  4. massive CPU Auslastung
146 Beiträge 17 Kommentatoren 42.7k Aufrufe 11 Beobachtet
    @da_woody sagte in massive CPU Auslastung:
    kann das wetterstation gewesen sein?
    Klar. Insbesondere, wenn das (unnötigerweise wohl) als root läuft. Dessen Prozesse kann man nicht so einfach rauskicken.
    da_WoodyD
    da_WoodyD
    #108
    hmm, eigentlich so gemacht wie es in der beschreibung steht...
    anyway. nach dem stop ja offensichtlich weg.
    trotzdem kommt
    No connection to databases possible ...
    woody@ioBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
    > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 22
    npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
    npm ERR! Exit status 22
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T13_08_27_568Z-debug.log
    notfalls hab ich mal eine 2. VM jetzt am laufen. wenns hart auf hart geht, versuch ich dort mal ein jännerbackup einspielen...
    @apollon77 jetzt hab ich länger gewartet...
    • da_WoodyD da_Woody
      trotzdem kommt
      npm ERR! errno 22
      npm ERR!
      apollon77A
      apollon77A
      #109
      @da_woody Ja jetzt kommt ja auch kein "can not lock database" - das war darauf bezogen.
      Ok, welche Version ist da denn jetzt drauf wirklich? Es gibt noch eine Idee die ich habe weil es ja jsonl ist.
      editiere /opt/iobroekr/iobroker-data/iobroker.json und schauee dort beide stellen wo ein "connectTiemout" steht und schreibe dort 5000 rein falls 2000 drin steht. Das war früher mal ein Issue - ist ab der 4.0.10 erledigt weil wir dann mindestens 5s warten :-)
      Danach nochmal versuchen
      • apollon77A apollon77
        da_WoodyD
        da_WoodyD
        #110
        @apollon77 gute frage, will einfach nicht starten...
        woody@ioBroker:/opt/iobroker$ iob start
        woody@ioBroker:/opt/iobroker$ iob status
        internal/modules/cjs/loader.js:905
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
            at Function.Module._load (internal/modules/cjs/loader.js:746:27)
            at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
            at internal/main/run_main_module.js:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
            throw err;
            requireStack: []
          apollon77A
          apollon77A
          #111
          @da_woody Naja das liegt daran das der npm install es kaputt gemacht hat ... als müssen wir da anfangen
            da_WoodyD
            da_WoodyD
            #112
            @apollon77 muss kurz mit dem hund raus, bin aber zu jeder schandtat bereit... ;)
              apollon77A
              apollon77A
              #113
              @da_woody siehe oben connectTimeout auf 500 setzen, nochmal versuchen
                #114
                @apollon77 sagte in massive CPU Auslastung:
                5000, oder?
                  5000, oder?
                  da_WoodyD
                  da_WoodyD
                  #115
                  @homoran klar, war auch ein tippfehler drinnen...
                  @apollon77 keine änderung...
                  gerade mal mit winscp geschaut. das verzeichniss /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js gibts nicht.
                    da_WoodyD
                    da_WoodyD
                    #116
                    @da_woody was ich aber gefunden habe:
                    /opt/iobroker/node_modules/iobroker.backitup/lib/restore/iobroker.js
                    /home/woody/node_modules/iobroker.js-controller/iobroker.js
                      apollon77A
                      apollon77A
                      #117
                      Naja das ist der Additional controller den Du dir weiter oben mal selbst verpasst hast. Das sollte aber egal sein.
                      Schreib mal anstelle 5000 eine 10000 an beiden stellen mit connectTimeout rein!! Dann ist die Frage wartet er ca. 10s bevor der Fehler kommt oder kürzer?
                        da_WoodyD
                        da_WoodyD
                        #118
                        @apollon77 beide connectTimeout auf 10000 geändert, gespeichert. nach iob start ist der prompt sofort wieder da max 1sec. keine 10sec.
                        woody@ioBroker:~$ iob start
                        woody@ioBroker:~$ iob status
                          throw err;
                          requireStack: []
                        woody@ioBroker:~$
                            throw err;
                            requireStack: []
                          woody@ioBroker:~$
                          apollon77A
                          apollon77A
                          #119
                          @da_woody Grmmppfffff ... du solltest ein "npm install iobroker.js-controller@3.3.22 --production" versuchen. Der kann nicht starten weil er grad nicht installiert ist. Also erstmal installieren und da gabs den "Connot connect to DB "Fehler
                            da_WoodyD
                            da_WoodyD
                            #120
                            @apollon77 sorry... :D
                            ok
                            woody@ioBroker:~$ npm install iobroker.js-controller@3.3.22 --production
                            > iobroker.js-controller@3.3.22 preinstall /home/woody/node_modules/iobroker.js-controller
                            > iobroker.js-controller@3.3.22 install /home/woody/node_modules/iobroker.js-controller
                            object _design/custom updated
                            object _design/system updated
                            ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                            ioBroker wants to make sure to deliver the most stable smart home system.
