  4. (gelöst)BLE-Adapter
    6.0k
(gelöst)BLE-Adapter
84 Beiträge 7 Kommentatoren 10.0k Aufrufe 5 Beobachtet
  • ostseereiterO Offline
    ostseereiter
    jetzt mal das gemacht
    andy@debian:~$ sudo service bluetooth start
    andy@debian:~$ sudo service bluetooth status
    ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: active (running) since Wed 2022-03-09 15:20:44 CET; 1h 6min ago
           Docs: man:bluetoothd(8)
       Main PID: 406 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 8870)
         Memory: 4.7M
            CPU: 69ms
         CGroup: /system.slice/bluetooth.service
                 └─406 /usr/libexec/bluetooth/bluetoothd
    Mär 09 15:20:44 debian bluetoothd[406]: Starting SDP server
    Mär 09 15:20:44 debian bluetoothd[406]: Bluetooth management interface 1.18 initialized
    Mär 09 15:20:44 debian bluetoothd[406]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
    Mär 09 15:20:44 debian bluetoothd[406]: sap-server: Operation not permitted (1)
    Mär 09 15:32:13 debian bluetoothd[406]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
    Mär 09 15:32:13 debian bluetoothd[406]: sap-server: Operation not permitted (1)
    Mär 09 15:34:29 debian bluetoothd[406]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
    Mär 09 15:34:29 debian bluetoothd[406]: sap-server: Operation not permitted (1)
    Mär 09 15:36:45 debian bluetoothd[406]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
    Mär 09 15:36:45 debian bluetoothd[406]: sap-server: Operation not permitted (1)
    andy@debian:~$
    Gruß OSR
    Plattform
    • ostseereiterO ostseereiter
           Status: "Running"
           Memory: 4.7M
              CPU: 69ms
      andy@debian:~$
      @ostseereiter sagte in BLE-Adapter:
      Bluetooth management interface 1.18 initialized Mär 09 15:20:44 debian bluetoothd[406]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
      sudo nano /etc/systemd/system/bluetooth.target.wants/bluetooth.service
      Ändere
      ExecStart=/usr/lib/bluetooth/bluetoothd
      in
      ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sap
      Dann Service einmal neustarten.
      sudo systemctl daemon-reload
      sudo service bluetooth restart
        ostseereiter
        alles erledigt aber adapter immer noch rot.
             Active: active (running) since Wed 2022-03-09 16:41:56 CET; 2min 38s ago
           Main PID: 123701 (bluetoothd)
             Status: "Running"
             Memory: 736.0K
                CPU: 46ms
                     └─123701 /usr/libexec/bluetooth/bluetoothd --noplugin=sap
        Mär 09 16:41:56 debian systemd[1]: Starting Bluetooth service...
        Mär 09 16:41:56 debian bluetoothd[123701]: Bluetooth daemon 5.55
        Mär 09 16:41:56 debian systemd[1]: Started Bluetooth service.
        Mär 09 16:41:56 debian bluetoothd[123701]: Starting SDP server
        Mär 09 16:41:56 debian bluetoothd[123701]: Excluding (cli) sap
        Mär 09 16:41:56 debian bluetoothd[123701]: Bluetooth management interface 1.18 initialized
        Gruß OSR
        Plattform
               Status: "Running"
               Memory: 736.0K
                  CPU: 46ms
          @ostseereiter
          Installier den ble-Adapter nochmal neu.
                 Status: "Running"
                 Memory: 736.0K
                    CPU: 46ms
            crunchipC Abwesend
            crunchipC Abwesend
            @ostseereiter was steht bei
            ble.0.info.driverState
            If the adapter starts but won't connect to your bluetooth hardware, please check the info.driverState state in ioBroker. If it is unauthorized, you need to give node additional permissions. For Linux, this is as simple as
            sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
            ostseereiterO 1 Antwort Letzte Antwort
              ostseereiter
              @crunchip sagte in BLE-Adapter:
              sudo setcap cap_net_raw+eip $(eval readlink -f which node)
              andy@debian:~$ sudo ble.0.info.driverState
              [sudo] Passwort für andy:
              sudo: ble.0.info.driverState: Befehl nicht gefunden
              andy@debian:~$ sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
              andy@debian:~$
              Gruß OSR
              Plattform
                andy@debian:~$
                @ostseereiter
                Mit
                war der entsprechende Datenpunkt im ioBroker gemeint.
                  ostseereiter
                  ooh wie peinlich.🙄
                  Gruß OSR
                  Plattform
                    ooh wie peinlich.🙄
                    @ostseereiter
                    Hardware/Treiber ist offenbar i. O.
