  4. Nach update js-controller 4.0.15 ioBroker problem
    6.0k
32 Beiträge 3 Kommentatoren 3.9k Aufrufe 3 Beobachtet
    @mrsonei6
    sudo apt update
    sagt nun?
    Und wie schaut
    iobroker status
    iobroker update -i
    iobroker list instances
    aus?
    MrSonei6
    schrieb am zuletzt editiert von MrSonei6
    pi@raspberrypi:~ $ iobroker status
    Objects type: file
    States  type: file
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iobroker update -i
    Used repository: stable
    hash changed or no sources cached => force download of new sources
    update done
    Adapter    "admin"         : 5.3.1    , installed 5.3.1
    Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
    Adapter    "backitup"      : 2.3.3    , installed 2.3.3
    Adapter    "discovery"     : 2.7.5    , installed 2.7.5
    Adapter    "fakeroku"      : 0.2.1    , installed 0.2.1
    Adapter    "harmony"       : 1.2.2    , installed 1.2.2
    Adapter    "hmip"          : 1.15.4   , installed 1.15.4
    Adapter    "hue"           : 3.6.5    , installed 3.6.5
    Adapter    "ical"          : 1.11.4   , installed 1.11.4
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "javascript"    : 5.2.21   , installed 5.2.21
    Controller "js-controller" : 4.0.15   , installed 3.3.22 [Updateable]
    Adapter    "telegram"      : 1.11.1   , installed 1.11.1
    Adapter    "trashschedule" : 1.4.1    , installed 1.4.1
    Adapter    "web"           : 3.4.16   , installed 3.4.16
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.fakeroku.0               : fakeroku              : raspberrypi                              -  enabled
    + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.siro.0                   : siro                  : raspberrypi                              - disabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    pi@raspberrypi:~ $
    • M MrSonei6
      Objects type: file
      States  type: file
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      update done
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      + instance is alive
      pi@raspberrypi:~ $
      @mrsonei6
      Bitte CodeTags verwenden.
        @mrsonei6
        MrSonei6
        sorry wusst ich nicht wie das geht ;)
        Habs geändert
        • M MrSonei6
          Habs geändert
          @mrsonei6
          Das schaut doch soweit schon mal gut aus.
          iobroker stop
          iobroker update
          iobroker upgrade self
          iobroker fix
          iobroker start
            @mrsonei6
            iobroker stop
            iobroker update
            iobroker fix
            iobroker start
            MrSonei6
            alles durch leider ist die web seite immer noch nciht erreichbar ;(
            Ich habe jetzt auch wieder die "iobroker.json" datei abgeändert und die beiden Types in "file" zurück geändert
            Mir hat jemand geraten das ich dort jsonl rein schreiben soll zweimal siehe anleitung
            Anleitung
            /opt/iobroker/iobroker-data/iobroker.json and change the "type": "file"
            that you have in section "objects" and in section "states" to "jsonl" (so goal: "type": "jsonl",)
            pi@raspberrypi:~ $ iobroker stop
            hash unchanged, use cached sources
            update done
            pi@raspberrypi:~ $ iobroker upgrade self
            Update js-controller from @3.3.22 to @4.0.15
            NPM version: 6.14.16
            npm install iobroker.js-controller@4.0.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
            Server Objects 127.0.0.1:51800 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
            Server Objects 127.0.0.1:51800 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
            Server States 127.0.0.1:52088 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
            Server States 127.0.0.1:52090 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
            Server Objects 127.0.0.1:51800 Error from InMemDB: Error: Unknown LUA script load
            Server Objects 127.0.0.1:51800 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
            Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
            pi@raspberrypi:~ $ iobroker fix
            library: loaded
            Library version=2022-02-10
                Welcome to the ioBroker installation fixer!
                Script version: 2022-02-13
                You might need to enter your password a couple of times.
