  4. js-controller 4.0.x jetzt für alle User im STABLE!
501 Beiträge 83 Kommentatoren 200.3k Aufrufe 58 Beobachtet
  • apollon77A apollon77
    @tomk81 Naja er ist jetzt gerade "kaputt" ... Das müssen wir zuerst fixen. Na dann versuchen wirs mal klein.
    versuchen wir die 3.1.6
    am Ende ists der npm befehl mit iobroker.js-controller@3.1.6
    Geht das?
    Tomk81
    #455
    @apollon77 said in js-controller 4.0.x jetzt für alle User im STABLE!:
    Geht das?
    pi@raspberrypi:/opt/iobroker $ /opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.1.6
    -bash: /opt/iobroker: Is a directory
    geht leider garnicht
    • T Tomk81
      Geht das?
      #456
      @tomk81 Ja schau mal was Du geschrieben hasdt ... hast zuviel kopiert ... durchatmen und langsam machen
        Tomk81
        #457
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.1.6
        > iobroker.js-controller@3.1.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.16
        > iobroker.js-controller@3.1.6 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short).                                                      Generating new Certificate!
        object system.certificates updated
        > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme/node_modules/acme-v2
        > node scripts/postinstall
        Greenlock and ACME.js v3 are on the way!
        Watch for updates at https://indiegogo.com/at/greenlock
        > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/greenlock/node_modules/acme-v2
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch"                                                     :"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/acme-v2/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/lie/package.json'
        + iobroker.js-controller@3.1.6
        added 45 packages from 82 contributors in 33.785s
        114 packages are looking for funding
          run `npm fund` for details
        • T Tomk81
          #458
          @tomk81 Ok, besser. Was sagt "iob status" und "iob setup custom" jetzt?
            Tomk81
            schrieb am zuletzt editiert von Tomk81
            #459
            pi@raspberrypi:/opt/iobroker $ iob status
            At least one iobroker host is running.
            Objects type: file
            States  type: file
            • T Tomk81
              Objects type: file
              States  type: file
              #460
              @tomk81 Warum läuft der????
              ps auxww|grep io
              T 2 Antworten Letzte Antwort
                ps auxww|grep io
                Tomk81
                #461
                ps auxww|grep io
                hätte ich den vorher stoppen müssen?
                Wie auch immer es jetzt passiert ist, ich hab jetzt die 4. Version drauf
                iob setup custom läuft noch
                • apollon77A Offline
                  #462
                  ÄÄÄÄHHMMM ... ja najk lar solltest DU ihn vorher stoppen ...
                  Und was heisst "iob custom läuft noch"?
                    ps auxww|grep io
                    Tomk81
                    #463
                    ps auxww|grep io
                    oder muss ich hier etwas auswählen?
                    Current configuration:
                    - Objects database:
                      - Type: file
                      - Host/Unix Socket: 127.0.0.1
                      - Port: 9001
                    - States database:
                      - Type: file
                      - Port: 9000
                    - Data Directory: ../../iobroker-data/
                    Type of objects DB [(f)ile, (r)edis], default [file]:
                    • T Tomk81
                      ps auxww|grep io
                      - Objects database:
                        - Type: file
                        - Port: 9001
                      - States database:
                        - Type: file
                        - Port: 9000
                      #464
                      @tomk81 nein CTRL-C und abbrechen. wollte nur die Daten sehen.
                      DU hast es ja selbst gesagt ... Dein ganzer Fehler war die Anleitungen von Thomas von oben nicht zu machen ... da war übert all ein "iob stop" VOR dem upgrade ...
                      Dann hättre auch der 4er upgrade direkt funktioniert
                        Tomk81
                        #465
                        da oben hab ich es noch gemacht. jetzt zum schluss hab ich nicht mehr dran gedacht. hab jetzt auf jeden fall die neuste version drauf obwohl ich doch die 3er zum schluss versucht habe. muss ich jetzt noch was machen?
                        apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                        • T Tomk81
                          #466
                          @tomk81 Ne wenn hast du jetzt die 3.1.6 drauf.
                          Sauber stoppen und dann nochmal den 4er Upgrade versuchen
                            Tomk81
                            #467
                            also
                            iobroker stop
                            iobroker update
                            iobroker upgrade
                            und zu schluss
                            iobroker start
                            ist das richtig?
                            • T Tomk81
                              #468
                              @tomk81 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                              Ich würde die Sache dann jetzt auch Rund machen und nodejs14 installieren.
                              Vorher zeig dir Ausgabe von
                              iobroker update -i
                              • T Tomk81
                                also
                                iobroker stop
                                iobroker update
                                iobroker upgrade
                                und zu schluss
                                iobroker start
                                ist das richtig?
                                #469
                                @tomk81 Das macht alles ausser den js-controller ... upgrade self ... aber bei dir würde ich lieber mot dem npm befehl auf die 4.0.23 gehen und njicht mich upgrade self
                                  Tomk81
                                  #470
                                  Sorry aber ihr verwirrt mich. Bitte nochmal für dumme
                                  bis jetzt hab ich den nur gestoppt
                                  • T Tomk81
                                    #471
                                    @tomk81 Jetzt mach den npm befehl von oben im richtigen verzeichnis mit @4.0.23 am Ende
                                    Dann iob status checken ... dann iob update und iob upgrade um alle Adapter zu aktualisieren
                                    • T Tomk81
                                      #472
                                      @tomk81 .
                                      iobroker stop
                                      iobroker update
                                      iobroker upgrade
                                      iobroker start
                                      iobroker status
                                        @tomk81 .
                                        iobroker stop
                                        iobroker update
                                        iobroker upgrade
                                        iobroker start
                                        iobroker status
                                        Tomk81
                                        #473
                                        @thomas-braun said in js-controller 4.0.x jetzt für alle User im STABLE!:
                                        iobroker status
                                        pi@raspberrypi:/opt/iobroker $ iobroker status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        • T Tomk81
                                          iobroker status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          #474
                                          @tomk81
                                          Und die anderen Befehle?
