  4. (gelöst)BLE-Adapter
    6.0k
(gelöst)BLE-Adapter
84 Beiträge 7 Kommentatoren 10.1k Aufrufe 5 Beobachtet
  • ostseereiterO Offline
    ostseereiter
    nun neu installiert nun ist er ja schon mal gelb
    	2022-03-09 18:24:26.455	error	ENODEV, No such device
    ble.0
    2022-03-09 18:24:25.527	info	starting scanner process...
    ble.0
    2022-03-09 18:24:25.524	info	monitored services: fe95
    ble.0
    2022-03-09 18:24:25.521	info	enabled plugins: Xiaomi, mi-flora, _default
    ble.0
    2022-03-09 18:24:25.519	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    ble.0
    2022-03-09 18:24:25.332	info	starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.0, js-controller: 4.0.19
    ble.0
    2022-03-09 18:24:23.559	debug	States connected to redis: 127.0.0.1:9000
    ble.0
    2022-03-09 18:24:23.436	debug	States create User PubSub Client
    ble.0
    2022-03-09 18:24:23.432	debug	States create System PubSub Client
    ble.0
    2022-03-09 18:24:23.354	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    ble.0
    2022-03-09 18:24:23.226	debug	Objects connected to redis: 127.0.0.1:9001
    ble.0
    2022-03-09 18:24:23.190	debug	Objects client initialize lua scripts
    ble.0
    2022-03-09 18:24:22.916	debug	Objects create User PubSub Client
    ble.0
    2022-03-09 18:24:22.914	debug	Objects create System PubSub Client
    ble.0
    2022-03-09 18:24:22.911	debug	Objects client ready ... initialize now
    ble.0
    2022-03-09 18:24:22.778	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    ble.0
    2022-03-09 18:24:16.856	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ble.0
    2022-03-09 18:24:16.854	info	terminating
    ble.0
    2022-03-09 18:24:16.851	info	Got terminate signal TERMINATE_YOURSELF
    ble.0
    2022-03-09 18:23:52.187	error	ENODEV, No such device
    ble.0
    2022-03-09 18:23:51.283	info	starting scanner process...
    ble.0
    2022-03-09 18:23:51.279	info	monitored services: fe95
    ble.0
    2022-03-09 18:23:51.274	info	enabled plugins: Xiaomi, mi-flora, _default
    ble.0
    2022-03-09 18:23:51.273	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    ble.0
    2022-03-09 18:23:51.075	info	starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.0, js-controller: 4.0.19
    ble.0
    2022-03-09 18:23:42.411	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ble.0
    2022-03-09 18:23:42.409	info	terminating
    ble.0
    2022-03-09 18:23:42.407	info	Got terminate signal TERMINATE_YOURSELF
    ble.0
    2022-03-09 18:22:07.322	error	ENODEV, No such device
    ble.0
    2022-03-09 18:22:06.419	info	starting scanner process...
    ble.0
    2022-03-09 18:22:06.407	info	monitored services: fe95
    ble.0
    2022-03-09 18:22:06.403	info	enabled plugins: Xiaomi, mi-flora, _default
    ble.0
    2022-03-09 18:22:06.399	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    ble.0
    2022-03-09 18:22:06.187	info	starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.0, js-controller: 4.0.19
    ble.0
    2022-03-09 18:21:56.769	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ble.0
    2022-03-09 18:21:56.767	info	terminating
    ble.0
    2022-03-09 18:21:56.765	info	Got terminate signal TERMINATE_YOURSELF
    ble.0
    2022-03-09 18:21:42.115	error	ENODEV, No such device
    ble.0
    2022-03-09 18:21:41.274	info	starting scanner process...
    ble.0
    2022-03-09 18:21:41.271	info	monitored services:
    ble.0
    2022-03-09 18:21:41.269	info	enabled plugins: _default
    ble.0
    2022-03-09 18:21:41.267	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    ble.0
    2022-03-09 18:21:40.971	info	starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.0, js-controller: 4.0.19
    Gruß OSR
    Plattform
    • ostseereiterO ostseereiter
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      ble.0
      @ostseereiter sagte in BLE-Adapter:
      Gerät in den Einstellungen angelegt?
      ostseereiterO 1 Antwort Letzte Antwort
        ostseereiter
        so sieht es aus
        Gruß OSR
        Plattform
          so sieht es aus
          @ostseereiter
          Ist denn das noch hci0 oder ist das Gerät durch die Restarts vielleicht auf hci1 gewandert?
