Error 25
sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs@thomas-braun sagte in Error 25:
uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejsaarch64 /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.3 v14.19.3 6.14.17 thommy /home/thommy OK:2 https://deb.debian.org/debian bullseye InRelease OK:3 https://deb.debian.org/debian bullseye-updates InRelease OK:4 https://deb.debian.org/debian-security bullseye-security InRelease OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease OK:6 https://deb.debian.org/debian bullseye-backports InRelease OK:1 https://armbian.site-meganet.com/apt bullseye InRelease Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Alle Pakete sind aktuell. nodejs: Installiert: 14.19.3-deb-1nodesource1 Installationskandidat: 14.19.3-deb-1nodesource1 Versionstabelle: *** 14.19.3-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 https://deb.debian.org/debian bullseye/main arm64 Packages 500 https://deb.debian.org/debian-security bullseye-security/main arm64 Packages -
uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejsaarch64 /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.3 v14.19.3 6.14.17 thommy /home/thommy OK:2 https://deb.debian.org/debian bullseye InRelease OK:3 https://deb.debian.org/debian bullseye-updates InRelease OK:4 https://deb.debian.org/debian-security bullseye-security InRelease OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease OK:6 https://deb.debian.org/debian bullseye-backports InRelease OK:1 https://armbian.site-meganet.com/apt bullseye InRelease Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Alle Pakete sind aktuell. nodejs: Installiert: 14.19.3-deb-1nodesource1 Installationskandidat: 14.19.3-deb-1nodesource1 Versionstabelle: *** 14.19.3-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 https://deb.debian.org/debian bullseye/main arm64 Packages 500 https://deb.debian.org/debian-security bullseye-security/main arm64 Packagescd /opt/iobroker/ npm ls | grep ERR -
cd /opt/iobroker/ npm ls | grep ERRthommy@DietPi:~$ cd /opt/iobroker thommy@DietPi:/opt/iobroker$ npm ls | grep ERR thommy@DietPi:/opt/iobroker$ -
Hey Leute,
das Problem hatte ich schon mal "Nach Neuinstallation ERROR: Process exited with code 25".Habe alle neu Installiert und bis vor kurzem ging alles.
Konnte aber nicht mehr über den Browser auf den iobroker zugreifen.
Auch das mit dem Fix hat nicht funktioniert.Also das System neu aufgesetzt und der gleiche Fehler ist wieder das.
Wer kann mir helfen?
LG
@thomas-brodmann sagte in Error 25:
und was hattest du vor kurzem gemacht, das alles geändert hat?
wie genau?
sofort von Beginn an?
schon Backup eingespielt?bei exakt welcher Aktion und mit exakt welchen Meldungen?
thommy@DietPi:~$ cd /opt/iobroker thommy@DietPi:/opt/iobroker$ npm ls | grep ERR thommy@DietPi:/opt/iobroker$Und jetzt mal konkret:
Wann wirst du mit der Meldung konfrontiert? -
wie genau?
Ich habe über den Browser IP-Adresse:8081 versucht mich anzumelden, doch die Website konnte nicht geladen werden.@thomas-brodmann sagte in Error 25:
iob stop
iob fix
iob startwie genau?
Ja
Schon versucht, ging aber nicht.bei exakt welcher Aktion und mit exakt welchen Meldungen?
