  4. Test Adapter fitbit-api v0.1.x Latest
tester
62 Beiträge 13 Kommentatoren 14.3k Aufrufe 15 Beobachtet
  • besterquesterB besterquester
    @schroed99 in der latest habe ich auf Minuten umgestellt in deiner Version noch sekunden genau lGC
    Ahnungsbefreit
    @besterquester ich habe eben auch mal auf meinem Testsystem die Version von Deinem Github installiert und bekomme auf Level "Debug" die folgenden Meldungen:
    $ iobroker url https://github.com/Chris-1965/ioBroker.fitbit --host ioBVM-test --debug
    install Chris-1965/ioBroker.fitbit#d0db61a1fc0d972faecb6ac90f3def37f356b0ea
    NPM version: 6.14.15
    npm install Chris-1965/ioBroker.fitbit#d0db61a1fc0d972faecb6ac90f3def37f356b0ea --prefix "/opt/iobroker" (System call)
    > cpu-features@0.0.2 install /opt/iobroker/node_modules/cpu-features> node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/cpu-features/build“ wird betreten
    ACTION Configuring dependencies /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile
    /bin/sh: 1: cmake: not found
    make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile] Fehler 127gyp ERR! build error make: Verzeichnis „/opt/iobroker/node_modules/cpu-features/build“ wird verlassengyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
    gyp ERR! System Linux 4.19.0-18-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/cpu-featuresgyp ERR! node -v v14.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.2 (node_modules/cpu-features):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + iobroker.fitbit@0.1.3added 3 packages from 3 contributors in 17.392s
    71 packages are looking for funding run `npm fund` for details
    upload [3] fitbit.admin /opt/iobroker/node_modules/iobroker.fitbit/admin/words.js words.js application/javascript
    upload [2] fitbit.admin /opt/iobroker/node_modules/iobroker.fitbit/admin/style.css style.css text/css
    upload [1] fitbit.admin /opt/iobroker/node_modules/iobroker.fitbit/admin/index_m.html index_m.html text/html
    upload [0] fitbit.admin /opt/iobroker/node_modules/iobroker.fitbit/admin/fitbit.png fitbit.png image/png
    Process exited with code 0
    Wollen mir der ERR und wie WARNs etwas sagen oder ist das "works as designed"? :-)
    besterquesterB 1 Antwort Letzte Antwort
      schroed99S Offline
      schroed99S Offline
      schroed99
      @besterquester
      Ja, sehr geil. Ich hab das Intervall auf 180 gestellt. Damit laufen beide Instanzen und liefern sauber die Daten. Kannst du mir sagen, wie ich Daten an FitBit senden kann(API)? Ich überlege gerade, eine VIS zu bauen, wo ich die Trink/Essdaten erfassen kann. Damit müsste ich zu Hause nicht die App/Webseite öffnen um Trinkmengen an meine FitBit Cloud zu senden. Bzw. möchte ich von meinen Bauchtrainer Wiederholungen/Kalorien an Fitbit senden.
      schroed99S 1 Antwort Letzte Antwort
      • schroed99S schroed99
        @besterquester
        schroed99S Offline
        schroed99S Offline
        schroed99
        schrieb am zuletzt editiert von schroed99
        @besterquester
        Guten Morgen,
        ich habe jetzt einen Tag lang die neue Adapter-Version von Chris getestet. Erst einmal vorweg, vielen Dank für die tolle Arbeit, ich bzw. wir freuen uns Entwickler wie Dich zu haben.
        Mein Ergebnis aus 24 h test´s ich bin bisher sehr zufrieden, paar wenige kleinere Dinge gilt es noch zu beseitigen dann ist der Adapter perfekt. 👍
        Was habe ich gemerkt, es kommen Daten von FitBit, aber leider unzuverlässig. Es gibt Daten die kommen sehr schnell z.b. meine Personenwaage, aber manche kommen gar nicht oder sehr spät. Konkretes Beispiel, ich habe heute bereits Trinkdaten eingegeben per Webseite/App. Diese werden nicht geändert bzw. wurden diese 0 Uhr nicht zurückgesetzt. Was gut funktioniert sind Daten von meiner Waage. Diese sind sehr schnell im System. Auf den Bild kann man sehen wann der Datenpunkt zuletzt geändert wurde. Wie man sehen kann, die anderen Daten wurden geändert.
        Danke Chris!
        Viele Grüße Tristan
        besterquesterB 2 Antworten Letzte Antwort
          @besterquester Ahh der Code 429 heisst dass hier mehr als 100 request per Stunde durchgeführt werden. Dieser Code wird von der API gesendet. Also auf 1 min gehen oder weniger requests.
          Du hast 2 Instanzen am Laufen und jede zieht Daten. Pausiere mal und teste in eine Stunde wieder mit nur einer Instanz.
          lg Chris
          locito09
          @besterquester
          Hallo Chris
          Erstmals vielen Dank für deine mühe und Arbeit.
