  4. js-controller 4.0.x jetzt für alle User im STABLE!
501 Beiträge 83 Kommentatoren 200.3k Aufrufe 58 Beobachtet
    @tomk81
    Die Fehler müssten da eigentlich alle weg...
    Versuch mal
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller@4.0.23
    Tomk81
    #446
    @thomas-braun said in js-controller 4.0.x jetzt für alle User im STABLE!:
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@4.0.23
    > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    ReplyError: Error scan NOT SUPPORTED
        at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
        at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at processTicksAndRejections (internal/process/task_queues.js:97:5) {
      command: {
        args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/acme-v2/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/lie/package.json'
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-05-11T20_00_03_043Z-debug.log
    • T Tomk81
              throw e;
        command: {
      npm ERR! errno 1
      npm ERR!
      #447
      @tomk81
      Ich würde vermuten, das hast mit dem Datenbanktypen zu tun.
      Was setzt du denn bisher ein?
      file/file oder irgendwas mit redis?
        @tomk81
        Tomk81
        #448
        @tomk81
        was meinst du damit?
        Entschuldige die blöden Fragen
        • apollon77A Offline
          #449
          Ok, ist das ein Single-Host System oder Multi Host?
          Bitte mal "iob setup custom" Ausgabe zeigen.
          Der Fehle roben kann an sich nur passieren wenn die "neue" DB Klassen gehen eine alte auf neue DB connecten. Das darf nicht passieren.
          Ist halt schon krass von 2.0 auf die 4.0 zu gehen ... wäre über die 3.x in über ein paar Schritte einfacher gewesen.
          T Thomas BraunT 3 Antworten Letzte Antwort
          • apollon77A apollon77
            Tomk81
            schrieb am zuletzt editiert von Tomk81
            #450
            @apollon77 said in js-controller 4.0.x jetzt für alle User im STABLE!:
            iob setup custom
            internal/modules/cjs/loader.js:818
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                at internal/main/run_main_module.js:17:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            Single Host
            wenn ich wüsste wie ich die 3 drauf bekomme, dann würde ich es machen. Wäre über jede Hilfe dankbar
              #451
              @apollon77 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
              So oft ist das auch noch nicht vorgekommen. Hatte auch überlegt einen Zwischenschritt über 3.x einzulegen. Aber im Eröffnungspost steht, dass man auch von 2 auf 4 springen könnte.
              • T Tomk81
                iob setup custom
                  throw err;
                  requireStack: []
                Single Host
                #452
                @tomk81 Naja er ist jetzt gerade "kaputt" ... Das müssen wir zuerst fixen. Na dann versuchen wirs mal klein.
                versuchen wir die 3.1.6
                am Ende ists der npm befehl mit iobroker.js-controller@3.1.6
                Geht das?
                  Tomk81
                  #453
                  Was muss ich tun dass es überhaupt läuft. nach dem letzten Befehl geht nichts mehr
                    #454
                    @thomas-braun Ja technisch spricht an sich nichts dagegen ... mich wundert der Fehler auch ... wie gesagt sollte das nur passieren wenn irgendwo was läuft ... strange
                      Geht das?
                      Tomk81
                      #455
                      Geht das?
                      pi@raspberrypi:/opt/iobroker $ /opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.1.6
                      -bash: /opt/iobroker: Is a directory
                      geht leider garnicht
                      • T Tomk81
                        Geht das?
                        #456
                        @tomk81 Ja schau mal was Du geschrieben hasdt ... hast zuviel kopiert ... durchatmen und langsam machen
                          Tomk81
                          #457
                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.1.6
                          > iobroker.js-controller@3.1.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                          > iobroker.js-controller@3.1.6 install /opt/iobroker/node_modules/iobroker.js-controller
                          Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short).                                                      Generating new Certificate!
                          object system.certificates updated
                          > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme/node_modules/acme-v2
                          > node scripts/postinstall
                          Greenlock and ACME.js v3 are on the way!
                          Watch for updates at https://indiegogo.com/at/greenlock
                          > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/greenlock/node_modules/acme-v2
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch"                                                     :"any"} (current: {"os":"linux","arch":"arm"})
                          + iobroker.js-controller@3.1.6
                          added 45 packages from 82 contributors in 33.785s
                          114 packages are looking for funding
                            run `npm fund` for details
                          • T Tomk81
                            #458
                            @tomk81 Ok, besser. Was sagt "iob status" und "iob setup custom" jetzt?
                              Tomk81
                              #459
                              pi@raspberrypi:/opt/iobroker $ iob status
                              At least one iobroker host is running.
                              Objects type: file
                              States  type: file
                              • T Tomk81
                                Objects type: file
                                States  type: file
                                #460
                                @tomk81 Warum läuft der????
                                ps auxww|grep io
                                T 2 Antworten Letzte Antwort
                                  ps auxww|grep io
                                  Tomk81
                                  #461
                                  ps auxww|grep io
                                  hätte ich den vorher stoppen müssen?
                                  Wie auch immer es jetzt passiert ist, ich hab jetzt die 4. Version drauf
                                  iob setup custom läuft noch
                                    #462
                                    ÄÄÄÄHHMMM ... ja najk lar solltest DU ihn vorher stoppen ...
                                    Und was heisst "iob custom läuft noch"?
                                      ps auxww|grep io
                                      Tomk81
                                      #463
                                      ps auxww|grep io
                                      oder muss ich hier etwas auswählen?
                                      Current configuration:
                                      - Objects database:
                                        - Type: file
                                        - Host/Unix Socket: 127.0.0.1
                                        - Port: 9001
                                      - States database:
                                        - Type: file
                                        - Port: 9000
                                      - Data Directory: ../../iobroker-data/
                                      Type of objects DB [(f)ile, (r)edis], default [file]:
                                      • T Tomk81
                                        ps auxww|grep io
                                        - Objects database:
                                          - Type: file
                                          - Port: 9001
                                        - States database:
                                          - Type: file
                                          - Port: 9000
                                        #464
                                        @tomk81 nein CTRL-C und abbrechen. wollte nur die Daten sehen.
                                        DU hast es ja selbst gesagt ... Dein ganzer Fehler war die Anleitungen von Thomas von oben nicht zu machen ... da war übert all ein "iob stop" VOR dem upgrade ...
                                        Dann hättre auch der 4er upgrade direkt funktioniert
                                          Tomk81
                                          #465
                                          da oben hab ich es noch gemacht. jetzt zum schluss hab ich nicht mehr dran gedacht. hab jetzt auf jeden fall die neuste version drauf obwohl ich doch die 3er zum schluss versucht habe. muss ich jetzt noch was machen?
                                          apollon77A Thomas BraunT 2 Antworten Letzte Antwort