                            To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                            THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                            For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                            If you want to disable the error reporting you can use the command
                            'iobroker plugin disable sentry'
                            This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                            npm WARN saveError ENOENT: no such file or directory, open '/home/woody/package.json'
                            npm WARN enoent ENOENT: no such file or directory, open '/home/woody/package.json'
                            npm WARN woody No description
                            npm WARN woody No repository field.
                            npm WARN woody No README data
                            npm WARN woody No license field.
                            + iobroker.js-controller@3.3.22
                            updated 1 package and audited 485 packages in 8.91s
                            12 packages are looking for funding
                              run `npm fund` for details
                            found 21 vulnerabilities (13 low, 5 moderate, 3 high)
                              run `npm audit fix` to fix them, or `npm audit` for details
                            woody@ioBroker:~$
                            sieht mal nicht so schlecht aus... denk ich mal.
                            was bedeutet das run npm audit fix to fix them, or npm audit for details jetzt? soll ich den fix ausführen vor iob start?
                            ich kann diese meldungen nicht wirklich interpretieren ob notwendig, oder nicht.
                              ok
                              woody@ioBroker:~$
                              apollon77A
                              apollon77A
                              #121
                              /home/woody/
                              Jetzt haste es wieder in deinem Home Dir ausgeführt und nicht in /opt/iobroker ... also nochmal bitte an deer richtigen Stelle.
                              npm audit ... ignorieren bzw wenn alles wieder tut machste einmal "iob fix" und das kommt eh nie wieder
                                /home/woody/
                                da_WoodyD
                                da_WoodyD
                                #122
                                @apollon77 oh mann. die shell geschichten treiben mich noch ins irrenhaus.
                                woody@ioBroker:/opt/iobroker$ npm install iobroker.js-controller@3.3.22 --production
                                Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                npm ERR! errno 24
                                npm ERR! Exit status 24
                                npm ERR!
                                npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T15_24_17_456Z-debug.log
                                jetzt kommen wieder die errors und plötzlich port 9000?
                                  npm ERR! errno 24
                                  npm ERR!
                                  apollon77A
                                  apollon77A
                                  #123
                                  @da_woody Ok, versuch mal ob er vllt den 4.0.10 installiert manuell ... so langsam gehen mir die ideeen aus ... und du bist sicher das nicht iiiiirgendwas auf der kiste noch läuft?
                                  opossumO 1 Antwort Letzte Antwort
                                    opossumO
                                    opossumO
                                    opossum
                                    #124
                                    Hallo, @apollon77,
                                    sorry, wenn ich mich hier reinhänge. Ich könnte anbieten, mit @da_Woody via Telefon und Anydesk die VM und den ioB neu aufzusetzen. Dann erst mal sein Backup zurückspielen und dann erst den Contoller 4.0.10. Habe ihm das auch per Chat angeboten. VM aufsetzen und IOB installieren dauert ja nicht lange. Da hätte man dann erst einmal eine "Grundstock", mit dem man arbeiten könnte. Ginge auch sofort.
                                    https://www.schlepper-petersdorf.de
                                    • opossumO opossum
                                      Hallo, @apollon77,
                                      apollon77A
                                      apollon77A
                                      #125
                                      @opossum So etwas wäre mein nächster Vorshclag gewesen ... Und eine super Idee. Ist natürlich @da_Woody entscheiden, aber vielen Dank für das Angebot von mir in jedem Fall!
                                      • da_WoodyD
                                        da_WoodyD
                                        #126
                                        login as: woody
                                        woody@192.168.0.250's password:
                                        Linux ioBroker 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64
                                        permitted by applicable law.
                                        Last login: Wed Feb 16 16:18:11 2022 from 192.168.7.209
                                        woody@ioBroker:~$ cd /opt/iobroker
                                        woody@ioBroker:/opt/iobroker$ ps auxww|grep io
                                        root        12  0.0  0.0      0     0 ?        S    16:17   0:00 [migration/0]
                                        root        16  0.0  0.0      0     0 ?        S    16:17   0:00 [migration/1]
                                        root       212  0.0  0.0      0     0 ?        I<   16:17   0:00 [rpciod]
                                        root       215  0.0  0.0      0     0 ?        I<   16:17   0:00 [xprtiod]
                                        message+   370  0.0  0.0   9100  4280 ?        Ss   16:17   0:07 /usr/bin/dbus-daemon --system --address=systemd: --nofork -        -nopidfile --systemd-activation --syslog-only
                                        woody    11698  0.0  0.0   6088   888 pts/1    S+   21:12   0:00 grep io
                                        woody@ioBroker:/opt/iobroker$ ps auxww|grep backup
                                        woody    11732  0.0  0.0   6088   888 pts/1    S+   21:12   0:00 grep backup
                                        sieht für mich nicht danach aus...