          Adapter funktioniert für mich sehr zuverlässig, ziehe nur das Gewicht von der Waage.
          Was ich festgestellt habe ist das man sich jeden Tag wägen muss sonst kommt einen error im LOG das keine Daten gefunden wurden, kann man das vielleicht ändern, das der Adapter nur Daten zieht wen auch Daten vorhanden sind?
          Vielen Dank
          • L locito09
            @besterquester
            Hallo Chris
            Vielen Dank
            besterquesterB Offline
            besterquester
            schrieb am zuletzt editiert von besterquester
            @locito09 : Ja das stimmt jeden Tag wiegen , da sonst im response json von der fitbit keine Daten da sind.
            Im grunde passiert ja genau was du willst. daten werden nur im State gespeichert wenn daten da sind. Die Warnung wird ja nur im Log angezeigt dass du weisst es gibt keine Gewichtsdaten, Fat, BMI von der Waage.
            Ich habe da so gelöst dass ich einen History Eintrag im iobroker am state mache dann kann ich leicht die Chart anzeigen. Wenn ein tag nicht gewogen wird fehlt halt der history Eintrag ist ja nicht schlimm. In der Chart Null nicht anzeigen und du hast auch keine Sprünge in der Chart
            lg C
            besterquesterB L 2 Antworten Letzte Antwort
            • F ftd
              @worldfakes said in Test Adapter fitbit-api v0.1.x Latest:
              Könntest du mir bitte eine genaue Anleitung geben? Im Voraus schon mal herzlichen Dank
              Google.ch als Callback fuktioniert nicht... musst eine andere nehmen. Nimm iobroker.net :-)
              Und stell die Expired Time gleich auf 1 Jahr.... 31536000
              1. du nimmst den grün markierten Link Copy... aus deiner Fitbit OAuth 2.0 tutorial page
              1. Paste in ein neues Privates Browser Fenster
              1. Dort mit den Fitbit Daten anmelden. Es kommt danach noch ein Fenster, wo du die Erlaubnis geben musst, Daten senden zu ürfen... mit "Erlauben" bestätigen
              2. Wenn du auf "Erlauben" geklickt hast, landest auf der Callback-URL aus der registrierten App
              1. Dieses gelb markierten Link, kopierst du auf der Fitbit Seite bei Pase response und hast dann den Token (hellblau)
              1. Token in ioBroker Instance einfügen
              @ftd Hi, hab gerade gesehen, dass du den Adapter auf vordermann bringst, super!
              Leider wurde wohl das mit dem Token veraendert.. bin deine Anleitung durchgegangen, ich kann mir auch den access token holen, und auch einen refresh_token, wenn ich dann wie auf der Seite angegeben, mit curl n Post absetze, kommt auch ein feedback...
              Aber der Adapter meldet immer Error 401 oder 403.. und dann wars das.. :-(
              Irgendeine Idee??
              F 1 Antwort Letzte Antwort
                Irgendeine Idee??
                ftd
                @ilovegym Hi... nein, da hast du etwas falsch gelesen. Ich hab mit dem Entwickeln von Adaptern nichts zu tun. Auch nicht mit dem Fitbit-Adapter. Nutzen tue ich ihn auch nicht mehr, da ich keine Fitbit-Uhr mehr habe.
                  lg C
                  besterquester
                  @besterquester
                  Ja du benötigst eigentlich nur das Token. Ich arbeite auch daran das Token im Adadapter zu refreshen.
                  Hier die Codes.
                  • 200: A successful request.
                  • 400: The request had bad syntax or was inherently impossible to be satified.
                  • 401: The request requires user authentication.
                  • 409: Returned if the given user is already subscribed to this stream using a different subscription ID, OR if the given subscription ID is already used to identify a subscription to a different stream.
                  • 429: Too many requests within an hour
                  Da hast du die auth ev. falsch abgesetzt.
                  Probier mal:
                  curl -X GET "https://api.fitbit.com/1/user/-/activities.json" -H  "accept: application/x-www-form-urlencoded" -H  "authorization: Bearer <your token here>"
                    @besterquester
                    Guten Morgen,
                    Danke Chris!
                    Viele Grüße Tristan
                    besterquester
                    @schroed99
                    Hi
                    Danke für deinen Input. Wenn du 5 Minuten Intervall eingestellt hast müsste das reichen. Eigentlich müssten alle Werte alle 5 Minuten gezogen werden. Has tdu dein Handy immer dabei denn über das Handy werden die Daten an FItBIT gechickt. Also wenn es in deimem Handy richtig ist dann müsste auch der Dapter richtig die Daten ziehen. Checke das mal.
