  4. massive CPU Auslastung
146 Beiträge 17 Kommentatoren 42.7k Aufrufe 11 Beobachtet
  • da_WoodyD da_Woody
    hmm, eigentlich so gemacht wie es in der beschreibung steht...
    anyway. nach dem stop ja offensichtlich weg.
    trotzdem kommt
    No connection to databases possible ...
    woody@ioBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
    > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 22
    npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
    npm ERR! Exit status 22
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T13_08_27_568Z-debug.log
    notfalls hab ich mal eine 2. VM jetzt am laufen. wenns hart auf hart geht, versuch ich dort mal ein jännerbackup einspielen...
    @apollon77 jetzt hab ich länger gewartet...
    apollon77A
    apollon77A
    #109
    @da_woody Ja jetzt kommt ja auch kein "can not lock database" - das war darauf bezogen.
    Ok, welche Version ist da denn jetzt drauf wirklich? Es gibt noch eine Idee die ich habe weil es ja jsonl ist.
    editiere /opt/iobroekr/iobroker-data/iobroker.json und schauee dort beide stellen wo ein "connectTiemout" steht und schreibe dort 5000 rein falls 2000 drin steht. Das war früher mal ein Issue - ist ab der 4.0.10 erledigt weil wir dann mindestens 5s warten :-)
    Danach nochmal versuchen
    • apollon77A apollon77
      da_WoodyD
      da_WoodyD
      #110
      @apollon77 gute frage, will einfach nicht starten...
      woody@ioBroker:/opt/iobroker$ iob start
      woody@ioBroker:/opt/iobroker$ iob status
      internal/modules/cjs/loader.js:905
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
          at Function.Module._load (internal/modules/cjs/loader.js:746:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
          throw err;
          requireStack: []
        apollon77A
        apollon77A
        #111
        @da_woody Naja das liegt daran das der npm install es kaputt gemacht hat ... als müssen wir da anfangen
          da_WoodyD
          da_WoodyD
          #112
          @apollon77 muss kurz mit dem hund raus, bin aber zu jeder schandtat bereit... ;)
            apollon77A
            apollon77A
            #113
            @da_woody siehe oben connectTimeout auf 500 setzen, nochmal versuchen
              #114
              @apollon77 sagte in massive CPU Auslastung:
              5000, oder?
                5000, oder?
                da_WoodyD
                da_WoodyD
                #115
                @homoran klar, war auch ein tippfehler drinnen...
                @apollon77 keine änderung...
                gerade mal mit winscp geschaut. das verzeichniss /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js gibts nicht.
                  da_WoodyD
                  da_WoodyD
                  #116
                  @da_woody was ich aber gefunden habe:
                  /opt/iobroker/node_modules/iobroker.backitup/lib/restore/iobroker.js
                  /home/woody/node_modules/iobroker.js-controller/iobroker.js
                    apollon77A
                    apollon77A
                    #117
                    @da_woody sagte in massive CPU Auslastung:
                    Naja das ist der Additional controller den Du dir weiter oben mal selbst verpasst hast. Das sollte aber egal sein.
                    Schreib mal anstelle 5000 eine 10000 an beiden stellen mit connectTimeout rein!! Dann ist die Frage wartet er ca. 10s bevor der Fehler kommt oder kürzer?
                      da_WoodyD
                      da_WoodyD
                      #118
                      @apollon77 beide connectTimeout auf 10000 geändert, gespeichert. nach iob start ist der prompt sofort wieder da max 1sec. keine 10sec.
                      woody@ioBroker:~$ iob start
                      woody@ioBroker:~$ iob status
                        throw err;
                        requireStack: []
                      woody@ioBroker:~$
                          throw err;
                          requireStack: []
                        woody@ioBroker:~$
                        apollon77A
                        apollon77A
                        #119
                        @da_woody Grmmppfffff ... du solltest ein "npm install iobroker.js-controller@3.3.22 --production" versuchen. Der kann nicht starten weil er grad nicht installiert ist. Also erstmal installieren und da gabs den "Connot connect to DB "Fehler
                          da_WoodyD
                          da_WoodyD
                          #120
                          @apollon77 sorry... :D
                          ok
                          woody@ioBroker:~$ npm install iobroker.js-controller@3.3.22 --production
                          > iobroker.js-controller@3.3.22 preinstall /home/woody/node_modules/iobroker.js-controller
                          > iobroker.js-controller@3.3.22 install /home/woody/node_modules/iobroker.js-controller
                          object _design/custom updated
                          object _design/system updated
                          ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                          ioBroker wants to make sure to deliver the most stable smart home system.
                          To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                          THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                          For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                          If you want to disable the error reporting you can use the command
                          'iobroker plugin disable sentry'
                          This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                          npm WARN saveError ENOENT: no such file or directory, open '/home/woody/package.json'
                          npm WARN enoent ENOENT: no such file or directory, open '/home/woody/package.json'
                          npm WARN woody No description
                          npm WARN woody No repository field.
                          npm WARN woody No README data
                          npm WARN woody No license field.
