  4. Alpha Test js-controller 4.0
    apollon77A
196 Beiträge 20 Kommentatoren 42.3k Aufrufe 22 Beobachtet
  • foxriver76F foxriver76
    @wendy2702 sagte in Alpha Test js-controller 4.0:
    Cannot clean up invalid user group assignments: Cannot read property 'length' of null
    Unabhängig von der Problematik mit dem Install: Kannst du mal deine system.group Objekte zeigen, irgendeins hat da wohl kein common.members Attribut.
    wendy2702W
    wendy2702W
    #152
    @foxriver76 sagte in Alpha Test js-controller 4.0:
    Meinst du das:
    • wendy2702W wendy2702
      Meinst du das:
      foxriver76F
      foxriver76F
      foxriver76
      #153
      @wendy2702 mal hinten dran auf den Stift und das raw JSON posten
      Videotutorials & mehr
        wendy2702W
        wendy2702W
        #154
          "_id": "system.group.administrator",
          "type": "group",
          "common": {
            "name": "Administrator",
            "description": {
              "en": "Can do everything with ioBroker"
            "members": [
              "system.user.admin"
            "dontDelete": true,
            "acl": {
              "object": {
                "list": true,
                "read": true,
                "write": true,
                "delete": true
              "state": {
                "list": true,
                "read": true,
                "write": true,
                "create": true,
                "delete": true
              "users": {
                "list": true,
                "read": true,
                "write": true,
                "create": true,
                "delete": true
              "other": {
                "execute": true,
                "http": true,
                "sendto": true
              "file": {
                "list": true,
                "read": true,
                "write": true,
                "create": true,
                "delete": true
            "icon": "data:image/svg+xml;base64,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"
          "acl": {
            "owner": "system.user.admin",
            "object": 1604
          "user": "system.user.admin",
          "ts": 1621797197839
        und
          "_id": "system.group.user",
          "type": "group",
          "common": {
            "name": "User",
            "description": {
              "en": "Cannot modify anything"
            "members": null,
            "dontDelete": true,
            "url": "https://github.com/ioBroker/ioBroker.js-controller/archive/master.zip",
            "meta": "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/io-package.json",
            "acl": {
              "object": {
                "list": true,
                "read": true,
                "write": false,
                "delete": false
              "state": {
                "list": true,
                "read": true,
                "write": true,
                "create": true,
                "delete": false
              "users": {
                "list": true,
                "read": true,
                "write": false,
                "create": false,
                "delete": false
              "other": {
                "execute": false,
                "http": true,
                "sendto": false
              "file": {
                "list": true,
                "read": true,
                "write": false,
                "create": false,
                "delete": false
            "icon": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgNmMxLjEgMCAyIC45IDIgMnMtLjkgMi0yIDItMi0uOS0yLTIgLjktMiAyLTJtMCAxMGMyLjcgMCA1LjggMS4yOSA2IDJINmMuMjMtLjcyIDMuMzEtMiA2LTJtMC0xMkM5Ljc5IDQgOCA1Ljc5IDggOHMxLjc5IDQgNCA0IDQtMS43OSA0LTQtMS43OS00LTQtNHptMCAxMGMtMi42NyAwLTggMS4zNC04IDR2MmgxNnYtMmMwLTIuNjYtNS4zMy00LTgtNHoiLz4NCjwvc3ZnPg=="
          "acl": {
            "object": 1604
          "ts": 1621797197839
            "type": "group",
            "common": {
              "description": {
              "members": [
                "system.user.admin"
              "dontDelete": true,
              "acl": {
                "object": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "delete": true
                "state": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "create": true,
                  "delete": true
                "users": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "create": true,
                  "delete": true
                "other": {
                  "execute": true,
                  "http": true,
                  "sendto": true
                "file": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "create": true,
                  "delete": true
            "acl": {
              "object": 1604
            "ts": 1621797197839
          und
            "type": "group",
            "common": {
              "name": "User",
              "description": {
              "members": null,
              "dontDelete": true,
              "acl": {
                "object": {
                  "list": true,
                  "read": true,
                  "write": false,
                  "delete": false
                "state": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "create": true,
                  "delete": false
                "users": {
                  "list": true,
                  "read": true,
                  "write": false,
                  "create": false,
                  "delete": false
                "other": {
                  "execute": false,
                  "http": true,
                  "sendto": false
                "file": {
                  "list": true,
                  "read": true,
                  "write": false,
                  "create": false,
                  "delete": false
            "acl": {
              "object": 1604
            "ts": 1621797197839
          apollon77A
          apollon77A
          #155
          @wendy2702 Foxriver hat den Fix schon gemacht. kommt dann in die 4.0.1 für Latest heute Abend
          • apollon77A apollon77
            So, dann sind wir nun mit @next bei alpha.74 :-)
            • (Apollon77) Optimize rebuild handling
            • (foxriver76) Optimize meta object sync
            FeuersturmF
            FeuersturmF
            Feuersturm
            #156
            @apollon77 sagte in Alpha Test js-controller 4.0:
            Update auf Alpha 74
            @foxriver76 Jetzt sind es nur noch 3. Wobei der iogo.admin nicht mehr installiert ist und eine Leiche ist.