                    Hast du den Adapter nochmal per reuild oder neuinstallation 'angepackt'?
                      ooh wie peinlich.🙄
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @ostseereiter und ist jetzt grün? oder immer noch Fehler
                        ostseereiter
                        @crunchip
                        immer noch rot
                        Gruß OSR
                        Plattform
                          @crunchip
                          immer noch rot
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @ostseereiter wenn du die Instanz im debug Modus startest, kommt eventuell ein Hinweis
                            ostseereiter
                            @crunchip
                            le.0
                            2022-03-09 17:18:15.441	error	Terminating because A dependency requires a rebuild.
                            ble.0
                            2022-03-09 17:18:14.642	info	starting scanner process...
                            ble.0
                            2022-03-09 17:18:14.636	info	monitored services: fe95
                            ble.0
                            2022-03-09 17:18:14.634	info	enabled plugins: Xiaomi, mi-flora, _default
                            ble.0
                            2022-03-09 17:18:14.632	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                            ble.0
                            2022-03-09 17:18:14.440	info	starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.0, js-controller: 4.0.19
                            ble.0
                            2022-03-09 17:18:13.009	debug	States connected to redis: 127.0.0.1:9000
                            ble.0
                            2022-03-09 17:18:12.752	debug	States create User PubSub Client
                            ble.0
                            2022-03-09 17:18:12.749	debug	States create System PubSub Client
                            ble.0
                            2022-03-09 17:18:12.589	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                            ble.0
                            2022-03-09 17:18:12.484	debug	Objects connected to redis: 127.0.0.1:9001
                            ble.0
                            2022-03-09 17:18:12.470	debug	Objects client initialize lua scripts
                            ble.0
                            2022-03-09 17:18:12.231	debug	Objects create User PubSub Client
                            ble.0
                            2022-03-09 17:18:12.229	debug	Objects create System PubSub Client
                            ble.0
                            2022-03-09 17:18:12.221	debug	Objects client ready ... initialize now
                            ble.0
                            2022-03-09 17:18:12.084	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                            Gruß OSR
                            Plattform
                              @crunchip
                              le.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              crunchipC Abwesend
                              crunchipC Abwesend
                              hast du wie oben erwähnt den rebuild ausgeführt?
                              iobroker rebuild ble
                                ostseereiter
                                @crunchip
                                ja habe ich
                                Gruß OSR
                                Plattform
                                  @crunchip
                                  ja habe ich
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @ostseereiter mit welcher Meldung?
                                    ostseereiter
                                    @crunchip
                                    das alles ok war ich hatte es nicht gespeichert aber ich kann ja nochmal
                                    Gruß OSR
                                    Plattform
                                      @crunchip
                                      ostseereiter
                                      @crunchip
                                      andy@debian:~$ cd /opt/iobroker
                                      andy@debian:/opt/iobroker$ iobroker rebuild ble
                                      Rebuilding native module "ble" ...
                                      Rebuilding native modules done
                                      Gruß OSR
                                      Plattform
                                        @crunchip
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @ostseereiter dann weiss ich auch nicht mehr weiter
                                        welche Geräte sind denn eigentlich per ble verbunden?
                                        HomoranH ostseereiterO 2 Antworten Letzte Antwort
                                          wenn ich das richtig deute:
                                          werden die deps gar nicht neu gebaut.
                                          müsste man vielleicht mit npm rebuild im richtigen Verzeichnis nochmal versuchen
