  4. Anfrage Tahoma/Somfy IO Adapter
611 Beiträge 103 Kommentatoren 306.3k Aufrufe 86 Beobachtet
  • StrathColeS StrathCole
    @mike2712 nein. Dann hat das Update nicht geklappt
    mike2712
    #275
    @strathcole habe das Update nochmals ausgeführt, für mich sieht es so aus als ob das sauber durchlief, immer noch keine Einstellung für die Box PIN, Browser Sitzung aktualisiert, etc.
    $ iobroker url https://github.com/StrathCole/ioBroker.tahoma.git --host iobroker
    install StrathCole/ioBroker.tahoma#69c66ee66b944a873083cd9e95c03722c77c4d24
    NPM version: 6.14.15
    Installing StrathCole/ioBroker.tahoma#69c66ee66b944a873083cd9e95c03722c77c4d24... (System call)
    > node-aead-crypto@2.2.1 preinstall /opt/iobroker/node_modules/node-aead-crypto> node lib/preinstall.js
    + iobroker.tahoma@0.6.1
    updated 1 package in 31.393s
    48 packages are looking for funding run `npm fund` for details
    upload [14] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [13] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [11] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [10] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [8] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [7] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [5] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [4] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/index_m.html index_m.html text/html
    upload [3] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/jsonConfig.json jsonConfig.json application/json
    upload [2] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/style.css style.css text/css
    upload [1] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/tahoma.png tahoma.png image/png
    upload [0] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/words.js words.js application/javascript
    Update "system.adapter.tahoma.0"
    Process exited with code 0
    ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
    StrathColeS 1 Antwort Letzte Antwort
    • M mike2712
      StrathColeS Offline
      StrathColeS Offline
      StrathCole
      schrieb am zuletzt editiert von StrathCole
      #276
      @mike2712 immer noch die falsche Adapter URL. Du musst schon die vollständige nehmen, die ich gepostet habe.
      SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
        @mike2712 nein, diese Adapterversion: https://github.com/StrathCole/ioBroker.tahoma/tree/local-api
        mike2712
        #277
        @strathcole sagte in Anfrage Tahoma/Somfy IO Adapter:
        habe diesen link angeklickt, dann den Code kopiert und das installiert, wo habe ich den jetzt meine Blockade ?
        • M mike2712
          StrathColeS Offline
          StrathColeS Offline
          StrathCole
          #278
          @mike2712 du musst einfach nur meinen Link in Iobroker bei Adapterinstallation eingeben. Nix vorher aufrufen und woanders herkopieren.
          M 2 Antworten Letzte Antwort
            mike2712
            #279
            Danke, jetzt hat es geklappt, habe ich wohl etwas zu kompliziert gedacht, jetzt teste ich später weiter, aber die Einstellungen sind jetzt da. DANKE
              mike2712
              schrieb am zuletzt editiert von mike2712
              #280
              @strathcole Denke das mit dem Token hat geklappt, aber es gibt doch einiger Meldungen
              tahoma.0
              2022-04-23 10:46:09.796	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup/gateways with payload:{}
              tahoma.0
              2022-04-23 10:45:59.782	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
              tahoma.0
              2022-04-23 10:45:59.781	debug	Update gateway status for id undefined
              tahoma.0
              2022-04-23 10:45:29.778	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup/gateways with payload:{}
              tahoma.0
              2022-04-23 10:45:19.856	warn	{"error":{"errno":-3001,"code":"EAI_AGAIN","syscall":"getaddrinfo","hostname":"gateway-2006-2989-5271.local"}}
              tahoma.0
              2022-04-23 10:45:19.856	warn	setup failed!
              tahoma.0
              2022-04-23 10:45:19.854	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup with payload:{}
              tahoma.0
              2022-04-23 10:45:19.761	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
              tahoma.0
              2022-04-23 10:45:19.760	debug	Update gateway status for id undefined
              tahoma.0
              2022-04-23 10:45:09.872	debug	stateChange tahoma.0.update {"val":false,"ack":true,"ts":1650703509865,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1639459009806}
              tahoma.0
              2022-04-23 10:45:09.868	debug	stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1650703509858,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1650703509858}
              tahoma.0
              2022-04-23 10:45:09.761	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup with payload:{}
              tahoma.0
              2022-04-23 10:45:09.759	info	Using stored bearer token 6263bc8bf4649771a996
              tahoma.0
              2022-04-23 10:45:09.753	debug	[START] Started Adapter
              • M mike2712
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                tahoma.0
                StrathColeS Offline
                StrathColeS Offline
                StrathCole
                #281
                @mike2712 du solltest die Logs anonymisiert posten. Da steht deine Pin drin.