                Installing prerequisites (1/3)
            OK:1 http://archive.raspberrypi.org/debian buster InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:3 https://deb.nodesource.com/node_12.x buster InRelease
            Installed gcc-c++
            Installed libcairo2-dev
            Installed libpango1.0-dev
            Installed libjpeg-dev
            Installed librsvg2-dev
            Installed cmake
                Checking ioBroker user and directory permissions (2/3)
                Checking autostart (3/3)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            pi@raspberrypi:~ $ iobroker start
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            Objects type: jsonl
            States  type: jsonl
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            Controller "js-controller": 4.0.15   , installed 4.0.15
            Adapter    "trashschedule": 1.4.1    , installed 1.4.1
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            + instance is alive
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            • M MrSonei6
              Anleitung
              update done
              library: loaded
              Installed gcc-c++
              Installed cmake
              Autostart enabled!
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              Objects type: jsonl
              States  type: jsonl
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              + instance is alive
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              @mrsonei6 sagte in Nach update js-controller 4.0.15 ioBroker problem:
              ? Lass die Finger von den json-Files.
              Das wird im Zuge eines ordentlichen Upgrades automatisch gemacht.
              Und jetzt kommst du nicht auf den Admin?
              Achtung! https verwenden.
                MrSonei6
                Es geht wieder
                Wiekann man nun auf node 14 umstellen?
                Was ist das eigentlich ;)
                • M MrSonei6
                  Es geht wieder
                  Schau in meiner Signatur.
                  nodeJS ist vereinfacht gesagt das 'Betriebssystem' für den ioBroker.
                    MrSonei6
                    OK es ist also nicht so einfach mit einem Befehl erledigt?
                    Das sieht nach mehr aus in deinem Link
                    Vielen dank trotzdem schon mal !!
                    Du hast mir das Wochenende gerettet ;)
                    • M MrSonei6
                      Mit zwei-drei.
                      Danach flutscht das auch mit den regulären Updates des Systems mit.
                      Wenn du das denn machen würdest...
                      Zuerst machst du mal ein Upgrade von dem ganzen Betriebssytem. Das hast du noch nie gemacht.
                      Also dringend regelmäßiger das System auf Stand halten.
                        Mit zwei-drei.
                        MrSonei6
                        Hallo ich schau mir gerade das thema Node 14 an.
                        Ich weiß nciht so recht welchen anfangsstatus ich habe und was ich machen muss/darf.
                        Würdest du mir kurz durch helfen Bitte? ;)
                        Muss ich ganz oben in der anleitung anfenagen mit Node Erstinstallation?
                        Ist bei mir nicht schon Node 12 installiert?
                        Hier mal ein Output
                        sudo nano /etc/apt/sources.list.d/nodesource.list
                        deb https://deb.nodesource.com/node_12.x buster main
                        deb-src https://deb.nodesource.com/node_12.x buster main
                        • M MrSonei6
                          Hier mal ein Output
                          Das weiß ich nicht.
                          Aber das passende Repo hast du offenbar.
                          In der Datei aus der 12 eine 14 machen und das ganz normale Systemupgrade dann.
                            Das weiß ich nicht.
                            MrSonei6
                            Hi
                            Gibt es einen befehl mir dem man sehen kann ob Node installiert ist?
                            Falls ja: muss ich also in die Datei rein und diese so bearbeiten?
                            deb https://deb.nodesource.com/node_14.x buster main
                            deb-src https://deb.nodesource.com/node_14.x buster main
                            und dann
                            iobroker stop
                            iobroker update
                            iobroker fix
                            iobroker start
                            richtig
                            Thomas BraunT M 2 Antworten Letzte Antwort
                            • M MrSonei6
                              Hi
                              und dann
                              iobroker stop
                              iobroker update
                              iobroker fix
                              iobroker start
                              richtig
                              Ja, der steht im HowTo drin.
                              Da steht auch drin, wie man sein Gesamtsystem aktualisiert.
                              • M MrSonei6
                                Hi
                                und dann
                                iobroker stop
                                iobroker update
                                iobroker fix
                                iobroker start
                                richtig
                                MrSonei6
                                @mrsonei6
                                Bei dem Link in deiner Signatur geht es gleich los mit Node ERST installation
                                Aber wie man siehen kann ob Node schon installiert ist finde ich ldieder nicht?
