  4. [gelöst] Probleme bei Update von admin
admin-adapterehostunreachfehlermeldungupdateupdate adapter
85 Beiträge 6 Kommentatoren 14.5k Aufrufe 3 Beobachtet
  • M Markus Faltermeier
    habe ich gemacht. Hab aber immer noch Fehler.
    Das sieht bei allen Adaptern ähnlich aus. Hier mal das Beispiel mit den Meldungen vom Bachitup
     iobroker upgrade backitup@2.3.3
    Update backitup from @2.2.3 to @2.3.3
    host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 6.14.16npm install iobroker.backitup@2.3.3 --loglevel error --prefix "/opt/iobroker" (System call)
    Traceback (most recent call last):
    File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module> import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module> import gyp.input File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module> import astImportError: No module named ast
    gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
    Traceback (most recent call last): File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module> import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module> import gyp.input File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module> import astImportError: No module named ast
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
    node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:400:28)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1058:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)node-pre-gyp ERR! System Linux 5.10.103-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v14.19.0node-pre-gyp ERR! node-pre-gyp -v v1.0.8node-pre-gyp ERR! not ok
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v14.19.0
    gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindingsgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@9.2.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR! Exit status 1
    npm ERR! npm ERR! Failed at the @serialport/bindings@9.2.8 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-11T11_17_16_464Z-debug.log
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    Adapter "backitup" updated
    host.raspberrypi Adapter "system.adapter.backitup.0" is started
    Process exited with code 0
    Er schreibt zwar, dass upgedated wurde aber nach dem aktualisieren der Seite wird wieder der alte Stand angezeigt
    @markus-faltermeier sagte in Probleme bei Update von admin:
    hatten wir gestern erst:
    https://forum.iobroker.net/topic/53259/gelöst-kann-nichts-updaten/22?_=1646992450663
    hast du zufällig auch den Uralt TR-064 installiert (gehabt)?
      npm ERR! errno 1
      Thomas BraunT
      Thomas BraunT
      Ja, weil das kein Fehler in den jeweiligen Adaptern ist sondern da steht was quer in der Pipeline. Solange das nicht weg ist kommen solche Meldungen.
      iobroker list adapters
      iobroker list instances
      iobroker update -u
        M
        M
        Markus Faltermeier
        ja den hab ich drauf ist aber deaktiviert
          Thomas BraunT
          Thomas BraunT
          @markus-faltermeier
          Dann deinstallier den.
            @markus-faltermeier
            M
            M
            Markus Faltermeier
            hab ihn jetzt gelöscht
              iobroker update -u
              M
              M
              Markus Faltermeier
              ich bekomme folgende Ausgabe:
              iobroker list adapter funktioniert aber nicht
              pi@raspberrypi:/ $ iobroker list adapter
              Unknown type: adapter
              pi@raspberrypi:/ $ iobroker list instances
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.178.42, run as: admin
                system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                system.adapter.deconz.0                 : deconz                : raspberrypi                              - disabled, port: 80
                system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
              + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                system.adapter.fhem.0                   : fhem                  : raspberrypi                              - disabled, port: 7072
                system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
              + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
              + system.adapter.geofency.0               : geofency              : raspberrypi                              -  enabled, port: 7999
              + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
              + system.adapter.history.0                : history               : raspberrypi                              -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 8081
              + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 8081
              + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
              + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
              + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 80
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                system.adapter.lightify.0               : lightify              : raspberrypi                              - disabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
              + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 192.168.178.42
                system.adapter.mobile.0                 : mobile                : raspberrypi                              -  enabled
              + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
                system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1886, bind: 0.0.0.0
                system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
              + system.adapter.nut.0                    : nut                   : raspberrypi                              -  enabled
                system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
              + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
              + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                system.adapter.radar.0                  : radar                 : raspberrypi                              - disabled
              + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.snmp.0                   : snmp                  : raspberrypi                              - disabled
              + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
                system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
              + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5000
              + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 192.168.178.42
              + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
              + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                system.adapter.vis-beta.0               : vis-beta              : raspberrypi                              -  enabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: tcp://192.168.178.135:8888
              + instance is alive
              pi@raspberrypi:/ $ iobroker update -u
              Used repository: stable
              hash unchanged, use cached sources
              update done
              Adapter    "admin"         : 5.3.1    , installed 5.2.3 [Updateable]
              Adapter    "discovery"     : 2.7.5    , installed 2.7.3 [Updateable]
              Adapter    "hue"           : 3.6.5    , installed 3.5.31 [Updateable]
              Controller "js-controller" : 4.0.19   , installed 3.3.22 [Updateable]
              Adapter    "mihome-vacuum" : 3.3.1    , installed 1.1.5 [Updateable]
              Adapter    "shelly"        : 5.3.2    , installed 4.0.7 [Updateable]
                Thomas BraunT
                Thomas BraunT
                @markus-faltermeier
                Die drei Befehlszeilen von oben liefern?
