[gelöst] kann nichts updaten
pi@iobroker:~ $ iobroker upgrade self Update js-controller from @4.0.18 to @4.0.19 Stopped Objects DB Stopped States DB NPM version: 8.5.3 Installing iobroker.js-controller@4.0.19... (System call) host.iobroker Cannot install iobroker.js-controller@4.0.19: 217iobroker upgrade iot@1.10.0 Update iot from @1.9.7 to @1.10.0 NPM version: 8.5.3 Installing iobroker.iot@1.10.0... (System call) host.iobroker Cannot install iobroker.iot@1.10.0: 217 ERROR: Process exited with code 25pi@iobroker:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs /usr/bin/nodejs v16.14.0 /usr/local/bin/node v16.14.0 /usr/local/bin/npm 8.5.3 nodejs: Installed: 16.14.0-deb-1nodesource1 Candidate: 16.14.0-deb-1nodesource1 Version table: *** 16.14.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf PackagesPlattform linux Betriebssystem linux Architektur arm CPUs 4 Geschwindigkeit 1500 MHz Modell ARMv7 Processor rev 3 (v7l) RAM 3.75 GB System-Betriebszeit 02:50:59 Node.js v16.14.0 (Empfohlene Version v14.19.0) time 1646922709434 timeOffset -60 Anzahl der Adapter 486 NPM v8.5.3 Datenträgergröße 28.95 GB freier Festplattenspeicher 14.85 GB -
pi@iobroker:~ $ iobroker upgrade self Update js-controller from @4.0.18 to @4.0.19 Stopped Objects DB Stopped States DB NPM version: 8.5.3 Installing iobroker.js-controller@4.0.19... (System call) host.iobroker Cannot install iobroker.js-controller@4.0.19: 217iobroker upgrade iot@1.10.0 Update iot from @1.9.7 to @1.10.0 NPM version: 8.5.3 Installing iobroker.iot@1.10.0... (System call) host.iobroker Cannot install iobroker.iot@1.10.0: 217 ERROR: Process exited with code 25pi@iobroker:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs /usr/bin/nodejs v16.14.0 /usr/local/bin/node v16.14.0 /usr/local/bin/npm 8.5.3 nodejs: Installed: 16.14.0-deb-1nodesource1 Candidate: 16.14.0-deb-1nodesource1 Version table: *** 16.14.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf PackagesPlattform linux Betriebssystem linux Architektur arm CPUs 4 Geschwindigkeit 1500 MHz Modell ARMv7 Processor rev 3 (v7l) RAM 3.75 GB System-Betriebszeit 02:50:59 Node.js v16.14.0 (Empfohlene Version v14.19.0) time 1646922709434 timeOffset -60 Anzahl der Adapter 486 NPM v8.5.3 Datenträgergröße 28.95 GB freier Festplattenspeicher 14.85 GB@skinni sagte in kann nichts updaten:
/usr/local/bin/npm 8.5.3NodeJS ist nicht gescheit installiert.
Schau in meiner Signatur wie es richtig geht. -
Schau in meiner Signatur wie es richtig geht.@thomas-braun Danke das hats geändert, leider ist jetzt was anderes kaputt was ich nicht hinbekomme
pi@iobroker:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.14.0 v16.14.0 (node:4008) [LRU_CACHE_OPTION_maxAge] DeprecationWarning: The maxAge option is deprecated. Please use options.ttl instead. (Use `node --trace-deprecation ...` to show where the warning was created) 8.3.1 pi /home/pi Hit:1 http://phoscon.de/apt/deconz buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 http://archive.raspberrypi.org/debian buster InRelease Hit:4 https://deb.nodesource.com/node_16.x buster InRelease Hit:5 https://repos.influxdata.com/debian buster InRelease Hit:6 https://www.pivccu.de/piVCCU stable InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. nodejs: Installed: 16.14.0-deb-1nodesource1 Candidate: 16.14.0-deb-1nodesource1 Version table: *** 16.14.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packagesnode --trace-deprecation ... node:internal/modules/cjs/loader:936 throw err; ^ Error: Cannot find module '/home/pi/...' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15) at Function.Module._load (node:internal/modules/cjs/loader:778:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) at node:internal/main/run_main_module:17:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } -
@homoran ja keine Ahnung. Das sieht jedes mal so aus, wenn ich nodejs 16 installiere. Habs mehrfach komplett gelöscht, reboot neuinstalliert.