                                LG
                                • M MrSonei6
                                  @mrsonei6
                                  LG
                                  @mrsonei6
                                  Mal komplett lesen?
                                  Unter Check steht... Wie man die Installation checkt.
                                  • M MrSonei6
                                    @mrsonei6
                                    LG
                                    MrSonei6
                                    @mrsonei6
                                    bin wie folgt vorgegangen
                                    iobroker stop
                                    Hab dann in der Datei aus den beidne 12 eine 14 gemacht
                                    -sudo nano /etc/apt/sources.list.d/nodesource.list
                                    dann
                                    sudo apt update
                                    sudo apt upgrade
                                    Und der Versionscheck Befehl
                                    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    Zeigt jetzt auch 14 an
                                    pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v14.19.0
                                    v14.19.0
                                    6.14.16
                                    pi
                                    /home/pi
                                    OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                                    Alle Pakete sind aktuell.
                                    nodejs:
                                      Installiert:           14.19.0-deb-1nodesource1
                                      Installationskandidat: 14.19.0-deb-1nodesource1
                                      Versionstabelle:
                                     *** 14.19.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                         10.24.0~dfsg-1~deb10u1 500
                                    pi@raspberrypi:~ $
                                    DANKE!!!!!!!
                                      @mrsonei6
                                      Mal komplett lesen?
                                      Kusi
                                      Bei mir wird beim ersten Start nach jedem Update des js-controller immer diverse Fehler angezeigt.
                                      Weist du woran das liegt?
                                      js-controller v4.0.19
                                      NPM v8.5.0
                                      Node.js v14.19.0
                                      javascript.0
                                      2022-03-09 01:32:58.388	error	coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                      javascript.0
                                      2022-03-09 01:32:58.388	error	deprecated
                                      javascript.0
                                      javascript.0
                                      2022-03-09 01:32:58.387	error	WARN
                                      javascript.0
                                      javascript.0
                                      2022-03-09 01:32:58.387	error	npm
                                      javascript.0
                                      2022-03-09 01:32:58.364	error	request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                      javascript.0
                                      2022-03-09 01:32:58.363	error	deprecated
                                      javascript.0
                                      javascript.0
                                      2022-03-09 01:32:58.363	error	WARN
                                      javascript.0
                                      2022-03-09 01:32:58.362	error
                                      javascript.0
                                      2022-03-09 01:32:58.362	error	npm
                                      javascript.0
                                      2022-03-09 01:32:58.341	error	uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                                      javascript.0
                                      2022-03-09 01:32:58.341	error	deprecated
                                      javascript.0
                                      2022-03-09 01:32:58.340	error
                                      javascript.0
                                      2022-03-09 01:32:58.340	error	WARN
                                      javascript.0
                                      javascript.0
                                      2022-03-09 01:32:58.339	error	npm
                                      javascript.0
                                      2022-03-09 01:32:58.290	error	node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                      javascript.0
                                      2022-03-09 01:32:58.290	error	deprecated
                                      javascript.0
                                      2022-03-09 01:32:58.289	error
                                      javascript.0
                                      2022-03-09 01:32:58.289	error	WARN
                                      javascript.0
                                      javascript.0
                                      2022-03-09 01:32:58.288	error	npm
                                      javascript.0
                                      2022-03-09 01:32:58.223	error	har-validator@5.1.5: this library is no longer supported
                                      javascript.0
                                      2022-03-09 01:32:58.223	error	deprecated
                                      javascript.0
                                      2022-03-09 01:32:58.222	error
                                      javascript.0
                                      2022-03-09 01:32:58.222	error	WARN
                                      javascript.0
                                      javascript.0
                                      2022-03-09 01:32:58.221	error	npm
                                      • K Kusi
                                        NPM v8.5.0
                                        Node.js v14.19.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        @kusi
                                        Keine Fehler, nur Hinweise. Kann man ignorieren.
                                        Allerdings passt dein npm nicht zu nodejs14.
                                          @kusi
                                          Kusi
                                          @thomas-braun sagte in Nach update js-controller 4.0.15 ioBroker problem:
                                          Danke für den Hinweis.
                                          Was soll ich machen um diesen Missstand zu beheben??
