  4. Anfrage Tahoma/Somfy IO Adapter
611 Beiträge 103 Kommentatoren 306.3k Aufrufe 86 Beobachtet
  • W Willi-Wunder
    @StrathCole
    Das wäre ja Klasse wenn die Box im eigenen Netzwerk jetzt alleine funktioniert, hab ich doch richtig verstanden, oder?
    Bekomme diese Warnhinweise:
    tahoma.0
    	2022-04-22 22:31:16.644	warn	Body: {"errorCode":"RESOURCE_ACCESS_DENIED","error":"Access denied to gateway #xxxx-xxxx-xxxx for action ADD_TOKEN"}
    tahoma.0
    	2022-04-22 22:31:16.643	warn	Response: {"statusCode":400,"body":{"errorCode":"RESOURCE_ACCESS_DENIED","error":"Access denied to gateway #xxxx-xxxx-xxxx for action ADD_TOKEN"},"headers":{"date":"Fri, 22 Apr 2022 20:31:16 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains, max-age=31536000 ; includeSubDomains","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","x-xss-protection":"1; mode=block","x-frame-options":"DENY","x-content-type-options":"nosniff","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"ha101-1.overkiz.com","port":443,"hostname":"ha101-1.overkiz.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI/config/xxxx-xxxx-xxxx/local/tokens","path":"/enduser-mobile-web/enduserAPI/config/xxxx-xxxx-xxxx/local/tokens","href":"https://ha101-1.overkiz.com/enduser-mobile-web/enduserAPI/config/xxxx-xxxx-xxxx/local/tokens"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","cookie":"JSESSIONID=22366DE68EB1D71B7DA49F7D81AAB7EB","accept":"application/json","content-type":"application/json","content-length":71}}}
    tahoma.0
    	2022-04-22 22:31:16.643	warn	error during request: null, request path: config/xxxx-xxxx-xxxx/local/tokens with payload:{"label":"Toto token","token":"62631094f9e9d16xxxx","scope":"devmode"}
    Kann damit leider nix anfangen.
    Gruß Willi
    StrathColeS Offline
    StrathColeS Offline
    StrathCole
    #268
    @willi-wunder Hi. Vermutlich hast du den Entwicklermodus nicht aktiviert. Siehe meinen Beitrag und die Infos auf der Somfy Seite
    SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
    W 1 Antwort Letzte Antwort
    • StrathColeS StrathCole
      @mike2712 das ist die ganz falsche URL für die Installation. Bitte noch mal meinen Beitrag lesen.
      mike2712
      #269
      @strathcole
      Also der normale Adapter, den anderen Link, das habe ich gemacht, bin auch im Expertenmodus, finde aber nicht die Stelle wo die Box PIN eingetragen werden muss.
      ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
      StrathColeS 1 Antwort Letzte Antwort
      • M mike2712
        @strathcole
        StrathColeS Offline
        StrathColeS Offline
        StrathCole
        #270
        @mike2712 nein, diese Adapterversion: https://github.com/StrathCole/ioBroker.tahoma/tree/local-api
        M 2 Antworten Letzte Antwort
          mike2712
          #271
          @strathcole danke, das konnte ich fehlerfrei installieren, aber ich habe keinen neuen Adapter hinzubekommen, in dem alten finde ich auch keine Einstellungen für die Box bin, irgendwie sehe ich vor lauter Bäumen den Wald nicht ?
          • M mike2712
            StrathColeS Offline
            StrathColeS Offline
            StrathCole
            schrieb am zuletzt editiert von StrathCole
            #272
              mike2712
              #273
              @strathcole die Einstellung habe ich nicht, muss ich eine weitere Instanz installieren ?
              • M mike2712
                StrathColeS Offline
                StrathColeS Offline
                StrathCole
                #274
                @mike2712 nein. Dann hat das Update nicht geklappt
                  mike2712
                  #275
                  @strathcole habe das Update nochmals ausgeführt, für mich sieht es so aus als ob das sauber durchlief, immer noch keine Einstellung für die Box PIN, Browser Sitzung aktualisiert, etc.