Hab jetzt die 14 genommen, damit kann ich Adapter aktualisieren, aber iobroker selbst nicht
which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.0 v14.19.0 6.14.16 pi /home/pi Hit:1 http://phoscon.de/apt/deconz buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 http://archive.raspberrypi.org/debian buster InRelease Hit:4 https://deb.nodesource.com/node_14.x buster InRelease Hit:5 https://repos.influxdata.com/debian buster InRelease Hit:6 https://www.pivccu.de/piVCCU stable InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. nodejs: Installed: 14.19.0-deb-1nodesource1 Candidate: 14.19.0-deb-1nodesource1 Version table: *** 14.19.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packagespi@iobroker:~ $ iobroker upgrade self Update js-controller from @4.0.18 to @4.0.19 Stopped Objects DB Stopped States DB NPM version: 6.14.16 Installing iobroker.js-controller@4.0.19... (System call) pi@iobroker:~ $ iobroker start pi@iobroker:~ $ iobroker update Used repository: beta Adapter "admin" : 5.3.1 , installed 5.3.1 Adapter "alexa2" : 3.12.0 , installed 3.12.0 Adapter "backitup" : 2.3.5 , installed 2.3.5 Adapter "daikin" : 1.3.3 , installed 1.3.3 Adapter "deconz" : 1.3.20 , installed 1.3.20 Adapter "devices" : 1.0.10 , installed 1.0.10 Adapter "discovery" : 2.8.0 , installed 2.8.0 Adapter "fb-checkpresence": 1.1.13, installed 1.1.13 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "fronius" : 1.1.3 , installed 1.1.3 Adapter "history" : 1.11.0 , installed 1.11.0 Adapter "hm-rega" : 3.0.37 , installed 3.0.37 Adapter "hm-rpc" : 1.15.8 , installed 1.15.8 Adapter "influxdb" : 2.6.3 , installed 2.6.2 [Updatable] Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.10.0 , installed 1.9.7 [Updatable] Adapter "jarvis" : 3.0.11 , installed 3.0.11 Adapter "javascript" : 5.3.3 , installed 5.3.1 [Updatable] Controller "js-controller": 4.0.19 , installed 4.0.18 [Updatable] ... -
which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.0 v14.19.0 6.14.16 pi /home/pi Hit:1 http://phoscon.de/apt/deconz buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 http://archive.raspberrypi.org/debian buster InRelease Hit:4 https://deb.nodesource.com/node_14.x buster InRelease Hit:5 https://repos.influxdata.com/debian buster InRelease Hit:6 https://www.pivccu.de/piVCCU stable InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. nodejs: Installed: 14.19.0-deb-1nodesource1 Candidate: 14.19.0-deb-1nodesource1 Version table: *** 14.19.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packagespi@iobroker:~ $ iobroker upgrade self Update js-controller from @4.0.18 to @4.0.19 Stopped Objects DB Stopped States DB NPM version: 6.14.16 Installing iobroker.js-controller@4.0.19... (System call) pi@iobroker:~ $ iobroker start pi@iobroker:~ $ iobroker update Used repository: beta Adapter "admin" : 5.3.1 , installed 5.3.1 Adapter "alexa2" : 3.12.0 , installed 3.12.0 Adapter "backitup" : 2.3.5 , installed 2.3.5 Adapter "daikin" : 1.3.3 , installed 1.3.3 Adapter "deconz" : 1.3.20 , installed 1.3.20 Adapter "devices" : 1.0.10 , installed 1.0.10 Adapter "discovery" : 2.8.0 , installed 2.8.0 Adapter "fb-checkpresence": 1.1.13, installed 1.1.13 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "fronius" : 1.1.3 , installed 1.1.3 Adapter "history" : 1.11.0 , installed 1.11.0 Adapter "hm-rega" : 3.0.37 , installed 3.0.37 Adapter "hm-rpc" : 1.15.8 , installed 1.15.8 Adapter "influxdb" : 2.6.3 , installed 2.6.2 [Updatable] Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.10.0 , installed 1.9.7 [Updatable] Adapter "jarvis" : 3.0.11 , installed 3.0.11 Adapter "javascript" : 5.3.3 , installed 5.3.1 [Updatable] Controller "js-controller": 4.0.19 , installed 4.0.18 [Updatable] ...@skinni sagte in kann nichts updaten:
und da ist auch brav npm v6 dabei!