                Die Meldung heißt, dass deine Box über die URL nicht erreichbar ist. Entweder der Entwicklermodus ist nicht aktiv, die IP ist lokal nicht erreichbar oder gesperrt, oder die Firmware der Box nicht aktuell.
                  mike2712
                  #282
                  @strathcole okay, danke, dann werde ich mal weiter danach schauen
                    mike2712
                    #283
                    die App sagt ist auf dem aktuellsten Stand, Version 1.9.0 März 22, im Web ist der Modus aktiviert.
                    Folgende Einträge kommen kontinuierlich im Log:
                    tahoma.0
                    2022-04-23 15:48:35.106	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-****-*****-*****.local, request path: setup/gateways with payload:{}
                    tahoma.0
                    2022-04-23 15:48:25.091	debug	GET request on https://gateway-****-*****-*****.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                    tahoma.0
                    2022-04-23 15:48:25.091	debug	Update gateway status for id undefined
                      @willi-wunder Hi. Vermutlich hast du den Entwicklermodus nicht aktiviert. Siehe meinen Beitrag und die Infos auf der Somfy Seite
                      W Offline
                      W Offline
                      Willi-Wunder
                      #284
                      @strathcole
                      Vielen Dank, den Entwicklermodus hatte ich ganz überlesen, jetzt funktioniert es. :-)
                      Damit sollten die erfolglosen Anmeldeversuche hoffentlich tabu sein. Sehr cool.
                      G 1 Antwort Letzte Antwort
                      • W Willi-Wunder
                        @strathcole
                        gammler2003
                        schrieb am zuletzt editiert von gammler2003
                        #285
                        @StrathCole Vielen Dank dir auch für den Hinweis. Ich habe alle Schritte wie von dir beschrieben durchgeführt und es funktioniert. So ganz sicher bin ich mir aber nicht, ob die Tahoma tatsächlich lokal angesprochen wird oder doch über die Cloud. Kann man das irgendwo sehen?
                        Edit: Habe mittlerweile herausgefunden, dass mit der neuen Installation die auf der Tahoma konfigurierten Szenen nicht funktionieren ("Action Groups" im Adapter). Also habe ich den Adapter deinstalliert und aus dem Stable neu geladen - jetzt geht wieder alles wie gehabt (und ich nutze wieder den Weg über die Cloud).
                        • G gammler2003
                          StrathColeS Offline
                          StrathColeS Offline
                          StrathCole
                          #286
                          @gammler2003 Action groups scheint es zumindest derzeit nur in der Cloud zu geben.
                          Wenn du die Pin aus der Konfig nimmst, sollte aber Cloud auch weiterhin gehen.
                          G 2 Antworten Letzte Antwort
                            gammler2003
                            #287
                            @strathcole Hi, nur die Pin rausnehmen hatte ich zuerst probiert, hat aber leider nicht den gewünschten Erfolg gebracht. Ich meine der Adapter hat lediglich ‚gemeckert‘, dass ihm die Pin fehlt. Kann aber auch sein, dass ich zu ungeduldig war.
                            Kann man den irgendwo sehen, welchen Weg der Adapter gerade nimmt (Cloud vs. lokal)? Fände ich zumindest nicht schlecht, die Info als Objekt oder im Log zu haben. Auch die Möglichkeit des einfachen Umschaltens zwischen den beiden Wegen wäre klasse.
                            Viele Grüße
                            StrathColeS W 2 Antworten Letzte Antwort
                            • G gammler2003
                              Viele Grüße
                              StrathColeS Offline
                              StrathColeS Offline
                              StrathCole
                              #288
                              @gammler2003 Nein, eine Anzeige gibts derzeit nicht. Vielleicht hat @Excodibur in nächster Zeit noch die Zeit, meinen Code zu verbessern. Mir ging es (erst einmal) nur darum, die lokale API zu unterstützen. Aus Zeitmangel kann ich selbst nicht viel machen gerade.
