  • simatecS simatec
    @rotamint sorry mein Fehler ...
    f5d28735-83c5-4c93-88ba-f82380633b07-system.adapter.shuttercontrol.0 (2).json
    rotamint
    #4657
    @simatec Danke. Ich werde testen und berichten!
    • simatecS simatec
      rotamint
      #4658
      @simatec Leider nein 😧
      shuttercontrol.0
      	2022-06-01 19:32:48.761	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 36. automatic is active
      shuttercontrol.0
      	2022-06-01 19:32:33.831	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 36. automatic is active
      shuttercontrol.0
      	2022-06-01 19:32:33.678	debug	Shutter WZ_Rolladenaktor_Panoramafenster was moved manually to: 36% - prevent trigger from driving back
      shuttercontrol.0
      	2022-06-01 19:32:33.677	debug	save current height after State Check: 36% from WZ_Rolladenaktor_Panoramafenster
      shuttercontrol.0
      	2022-06-01 19:32:01.555	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 371
      shuttercontrol.0
      	2022-06-01 19:31:54.927	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 100. automatic is active
      shuttercontrol.0
      	2022-06-01 19:31:54.927	debug	Shutter state changed: WZ_Rolladenaktor_Panoramafenster old value = 36 new value = 100
      shuttercontrol.0
      	2022-06-01 19:31:54.820	debug	Shutter WZ_Rolladenaktor_Panoramafenster was moved manually to: 100% - prevent trigger from driving back
      shuttercontrol.0
      	2022-06-01 19:31:54.820	debug	save current height after State Check: 100% from WZ_Rolladenaktor_Panoramafenster
      shuttercontrol.0
      	2022-06-01 19:31:54.769	debug	WZ_Rolladenaktor_Panoramafenster Updated trigger action to Manu_Mode to prevent moving after window close
      shuttercontrol.0
      	2022-06-01 19:31:54.769	debug	WZ_Rolladenaktor_Panoramafenster drived manually to 100. Old value = 36. New value = 100
      shuttercontrol.0
      	2022-06-01 19:31:54.760	debug	Shutter state changed: WZ_Rolladenaktor_Panoramafenster old value = 36 new value = 100
      shuttercontrol.0
      	2022-06-01 19:31:53.673	debug	Sunprotect WZ_Rolladenaktor_Panoramafenster old height: 36% new height: 36%
      shuttercontrol.0
      	2022-06-01 19:31:53.672	debug	Temperature outside: 347 > 100 AND Light: 0 > 15
      shuttercontrol.0
      	2022-06-01 19:31:53.672	debug	Sunprotect for WZ_Rolladenaktor_Panoramafenster is active
      shuttercontrol.0
      	2022-06-01 19:31:53.672	debug	last automatic Action for WZ_Rolladenaktor_Panoramafenster: down_Sunprotect
      shuttercontrol.0
      	2022-06-01 19:31:53.649	info	Sunprotect #418 Set ID: WZ_Rolladenaktor_Panoramafenster value: 36%
      shuttercontrol.0
      	2022-06-01 19:31:53.649	debug	WZ_Rolladenaktor_Panoramafenster: Check basis for sunprotect. Height:100 > HeightDownSun: 36 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
      shuttercontrol.0
      	2022-06-01 19:31:51.643	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 347
      shuttercontrol.0
      	2022-06-01 19:31:46.657	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 45
      • R rotamint
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        simatecS Online
        simatecS Online
        simatec
        #4659
        @rotamint Laut dem Log ist der Check erfolgreich
        Wie gesagt ... prüfe den Aktor ... der funkt dir dazwischen.
        Es gibt hier aber einige User, die diesen Aktor nutzen.
        Es geht also damit
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        R 1 Antwort Letzte Antwort
        • simatecS simatec
          Es geht also damit
          rotamint
          schrieb am zuletzt editiert von rotamint
          #4660
          @simatec Danke an Deiner Stelle nochmals für Deinen Einsatz, der Ursache auf die Schliche zu kommen. Ich habe mich gestern und heute nochmals mit der Thematik auseinander gesetzt und komme erneut zu der Annahme, dass die Ursache nicht an meinem Aktor zu suchen ist, sondern auf einem Timingfehlverhalten im Code beruht (neuer Wert wird geliefert / von Shuttercontrol berücksichtigt bevor der aktuell laufende Prozess abgeschlossen wurde).