                          + iobroker.js-controller@3.3.22
                          updated 1 package and audited 485 packages in 8.91s
                          12 packages are looking for funding
                            run `npm fund` for details
                          found 21 vulnerabilities (13 low, 5 moderate, 3 high)
                            run `npm audit fix` to fix them, or `npm audit` for details
                          woody@ioBroker:~$
                          sieht mal nicht so schlecht aus... denk ich mal.
                          was bedeutet das run npm audit fix to fix them, or npm audit for details jetzt? soll ich den fix ausführen vor iob start?
                          ich kann diese meldungen nicht wirklich interpretieren ob notwendig, oder nicht.
                            ok
                            woody@ioBroker:~$
                            apollon77A
                            apollon77A
                            #121
                            /home/woody/
                            Jetzt haste es wieder in deinem Home Dir ausgeführt und nicht in /opt/iobroker ... also nochmal bitte an deer richtigen Stelle.
                            npm audit ... ignorieren bzw wenn alles wieder tut machste einmal "iob fix" und das kommt eh nie wieder
                              /home/woody/
                              da_WoodyD
                              da_WoodyD
                              #122
                              @apollon77 oh mann. die shell geschichten treiben mich noch ins irrenhaus.
                              woody@ioBroker:/opt/iobroker$ npm install iobroker.js-controller@3.3.22 --production
                              Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                              npm ERR! errno 24
                              npm ERR! Exit status 24
                              npm ERR!
                              npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T15_24_17_456Z-debug.log
                              jetzt kommen wieder die errors und plötzlich port 9000?
                                npm ERR! errno 24
                                npm ERR!
                                apollon77A
                                apollon77A
                                #123
                                @da_woody Ok, versuch mal ob er vllt den 4.0.10 installiert manuell ... so langsam gehen mir die ideeen aus ... und du bist sicher das nicht iiiiirgendwas auf der kiste noch läuft?
                                opossumO 1 Antwort Letzte Antwort
                                  opossumO
                                  opossumO
                                  opossum
                                  #124
                                  Hallo, @apollon77,
                                  sorry, wenn ich mich hier reinhänge. Ich könnte anbieten, mit @da_Woody via Telefon und Anydesk die VM und den ioB neu aufzusetzen. Dann erst mal sein Backup zurückspielen und dann erst den Contoller 4.0.10. Habe ihm das auch per Chat angeboten. VM aufsetzen und IOB installieren dauert ja nicht lange. Da hätte man dann erst einmal eine "Grundstock", mit dem man arbeiten könnte. Ginge auch sofort.
                                  https://www.schlepper-petersdorf.de
                                  • opossumO opossum
                                    Hallo, @apollon77,
                                    apollon77A
                                    apollon77A
                                    #125
                                    @opossum So etwas wäre mein nächster Vorshclag gewesen ... Und eine super Idee. Ist natürlich @da_Woody entscheiden, aber vielen Dank für das Angebot von mir in jedem Fall!
                                    • da_WoodyD
                                      da_WoodyD
                                      #126
                                      login as: woody
                                      woody@192.168.0.250's password:
                                      Linux ioBroker 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64
                                      permitted by applicable law.
                                      Last login: Wed Feb 16 16:18:11 2022 from 192.168.7.209
                                      woody@ioBroker:~$ cd /opt/iobroker
                                      woody@ioBroker:/opt/iobroker$ ps auxww|grep io
                                      root        12  0.0  0.0      0     0 ?        S    16:17   0:00 [migration/0]
                                      root        16  0.0  0.0      0     0 ?        S    16:17   0:00 [migration/1]
                                      root       212  0.0  0.0      0     0 ?        I<   16:17   0:00 [rpciod]
                                      root       215  0.0  0.0      0     0 ?        I<   16:17   0:00 [xprtiod]
                                      message+   370  0.0  0.0   9100  4280 ?        Ss   16:17   0:07 /usr/bin/dbus-daemon --system --address=systemd: --nofork -        -nopidfile --systemd-activation --syslog-only
                                      woody    11698  0.0  0.0   6088   888 pts/1    S+   21:12   0:00 grep io
                                      woody@ioBroker:/opt/iobroker$ ps auxww|grep backup
                                      woody    11732  0.0  0.0   6088   888 pts/1    S+   21:12   0:00 grep backup
                                      sieht für mich nicht danach aus...
                                      versucht mit 4.0.10. auch nicht. hab aber das log mal rausgefischt das am schluß angegeben ist. vllt hilft das?