                              • G gammler2003
                                Viele Grüße
                                W Offline
                                W Offline
                                wusa
                                #289
                                @gammler2003
                                Ich habe mich auch gefragt, welchen Weg der Adapter jetzt nimmt und ob ich sichergehen kann, dass es jetzt auch wirklich lokal funktioniert.
                                Ich bin dann radikal hergegangen und habe in meiner Firewall der Tahoma-Box keinen Zugriff auf das Internet gegeben. Lokal habe ich die Box aber weiterhin erreichbar gemacht.
                                Die LED von der Tahoma-Box war dann bei mir auch rot, was ja bedeutet, dass keine Internetverbindung bestellt.
                                Dann habe ich über den ioBroker Befehle an die Tahoma-Box geschickt (Rollo auf, Rollo zu) und siehe da, es funktioniert weiterhin. So weiß ich jetzt ziemlich sicher, dass Lokal alles funktioniert.
                                Ich hatte auch immer wieder Probleme mit der Cloud. Das sollte jetzt denke ich aber gegessen sein. @StrathCole Danke!
                                • W wusa
                                  @gammler2003
                                  StrathColeS Offline
                                  StrathColeS Offline
                                  StrathCole
                                  #290
                                  @wusa sagte in Anfrage Tahoma/Somfy IO Adapter:
                                  Genau das ist auch meine Hoffnung. Vielleicht kommen ja noch ein paar Funktionen lokal, die derzeit nicht funktionieren oder nur via Workaround (Event-Listener, Szenen …).
                                  Zumindest die Event-Listener sollen angeblich schon gepatcht sein und beim nächsten Firmwareupdate laufen. Der Adapter sollte das schon drin haben und dann automatisch nutzen.
                                  W 1 Antwort Letzte Antwort
                                    W Offline
                                    W Offline
                                    wusa
                                    #291
                                    @strathcole
                                    Event-Listener sagt mir z.B. leider gar nichts. Ich vermute, dann habe ich das bisher auch nicht genutzt.
                                    Kannst du mir kurz sagen, was damit gemeint ist? Vielleicht "brauche" ich es wenn es funktioniert 😉
                                    • W wusa
                                      @strathcole
                                      StrathColeS Offline
                                      StrathColeS Offline
                                      StrathCole
                                      #292
                                      @wusa das ist eine interne Geschichte, damit er nicht alle X Sekunden alle Geräte anfragen muss, sondern nur die Ereignisse, die seit der letzten Anfrage passiert sind. Via Cloud geht das, lokal ist da ein Bug drin, sodass ich einen Fallback nutzen musste.
                                        W Offline
                                        W Offline
                                        wusa
                                        schrieb am zuletzt editiert von wusa
                                        #293
                                        @strathcole
                                        Ok, Danke
                                        Ich bin relativ froh, dass das ganze jetzt lokal funktioniert.
                                        Hier im Forum ist ja zu lesen, dass einige User unter anderem auch ich schon paar mal bei Somfy /Tahoma gesperrt wurde. Da kam dann die Meldung "Auf Ebene des Servers ist ein Fehler aufgetreten".
                                        Man konnte das dann nur durch Anrufen bei Somfy lösen.
                                        Wenn ich das so lesen, dass so viele Anfragen bei Somfy eingehen, dann kann ich mir gut vorstellen, dass manchmal jemand gesperrt wird. Das solle aber vermutlich auch bald der Vergangenheit angehören, wenn nicht mehr so viele Anfrage bei Somfy eingehen.
                                        Server werden dann ja auch ganz schön entlastet.
                                        • W wusa
                                          @strathcole
                                          Ok, Danke
                                          derdominik
                                          #294
                                          Hallo. Voller Freude bin ich auf die Suche nach dem Developer-Mode meiner Connexoon gegangen. Finde ihn aber nicht.
                                          Gibt es den nur bei der großen Tahoma Box?
                                          StrathColeS 2 Antworten Letzte Antwort