Dann klappt das auch@skinni sagte in kann nichts updaten:
davon sehe ich aber nichts in der Konsolenausgabe
der scheint noch nicht fertig gewesen zu sein.gestoppt hattest du vorher auch nicht?
und auch nicht iob update aufgerufen? -
und auch nicht iob update aufgerufen?@homoran said in kann nichts updaten:
und auch nicht iob update aufgerufen?pi@iobroker:~ $ iobroker update Used repository: beta Adapter "admin" : 5.3.1 , installed 5.3.1 Adapter "alexa2" : 3.12.0 , installed 3.12.0 Adapter "backitup" : 2.3.5 , installed 2.3.5 Adapter "daikin" : 1.3.3 , installed 1.3.3 Adapter "deconz" : 1.3.20 , installed 1.3.20 Adapter "devices" : 1.0.10 , installed 1.0.10 Adapter "discovery" : 2.8.0 , installed 2.8.0 Adapter "fb-checkpresence": 1.1.13, installed 1.1.13 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "fronius" : 1.1.3 , installed 1.1.3 Adapter "history" : 1.11.0 , installed 1.11.0 Adapter "hm-rega" : 3.0.37 , installed 3.0.37 Adapter "hm-rpc" : 1.15.8 , installed 1.15.8 Adapter "influxdb" : 2.6.3 , installed 2.6.2 [Updatable] Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.10.0 , installed 1.9.7 [Updatable] Adapter "jarvis" : 3.0.11 , installed 3.0.11 Adapter "javascript" : 5.3.3 , installed 5.3.1 [Updatable] Controller "js-controller": 4.0.19 , installed 4.0.18 [Updatable] Adapter "luftdaten" : 2.1.3 , installed 2.1.3 Adapter "mihome-vacuum": 3.3.3 , installed 3.3.3 Adapter "net-tools" : 0.1.7 , installed 0.1.7 Adapter "ph803w" : 1.0.1 , installed 1.0.1 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 5.3.2 , installed 4.1.2 [Updatable] Adapter "simple-api" : 2.6.3 , installed 2.6.3 Adapter "socketio" : 4.1.4 , installed 4.1.4 Adapter "sonoff" : 2.4.7 , installed 2.4.7 Adapter "statistics" : 1.0.10 , installed 1.0.10 Adapter "synology" : 1.1.3 , installed 1.1.3 Adapter "telegram" : 1.11.1 , installed 1.11.1 Adapter "text2command" : 2.2.1 , installed 2.2.1 Adapter "tr-064" : 4.2.15 , installed 4.2.15 Adapter "web" : 4.2.0 , installed 4.2.0 Adapter "ws" : 1.2.0 , installed 1.2.0 Adapter "zigbee" : 1.6.16 , installed 1.6.16 pi@iobroker:~ $ pi@iobroker:~ $ iobroker stop pi@iobroker:~ $ iobroker upgrade self Update js-controller from @4.0.18 to @4.0.19 Stopped Objects DB Stopped States DB NPM version: 6.14.16 Installing iobroker.js-controller@4.0.19... (System call) pi@iobroker:~ $danach passiert nichts mehr.
Hab jetzt auch gesehen, dass das adapter update mit error code 0 beendet, aber trotzdem nicht aktualisiert wurde
welcher Adapter?
Mach mal:
iob stop iob upload all iob start@skinni sagte in kann nichts updaten:
im Log steht nichts?
welcher Adapter?
Mach mal:
welcher Adapter?
Mach mal:
upload all hab ich gemacht, das ist durchgelaufen. Hab dann IOT aktualisiert:
$ iobroker upgrade iot@1.10.0 Update iot from @1.9.7 to @1.10.0 NPM version: 6.14.16 Installing iobroker.iot@1.10.0... (System call) Update "system.adapter.iot.0" upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.f1408482.chunk.js static/js/2.f1408482.chunk.js application/javascript upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.f1408482.chunk.js.LICENSE.txt static/js/2.f1408482.chunk.js.LICENSE.txt text/plain upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.f1408482.chunk.js.map static/js/2.f1408482.chunk.js.map application/json upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.eedf2471.chunk.js static/js/main.eedf2471.chunk.js application/javascript upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.eedf2471.chunk.js.map static/js/main.eedf2471.chunk.js.map application/json upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ef534f76.js static/js/runtime-main.ef534f76.js application/javascript upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ef534f76.js.map static/js/runtime-main.ef534f76.js.map application/json Process exited with code 0aber die version wurde nicht geändert. Weiß leider nicht wo ich noch andere logs finde die mir mehr zeigen
welcher Adapter?
