  4. js-controller 4.0.x jetzt für alle User im STABLE!
501 Beiträge 83 Kommentatoren 238.3k Aufrufe 58 Beobachtet
  • M
    M
    marios774
    #211
    Hallo, nach dem Update kamen nun diese Fehlermeldung..
    Was nun? Die Adapter scheinen alle zu laufen.
    parallels@deb11iobroker:~$ iob upgrade self
    Update js-controller from @3.3.22 to @4.0.19
    NPM version: 6.14.16
    npm install iobroker.js-controller@4.0.19 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../../nan/nan.h:58,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      793 |       (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
      827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
    Server Objects 127.0.0.1:43698 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
    Server States 127.0.0.1:53512 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
    Server Objects 127.0.0.1:43698 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
    Server States 127.0.0.1:53514 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
    Server Objects 127.0.0.1:43698 Error from InMemDB: Error: Unknown LUA script load
    Server Objects 127.0.0.1:43698 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    parallels@deb11iobroker:~$ iob fix
    • M marios774
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #212
      @marios774 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
      Was nun?
      Nix. Alles i. O.
        Was nun?
        Nix. Alles i. O.
        M
        M
        marios774
        #213
        Dann bin ich beruhigt... Fehlermeldungen, die ich nicht deuten kann, bringen immer so kleine Perlen auf die Stirn...
        • M marios774
          apollon77A
          apollon77A
          #214
          @marios774 Dann liess mal ganz oben den ersten post :-)
          • apollon77A apollon77
            @boronsbruder Hi,
            ja, die Meldungkannst Du ignorieren ... da fehlt ein Check ... Wird gerade immer geloggt auch wenn es gar keinen Fehler gab :-( Fixen wir in der nächsten Controller Version
            O
            O
            oFbEQnpoLKKl6mbY5e13
            #215
            @apollon77 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
            @boronsbruder Hi,
            Ist euch das durchgegangen, denn ich erhalte die Meldung auch mit der 19er?
            (Cannot set object: null)
            • O oFbEQnpoLKKl6mbY5e13
              @boronsbruder Hi,
              apollon77A
              apollon77A
              #216
              @ofbeqnpolkkl6mby5e13 ne der wurde gemeldet nachdem der 4.0.19 schon released war.
              O haselchenH 2 Antworten Letzte Antwort
                O
                O
                #217
                @apollon77
                Ach so, okay.
                  haselchenH
                  haselchenH
                  haselchen
                  #218
                  @apollon77
                  Nachdem ich nun einen aktuellen Container gestartet habe , mein Backup zurückspielen konnte (JS Controller 3.3.22) , wurde das System auf 4.0.19 aktualisiert.
                  Nun verzweifel ich an Adapter Updates.
                  Jedesmal wenn ich das über den Admin mache kommt: (iot als Beispiel)
                  host.IOBrokerSynology	2022-03-10 13:03:53.359	error	iobroker host.IOBrokerSynology Cannot install iobroker.iot@1.10.0: 216
                  host.IOBrokerSynology	2022-03-10 13:02:21.374	info	iobroker Installing iobroker.iot@1.10.0... (System call)
                  host.IOBrokerSynology	2022-03-10 13:02:21.373	info	iobroker NPM version: 6.14.16
                  host.IOBrokerSynology	2022-03-10 13:02:19.662	info	iobroker Update iot from @1.9.7 to @1.10.0
                  host.IOBrokerSynology	2022-03-10 13:02:12.355	info	iobroker upgrade iot
                  Fixer ist gelaufen, Fehler bleibt. Auch sonst alles probiert.
                  Upload all oder setup custom um von jsonl wieder auf file zu ändern.
                  Eine Idee wie ich das Problem löse?
                  • haselchenH haselchen
                    @apollon77
                    apollon77A
                    apollon77A
                    #219
                    @haselchen Ja, erstmal durchatmen und ruhig bleiben :-))
                    Da sagt npm einen Fehler und der wird nicht angezeigt.
                    Also bitte an der Kommandozeile mal iob upgrade iot --debug ausführen ... dann sollten die Fehlermeldungen ausgegeben werden
                    • haselchenH
                      haselchenH
                      haselchen
                      #220
                      @apollon77
                      Sorry für den Screenshot, im Container geht das nicht anders.
                      Was hat das verdammte castv2-client Ding für Probleme?
                      Das bringe ich irgendwie mit dem Chromecast in Verbindung.
                      Edit:
                      So , nach x Schweißattacken, des Rätsels Lösung.
                      In node_modules gab es keinen castv2-client Ordner.
                      Dann durch eine Eingebung mal in die package.json geguckt.
                      Dort war oben gleich ein Eintrag mit castv2-client.
                      Den gelöscht und zack, Updates gehen wieder.