                  $ iobroker url https://github.com/StrathCole/ioBroker.tahoma.git --host iobroker
                  install StrathCole/ioBroker.tahoma#69c66ee66b944a873083cd9e95c03722c77c4d24
                  NPM version: 6.14.15
                  Installing StrathCole/ioBroker.tahoma#69c66ee66b944a873083cd9e95c03722c77c4d24... (System call)
                  > node-aead-crypto@2.2.1 preinstall /opt/iobroker/node_modules/node-aead-crypto> node lib/preinstall.js
                  + iobroker.tahoma@0.6.1
                  updated 1 package in 31.393s
                  48 packages are looking for funding run `npm fund` for details
                  upload [14] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [13] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [12] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [11] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [10] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [9] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [8] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [7] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [6] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [5] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [4] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/index_m.html index_m.html text/html
                  upload [3] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/jsonConfig.json jsonConfig.json application/json
                  upload [2] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/style.css style.css text/css
                  upload [1] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/tahoma.png tahoma.png image/png
                  upload [0] tahoma.admin /opt/iobroker/node_modules/iobroker.tahoma/admin/words.js words.js application/javascript
                  Update "system.adapter.tahoma.0"
                  Process exited with code 0
                  • M mike2712
                    StrathColeS Offline
                    StrathColeS Offline
                    StrathCole
                    #276
                    @mike2712 immer noch die falsche Adapter URL. Du musst schon die vollständige nehmen, die ich gepostet habe.
                      mike2712
                      #277
                      @strathcole sagte in Anfrage Tahoma/Somfy IO Adapter:
                      habe diesen link angeklickt, dann den Code kopiert und das installiert, wo habe ich den jetzt meine Blockade ?
                      • M mike2712
                        StrathColeS Offline
                        StrathColeS Offline
                        StrathCole
                        #278
                        @mike2712 du musst einfach nur meinen Link in Iobroker bei Adapterinstallation eingeben. Nix vorher aufrufen und woanders herkopieren.
                          mike2712
                          #279
                          Danke, jetzt hat es geklappt, habe ich wohl etwas zu kompliziert gedacht, jetzt teste ich später weiter, aber die Einstellungen sind jetzt da. DANKE
                            mike2712
                            schrieb am zuletzt editiert von mike2712
                            #280
                            @strathcole Denke das mit dem Token hat geklappt, aber es gibt doch einiger Meldungen
                            tahoma.0
                            2022-04-23 10:46:09.796	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup/gateways with payload:{}
                            tahoma.0
                            2022-04-23 10:45:59.782	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                            tahoma.0
                            2022-04-23 10:45:59.781	debug	Update gateway status for id undefined
                            tahoma.0
                            2022-04-23 10:45:29.778	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup/gateways with payload:{}
                            tahoma.0
                            2022-04-23 10:45:19.856	warn	{"error":{"errno":-3001,"code":"EAI_AGAIN","syscall":"getaddrinfo","hostname":"gateway-2006-2989-5271.local"}}
                            tahoma.0
                            2022-04-23 10:45:19.856	warn	setup failed!
                            tahoma.0
                            2022-04-23 10:45:19.854	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup with payload:{}
                            tahoma.0
                            2022-04-23 10:45:19.761	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                            tahoma.0
                            2022-04-23 10:45:19.760	debug	Update gateway status for id undefined
                            tahoma.0
                            2022-04-23 10:45:09.872	debug	stateChange tahoma.0.update {"val":false,"ack":true,"ts":1650703509865,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1639459009806}
                            tahoma.0
                            2022-04-23 10:45:09.868	debug	stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1650703509858,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1650703509858}
                            tahoma.0
                            2022-04-23 10:45:09.761	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup with payload:{}
                            tahoma.0
                            2022-04-23 10:45:09.759	info	Using stored bearer token 6263bc8bf4649771a996
                            tahoma.0
                            2022-04-23 10:45:09.753	debug	[START] Started Adapter
                            • M mike2712
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              tahoma.0
                              StrathColeS Offline
                              StrathColeS Offline
                              StrathCole
                              #281
                              @mike2712 du solltest die Logs anonymisiert posten. Da steht deine Pin drin.