Mach mal:
im Admin auf der Seite "Protokolle"
Hast du mal den Browsercache gelöscht?
oder wo siehst du dir die Versionen an? -
oder wo siehst du dir die Versionen an?@homoran said in kann nichts updaten:
oder wo siehst du dir die Versionen an?protokolle steht auch nix anderes.
hier jsadapter über console aktualisiert, aber dann doch nicht:Would you like to upgrade javascript from @5.3.1 to @5.3.3 now? [(y)es, (n)o]: y Update javascript from @5.3.1 to @5.3.3 NPM version: 6.14.16 Installing iobroker.javascript@5.3.3... (System call) upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.367f9424.js static/js/runtime-main.367f9424.js application/javascript upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t This upgrade of "iot" will introduce the following changes: ========================================================================== -> 1.10.0: Respect min/max when calculating the value for byOn with % values ========================================================================== Would you like to upgrade iot from @1.9.7 to @1.10.0 now? [(y)es, (n)o]: n No upgrade of "iot" desired. This upgrade of "influxdb" will introduce the following changes: ========================================================================== -> 2.6.3: Fix potential crash cases (Sentry IOBROKER-INFLUXDB-4Q) ========================================================================== Would you like to upgrade influxdb from @2.6.2 to @2.6.3 now? [(y)es, (n)o]: n No upgrade of "influxdb" desired. pi@iobroker:~ $ iob update Used repository: beta Adapter "admin" : 5.3.1 , installed 5.3.1 Adapter "alexa2" : 3.12.0 , installed 3.12.0 Adapter "backitup" : 2.3.5 , installed 2.3.5 Adapter "daikin" : 1.3.3 , installed 1.3.3 Adapter "deconz" : 1.3.20 , installed 1.3.20 Adapter "devices" : 1.0.10 , installed 1.0.10 Adapter "discovery" : 2.8.0 , installed 2.8.0 Adapter "fb-checkpresence": 1.1.13, installed 1.1.13 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "fronius" : 1.1.3 , installed 1.1.3 Adapter "history" : 1.11.0 , installed 1.11.0 Adapter "hm-rega" : 3.0.37 , installed 3.0.37 Adapter "hm-rpc" : 1.15.8 , installed 1.15.8 Adapter "influxdb" : 2.6.3 , installed 2.6.2 [Updatable] Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.10.0 , installed 1.9.7 [Updatable] Adapter "jarvis" : 3.0.11 , installed 3.0.11 Adapter "javascript" : 5.3.3 , installed 5.3.1 [Updatable] -
was macht das bei javascript?
ich hatte einfach "iob upgrade"und nur bei js yes gesagt
ich würde ja denken die sd karte ist kaputt, aber außerhalb von iobroker kann ich sachen installieren/löschen
wäre eine Möglichkeit, dass die nur noch Read Only ist
@homoran jo das war mein erster Gedanke, aber ich hatte ja mehrfach nodejs gelöscht und zwischen 14 und 16 gewechselt mit reboots zwischendrin, alle Änderungen hat er so gemacht wie es sein soll.
Und vor alle dem hab ich heute erstmal ein paar ausstehende raspberry Updates installiert. Das klappt alles, nur iobroker will nicht updaten.
iobroker ansich läuft und ich kann auch Config Änderungen an Adaptern vornehmen die er sich auch nach einem reboot noch merkt.
nach korrektur von Node und NPM empfiehlt sich:
iob stop iob fix iob startBitte die Log ausgaben posten.
@wendy2702 said in kann nichts updaten:
Das hab ich auch immer brav gemacht, aber eben trotzdem nochmal:
pi@iobroker:~ $ iob fix library: loaded Library version=2022-02-10 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-02-13 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 http://phoscon.de/apt/deconz buster InRelease Hit:4 https://repos.influxdata.com/debian buster InRelease Hit:5 https://deb.nodesource.com/node_14.x buster InRelease Hit:6 https://www.pivccu.de/piVCCU stable InRelease Reading package lists... Done Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@iobroker:~ $ iob start pi@iobroker:~ $ -
pi@iobroker:~ $ iob fix library: loaded Library version=2022-02-10 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-02-13 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 http://phoscon.de/apt/deconz buster InRelease Hit:4 https://repos.influxdata.com/debian buster InRelease Hit:5 https://deb.nodesource.com/node_14.x buster InRelease Hit:6 https://www.pivccu.de/piVCCU stable InRelease Reading package lists... Done Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@iobroker:~ $ iob start pi@iobroker:~ $iobroker repo list iobroker update iobroker upgrade -