          Die Gründe dafür im Einzelnen:
          Die Beschattung hat in der vergangenen Zeit mit anderen "Wertelieferanten" bei gleichen Aktoren tadellos funktioniert. In fast zwei jähriger Einsatzzeit vom Shuttercontrol hatte ich noch nie einen "unbekannten" Manu_Mode vorgefunden. Damals habe ich über Innen-/Aussentemperatur und Sonnenstand gesteuert. Ohne jegliche Manu_Mode-Vorkomnisse, absolut störungsfrei!
          Das Problem ist somit ganz klar dem neuerlichen Einsatz der Lichtsensoren zuzuordnen.
          Den Github-Issues ist zu entnehmen, dass ich mit dem Problem "Manu_Mode / HM Aktor / Lichtsensor" nicht alleinig dastehe, es betrifft wohl weitere User. Teilweise wird berichtet, sie hätten keine Veränderungen am System vorgenommen, letzten Somme häbe alles hervorragend funktioniert.
          Das Fehlverhalten kann reproduziert werden:
          Der Lichtsensor hängt hierzu auf der Innenseite des Fensters und wird während der Abfahrt verdunkelt (Beschattungswert Unterschreitung) bevor die Sonnenschutzfahrt runter mit dem Abfragen der Position beendet wurde. Nachdem die Unten-Sonnenschutz-Endposition erreicht ist, wechselt der Rolladen sofort in die Gegenrichtung, Fahrt nach oben, speichert falsche Werte und wechselt in den Manu_Mode.
          shuttercontrol.0
          	2022-06-02 12:21:20.439	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          	2022-06-02 12:21:19.786	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          	2022-06-02 12:21:13.016	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          	2022-06-02 12:20:53.523	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 5497
          shuttercontrol.0
          	2022-06-02 12:20:48.523	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 3533
          shuttercontrol.0
          	2022-06-02 12:20:46.356	debug	KZ_Rolladenaktor_Balkontuere1 Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          	2022-06-02 12:20:46.354	debug	KZ_Rolladenaktor_Balkontuere1 drived manually to 5. Old value = 100. New value = 5
          shuttercontrol.0
          	2022-06-02 12:20:46.337	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 5
          shuttercontrol.0
          	2022-06-02 12:20:46.186	debug	KZ_Rolladenaktor_Balkontuere1 Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          	2022-06-02 12:20:46.184	debug	KZ_Rolladenaktor_Balkontuere1 drived manually to 5. Old value = 100. New value = 5
          shuttercontrol.0
          	2022-06-02 12:20:46.168	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 5
          shuttercontrol.0
          	2022-06-02 12:20:43.534	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 142
          shuttercontrol.0
          	2022-06-02 12:20:40.403	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 100%
          shuttercontrol.0
          	2022-06-02 12:20:40.403	debug	Temperature outside: 389 < 4750.00 OR Light: 0 < 14.25
          shuttercontrol.0
          	2022-06-02 12:20:40.403	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is not active
          shuttercontrol.0
          	2022-06-02 12:20:40.402	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: up_Sunprotect_end
          shuttercontrol.0
          	2022-06-02 12:20:39.764	info	Sunprotect #419 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 100%
          shuttercontrol.0
          	2022-06-02 12:20:38.532	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 389
          shuttercontrol.0
          	2022-06-02 12:20:33.554	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 2927
          shuttercontrol.0
          	2022-06-02 12:20:06.228	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 5%
          shuttercontrol.0
          	2022-06-02 12:20:06.227	debug	Temperature outside: 5545 > 5000 AND Light: 0 > 15
          shuttercontrol.0
          	2022-06-02 12:20:06.225	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is active
          shuttercontrol.0
          	2022-06-02 12:20:06.225	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: down_Sunprotect
          shuttercontrol.0
          	2022-06-02 12:20:06.146	info	Sunprotect #418 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 5%
          shuttercontrol.0
          	2022-06-02 12:20:06.145	debug	KZ_Rolladenaktor_Balkontuere1: Check basis for sunprotect. Height:100 > HeightDownSun: 5 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
          shuttercontrol.0
          	2022-06-02 12:20:03.092	debug	Lightsensor up DWZ_Rolladenaktor already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:20:01.074	debug	Lightsensor up BZ_Rolladenaktor already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:20:00.987	debug	Brightness State Down is: false
          shuttercontrol.0
          	2022-06-02 12:20:00.034	debug	Sun Elevation: 61.3°
          shuttercontrol.0
          	2022-06-02 12:20:00.031	debug	Sun Azimut: 151°
          shuttercontrol.0
          	2022-06-02 12:20:00.029	debug	calculate astrodata ...