            Hilft es die anderen beiden Adapter einfach mal zu deinstallieren und neu zu installieren und mit der 4.0.1 dann zu schauen ob die Meldungen weiterhin kommen?
            The following notifications happened during sync:
            - Ignoring Directory "daswetter" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "iogo.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
            apollon77A foxriver76F 2 Antworten Letzte Antwort
            • FeuersturmF Feuersturm
              Update auf Alpha 74
              apollon77A
              apollon77A
              #157
              @feuersturm ich denke der tr-064-Community ist auch ne Altlast oder?!
                Update auf Alpha 74
                foxriver76F
                foxriver76F
                foxriver76
                #158
                @feuersturm zeig mal die Objekte ob es Typ Meta sind sonst jammert er korrekterweise
                  FeuersturmF
                  FeuersturmF
                  Feuersturm
                  #159
                  @apollon77 @foxriver76
                  So wie es aussieht sind die drei monierten "Adapter" alles Leichen wenn man sich die Zeitstempel der Dateien so ansieht.
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter.admin$ ls -l
                  total 216
                  -rw-rwxr--+ 1 iobroker iobroker 154292 Feb  4 18:48 _data.json
                  -rw-rwxr--+ 1 iobroker iobroker   2589 Feb  3 22:06 daswettercom.png
                  drwxrwxr-x+ 5 iobroker iobroker   4096 Jan 12  2020 icons
                  -rw-rwxr--+ 1 iobroker iobroker   4195 May  2  2020 index.html
                  -rw-rwxr--+ 1 iobroker iobroker  20265 Feb  3 22:06 index_m.html
                  -rw-rwxr--+ 1 iobroker iobroker   5673 Feb  3 22:06 jsonConfig.json
                  -rw-rwxr--+ 1 iobroker iobroker  14893 Feb  3 22:06 words.js
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter.admin$ cd ..
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd daswetter
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter$ ls -l
                  total 64
                  -rw-rwxr--+ 1 iobroker iobroker 60096 Jan 16  2021 _data.json
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter$ cd ..
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr
                  tr-064-community.admin/ tr-064.admin/           trashschedule.admin/
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr-064-community.admin/
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064-community.admin$ ls -l
                  total 92
                  -rw-rwxr--+  1 iobroker iobroker  3035 Jan 10  2021 _data.json
                  drwxrwxr-x+ 12 iobroker iobroker  4096 Jan 20  2020 i18n
                  -rw-rwxr--+  1 iobroker iobroker 21842 Jan 20  2020 index.html
                  -rw-rwxr--+  1 iobroker iobroker 22279 Jan 20  2020 index_m.html
                  -rw-rwxr--+  1 iobroker iobroker 30797 Jan 20  2020 words.js
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064-community.admin$ cd ..