                                        versucht mit 4.0.10. auch nicht. hab aber das log mal rausgefischt das am schluß angegeben ist. vllt hilft das?
                                        0 info it worked if it ends with ok
                                        1 verbose cli [
                                        1 verbose cli   '/usr/bin/node',
                                        1 verbose cli   '/usr/bin/npm',
                                        1 verbose cli   'install',
                                        1 verbose cli   'iobroker.js-controller@4.0.10',
                                        1 verbose cli   '--production'
                                        1 verbose cli ]
                                        2 info using npm@6.14.16
                                        3 info using node@v14.19.0
                                        4 verbose npm-session ec259e75475dbf14
                                        5 silly install loadCurrentTree
                                        6 silly install readLocalPackageData
                                        7 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 1004ms
                                        8 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller/-/iobroker.js-controller-4.0.10.tgz 97ms
                                        9 silly pacote version manifest for iobroker.js-controller@4.0.10 fetched in 1127ms
                                        10 timing stage:loadCurrentTree Completed in 3105ms
                                        11 silly install loadIdealTree
                                        12 silly install cloneCurrentTreeToIdealTree
                                        13 timing stage:loadIdealTree:cloneCurrentTree Completed in 29ms
                                        14 silly install loadShrinkwrap
                                        15 timing stage:loadIdealTree:loadShrinkwrap Completed in 1076ms
                                        16 silly install loadAllDepsIntoIdealTree
                                        17 silly resolveWithNewModule iobroker.js-controller@4.0.10 checking installable status
                                        18 silly removeObsoleteDep removing iobroker.js-controller@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                        19 silly removeObsoleteDep removing @alcalzone/esbuild-register@2.5.1-1 from the tree as its been replaced by a newer version or is no longer required
                                        20 silly removeObsoleteDep removing esbuild@0.11.23 from the tree as its been replaced by a newer version or is no longer required
                                        21 silly removeObsoleteDep removing jsonc-parser@3.0.0 from the tree as its been replaced by a newer version or is no longer required
                                        22 silly removeObsoleteDep removing @iobroker/js-controller-adapter@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                        23 silly removeObsoleteDep removing node-schedule@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                        24 silly removeObsoleteDep removing cron-parser@3.5.0 from the tree as its been replaced by a newer version or is no longer required
                                        25 silly removeObsoleteDep removing luxon@1.28.0 from the tree as its been replaced by a newer version or is no longer required
                                        26 silly removeObsoleteDep removing semver@7.3.5 from the tree as its been replaced by a newer version or is no longer required
                                        27 silly removeObsoleteDep removing @iobroker/js-controller-cli@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                        28 silly removeObsoleteDep removing debug@4.3.3 from the tree as its been replaced by a newer version or is no longer required
                                        29 silly removeObsoleteDep removing ms@2.1.2 from the tree as its been replaced by a newer version or is no longer required
                                        30 silly removeObsoleteDep removing @iobroker/js-controller-common-db@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                        31 silly removeObsoleteDep removing @iobroker/db-objects-file@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                        32 silly removeObsoleteDep removing @iobroker/db-base@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                        33 silly removeObsoleteDep removing @iobroker/js-controller-common@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                        34 silly removeObsoleteDep removing @alcalzone/pak@0.7.0 from the tree as its been replaced by a newer version or is no longer required
                                        35 silly removeObsoleteDep removing execa@5.1.1 from the tree as its been replaced by a newer version or is no longer required
                                        36 silly removeObsoleteDep removing cross-spawn@7.0.3 from the tree as its been replaced by a newer version or is no longer required
                                        37 silly removeObsoleteDep removing path-key@3.1.1 from the tree as its been replaced by a newer version or is no longer required
                                        38 silly removeObsoleteDep removing shebang-command@2.0.0 from the tree as its been replaced by a newer version or is no longer required
                                        39 silly removeObsoleteDep removing shebang-regex@3.0.0 from the tree as its been replaced by a newer version or is no longer required
                                        40 silly removeObsoleteDep removing get-stream@6.0.1 from the tree as its been replaced by a newer version or is no longer required
                                        41 silly removeObsoleteDep removing human-signals@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                        42 silly removeObsoleteDep removing merge-stream@2.0.0 from the tree as its been replaced by a newer version or is no longer required
                                        43 silly removeObsoleteDep removing npm-run-path@4.0.1 from the tree as its been replaced by a newer version or is no longer required
                                        44 silly removeObsoleteDep removing onetime@5.1.2 from the tree as its been replaced by a newer version or is no longer required
                                        45 silly removeObsoleteDep removing mimic-fn@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                        • Jabba_the_HuttJ
                                          Jabba_the_HuttJ
                                          Jabba_the_Hutt
                                          #127
                                          nachdem ja der Port 9000 blockiert war/ist ...
                                          was bringt
                                          sudo netstat -tulpen | grep -i 9000
                                          33.2k
                                          84.4k