          Wird ein veränderter Wert des Luxsensors erst dann verarbeitet wenn die Fahrtrichtung (egal ob auf oder ab) abgeschlossen und die korrekten Positionen gespeichert sind, funktioniert die Steuerung einwanfrei und wechselt auch nicht in den Manu_Mode:
          AB:
          shuttercontrol.0
          	2022-06-02 12:25:46.357	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 25. automatic is active
          shuttercontrol.0
          	2022-06-02 12:25:46.357	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 25
          shuttercontrol.0
          	2022-06-02 12:25:46.182	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 25. automatic is active
          shuttercontrol.0
          	2022-06-02 12:25:46.181	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 25
          shuttercontrol.0
          	2022-06-02 12:25:26.716	debug	Lightsensor up DWZ_Rolladenaktor already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:25:24.690	debug	Lightsensor up BZ_Rolladenaktor already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:25:24.578	debug	Brightness State Down is: false
          shuttercontrol.0
          	2022-06-02 12:25:22.670	debug	Lightsensor up BD_Rolladenaktor1 already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:25:20.654	debug	Lightsensor up WZ_Rolladenaktor_Terrassentuere already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:25:18.632	debug	Lightsensor up WZ_Rolladenaktor_Panoramafenster already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:25:16.617	debug	Lightsensor up WZ_Rolladenaktor_Esstisch already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:25:14.974	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 4883
          shuttercontrol.0
          	2022-06-02 12:25:14.603	debug	Lightsensor up Kue Rolladenaktor1 already up at: 100% - setting current action: up
          shuttercontrol.0
          	2022-06-02 12:25:14.576	debug	Brightness sensor value: 3340
          shuttercontrol.0
          	2022-06-02 12:25:06.237	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 25%
          shuttercontrol.0
          	2022-06-02 12:25:06.237	debug	Temperature outside: 5497 > 5000 AND Light: 0 > 15
          shuttercontrol.0
          	2022-06-02 12:25:06.236	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is active
          shuttercontrol.0
          	2022-06-02 12:25:06.235	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: down_Sunprotect
          shuttercontrol.0
          	2022-06-02 12:25:06.162	info	Sunprotect #418 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 25%
          shuttercontrol.0
          	2022-06-02 12:25:06.160	debug	KZ_Rolladenaktor_Balkontuere1: Check basis for sunprotect. Height:100 > HeightDownSun: 25 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
          shuttercontrol.0
          	2022-06-02 12:25:00.027	debug	Sun Elevation: 61.7°
          shuttercontrol.0
          	2022-06-02 12:25:00.026	debug	Sun Azimut: 153.3°
          shuttercontrol.0
          	2022-06-02 12:25:00.025	debug	calculate astrodata ...
          AUF:
          shuttercontrol.0
          	2022-06-02 12:27:36.523	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          	2022-06-02 12:27:35.890	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
          shuttercontrol.0
          	2022-06-02 12:27:14.718	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 16
          shuttercontrol.0
          	2022-06-02 12:26:56.529	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 100%
          shuttercontrol.0
          	2022-06-02 12:26:56.529	debug	Temperature outside: 9 < 4750.00 OR Light: 0 < 14.25
          shuttercontrol.0
          	2022-06-02 12:26:56.529	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is not active
          shuttercontrol.0
          	2022-06-02 12:26:56.528	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: up_Sunprotect_end
          shuttercontrol.0
          	2022-06-02 12:26:55.829	info	Sunprotect #419 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 100%
          shuttercontrol.0
          	2022-06-02 12:26:54.740	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 9
          shuttercontrol.0
          	2022-06-02 12:26:49.798	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 483
          Hierzu nochmals mein Vorschlag vom 27.05.22, unzählige Posts zuvor:
          "Ich vermute(!): Das "Problem" tritt meiner Meinung nach dann auf, wenn während eines "laufendes Prozesses" ein "neuer / anderer Prozess" angestossen wird.