                    Die Personenwaage braucht kein Handy da direkt über Wlan an Fitbit ;)
                    Bin jetzt auf https://github.com/Chris-1965/ioBroker.fitbit-fitness gewechselt da ich einen Namenskonflikt hatte (neue Version direkt von hier)
                    Auf deine Frage: Kannst du mir sagen, wie ich Daten an FitBit senden kann(API)?
                    Ja das geht über post. Du kannst hier mit dem Tool die API sehr gut testen.
                    Swagger: https://dev.fitbit.com/build/reference/web-api/explore/#/
                    Wenn du Daten schreiben willst poste das Commando hier ev. können wir das ja in den Adapter einbauen.
                    lG Chris
                      @besterquester
                      Guten Morgen,
                      Danke Chris!
                      Viele Grüße Tristan
                      besterquester
                      @schroed99
                      ich habe eine neue Version erstellt. Wasser Record gefixed und um Carbon, Fiber ergänzt. Teste mal ob es nun besser geht.
                      Version 0.2.3: https://github.com/Chris-1965/ioBroker.fitbit-fitness
                      lG C
                        lg C
                        locito09
                        @besterquester
                        Es ist einfach mühsam wenn im LOG die ganze zeit eine Fehlermeldung kommt das Fitbit kein Gewicht findet wen an diesen Tag nicht gewogen wurde. Kann man wenigstens dieser Fehler als info anzeigen im LOG? Somit könnte ich den Adapter auf Warn/Error stellen und die Meldung wäre im LOG nicht mehr sichtbar und spamt den LOG nicht voll. Habe gleichzeitig 4 Adapter im Einsatz, da kommen schon einige Meldungen zusammen.
                        • L locito09
                          @besterquester
                          besterquester
                          @locito09 : Es ist eine Warnung kann ich gerne umstellen.
                          lG Chris
                          • A Ahnungsbefreit
                            besterquester
                            @ahnungsbefreit : Hi hast du neue Version mal getestet ? Welches OS hast du im Einsatz.
                            lg Chris
                            A L 2 Antworten Letzte Antwort
                              lg Chris
                              Ahnungsbefreit
                              @besterquester Ich werde die neue Version mal testen. OS ist Debian in einer VM unter ProxMox.
                              -1
                              • A Ahnungsbefreit
                                Ahnungsbefreit
                                @besterquester Habe eben mal die letzte Version von github installiert:
                                $ iobroker url https://github.com/Chris-1965/ioBroker.fitbit-fitness --host ioBVM-test
                                install Chris-1965/ioBroker.fitbit-fitness#4d56410b25fbf9279ede82c9b12b3b83326cfe2a
                                npm install Chris-1965/ioBroker.fitbit-fitness#4d56410b25fbf9279ede82c9b12b3b83326cfe2a --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                                upload [3] fitbit-fitness.admin /opt/iobroker/node_modules/iobroker.fitbit-fitness/admin/words.js words.js application/javascript
                                upload [2] fitbit-fitness.admin /opt/iobroker/node_modules/iobroker.fitbit-fitness/admin/style.css style.css text/css
                                upload [1] fitbit-fitness.admin /opt/iobroker/node_modules/iobroker.fitbit-fitness/admin/index_m.html index_m.html text/html
                                upload [0] fitbit-fitness.admin /opt/iobroker/node_modules/iobroker.fitbit-fitness/admin/fitbit-fitness.png fitbit-fitness.png image/png
                                  lg Chris
                                  locito09
                                  @besterquester
                                  Habe die letzte Version aus github getestet, ich schaffe es nicht den Token zu konfigurieren im adapter.
                                  Fehlermeldung: Verbindung wurde abgelehnt.
                                  Auch einen vorhandenen Token lässt sich nicht einfügen. Getestet mit Chrome,Firefox,Edge
                                  • S schmax
                                    Hallo Zusammen,
                                    klasse, dass man über die Fitbit API die Inhalte auslesen kann, Danke für den Adapter für ioBroker!
                                    Die Anzeige der Historie über den History Adapter macht m.E. nur bedingt Sinn, nämlich nur dann, wenn man täglich kurz vor Mitternacht seine Fitbit synced und dann den Wert via History mitloggt. Wieso wird nicht auf die historischen Daten als JSON zugegegriffen? Das sollte laut API Dokumentation ja möglich sein, sowohl für die Schritte als auch für die Aktivitäten. Damit könnte man sich ein Dashboard ähnlich der Fitbit App nachbauen...
                                    Hat das schon mal jemand in Angriff genommen?
                                    Danke und Grüße
                                    schmax
                                    Raptor
                                    schrieb am zuletzt editiert von Raptor
                                    @Bluefox Ich habe den Adapter installiert. Was mir aufgefallen ist:
                                    • Der Token ist scheinbar nur wenige Stunden gültig
                                    • Food Werte werden nicht abgefragt
                                    • Body Werte werden nicht abgefragt
                                    • Sleep Werte wurden einmal abgefragt, am Folgetag nicht wieder.