            @ostseereiter
            ostseereiter
            andy@debian:~$ hciconfig
            hci1: Type: Primary Bus: USB
            BD Address: 00:1A:7D:DA:71:0F ACL MTU: 310:10 SCO MTU: 64:8
            UP RUNNING
            RX bytes:6547330 acl:0 sco:0 events:183574 errors:0
            TX bytes:14599 acl:0 sco:0 commands:1417 errors:0
            Gruß OSR
            Plattform
              UP RUNNING
              ostseereiter
              @ostseereiter
              ist auf der 1 danke an alle alles grün
              Gruß OSR
              Plattform
                so sieht es aus
                crunchipC Offline
                crunchipC Offline
                @ostseereiter so nebenbei, das update intervall wieder anpassen, z.b. 20000
                  ostseereiter
                  @crunchip sagte in BLE-Adapter:
                  20000
                  ok erledigt
                  Gruß OSR
                  Plattform
                    20000
                    ok erledigt
                    Jan1
                    @ostseereiter
                    bei mir ist auch der Wurm drin:
                    hier sieht noch alles gut aus
                    jan@Beelink:~$ sudo systemctl status bluetooth                                  ● bluetooth.service - Bluetooth service
                         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor pre>
                         Active: active (running) since Wed 2022-03-09 19:08:57 CET; 54min ago
                           Docs: man:bluetoothd(8)
                       Main PID: 557 (bluetoothd)
                         Status: "Running"
                          Tasks: 1 (limit: 4459)
                         Memory: 3.9M
                            CPU: 31ms
                         CGroup: /system.slice/bluetooth.service
                                 └─557 /usr/libexec/bluetooth/bluetoothd
                    hier ist das Ding down
                    jan@Beelink:~$ sudo hciconfig
                    hci0:   Type: Primary  Bus: USB
                            BD Address: 00:00:00:00:00:00  ACL MTU: 0:0  SCO MTU: 0:0
                            DOWN
                            RX bytes:0 acl:0 sco:0 events:0 errors:0
                            TX bytes:4 acl:0 sco:0 commands:1 errors:0
                    • J Jan1
                      @ostseereiter
                           Status: "Running"
                           Memory: 3.9M
                              CPU: 31ms
                              DOWN
                      crunchipC Offline
                      crunchipC Offline
                      @jan1
                      sudo hcitool hci0 up
                        @jan1
                        Jan1
                        @crunchip
                        wäre zu einfach gewesen :
                        jan@Beelink:~$ sudo hcitool hci0 up
                        [sudo] Passwort für jan:
                        Unknown command - "hci0"
                        • J Jan1
                          @crunchip
                          @jan1
                          sudo hciconfig hci0 reset
                          • J Jan1
                            @crunchip
                            crunchipC Offline
                            crunchipC Offline
                            @jan1
                            sudo rfkill list
                              @jan1
                              sudo rfkill list
                              Jan1
                              @crunchip
                              0: phy0: Wireless LAN
                                      Soft blocked: no
                                      Hard blocked: no
                              1: hci0: Bluetooth
                                      Soft blocked: no
                                      Hard blocked: no
                                @jan1
                                Jan1
                                jan@Beelink:~$ sudo hciconfig hci0 reset
                                Can't init device hci0: Connection timed out (110)
                                • crunchipC Offline
                                  crunchipC Offline
                                  @jan1 mal probiert, deinen beelink kurz vom Strom zu nehmen, bei meinem zotac gab es auch hin und wieder Probleme mit dem internen bluetooth, musst dann den rechner kurz vom Strom nehmen, danach funktionierte es wieder
                                    Jan1
                                    @crunchip
                                    das hatte ich zwar schon gemacht, aber eben gerade noch mal und siehe da:
                                            BD Address: F4:D1:08:43:46:D9  ACL MTU: 1021:5  SCO MTU: 96:6
                                            UP RUNNING
                                            RX bytes:1303 acl:0 sco:0 events:83 errors:0
                                            TX bytes:2840 acl:0 sco:0 commands:83 errors:0
                                    • J Offline
                                      Jan1
                                      Die Freude war nur kurz, gestern zwar beide Sensoren gefunden und Adapter grün. Heute Adapter grün aber keine Daten von den Sensoren.
                                      Immer die Kiste runter fahren und stromlos schalten ist daher auch keine wirkliche Alternative um den wieder zu beleben, zumal der auch schon mal zuverlässiger lief. Kein Plan warum der BLE so zickig ist.
                                      • crunchipC Offline
                                        crunchipC Offline
                                        @jan1 alternativ nen externen Stick nehmen
                                          Jan1
                                          @crunchip
                                          Hatte ich auch schon, wobei der interne ja lief.