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. ───────────────────────────────────────────────────── DietPi v8.5.1 : 14:04 - Mi 15.06.2022 ───────────────────────────────────────────────────── - Device model : PINE A64 (aarch64) - CPU temp : 45 °C / 113 °F : Optimal temperature - LAN IP : 192.168.178.60 (eth0) - MOTD : Check out the DietPi v8.5 release notes: https://dietpi.com/docs/releases/v8_5/ ───────────────────────────────────────────────────── DietPi Team : https://github.com/MichaIng/DietPi#the-dietpi-project-team Image by : DietPi Core Team (pre-image: Armbian) Patreon Legends : Camry2731, Chris Gelatt Website : https://dietpi.com/ | https://twitter.com/DietPi_ Contribute : https://dietpi.com/contribute.html Web Hosting by : https://myvirtualserver.com dietpi-launcher : All the DietPi programs in one place dietpi-config : Feature rich configuration tool for your device dietpi-software : Select optimised software for installation htop : Resource monitor cpu : Shows CPU information and stats thommy@DietPi:~$ vode -v -bash: vode: Kommando nicht gefunden. thommy@DietPi:~$ node -v v14.19.3 thommy@DietPi:~$ nodejs -v -bash: nodejs: Kommando nicht gefunden. thommy@DietPi:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs [sudo] Passwort für thommy: thommy@DietPi:~$ nodejs -v v14.19.3 thommy@DietPi:~$ node -v v14.19.3 thommy@DietPi:~$ npm -v 6.14.17 thommy@DietPi:~$ curl -sLf https://iobroker.net/install.sh | bash - library: loaded Library version=2022-06-03 ========================================================================== Welcome to the ioBroker installer! Installer version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/4) ========================================================================== OK:1 https://deb.debian.org/debian bullseye InRelease OK:2 https://deb.debian.org/debian bullseye-updates InRelease OK:3 https://deb.debian.org/debian-security bullseye-security InRelease OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease OK:6 https://deb.debian.org/debian bullseye-backports InRelease OK:4 http://armbian.systemonachip.net/apt bullseye InRelease Paketlisten werden gelesen… Fertig Changing npm registry to https://registry.npmjs.org ╭───────────────────────────────────────────────────────────────── │ │ │ New major version of npm available! 6.14.17 → 8.12.1 │ │ Changelog: https://github.com/npm/cli/releases/tag/v8.12.1 │ │ Run npm install -g npm to update! │ │ │ ╰───────────────────────────────────────────────────────────────── Installed gcc-c++ ========================================================================== Creating ioBroker user and directory (2/4) ========================================================================== Created /etc/sudoers.d/iobroker Directory /opt/iobroker created ========================================================================== Installing ioBroker (3/4) ========================================================================== In file included from ../../nan/nan.h:60, from ../src/main.cpp:3: /home/thommy/.cache/node-gyp/14.19.3/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 793 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/thommy/.cache/node-gyp/14.19.3/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ 827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~ ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’ 42 | NODE_MODULE(diskusage, Init) | ^~~~~~~~~~~ In file included from ../../nan/nan.h:60, from ../src/unix_dgram.cc:5: /home/thommy/.cache/node-gyp/14.19.3/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 793 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/thommy/.cache/node-gyp/14.19.3/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ 827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’ 404 | NODE_MODULE(unix_dgram, Initialize) | ^~~~~~~~~~~ ========================================================================== Finalizing installation (4/4) ========================================================================== Enabling autostart... Usage: iobroker \{start\|stop\|restart\} Autostart enabled! Fixing directory permissions... ========================================================================== ioBroker was installed successfully Open http://192.168.178.60:8081 in a browser and start configuring! ========================================================================== You need to re-login before doing anything else on the console! thommy@DietPi:~$ thommy@DietPi:~$ mc thommy@DietPi:~$ ps -A | grep iobroker 4124 ? 00:05:11 iobroker.js-con thommy@DietPi:~$ iobroker stop iobroker controller daemon is not running thommy@DietPi:~$ iobroker fix library: loaded Library version=2022-06-03 ioBroker or some processes are still running: io.admin.0 io.backitup.0 io.discovery.0 Please stop them first and try again! thommy@DietPi:~$ iobroker stop iobroker controller daemon is not running thommy@DietPi:~$ iobroker fix library: loaded Library version=2022-06-03 ioBroker or some processes are still running: io.admin.0 io.backitup.0 io.discovery.0 Please stop them first and try again! thommy@DietPi:~$ iobroker start Starting iobroker controller daemon... iobroker controller daemon started. PID: 4801 thommy@DietPi:~$ sudo reboothttps://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
iob stop
iob fix
iob startwie genau?
Ja
ich wollte wissen was vorher war!
und dann hast du über die Konsoleiobroker statusabgefragt?@thomas-brodmann sagte in Error 25:
ich sehe da keinen Error 25
Ja habe ich, aber kein Adapter wurde gestartet.@thomas-brodmann sagte in Error 25:
Die Meldung bekomme ich, wenn ich einen Adapter über der Browser installieren möchte.ERROR: Process exited with code 25 $ iobroker add sonoff --host DietPi NPM version: 6.14.17 Installing iobroker.sonoff@2.5.1... (System call) host.DietPi Cannot install iobroker.sonoff@2.5.1: 243 ERROR: Process exited with code 25 -
Die Meldung bekomme ich, wenn ich einen Adapter über der Browser installieren möchte.ERROR: Process exited with code 25 $ iobroker add sonoff --host DietPi NPM version: 6.14.17 Installing iobroker.sonoff@2.5.1... (System call) host.DietPi Cannot install iobroker.sonoff@2.5.1: 243 ERROR: Process exited with code 25@thomas-brodmann sagte in Error 25:
ok! also nur noch scheibchenweise!
