  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • simatecS simatec
    Ab sofort steht auf Github und in kürze auch im latest die Version 2.4.2 zur Verfügung.
    Changelog
    2.4.2 (2022-03-29)
    • (simatec) Bugfixes Dropbox
    sigi234S Online
    sigi234S Online
    #1856
    @simatec sagte in Test Adapter Backitup v2.4.x:
    Changelog
    2.4.2 (2022-03-29)
    Läuft wieder ohne Fehler. 👍
    • simatecS Offline
      simatecS Offline
      simatec
      #1857
      Ab sofort steht auf Github und in kürze auch im latest die Version 2.4.3 zur Verfügung.
      Changelog
      2.4.3 (2022-03-29)
      • (simatec) try/catch options added
      • (simatec) code verifier check for Dropbox oAuth
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • JB_SullivanJ Offline
        JB_Sullivan
        #1858
        Muss das mit sentry so?
        backitup.0
        11204	2022-03-30 08:03:04.496	info	[iobroker] backup was activated at 02:00 every 1 day(s)
        backitup.0
        11204	2022-03-30 08:03:04.237	debug	Backitup has recognized a win32 system
        backitup.0
        11204	2022-03-30 08:03:04.215	info	starting. Version 2.4.2 in C:/iobroker/GLT/node_modules/iobroker.backitup, node: v14.16.0, js-controller: 4.0.21
        backitup.0
        11204	2022-03-30 08:03:03.857	debug	Plugin sentry destroyed because not initialized correctly
        backitup.0
        11204	2022-03-30 08:03:03.848	debug	Plugin sentry Do not initialize Plugin (enabled=false)
        backitup.0
        11204	2022-03-30 08:03:03.429	debug	States connected to redis: 127.0.0.1:9000
        backitup.0
        11204	2022-03-30 08:03:03.340	debug	States create User PubSub Client
        backitup.0
        11204	2022-03-30 08:03:03.339	debug	States create System PubSub Client
        backitup.0
        11204	2022-03-30 08:03:03.310	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        backitup.0
        11204	2022-03-30 08:03:03.270	debug	Objects connected to redis: 127.0.0.1:9001
        backitup.0
        11204	2022-03-30 08:03:03.264	debug	Objects client initialize lua scripts
        backitup.0
        11204	2022-03-30 08:03:03.158	debug	Objects create User PubSub Client
        backitup.0
        11204	2022-03-30 08:03:03.157	debug	Objects create System PubSub Client
        backitup.0
        11204	2022-03-30 08:03:03.156	debug	Objects client ready ... initialize now
        backitup.0
        11204	2022-03-30 08:03:03.110	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        • JB_SullivanJ JB_Sullivan
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          simatecS Offline
          simatecS Offline
          simatec
          #1859
          @jb_sullivan Dann hast du sentry sicher für Backitup deaktiviert
          L 1 Antwort Letzte Antwort
          • simatecS simatec
            legro
            #1860
            Die Erfahrungen, die ich mit den Entwicklungen im ZigBee-Adapter gemacht habe, lassen mich aufschrecken. Ich frage mich, wie kann ich mein System so sichern, dass ich es exakt wiederherstellen kann?
            Sehe ich das richtig, dass Backitup den Programmcode gar nicht sichert, sondern nur dessen Wiederherstellung, indem die benötigten Teile aus dem GitHub geladen werden? Jedenfalls erscheinen mir die erzeugten Backups viel zu klein.
            Wenn, wie im ZigBee-Adapter geschehen, alte, noch funktionierende Versionen gar nicht mehr verfügbar sind, so sollte Backitup doch wohl beim Wiederherstellen scheitern.
            Somit bliebe dann wohl nur, eine Software à la Apple Pi Baker zu verwenden, die ein eins-zu-eins Abbild des Speichermediums (SD, SSD) erstellt.
            Schiebe ich unberechtigt Panik oder ist dem wirklich so, wie hier von mir vermutet?
            Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
            Thomas BraunT simatecS 2 Antworten Letzte Antwort
            • L legro
              #1861
              @legro sagte in Test Adapter Backitup v2.4.x:
              Es wird (mehr oder weniger) der Bauplan gesichert, nicht das komplette Haus.
              Das reicht auch eigentlich aus, gibt also keinen Grund irgendeine 'Panik' zu schieben.