                  + instance is alive
                  update done
                  Thomas BraunT
                  Thomas BraunT
                  terminal
                  Den terminal-Adapter auch rauswerfen. Der sorgt auch für Probleme bei Updates.
                  radar? Ist das nicht mittlerweile radar2? Wenn nicht benötigt, rauswerfen.
                    terminal
                    M
                    M
                    Markus Faltermeier
                    hab ich gelöscht. Muss ich nach dem löschen den IOBROKER eigentlich rebooten?
                      Thomas BraunT
                      Thomas BraunT
                      @markus-faltermeier
                      Nee.
                        + instance is alive
                        update done
                        da fehlt ja auch ein s
                          M
                          M
                          Markus Faltermeier
                          ups du hast recht :-)
                          pi@raspberrypi:/ $ iobroker list adapters
                          system.adapter.admin                   : admin          - v5.3.1
                          system.adapter.alexa2                  : alexa2         - v3.11.2
                          system.adapter.backitup                : backitup       - v2.3.3
                          system.adapter.cloud                   : cloud          - v4.1.0
                          system.adapter.daswetter               : daswetter      - v3.0.9
                          system.adapter.deconz                  : deconz         - v1.3.19
                          system.adapter.denon                   : denon          - v1.12.1
                          system.adapter.discovery               : discovery      - v2.7.5
                          system.adapter.dwd                     : dwd            - v2.7.7
                          system.adapter.email                   : email          - v1.0.10
                          system.adapter.fhem                    : fhem           - v1.6.3
                          system.adapter.flot                    : flot           - v1.10.7
                          system.adapter.fritzbox                : fritzbox       - v0.2.1
                          system.adapter.geofency                : geofency       - v1.0.3
                          system.adapter.harmony                 : harmony        - v1.2.2
                          system.adapter.heatingcontrol          : heatingcontrol - v2.7.2
                          system.adapter.history                 : history        - v1.10.5
                          system.adapter.hm-rega                 : hm-rega        - v3.0.35
                          system.adapter.hm-rpc                  : hm-rpc         - v1.15.0
                          system.adapter.hmm                     : hmm            - v1.0.1
                          system.adapter.hue                     : hue            - v3.6.5
                          system.adapter.ical                    : ical           - v1.11.4
                          system.adapter.icons-icons8            : icons-icons8   - v0.0.1
                          system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
                          system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                          system.adapter.info                    : info           - v1.9.8
                          system.adapter.iot                     : iot            - v1.8.24
                          system.adapter.javascript              : javascript     - v5.2.21
                          system.adapter.lightify                : lightify       - v0.2.16
                          system.adapter.mihome                  : mihome         - v1.3.7
                          system.adapter.mihome-vacuum           : mihome-vacuum  - v1.1.5
                          system.adapter.mobile                  : mobile         - v1.0.1
                          system.adapter.mqtt                    : mqtt           - v2.4.1
                          system.adapter.mqtt-client             : mqtt-client    - v1.5.0
                          system.adapter.node-red                : node-red       - v1.9.0
                          system.adapter.nut                     : nut            - v1.5.0
                          system.adapter.octoprint               : octoprint      - v2.1.0
                          system.adapter.ping                    : ping           - v1.5.0
                          system.adapter.pushover                : pushover       - v2.0.5
                          system.adapter.radar                   : radar          - v1.1.3
                          system.adapter.rpi2                    : rpi2           - v1.3.1
                          system.adapter.scenes                  : scenes         - v2.3.8
                          system.adapter.shelly                  : shelly         - v5.3.2
                          system.adapter.simple-api              : simple-api     - v2.6.2
                          system.adapter.snmp                    : snmp           - v0.5.0