          Fall A: Beispiel: Der Rolladen befindet sich in Sonnenschutzposition (und der "Prozess" wurde mit dem "Abfragen des Rolladenstatus nach X Sek" vollständig abgeschlossen.) Jetzt wird also beschattet und soweit ist alles schön.
          Jetzt meldet das Luxmeter z. B. dass die Sonne hinter einer Wolke ist (Wert < Sonnenschutzanforderung). Der "Verzögerung bis Beschattung beendet wird (Min)-Timer" läuft an und weil die Sonne beim Timerablauf immernoch verdeckt ist, wird der Rolladen jetzt nach oben gezogen.
          Während(!) dieser Fahrt nach oben, bzw. in jedem Fall aber bevor nach dieser Fahrt nach oben das "Abfragen des Rolladenstatus nach X Sek" erfolgt ist, erfolgt eine Werteänderung des Luxmeters (Wolke ist wieder weg, Wert vom Luxmeter > Auslöseschwelle).
          Der Rolladen fährt zuerst einmal hoch, dann wird sofort die Beschattung wieder eingeleitet, Richtungsumkehr und der Rolladen fährt wieder runter.
          Während dieser anschließenden Fahrt wieder nach unten wird das verzögert getimte "Abfragen des Rolladenstatus nach X Sek" (noch von der Fahrt nach oben) eingeleitet und liefert unsinnige Werte, da der Rolladen ja noch (wieder) fährt, bzw. der Aktor den Status noch nicht korrekt aktualisiert hat. Rolladen wechselt in den Manu_Mode."
          Ein ignorieren des / der (veränderten) Sensorwerte/s während der Fahrt des betreffenden Rolladens bis einschließlich der darauffolgenden Speicherung der korrekten Positionsdaten würde m. E. dieses Problem aus der Welt schaffen. Unabhängig vom Aktor.
          Klar ist auch, dass dies bei Temperaturänderungen in diesem Umfang niemals auftreten würde, kann aber hierüber genauso reproduziert werden.
          Daß die "Verzögerung nach der Beschattung" in der v.1.4.13 nicht mehr funktioniert hatte ich in einem vergangenen Threat bereits angesprochen. Ist das nur bei mir so? Ich bilde mir ein, in der v.1.4.12 entsprechend Logs noch gelesen zu haben und die Funktion war noch gegeben.
          simatecS 2 Antworten Letzte Antwort
          • R rotamint
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            AB:
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            AUF:
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            simatecS Online
            simatecS Online
            simatec
            #4661
            @rotamint Wie gesagt sehe ich deinen Lichtsensor als sehr wild von den Wertänderungen.
            Hier mal ein Script zum beruhigen der Sensorwerte.
            /********* Werte glätten und alle 5 Minuten ausgeben ***********/
            createState('0_userdata.0.shuttercontrol.illuminance', {
                role: "value",
                type: "number",
                read: true,
                write: true
            const time = 5; // Ausgabezeit des Sensorwertes in Minuten
            const sensor = 'zigbee.0.04cf8cdf3c78a785.illuminance'; // Zigbee Lichtsensor
            const illuminance = '0_userdata.0.shuttercontrol.illuminance'; // Wert für shuttercontrol Config
            on({ id: sensor, change: "ne" }, function (obj) {
                // @ts-ignore
                if (Math.round((new Date() - new Date(getState(illuminance).ts)) / 1000 / 60) > time) {
                    setState(illuminance, obj.state.val, true);
            Einfach in Javascript einen Script erstellen und reinkopieren.
            In der Config von shuttercontrol ersetzt du alle ID's des Sensors "zigbee.0.04cf8cdf3c78a785.illuminance" durch "0_userdata.0.shuttercontrol.illuminance"
            • R rotamint
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              AB:
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              AUF:
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              simatecS Online
              simatecS Online
              simatec
              #4662
              @rotamint sagte in Test Adapter shuttercontrol v1.4.x:
              Ich glaube hier liegt auch das generelle Verständnisproblem.
              Du hebelst dich ja mit der Standortauswahl selber aus.
              Der Sensor kann doch nicht drin sitzen.
              Du verdunkelst und der Sensor meldet an shuttercontrol direkt wieder hochfahren ist zu dunkel
              Ein Lichtsensor sollte draußen vor dem Rollladen sitzen.
