  4. massive CPU Auslastung
146 Beiträge 17 Kommentatoren 42.7k Aufrufe 11 Beobachtet
  • da_WoodyD da_Woody
    @crunchip wahrscheinlich war die birne gestern schon zu voll. heute hats geklappt... die 2. broker VM steht mal.
    wenigstens was mal.
    dafür hats mir den anderen bei downgrade jetzt zerbröselt. :(
    woody@ioBroker:/$ cd /opt/iobroker
    woody@ioBroker:/opt/iobroker$ iob stop
    woody@ioBroker:/opt/iobroker$ npm install iobroker.js-controller@3.3.22
    [sudo] Passwort für woody:
    > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    No connection to databases possible ...
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 22
    npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
    npm ERR! Exit status 22
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T10_02_10_749Z-debug.log
    und zum drüberstreuen:
    woody@ioBroker:/opt/iobroker$ iob start
    woody@ioBroker:/opt/iobroker$ iob status
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #94
    @da_woody sagte in massive CPU Auslastung:
    Müsste
    sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
    lauten.
      Müsste
      lauten.
      da_WoodyD
      da_WoodyD
      #95
      @thomas-braun du meinst für eine neuinstall?
      ich hab mich ja an die beschreibung für dein downgrade (jetzt im richtigen verzeichniss gehalten...)
      wenn ich das richtig verstehe, dürfte keine 2. version im system sein.
      Thomas BraunT apollon77A 2 Antworten Letzte Antwort
        Thomas BraunT
        Thomas BraunT
        #96
        @da_woody
        Wenn du mit
        eine Neuinstallation (genauer: 'Drüberinstallation) bezwecken wolltest:
        Der npm-Aufruf sollte im Kontext des users 'iobroker' erfolgen. Dann passen auch die Rechte.
        Macht man dann halt so:
          @da_woody
          Wenn du mit
          da_WoodyD
          da_WoodyD
          #97
          @thomas-braun sagte in massive CPU Auslastung:
          eine Neuinstallation bezwecken wolltest:
          nein, das war für den downgrade von 4.0.9 gedacht!
          sorry, aber ich hinterfrage jetzt lieber, als wieder einen fehler zu machen. bin ja lernwillig.
            Thomas BraunT
            Thomas BraunT
            #98
            @da_woody
            Auch ein Downgrade geht so.
              @da_woody
              da_WoodyD
              da_WoodyD
              #99
              @thomas-braun hmm, dann stimmt die beschreibung nicht...
              ok mal gamacht:
              woody@ioBroker:/$
              woody@ioBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
              Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
              npm ERR! errno 24
              npm ERR! Exit status 24
              npm ERR!
              npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T12_27_04_526Z-debug.log
              sieht nicht so gut aus...
                throw err;
                requireStack: []
                ok mal gamacht:
                woody@ioBroker:/$
                npm ERR! errno 24
                npm ERR!
                  throw err;
                  requireStack: []
                Thomas BraunT
                Thomas BraunT
                #100
                Vermutlich läuft da schon oder noch was anderes auf dem Port.
                Oder das hängt mit dem neuen Format jsonl der Datenbank zusammen.
                Da weiß ich aber so aus dem Stehgreif nicht wie man das beibiegen kann.
                  da_WoodyD
                  da_WoodyD
                  #101
                  @thomas-braun die zeile ist mir auch ins auge gehüpft. also doch noch ein anderer JS-Contoller?
                  sonst würde mir nichts einfallen...
                    apollon77A
                    apollon77A
                    #102
                    Also einen Neuinstall bitte mit dem Installer machen!!!!!
                      ok mal gamacht:
                      woody@ioBroker:/$
                      npm ERR! errno 24
                      npm ERR!
                        throw err;
                        requireStack: []
                      apollon77A
                      apollon77A
                      #103
                      @da_woody Stelle sicher das alles von ioBroker gestoppt ist bevor du den Befehl machst und warte bitte sicherheitshalber 10s nachdem alles nachweislich gestoppt ist bevir du den 3.3.22 install machst
                      • apollon77A apollon77
                        da_WoodyD
                        da_WoodyD
                        #104
                        @apollon77 da gings um den js-contoller!