                          system.adapter.socketio                : socketio       - v3.1.5
                          system.adapter.sonoff                  : sonoff         - v2.4.7
                          system.adapter.spotify-premium         : spotify-premium - v1.0.0
                          system.adapter.statistics              : statistics     - v1.0.9
                          system.adapter.synology                : synology       - v1.1.3
                          system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
                          system.adapter.telegram                : telegram       - v1.11.1
                          system.adapter.terminal                : terminal       - v0.1.2
                          system.adapter.text2command            : text2command   - v2.1.1
                          system.adapter.tr-064                  : tr-064         - v4.2.15
                          system.adapter.upnp                    : upnp           - v1.0.19
                          system.adapter.vis                     : vis            - v1.4.5
                          system.adapter.vis-bars                : vis-bars       - v0.1.4
                          system.adapter.vis-beta                : vis-beta       - v0.12.11
                          system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                          system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                          system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.3
                          system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
                          system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                          system.adapter.vis-metro               : vis-metro      - v1.1.2
                          system.adapter.vis-players             : vis-players    - v0.1.6
                          system.adapter.vis-plumb               : vis-plumb      - v1.0.2
                          system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                          system.adapter.vis-weather             : vis-weather    - v2.5.5
                          system.adapter.web                     : web            - v3.4.16
                          system.adapter.zigbee                  : zigbee         - v1.6.16
                          Da taucht aber der TR064 wieder auf, obwohl ich die Instanz gelöscht habe...
                          M HomoranH 2 Antworten Letzte Antwort
                            M
                            M
                            Markus Faltermeier
                            @markus-faltermeier
                            jetzt hab uch den ganzen Adapter gelöscht
                              natürlich.
                              du solltest ja auch den Adapter löschen.
                              Warum meinst du dass der Befehl ....adapters heisst :-)
                                natürlich.
                                M
                                M
                                Markus Faltermeier
                                habs probiert. aber auch beim Löschen kommen ähnliche Fehler...
                                geht also auch nicht
                                $ iobroker del tr-064
                                Delete adapter "tr-064"
                                host.raspberrypi Counted 2 meta of tr-064
                                host.raspberrypi Counted 1 adapter for tr-064
                                host.raspberrypi Counted 1 states of system.adapter.tr-064
                                host.raspberrypi Counted 1 states (system.adapter.tr-064.*) from states
                                host.raspberrypi file tr-064.admin deleted
                                host.raspberrypi object tr-064 deleted
                                host.raspberrypi object tr-064.admin deleted
                                host.raspberrypi Deleting 4 object(s).
                                host.raspberrypi Deleting 1 state(s).
                                npm uninstall iobroker.tr-064 --loglevel error --prefix "/opt/iobroker" (System call)
                                Traceback (most recent call last): File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module> import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module> import gyp.input File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module> import astImportError: No module named astgyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:400:28)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1058:16)
                                gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindingsgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR! Exit status 1npm ERR! npm ERR! Failed at the @serialport/bindings@9.2.8 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-11T12_00_44_147Z-debug.log
                                Error deleting adapter tr-064 from disk: Error: host.raspberrypi: Cannot uninstall iobroker.tr-064: 1You might have to delete it yourself!