und?
iobroker add sonoff --host DietPiInstallier mal über das Terminal. Das liefert u. U. mehr Informationen.
thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi NPM version: 6.14.17 Installing iobroker.sonoff@2.5.1... (System call) host.DietPi Cannot install iobroker.sonoff@2.5.1: 243 thommy@DietPi:/opt/iobroker$ -
Error: Failed to npm install <package> (code 243)
This is likely an “EACCES” error that affects macOS and Linux users in which npm cannot write to its cache directory due to a file permission issue.
Wieder als root unterwegs gewesen?
sudo -H -u iobroker npm cache clear --forceAlternativ
iobroker stop iobroker fix iobroker start -
iobroker stop iobroker fix iobroker start@thomas-braun sagte in Error 25:
Nein, aus seinen Fehlern soll man ja lernen.
sudo -H -u iobroker npm cache clear --forcethommy@DietPi:/opt/iobroker$ sudo -H -u iobroker npm cache clear --force [sudo] Passwort für thommy: npm WARN using --force I sure hope you know what you are doing. thommy@DietPi:/opt/iobroker$Alternativ
Hatte ich auch schon gemacht.iobroker stop iobroker fix iobroker start -
Hatte ich auch schon gemacht.iobroker stop iobroker fix iobroker start@thomas-brodmann sagte in Error 25:
Häng mal deine Antworten nicht dauernd in die Zitate! wer sucht denn da?
da hat aber iobroker vorher nie wirklich gestoppt.
möglicherweise ist da dietpi etwas verschnupft. Vielleicht hilftsudo systemctl stop iobrokerwie oder warum hast du node vorher per Hand installiert?
sudo chown -R iobroker:iobroker /home/iobroker/.npm
thommy@DietPi:/opt/iobroker$ sudo chown -R iobroker:iobroker /home/iobroker/.npm chown: Zugriff auf '/home/iobroker/.npm' nicht möglich: Datei oder Verzeichnis nicht gefunden thommy@DietPi:/opt/iobroker$ -
thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi NPM version: 6.14.17 Installing iobroker.sonoff@2.5.1... (System call) host.DietPi Cannot install iobroker.sonoff@2.5.1: 243 thommy@DietPi:/opt/iobroker$@thomas-brodmann sagte in Error 25:
thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi NPM version: 6.14.17 Installing iobroker.sonoff@2.5.1... (System call) host.DietPi Cannot install iobroker.sonoff@2.5.1: 243 thommy@DietPi:/opt/iobroker$Zeige mal die Ausgabe mit debug
iobroker add sonoff --host DietPi --debug -
@thomas-braun ich hab ja schon oft gehört dass DietPi anders tickt.
kann das sein, dass der user gar nicht angelegt werden konnte?@thomas-brodmann sagte in Error 25:
iobroker add sonoff --host DietPi --debugthommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi --debug NPM version: 6.14.17 Installing iobroker.sonoff@2.5.1... (System call) npm ERR! code EACCES npm ERR! syscall mkdir npm ERR! path /home/iobroker npm ERR! errno -13 npm ERR! Error: EACCES: permission denied, mkdir '/home/iobroker' npm ERR! [OperationalError: EACCES: permission denied, mkdir '/home/iobroker'] { npm ERR! cause: [Error: EACCES: permission denied, mkdir '/home/iobroker'] { npm ERR! errno: -13, npm ERR! code: 'EACCES', npm ERR! syscall: 'mkdir', npm ERR! path: '/home/iobroker' npm ERR! }, npm ERR! isOperational: true, npm ERR! errno: -13, npm ERR! code: 'EACCES', npm ERR! syscall: 'mkdir', npm ERR! path: '/home/iobroker' npm ERR! } npm ERR! npm ERR! The operation was rejected by your operating system. npm ERR! It is likely you do not have the permissions to access this file as the current user npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check the npm ERR! permissions of the file and its containing directories, or try running npm ERR! the command again as root/Administrator. host.DietPi Cannot install iobroker.sonoff@2.5.1: 243 thommy@DietPi:/opt/iobroker$