              • L legro
                simatecS Offline
                simatecS Offline
                simatec
                #1862
                @legro Da liegst du falsch ... Im Gegenteil. das von Backitup erstellte Backup stellt dir ein sauberes und fehlerfreies System wieder her ...
                  legro
                  schrieb am zuletzt editiert von legro
                  #1863
                  @thomas-braun, @simatec
                  Vielen Dank für eure Hinweise. Leider beruhigen sie mich nicht so sehr, wie ich es mir wünschen würde.
                  Wenn der Code der Adapter nicht im Backup gesichert wird, von wo wird dieser dann wiederhergestellt?
                  In dem oben verlinkten Beispiel zum ZigBee-Adapter für BITRON Sirenen war die letzte für meine Geräte noch funktionierende Version die 1.6.0. Nicht einmal die Entwickler hatten diese Version noch zur Hand. Woher nimmt BackItUp denn in diesem Fall den Programmcode?
                  Mittlerweile hat @Asgothian eine Testversion in seinem Fork auf GitHub bereitgestellt, mit der ich mein Alarmsystem aus BITRON Geräten wieder zum Laufen bekomme.
                  • L legro
                    #1864
                    Aus den Repositories.
                    • L legro
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #1865
                      @legro Deine Aussage kann ich nicht nachvollziehen.
                      Alle Versionen liegen auf npm und du kannst diese jederzeit installieren
                      https://www.npmjs.com/package/iobroker.zigbee
                      • simatecS simatec
                        legro
                        #1866
                        @simatec
                        Irgendwie habe ich das Gefühl, dass wir aneinander vorbei argumentieren.
                        Das von mir ins Spiel gebrachte Beispiel hätte die Wiederstellung des ZigBee Adapters zurück auf die Version 1.6.0 erfordert. Aber diese ist anscheinend nicht mehr verfügbar zu sein.
                        Für mich sieht das noch immer so aus, dass man die Wahl zwischen zwei Optionen hat, wobei jede ihre ureigenen Vor- und Nachteile zu haben scheint. Verwende ich etwa Apple Pi Baker, so wird auch der Programmcode eingefroren und bei der Wiederherstellung gehen mir dafür alle zwischenzeitlich angefallenen Daten, Einstellungen und Konfigurationen verloren. Hingegen bleiben mir bei BackItUp alle Daten, Konfigurationen und Einstellungen erhalten, dafür geht jedoch alte Programmcode verloren.
                        Oder sehe ich bloß noch immer keinen Weg, wie ich die hier von mir befürchteten Nachteile vermeiden kann? Derzeit fahre ich daher zweigleisig: Ich verwende BackItUp und ApplePiBaker.
                        Um bei meinem Dilemma zu bleiben: Leider habe ich kein Backup mit ZigBee 1.6.0 aufbewahrt )weder von BackItUp noch von ApplePiBaker), sodass ich das hätte ausprobieren können.
                        Thomas BraunT M K 3 Antworten Letzte Antwort
                        • L legro
                          @simatec
                          #1867
                          @legro
                          iobroker upgrade adaptername@versionsnummer
                          schaufelt dir eine genaue Version auf das System.
                          • L legro
                            @simatec
                            MCU
                            #1868
                            @legro Zur Info es gibt immer die Commits zum Projekt, auch von v1.6.0:
                            Welches man nutzen muss, um die v1.6.0 zurückzusichern, muss man probieren. Sie ist auf jeden Fall da.