                                  npm ERR! errno 1
                                  M
                                  M
                                  Markus Faltermeier
                                  @markus-faltermeier
                                  aber weg ist er jetzt. trotz Fehlermeldungen
                                    npm ERR! errno 1
                                    hast du den verlinkten Thread gelesen?
                                    und auch den darin enthaltenen Link?
                                    https://forum.iobroker.net/topic/46210/npm-problem/7?_=1646992450721
                                      M
                                      M
                                      Markus Faltermeier
                                      ich versuch das grade alles zu verstehen.
                                      ich habe jetzt auch noch mal den oberen Befehl benutzt.
                                      Wie es aussieht ist er jetzt wirklich deinstalliert. Er taucht zumindest nicht mehr in der Liste auf
                                        hast du denn keine Probleme mehr.
                                        im zweiten verlinkten Thread brachte
                                        cd /opt/iobroker/
                                        npm list
                                        noch die Überreste hervor
                                          cd /opt/iobroker/
                                          npm list
                                          M
                                          M
                                          Markus Faltermeier
                                          hab ich probiert. Ich bekomme bei diesem Befehl auch jede Menge Fehler:
                                            │   │ ├─┬ parse-json@2.2.0
                                            │   │ │ └─┬ error-ex@1.3.2
                                            │   │ │   └── is-arrayish@0.2.1
                                            │   │ ├── pify@2.3.0
                                            │   │ ├── pinkie-promise@2.0.1 deduped
                                            │   │ └─┬ strip-bom@2.0.0
                                            │   │   └── is-utf8@0.2.1
                                            │   ├─┬ normalize-package-data@2.5.0
                                            │   │ ├── hosted-git-info@2.8.8
                                            │   │ ├─┬ resolve@1.17.0
                                            │   │ │ └── path-parse@1.0.6
                                            │   │ ├── semver@5.7.1 deduped
                                            │   │ └─┬ validate-npm-package-license@3.0.4
                                            │   │   ├─┬ spdx-correct@3.1.0
                                            │   │   │ ├── spdx-expression-parse@3.0.0 deduped
                                            │   │   │ └── spdx-license-ids@3.0.5
                                            │   │   └─┬ spdx-expression-parse@3.0.0
                                            │   │     ├── spdx-exceptions@2.3.0
                                            │   │     └── spdx-license-ids@3.0.5 deduped
                                            │   └─┬ path-type@1.1.0
                                            │     ├── graceful-fs@4.2.4 deduped
                                            │     ├── pify@2.3.0 deduped
                                            │     └── pinkie-promise@2.0.1 deduped
                                            ├── require-directory@2.1.1
                                            ├── require-main-filename@1.0.1
                                            ├── set-blocking@2.0.0
                                            ├─┬ string-width@1.0.2
                                            │ ├── code-point-at@1.1.0
                                            │ ├─┬ is-fullwidth-code-point@1.0.0
                                            │ │ └── number-is-nan@1.0.1
                                            │ └── strip-ansi@3.0.1 deduped
                                            ├── which-module@1.0.0
                                            ├── y18n@3.2.1
                                            └─┬ yargs-parser@5.0.0
                                              └── camelcase@3.0.0 deduped
                                          npm ERR! missing: iobroker.terminal@0.1.2, required by iobroker.inst@2.0.3
                                          npm ERR! missing: iobroker.zigbee@1.6.16, required by iobroker.inst@2.0.3
                                          npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
                                          npm ERR! missing: commander@5.1.0, required by iobroker.terminal@0.1.2
                                          npm ERR! missing: connect@3.7.0, required by iobroker.terminal@0.1.2
                                          npm ERR! missing: passport@0.2.2, required by iobroker.terminal@0.1.2
                                          npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.zigbee@1.6.        16
                                          npm ERR! missing: typescript@4.5.4, required by iobroker.zigbee@1.6.16
                                          npm ERR! missing: zigbee-herdsman-converters@14.0.422, required by iobroker.zigb        ee@1.6.16
                                          npm ERR! missing: @types/iobroker@3.3.4, required by @iobroker/adapter-core@2.5.        1
                                          npm ERR! missing: axios@0.25.0, required by zigbee-herdsman-converters@14.0.422
                                          npm ERR! missing: buffer-crc32@0.2.13, required by zigbee-herdsman-converters@14        .0.422
                                          npm ERR! missing: https-proxy-agent@5.0.0, required by zigbee-herdsman-converter        s@14.0.422
                                          npm ERR! missing: tar-stream@2.2.0, required by zigbee-herdsman-converters@14.0.        422
                                          npm ERR! missing: zigbee-herdsman@0.14.14, required by zigbee-herdsman-converter        s@14.0.422