              So drehst du dich doch immer im Kreis
              R HomoranH 2 Antworten Letzte Antwort
              • simatecS simatec
                rotamint
                #4663
                @simatec Ich habe das einzig geschrieben, um dem Fehler reproduzierbar zu machen. Zur Vereinfachung der Anschaulichkeit! So kann das Fehlverhalten mit wenigen Handgriffen nachgestellt werden. Es verhält sich identisch wenn der Sensor aussen sitzt und die Sonnenintensität den Schwellenwert während des Rolladenlaufs im Shuttercontrol ändert.
                Alternativ auf Temperatur getriggert und den Temperaturwert während der Fahrt über den Schwellwert hinaus verändern. Führt auch zum Manu_Mode.
                Wüsste wirklich nicht wie ich den Fehler deutlicher beschreiben könnte...
                • simatecS simatec
                      role: "value",
                      type: "number",
                      read: true,
                      write: true
                      // @ts-ignore
                  rotamint
                  #4664
                  @simatec Besten Dank! Ich werde es heute abend probieren...
                  • simatecS simatec
                    #4665
                    @simatec sagte in Test Adapter shuttercontrol v1.4.x:
                    aber nicht wenn der Sensor anscheinend die "Raumtemperatur" darstellt.
                    "enabled": true,
                        "shutterName": "KZ Rolladenaktor Balkontüre:1.LEVEL",
                        "name": "hm-rpc.0.OEQ0550585.1.LEVEL",
                        "triggerID": "hm-rpc.0.JEQ0152196.1.STATE",
                        "typeUp": "children",
                        "typeDown": "lightsensor",
                        **"type": "only inside temperature",**
                        "heightDownSun": "24",
                        "direction": "165",
                        "directionRange": "70",
                        "tempInside": "10000",
                    > "tempSensor": "zigbee.0.04cf8cdf3c78a785.illuminance",
                        "outsideTempSensor": "",
                        "tempOutside": "",
                        "lightSensor": "",
                      "enabled": true,
                          "direction": "165",
                          "tempOutside": "",
                          "lightSensor": "",
                      simatecS Online
                      simatecS Online
                      simatec
                      #4666
                      @homoran Doch Rainer, da sich ja bei einem Lichtsensor, egal ob als Innentemperatur konfiguriert der Wert beim schließen der Rollläden schlagartig ändert und somit die Beschattung sofort beendet wird.
                      • simatecS simatec
                        #4667
                        @simatec stimmt!
                        Das passt
                        • simatecS Online
                          simatecS Online
                          simatec
                          #4668
                          Ab sofort steht die Version 1.4.14 auf Github und in kürze auch im latest zur Verfügung.
                          Changelog
                          1.4.14 (2022-06-02)
                          • (simatec) delay for Lightsensor added
                          • (simatec) Dependencies updated
                          • (simatec) Dev-Dependencies updated
                          • R rotamint
                            simatecS Online
                            simatecS Online
                            simatec
                            #4669
                            @rotamint Den Skript brauchst im Prinzip mit Version 1.4.14 nicht mehr.
                            Habe ein ständiges senden des Lichtsensor dort abgefangen.
                            Die Werte werde nur noch alle 3 Minuten im Adapter verarbeitet.
                            Das kann auch den guten Nebeneffekt haben, dass bei einer kleinen Wolke nicht gleich hochgefahren wird.
                            Eventuell mach ich die Zeitspanne noch konfigurierbar ... mal schauen
                            • simatecS simatec
                              rotamint
                              #4670
                              Schade für Deine Mühe, aber trotzdem ein dickes Dankeschön!
                              Lernfragen:
                              1. Habe den Lichtsensor als "Innentemperatur" konfiguriert, da meines Wissens nach der Lichtsensor nicht alleinig, sondern nur in Kombination mit einem weiteren Sensor abgefragt wird. Wie erkennt der Shuttercontrol, dass sich hinter der Innentemperatur ein Lichtsensor versteckt? Oder gilt die 3-Minuten-Abfrage für alle hinterlegten Sensoren?
                              2. Soll ich weiterhin mit der von Dir übersendeten Config arbeiten, oder zu meiner ursprünglichen zurück kehren (was ist in Deiner Config anders / besser / sauberer)?
                              3. Funktioniert die Funktion "Verzögerung nach Beschattungsende" in der 1.4.14 wieder? Bei 1.4.13 sind die Rolläden immer sofort gefahren, unabhängig davon welchen Zeitwert ich eingstellt hatte.