                            Stimmt:
                             npm show iobroker.zigbee versions
                              '0.5.0',  '0.5.2',  '0.5.3',  '0.5.4',  '0.5.5',
                              '0.5.6',  '0.5.7',  '0.5.8',  '0.6.0',  '0.7.0',
                              '0.7.1',  '0.7.3',  '0.7.5',  '0.7.6',  '0.7.7',
                              '0.8.0',  '0.9.0',  '0.9.1',  '0.9.2',  '0.10.0',
                              '0.10.1', '0.10.2', '0.10.3', '0.11.0', '0.11.1',
                              '0.11.2', '0.11.3', '0.11.5', '1.0.0',  '1.0.1',
                              '1.0.2',  '1.0.3',  '1.0.4',  '1.1.0',  '1.1.1',
                              '1.2.0',  '1.2.1',  '1.3.0',  '1.3.1',  '1.4.0',
                              '1.4.1',  '1.4.2',  '1.4.4',  '1.5.0',  '1.5.1',
                              '1.5.2',  '1.5.3',  '1.5.5',  '1.5.6',  '1.6.0',
                              '1.6.3',  '1.6.6',  '1.6.8',  '1.6.12', '1.6.14',
                              '1.6.15', '1.6.16'
                            • L legro
                              @simatec
                              Kueppert
                              #1869
                              @legro ansonsten einfach Proxmox nutzen und die VM/LXC jeden Tag sichern. Ich nutze beides...Backitup und die Sicherung des gesamten Systems
                                @legro
                                legro
                                #1870
                                @thomas-braun said in Test Adapter Backitup v2.4.x:
                                Vielen Dank für deinen Hinweis. Genau dies hatte ich jedoch ohne Erfolg versucht und dachte daher, dass die Version 1.6.0 tatsächlich nicht mehr verfügbar ist - zumal sogar Artec und Asgothian meinten, dass diese Versionen nicht mehr verfügbar seien.😕
                                Das System scheint so seine Tücken zu haben. Die von @Asgothian in seinem Fork auf GitHub zu Verfügung gestellte Beta (1.6.17) ließ sich auch zunächst nicht installieren; erst der dritte Versuch führte zum Erfolg.
                                Zur Sicherheit habe ich nun meine npm Version von 6.14.15 auf 8.6.0 aktualisiert.
                                • L legro
                                  #1871
                                  Das ist nicht die beste Idee.
                                  Am besten die Version von npm verwenden, die auch für die nodeJS-Version vorgesehen ist und auch mit im Paket von nodesource liegt.
                                  • M MCU
                                    Stimmt:
                                      '1.6.15', '1.6.16'
                                    legro
                                    #1872
                                    @mcu said in Test Adapter Backitup v2.4.x:
                                    Wo finde ich diese?
                                    Bei meinem aktuellen Problem war's wohl so, dass im zigbee-herdsman-converters: 14.0.422 als auch zigbee-herdsman: 0.14.16 Veränderungen vorgenommen wurden, die dazu führten, dass meine BITRON Rauchmelder und Sirenen nicht mehr funktionierten. Da kam dann bei mir Panik auf, ganz ohne Alarmsystem wollte ich dann doch nicht sein.
                                    Dank deines Tipps kann ich in Zukunft solche Dinge beruhigter angehen.👍
                                    • L legro
                                      Wo finde ich diese?
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #1873
                                      @legro Bitte grundsätzliche Diskussionen zu Installationen oder zum Zigbee Adapter in den jeweiligen Threads führen.
                                      Es würde hier sonst den Rahmen sprengen und der Thread ist schon lang genug.
                                      • simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #1874
                                        Ab sofort steht auf Github und in kürze auch im latest die Version 2.4.4 bereit.
                                        Changelog
                                        2.4.4 (2022-04-02)
                                        • (simatec) try/catch GoogleDrive added
                                        • (Bluefox/simatec) Backup Download added
                                        • simatecS simatec
                                          @diwoma Kannst du mir mal zeigen, was du für einen Fehlerlog bei Start der Slave Instanz bekommst.
                                          Ich bin gerade mit den Entwicklern der dropbox Api am schreiben.
                                          Hier wurde etwas umgestellt, was irgendwie murks ist. Der Token ist bei neuen Apps nur noch "short_live".
                                          Das bedeutet aktuell hat der Token nur noch 4 Stunden Gültigkeit.
                                          Ich bin auf Lösungssuche ... aber das dauert noch.
                                          Wenn du aber erstmal schnell die Lösung benötigst, dann sichere dir mal aus deinem Master die Einstellungen (Pfeile oben Links in der Konfiguration)
                                          Danach kannst du die json lokal öffnen und findest dort den API-Token deines Masters.
                                          Den kannst du dann im Slave eintragen und nutzt damit die gleiche APP mit dem Token
                                          diwoma
                                          #1875
                                          @simatec
                                          Sorry für die so späte Antwort. Ich habe das Forum nicht mehr beobachtet und anscheinend habe ich kein Mail bekommen oder es übersehen und gelöscht.
                                          Das mit dem Token des Masters werde ich probieren. Ich habe gesehen, dass Du schon an der API gearbeitet hast und sie bald ins latest kommen wird. Brauchst Du das Slave-Log noch?
                                          -- diwoma
                                          ioBroker in LX-Container in Proxmox
                                          Zigbee-Coordinator: CC2652P2-TCP FW: 20230507