                                          npm ERR! missing: follow-redirects@1.14.8, required by axios@0.25.0
                                          npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
                                          npm ERR! missing: debug@4.3.3, required by https-proxy-agent@5.0.0
                                          npm ERR! missing: debug@4.3.3, required by agent-base@6.0.2
                                          npm ERR! missing: ms@2.1.2, required by debug@4.3.3
                                          npm ERR! missing: bl@4.1.0, required by tar-stream@2.2.0
                                          npm ERR! missing: end-of-stream@1.4.4, required by tar-stream@2.2.0
                                          npm ERR! missing: fs-constants@1.0.0, required by tar-stream@2.2.0
                                          npm ERR! missing: inherits@2.0.4, required by tar-stream@2.2.0
                                          npm ERR! missing: readable-stream@3.6.0, required by tar-stream@2.2.0
                                          npm ERR! missing: buffer@5.7.1, required by bl@4.1.0
                                          npm ERR! missing: inherits@2.0.4, required by bl@4.1.0
                                          npm ERR! missing: readable-stream@3.6.0, required by bl@4.1.0
                                          npm ERR! missing: base64-js@1.5.1, required by buffer@5.7.1
                                          npm ERR! missing: ieee754@1.2.1, required by buffer@5.7.1
                                          npm ERR! missing: once@1.4.0, required by end-of-stream@1.4.4
                                          npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
                                          npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
                                          npm ERR! missing: string_decoder@1.3.0, required by readable-stream@3.6.0
                                          npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
                                          npm ERR! missing: safe-buffer@5.2.1, required by string_decoder@1.3.0
                                          npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.14
                                          npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.14
                                          npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.14
                                          npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.14
                                          npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.14
                                          npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.14
                                          npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.14
                                          npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
                                          npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
                                          npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
                                          npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
                                          npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
                                          npm ERR! missing: @serialport/binding-mock@9.2.4, required by serialport@9.2.8
                                          npm ERR! missing: @serialport/bindings@9.2.8, required by serialport@9.2.8
                                          npm ERR! missing: @serialport/parser-byte-length@9.2.4, required by serialport@9        .2.8
                                          npm ERR! missing: @serialport/parser-cctalk@9.2.4, required by serialport@9.2.8
                                          npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by serialport@9.2        .8
                                          npm ERR! missing: @serialport/parser-inter-byte-timeout@9.2.4, required by seria        lport@9.2.8
                                          npm ERR! missing: @serialport/parser-readline@9.2.4, required by serialport@9.2.        8
                                          npm ERR! missing: @serialport/parser-ready@9.2.4, required by serialport@9.2.8
                                          npm ERR! missing: @serialport/parser-regex@9.2.4, required by serialport@9.2.8
                                          npm ERR! missing: @serialport/stream@9.2.4, required by serialport@9.2.8
                                          npm ERR! missing: debug@4.3.3, required by serialport@9.2.8
                                          npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bi        nding-mock@9.2.4
                                          npm ERR! missing: debug@4.3.3, required by @serialport/binding-mock@9.2.4
                                          npm ERR! missing: debug@4.3.3, required by @serialport/binding-abstract@9.2.3
                                          npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bi        ndings@9.2.8
                                          npm ERR! missing: @serialport/parser-readline@9.2.4, required by @serialport/bin        dings@9.2.8
                                          npm ERR! missing: bindings@1.5.0, required by @serialport/bindings@9.2.8
                                          npm ERR! missing: debug@4.3.3, required by @serialport/bindings@9.2.8
                                          npm ERR! missing: nan@2.15.0, required by @serialport/bindings@9.2.8
                                          npm ERR! missing: prebuild-install@7.0.1, required by @serialport/bindings@9.2.8
                                          npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
                                          npm ERR! missing: detect-libc@2.0.0, required by prebuild-install@7.0.1
                                          npm ERR! missing: expand-template@2.0.3, required by prebuild-install@7.0.1