                              Die Meldung heißt, dass deine Box über die URL nicht erreichbar ist. Entweder der Entwicklermodus ist nicht aktiv, die IP ist lokal nicht erreichbar oder gesperrt, oder die Firmware der Box nicht aktuell.
                                mike2712
                                #282
                                @strathcole okay, danke, dann werde ich mal weiter danach schauen
                                  mike2712
                                  #283
                                  die App sagt ist auf dem aktuellsten Stand, Version 1.9.0 März 22, im Web ist der Modus aktiviert.
                                  Folgende Einträge kommen kontinuierlich im Log:
                                  tahoma.0
                                  2022-04-23 15:48:35.106	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-****-*****-*****.local, request path: setup/gateways with payload:{}
                                  tahoma.0
                                  2022-04-23 15:48:25.091	debug	GET request on https://gateway-****-*****-*****.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                                  tahoma.0
                                  2022-04-23 15:48:25.091	debug	Update gateway status for id undefined
                                    W Offline
                                    W Offline
                                    Willi-Wunder
                                    #284
                                    @strathcole
                                    Vielen Dank, den Entwicklermodus hatte ich ganz überlesen, jetzt funktioniert es. :-)
                                    Damit sollten die erfolglosen Anmeldeversuche hoffentlich tabu sein. Sehr cool.
                                    G 1 Antwort Letzte Antwort
                                    • W Willi-Wunder
                                      @strathcole
                                      gammler2003
                                      schrieb am zuletzt editiert von gammler2003
                                      #285
                                      @StrathCole Vielen Dank dir auch für den Hinweis. Ich habe alle Schritte wie von dir beschrieben durchgeführt und es funktioniert. So ganz sicher bin ich mir aber nicht, ob die Tahoma tatsächlich lokal angesprochen wird oder doch über die Cloud. Kann man das irgendwo sehen?
                                      Edit: Habe mittlerweile herausgefunden, dass mit der neuen Installation die auf der Tahoma konfigurierten Szenen nicht funktionieren ("Action Groups" im Adapter). Also habe ich den Adapter deinstalliert und aus dem Stable neu geladen - jetzt geht wieder alles wie gehabt (und ich nutze wieder den Weg über die Cloud).
                                      • G gammler2003
                                        StrathColeS Offline
                                        StrathColeS Offline
                                        StrathCole
                                        #286
                                        @gammler2003 Action groups scheint es zumindest derzeit nur in der Cloud zu geben.
                                        Wenn du die Pin aus der Konfig nimmst, sollte aber Cloud auch weiterhin gehen.
                                        G 2 Antworten Letzte Antwort
                                          gammler2003
                                          #287
                                          @strathcole Hi, nur die Pin rausnehmen hatte ich zuerst probiert, hat aber leider nicht den gewünschten Erfolg gebracht. Ich meine der Adapter hat lediglich ‚gemeckert‘, dass ihm die Pin fehlt. Kann aber auch sein, dass ich zu ungeduldig war.
                                          Kann man den irgendwo sehen, welchen Weg der Adapter gerade nimmt (Cloud vs. lokal)? Fände ich zumindest nicht schlecht, die Info als Objekt oder im Log zu haben. Auch die Möglichkeit des einfachen Umschaltens zwischen den beiden Wegen wäre klasse.
                                          Viele Grüße
                                          StrathColeS W 2 Antworten Letzte Antwort