                      Kein Plan , wie da was und wo zusammenhängt.
                        @apollon77
                        Edit:
                        apollon77A
                        apollon77A
                        #221
                        @haselchen Sehr interessant. Jetzt müsste man überlegen wo denn bei Dir das "castv2-client" Paket herkam was dnn nicht wirklich da war
                          @feinfinger
                          Dann mache es nochmal...
                          Und wie gesagt, hampel da nicht als root rum.
                          F
                          F
                          Feinfinger
                          #222
                          @thomas-braun sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                          @feinfinger
                          Erledigt, läuft wieder und update auf 4.0.19 hat auch geklappt.
                          Musste ca. 200 Ordner umbenennen bzw. habe sie gelöscht. (backup war ja vorhanden)
                          Das einzige was sich jetzt nicht updaten lässt ist der influxdb Adapter, da bin ich noch auf 1.9.5 und soll auf 2.6.3.
                          Gibt es hierfür ne Idee?
                          iob als LXC im Proxmox
                          Node.js: v22.19.0
                          NPM: 10.9.3
                          js-controller 7.0.7
                          • F Feinfinger
                            @feinfinger
                            apollon77A
                            apollon77A
                            #223
                            @feinfinger sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                            Ohne das Du und mehr Infos gibst was das Problem ist hat glaube keiner eine Idee ;-)
                            F 1 Antwort Letzte Antwort
                              F
                              F
                              Feinfinger
                              #224
                              @apollon77
                              Ok, verständlich ;-)
                              $ iobroker upgrade influxdb@2.6.3
                              Update influxdb from @1.9.5 to @2.6.3
                              NPM version: 8.1.4Installing iobroker.influxdb@2.6.3... (System call)
                              host.ioBroker Cannot install iobroker.influxdb@2.6.3: 217
                              ERROR: Process exited with code 25
                              Node.js: v22.19.0
                              NPM: 10.9.3
                              js-controller 7.0.7
                              • F Feinfinger
                                @apollon77
                                apollon77A
                                apollon77A
                                #225
                                Da gefällt npm irgendwas nicht.
                                Dann mach mal
                                iobroker upgrade influxdb@2.6.3 --debug
                                Was ist die Ausgabe?
                                  Dann mach mal
                                  F
                                  F
                                  Feinfinger
                                  #226
                                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                  Would you like to upgrade influxdb from @1.9.5 to @2.6.3 now? [(y)es, (n)o]: y
                                  NPM version: 8.1.4
                                  npm ERR! code ENOTEMPTY
                                  npm ERR! syscall rename
                                  npm ERR! path /opt/iobroker/node_modules/bcrypt-pbkdf/node_modules/tweetnacl
                                  npm ERR! dest /opt/iobroker/node_modules/bcrypt-pbkdf/node_modules/.tweetnacl-DWEcN9yD
                                  npm ERR! errno -39
                                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/bcrypt-pbkdf/node_modules/tweetnacl' -> '/opt/iobroker/node_modules/bcrypt-pbkdf/node_modules/.tweetnacl-DWEcN9yD'
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-10T16_50_21_221Z-debug.log
                                  Dann geh ich mal wieder dem rename Hobby nach ;-)
                                  Node.js: v22.19.0
                                  NPM: 10.9.3
                                  js-controller 7.0.7
                                  • F Feinfinger
                                    NPM version: 8.1.4
                                    npm ERR! errno -39
                                    apollon77A
                                    apollon77A
                                    #227
                                    @feinfinger Am Ende ist das aber nur ein zeichen das sich in deinem npm Baum Dinger verdreht haben ... Vllt doch mal besser sauberer aufzuräumen ( also node_module löschen, js-controller ma uell installieren und dann starten und ihn alles nacheinander neu installieren lassen .. ja dauert bissl
                                      F
                                      F
                                      Feinfinger
                                      #228
                                      @apollon77
                                      Das würde ich gerne machen, also den gesamten node_module Ordner löschen ist klar, aber wie installiere ich denn den js-controller manuell neu?
                                      Node.js: v22.19.0
                                      NPM: 10.9.3
                                      js-controller 7.0.7
                                      • F Feinfinger
                                        @apollon77
                                        apollon77A
                                        apollon77A
                                        #229
                                        @feinfinger Effektiv wie in https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten bei "d) Reset aller Module in node_modules" beschrieben. Halt beim js-controller mit der neuen Versionsnummer
                                        F 2 Antworten Letzte Antwort
                                          F
                                          F
                                          Feinfinger
                                          #230
                                          @apollon77
                                          Danke dir!
                                          Nur zur Sicherheit, bevor ich anfange ein backup und ein iob stop, richtig?
                                          Node.js: v22.19.0
                                          NPM: 10.9.3
                                          js-controller 7.0.7
                                          33.2k
                                          84.3k