                                          npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@7.0.1
                                          npm ERR! missing: minimist@1.2.5, required by prebuild-install@7.0.1
                                          npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@7.0.1
                                          npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@7.0.1
                                          npm ERR! missing: node-abi@3.8.0, required by prebuild-install@7.0.1
                                          npm ERR! missing: npmlog@4.1.2, required by prebuild-install@7.0.1
                                          npm ERR! missing: pump@3.0.0, required by prebuild-install@7.0.1
                                          npm ERR! missing: rc@1.2.8, required by prebuild-install@7.0.1
                                          npm ERR! missing: simple-get@4.0.1, required by prebuild-install@7.0.1
                                          npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@7.0.1
                                          npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@7.0.1
                                          npm ERR! missing: semver@7.3.5, required by node-abi@3.8.0
                                          npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
                                          npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
                                          npm ERR! missing: are-we-there-yet@1.1.7, required by npmlog@4.1.2
                                          npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
                                          npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
                                          npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
                                          npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.7
                                          npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.7
                                          npm ERR! missing: core-util-is@1.0.3, required by readable-stream@2.3.7
                                          npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
                                          npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
                                          npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
                                          npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
                                          npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
                                          npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
                                          npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
                                          npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
                                          npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
                                          npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
                                          npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
                                          npm ERR! missing: signal-exit@3.0.7, required by gauge@2.7.4
                                          npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
                                          npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
                                          npm ERR! missing: wide-align@1.1.5, required by gauge@2.7.4
                                          npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
                                          npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
                                          npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
                                          npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
                                          npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
                                          npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.5
                                          npm ERR! missing: end-of-stream@1.4.4, required by pump@3.0.0
                                          npm ERR! missing: once@1.4.0, required by pump@3.0.0
                                          npm ERR! missing: deep-extend@0.6.0, required by rc@1.2.8
                                          npm ERR! missing: ini@1.3.8, required by rc@1.2.8
                                          npm ERR! missing: minimist@1.2.5, required by rc@1.2.8
                                          npm ERR! missing: strip-json-comments@2.0.1, required by rc@1.2.8
                                          npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.1
                                          npm ERR! missing: once@1.4.0, required by simple-get@4.0.1
                                          npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.1
                                          npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
                                          npm ERR! missing: chownr@1.1.4, required by tar-fs@2.1.1
                                          npm ERR! missing: mkdirp-classic@0.5.3, required by tar-fs@2.1.1
                                          npm ERR! missing: pump@3.0.0, required by tar-fs@2.1.1
                                          npm ERR! missing: tar-stream@2.2.0, required by tar-fs@2.1.1
                                          npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
                                          npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
                                          npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by @serialport/pa        rser-readline@9.2.4
                                          npm ERR! missing: debug@4.3.3, required by @serialport/stream@9.2.4
                                          83.8k