                              ... Ich bin voller Hoffnung ;-)
                              Auf jeden Fall danke ich Dir für Deine Geduld und Engagement! Wenngleich mich eine gewisse Sturheit des "mich nicht verstehen wollens" zeitweise nicht losgelassen hat ;-)
                              Spende ist nochmals raus an Dich, das ist Ehrensache! Deine "Betreuung" sowieso unbezahlbar.
                              Werde wieder Berichten 🤦
                              Danke nochmals! LG S.
                              HomoranH simatecS 2 Antworten Letzte Antwort
                              • R rotamint
                                Lernfragen:
                                #4671
                                und genau das wird dein Problem sein, weil:
                                egal wie er eingebunden wird, ist er als Außensensor konzipiert.
                                  rotamint
                                  #4672
                                  @homoran sagte in Test Adapter shuttercontrol v1.4.x:
                                  Würde hinter dem Innentemperatursensor auch wirklich ein Thermometer sitzen, wäre dies doch bei einem plötzlichen Temperaturabfall (z. b. Lüften im Winter) exakt der selbe Ablauf?!?
                                  Welchen Unterschied macht es, ob es sich um einen Innen- oder Außensensor handelt? Die Dokumentation lässt darüber gar nichts durchblicken. Für mein Verständnis ist es so, dass die Sensoren eben mit Namen / Vorschlägen unveränderbar vorbelegt sind, was sich letztendlich dahinter verbirgt kann aber durch den User völlig flexibel belegt werden? Oder habe ich da was falsch interpretiert?
                                  LG S.
                                  • R rotamint
                                    LG S.
                                    #4673
                                    aber die Temperatur ändert dich nicht weil der Rollladen fährt.
                                    weil die Helligkeit, die zu einer Beschattung führt nicht durchvdie Beschattungsfahrt verändert wird, wenn der Sensor draußen ist.
                                    • rtwlR Offline
                                      rtwlR Offline
                                      rtwl
                                      #4674
                                      kurze Zwischenfrage:
                                      kommt man eigentlich manuell irgendwie aus dem Manu_mode raus?
                                      wenn man morgens bevor die Beschattung greift eine Jalousie bewegt hat, landet man sofort im manu_mode was leider zur Folge hat, dass nachmittags (wenn beschattet werden soll) die eine Jalousie nicht runter fährt.
                                      kann man das irgendwie einzeln pro Jalousie einstellen?
                                      oder generell zb um 12 Uhr wieder alle auf automatisch stehen?
                                      -Peter
                                      • rtwlR rtwl
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        #4675
                                        @rtwl Dafür gibt es die Button Funktionen
                                        rtwlR 1 Antwort Letzte Antwort
                                        • R rotamint
                                          Lernfragen:
                                          simatecS Online
                                          simatecS Online
                                          simatec
                                          #4676
                                          Gerne …
                                          Lernfragen:
                                          Du brauchst dafür den Wert des Lichtsensors in Shuttercontrol.
                                          Setze den Sensor bei der Config dann bei beiden Objekten ein. Den Wert für für z.B. Innentemp setze auf eine Wert, der immer ausgelöst wäre.
                                          1. Soll ich weiterhin mit der von Dir übersendeten Config arbeiten, oder zu meiner ursprünglichen zurück kehren (was ist in Deiner Config anders / besser / sauberer)?
                                          Ja nimm die Config bitte.
                                          1. Funktioniert die Funktion "Verzögerung nach Beschattungsende" in der 1.4.14 wieder? Bei 1.4.13 sind die Rolläden immer sofort gefahren, unabhängig davon welchen Zeitwert ich eingstellt hatte.
                                          Das muss ich mir noch anschauen
                                          Nein keine Sturheit, es ist nur oft schwierig zu verstehen, wo genau das Problem liegt, wenn man es nicht selber testen kann.
                                          In meinen Testumgebungen kann ich viel simulieren.
                                          Aber wenn ich mit dem lesen deine lange Texte fertig bin und gerade versuche nachzustellen, war dein Post editiert. Das mehrmals hintereinander.
                                          Das hat mich teilweise verzweifeln lassen.
                                          Ich habe gerade versucht zu deuten, wo dein Problem liegt, schwubs war der Text ein anderer
                                          Vielen dank