                        die neue VM hab ich sehr wohl mit dem installer gemacht.
                          da_WoodyD
                          da_WoodyD
                          #105
                          @apollon77 sagte in massive CPU Auslastung:
                          woody@ioBroker:/opt/iobroker$ ps auxww|grep io
                          root        12  0.0  0.0      0     0 ?        S    Feb15   0:00 [migration/0]
                          root        16  0.0  0.0      0     0 ?        S    Feb15   0:00 [migration/1]
                          root       193  0.0  0.0      0     0 ?        I<   Feb15   0:00 [rpciod]
                          root       194  0.0  0.0      0     0 ?        I<   Feb15   0:00 [xprtiod]
                          root       352  0.1  0.0   7920  3188 ?        Ss   Feb15   1:35 /bin/bash /home/woody/wetterstation.sh
                          message+   359  0.0  0.0   9068  1668 ?        Ss   Feb15   0:04 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                          root      1172  0.0  0.0      0     0 ?        I<   Feb15   0:00 [cifsiod]
                          root      9724  0.0  0.0   7920  2428 ?        S    13:55   0:00 /bin/bash /home/woody/wetterstation.sh
                          woody     9729  0.0  0.0   6088   884 pts/0    S+   13:55   0:00 grep io
                          woody@ioBroker:/opt/iobroker$ sudo systemctl stop wetterstation
                          woody    10247  0.0  0.0   6088   892 pts/0    S+   13:57   0:00 grep io
                          woody@ioBroker:/opt/iobroker$ ps auxww|grep backup
                          woody    10249  0.0  0.0   6088   888 pts/0    S+   13:57   0:00 grep backup
                          kann das wetterstation gewesen sein?
                            Thomas BraunT
                            Thomas BraunT
                            #106
                            Klar. Insbesondere, wenn das (unnötigerweise wohl) als root läuft. Dessen Prozesse kann man nicht so einfach rauskicken.
                              apollon77A
                              apollon77A
                              #107
                              @da_woody Nein, die hat ja nix mit dem File zu tun. Ich denke du warst ggf nach dem Stoppen zu schnell
                                da_WoodyD
                                da_WoodyD
                                #108
                                hmm, eigentlich so gemacht wie es in der beschreibung steht...
                                anyway. nach dem stop ja offensichtlich weg.
                                trotzdem kommt
                                npm ERR! errno 22
                                npm ERR!
                                npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T13_08_27_568Z-debug.log
                                notfalls hab ich mal eine 2. VM jetzt am laufen. wenns hart auf hart geht, versuch ich dort mal ein jännerbackup einspielen...
                                @apollon77 jetzt hab ich länger gewartet...
                                  trotzdem kommt
                                  npm ERR! errno 22
                                  npm ERR!
                                  apollon77A
                                  apollon77A
                                  #109
                                  @da_woody Ja jetzt kommt ja auch kein "can not lock database" - das war darauf bezogen.
                                  Ok, welche Version ist da denn jetzt drauf wirklich? Es gibt noch eine Idee die ich habe weil es ja jsonl ist.
                                  editiere /opt/iobroekr/iobroker-data/iobroker.json und schauee dort beide stellen wo ein "connectTiemout" steht und schreibe dort 5000 rein falls 2000 drin steht. Das war früher mal ein Issue - ist ab der 4.0.10 erledigt weil wir dann mindestens 5s warten :-)
                                  Danach nochmal versuchen
                                    da_WoodyD
                                    da_WoodyD
                                    #110
                                    @apollon77 gute frage, will einfach nicht starten...
                                      throw err;
                                      requireStack: []
                                        throw err;
                                        requireStack: []
                                      apollon77A
                                      apollon77A
                                      #111
                                      @da_woody Naja das liegt daran das der npm install es kaputt gemacht hat ... als müssen wir da anfangen
                                        da_WoodyD
                                        da_WoodyD
                                        #112
                                        @apollon77 muss kurz mit dem hund raus, bin aber zu jeder schandtat bereit... ;)
                                          apollon77A
                                          apollon77A
                                          #113
                                          @da_woody siehe oben connectTimeout auf 500 setzen, nochmal versuchen
                                          33.2k
                                          84.4k