                                      0 info it worked if it ends with ok
                                      1 verbose cli [
                                      1 verbose cli   '/usr/bin/node',
                                      1 verbose cli   '/usr/bin/npm',
                                      1 verbose cli   'install',
                                      1 verbose cli   'iobroker.js-controller@4.0.10',
                                      1 verbose cli   '--production'
                                      1 verbose cli ]
                                      2 info using npm@6.14.16
                                      3 info using node@v14.19.0
                                      4 verbose npm-session ec259e75475dbf14
                                      5 silly install loadCurrentTree
                                      6 silly install readLocalPackageData
                                      7 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 1004ms
                                      8 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller/-/iobroker.js-controller-4.0.10.tgz 97ms
                                      9 silly pacote version manifest for iobroker.js-controller@4.0.10 fetched in 1127ms
                                      10 timing stage:loadCurrentTree Completed in 3105ms
                                      11 silly install loadIdealTree
                                      12 silly install cloneCurrentTreeToIdealTree
                                      13 timing stage:loadIdealTree:cloneCurrentTree Completed in 29ms
                                      14 silly install loadShrinkwrap
                                      15 timing stage:loadIdealTree:loadShrinkwrap Completed in 1076ms
                                      16 silly install loadAllDepsIntoIdealTree
                                      17 silly resolveWithNewModule iobroker.js-controller@4.0.10 checking installable status
                                      18 silly removeObsoleteDep removing iobroker.js-controller@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                      19 silly removeObsoleteDep removing @alcalzone/esbuild-register@2.5.1-1 from the tree as its been replaced by a newer version or is no longer required
                                      20 silly removeObsoleteDep removing esbuild@0.11.23 from the tree as its been replaced by a newer version or is no longer required
                                      21 silly removeObsoleteDep removing jsonc-parser@3.0.0 from the tree as its been replaced by a newer version or is no longer required
                                      22 silly removeObsoleteDep removing @iobroker/js-controller-adapter@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                      23 silly removeObsoleteDep removing node-schedule@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                      24 silly removeObsoleteDep removing cron-parser@3.5.0 from the tree as its been replaced by a newer version or is no longer required
                                      25 silly removeObsoleteDep removing luxon@1.28.0 from the tree as its been replaced by a newer version or is no longer required
                                      26 silly removeObsoleteDep removing semver@7.3.5 from the tree as its been replaced by a newer version or is no longer required
                                      27 silly removeObsoleteDep removing @iobroker/js-controller-cli@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                      28 silly removeObsoleteDep removing debug@4.3.3 from the tree as its been replaced by a newer version or is no longer required
                                      29 silly removeObsoleteDep removing ms@2.1.2 from the tree as its been replaced by a newer version or is no longer required
                                      30 silly removeObsoleteDep removing @iobroker/js-controller-common-db@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                      31 silly removeObsoleteDep removing @iobroker/db-objects-file@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                      32 silly removeObsoleteDep removing @iobroker/db-base@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                      33 silly removeObsoleteDep removing @iobroker/js-controller-common@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                      34 silly removeObsoleteDep removing @alcalzone/pak@0.7.0 from the tree as its been replaced by a newer version or is no longer required
                                      35 silly removeObsoleteDep removing execa@5.1.1 from the tree as its been replaced by a newer version or is no longer required
                                      36 silly removeObsoleteDep removing cross-spawn@7.0.3 from the tree as its been replaced by a newer version or is no longer required
                                      37 silly removeObsoleteDep removing path-key@3.1.1 from the tree as its been replaced by a newer version or is no longer required
                                      38 silly removeObsoleteDep removing shebang-command@2.0.0 from the tree as its been replaced by a newer version or is no longer required
                                      39 silly removeObsoleteDep removing shebang-regex@3.0.0 from the tree as its been replaced by a newer version or is no longer required
                                      40 silly removeObsoleteDep removing get-stream@6.0.1 from the tree as its been replaced by a newer version or is no longer required
                                      41 silly removeObsoleteDep removing human-signals@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                      42 silly removeObsoleteDep removing merge-stream@2.0.0 from the tree as its been replaced by a newer version or is no longer required
                                      43 silly removeObsoleteDep removing npm-run-path@4.0.1 from the tree as its been replaced by a newer version or is no longer required
                                      44 silly removeObsoleteDep removing onetime@5.1.2 from the tree as its been replaced by a newer version or is no longer required
                                      45 silly removeObsoleteDep removing mimic-fn@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                      • Jabba_the_HuttJ
                                        Jabba_the_HuttJ
                                        Jabba_the_Hutt
                                        #127
                                        nachdem ja der Port 9000 blockiert war/ist ...
                                        was bringt
                                        sudo netstat -tulpen | grep -i 9000
                                        • Jabba_the_HuttJ Jabba_the_Hutt
                                          was bringt
                                          da_WoodyD
                                          da_WoodyD
                                          #128
                                          @jabba_the_hutt moin. jetzt gar nichts mehr... :D
                                          gestern spät abends noch mit @opossum rumgefummelt. wir hatten schon eine neue VM fertig mit backup, mussten dann aber feststellen, daß das backup zu jung war. war schon auf jsonl. dann drauf gepfiffen und die ioBroker VMs platt gemacht.
                                          nachdem dann auch noch proxmox rumgezickt hat, ich konnte keine IP an die MAC binden, haben wir dann aufgehört und machen heute weiter.
                                          inzwischen hab ich mal eine debian11 VM mit richtiger IP. kurze nacht...
                                          33.2k
                                          84.4k
