4 500
                                     7.5.3 500
                                     7.5.2 500
                                     7.5.1 500
                                     7.5.0 500
                                     7.4.5 500
                                     7.4.3 500
                                     7.4.2 500
                                     7.4.1 500
                                     7.4.0 500
                                     7.3.10 500
                                     7.3.7 500
                                     7.3.6 500
                                     7.3.5 500
                                     7.3.4 500
                                     7.3.3 500
                                     7.3.2 500
                                     7.3.1 500
                                     7.3.0 500
                                     7.2.2 500
                                     7.2.1 500
                                     7.2.0 500
                                     7.1.5 500
                                     7.1.4 500
                                     7.1.3 500
                                     7.1.2 500
                                     7.1.1 500
                                     7.1.0 500
                                     7.0.6 500
                                     7.0.5 500
                                     7.0.4 500
                                     7.0.3 500
                                     7.0.2 500
                                     7.0.1 500
                                     7.0.0 500
                                     6.7.6 500
                                     6.7.5 500
                                     6.7.4 500
                                     6.7.3 500
                                     6.7.2 500
                                     6.7.1 500
                                     6.7.0 500
                                     6.6.2 500
                                     6.6.1 500
                                     6.6.0 500
                                     6.5.3 500
                                     6.5.2 500
                                     6.5.1 500
                                     6.5.0 500
                                     6.4.5 500
                                     6.4.4 500
                                     6.4.3 500
                                     6.4.2 500
                                     6.4.1 500
                                     6.4.0 500
                                     6.3.7 500
                                     6.3.6 500
                                     6.3.5 500
                                     6.3.4 500
                                     6.3.3 500
                                     6.3.2 500
                                     6.3.1 500
                                     6.3.0 500
                                     6.2.5 500
                                     6.2.4 500
                                     6.2.3 500
                                     6.2.2 500
                                     6.2.1 500
                                     6.2.0 500
                                     6.1.6 500
                                     6.1.5 500
                                     6.1.4 500
                                     6.1.3 500
                                     6.1.2 500
                                     6.1.1 500
                                     6.1.0 500
                                     6.0.2 500
                                     6.0.1 500
                                     6.0.0 500
                                     5.4.5 500
                                     5.4.4 500
                                     5.4.3 500
                                     5.4.2 500
                                     5.4.1 500
                                     5.4.0 500
                                     5.3.4 500
                                     5.3.3 500
                                     5.3.2 500
                                     5.3.1 500
                                     5.3.0 500
                                     5.2.5 500
                                     5.2.4 500
                                     5.2.3 500
                                     5.2.2 500
                                     5.2.1 500
                                     5.2.0 500
                                @timov
                                Ja, das schaut besser aus.
                                Jetzt noch auf nodejs 16 hüpfen und du bist soweit 'auf Stand'.
                                  grafana-rpi
                                  sudo apt update
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @thomas-braun sagte in Grafana stürzt mehrfach täglich ab:
                                  -P
                                  Blöde Frage, was bedeutet dies?
                                    -P
                                    @crunchip
                                    Prune
                                    Das kratzt auch die config aus dem System.
                                    GlasfaserG crunchipC 2 Antworten Letzte Antwort
                                      @crunchip
                                      Prune
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @crunchip
                                      stimmt ... Sorry konnte ich mir nicht verkneifen :)
                                        @crunchip
                                        Prune
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @thomas-braun hätt ich auch selbst drauf kommen können
                                        Steh heut irgendwie bisserl neben mir
                                        @glasfaser sagte in Grafana stürzt mehrfach täglich ab:
                                        Hahaha😜
                                        • GlasfaserG Glasfaser
                                          @crunchip
                                          @glasfaser
                                          Zu warm...
                                          Verstehe ich nicht.