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr-064.admin/
                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064.admin$ ls -l
                  total 100
                  -rw-rwxr--+  1 iobroker iobroker  3103 Feb  4 18:48 _data.json
                  drwxrwxr-x+ 12 iobroker iobroker  4096 Jan 24  2020 i18n
                  -rw-rwxr--+  1 iobroker iobroker 21822 Jan 27  2020 index.html
                  -rw-rwxr--+  1 iobroker iobroker 28639 Feb  3 22:04 index_m.html
                  -rw-rwxr--+  1 iobroker iobroker  1736 Feb  3 22:04 tr-064.png
                  -rw-rwxr--+  1 iobroker iobroker 34320 Feb  3 22:04 words.js
                    total 216
                    total 64
                    total 92
                    total 100
                    foxriver76F
                    foxriver76F
                    foxriver76
                    #160
                    @feuersturm dann passt die Meldung ja: please remove directory 👍🏼
                      wendy2702W
                      wendy2702W
                      #161
                      Ok.
                      Schaffe ich hoffentlich morgen einzuspielen
                      • D
                        D
                        darkiop
                        #162
                        Guten Abend, hatte bis heute leider keine Zeit den neuen 4.0.0 zu testen.
                        Eben aber direkt mein P-System (redis/redis + node14 / npm6) umgestellt. Melde mich bei Auffälligkeiten.
                        ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                        • apollon77A
                          apollon77A
                          #163
                          Hallo alle zusammen,
                          ich habe @next nochmals aktualisiert mit der 4.0.3, was die geplante Beta/Latest version für heute Nachmittag/Abend ist. Meine Tests sehen soweit gut aus.
                          Von daher wäre cool wenn Ihr, wie Zeit, es nochmal bei euch aktualisiert - dann habt Ihr auch gleich die Latest Version drauf :-)
                          Änderungen sind minimaler Kleinkram und Fixes der noch gemeldet wurde (und einige Version haben wir "verloren" weil der Release-Prozess nicht so wollte wie wir ;-) )
                          • (foxriver76) Fix user-group objects with invalid member list - reported by @wendy2702
                          • (foxriver76) Fix multihost commands - reported in GitHub
                          • (foxriver76) Fix meto object check/sync to prevent false positive logs
                          L FeuersturmF 2 Antworten Letzte Antwort
                            L
                            L
                            lonsimbt
                            #164
                            @apollon77
                            Ich war mal so mutig und habe die 4.0.3 auf mein Produktivsystem losgelassen (ein Hoch auf proxmox und die Möglichkeit von snapshots). Dabei sind folgende Meldungen noch hochgekommen:
                            - Ignoring Directory "gartenbewaesserung.admin" because officially not created as meta object. Please remove directory!
                            - Ignoring Directory "robonect.admin" because officially not created as meta object. Please remove directory!
                            Beide Adapter sind zzt. nicht in Benutzung. Können die Ordner tatsächlich gefahrlos gelöscht werden?
                            Ferner folgende Warnungen im Log:
                            shuttercontrol.0
                            	2022-02-05 11:15:36.840	warn	This object will not be created in future versions. Please report this to the developer.
                            shuttercontrol.0
                            	2022-02-05 11:15:36.839	warn	Object shuttercontrol.0.info.Azimut is invalid: Default value has to be type "number" but received type "string"
                            shuttercontrol.0
                            	2022-02-05 11:15:36.832	warn	This object will not be created in future versions. Please report this to the developer.
                            shuttercontrol.0
                            	2022-02-05 11:15:36.830	warn	Object shuttercontrol.0.info.Elevation is invalid: Default value has to be type "number" but received type "string"
                            mqtt.0
                            	2022-02-05 11:15:00.871	warn	This object will not be created in future versions. Please report this to the developer.
                            mqtt.0
                            	2022-02-05 11:15:00.870	warn	Object mqtt.0.info.connection is invalid: Default value has to be type "string" but received type "boolean"
                            Issue beim Adapter erstellen?
                            Gruß Marco
                            iobroker im Container (debian Bullseye) unter proxmox 7.1
                            debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
                            40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
                            simatecS apollon77A foxriver76F 3 Antworten Letzte Antwort
                            • L lonsimbt
                              @apollon77
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              mqtt.0
                              mqtt.0
                              Gruß Marco
                              simatecS
                              simatecS
                              simatec
                              #165
                              @lonsimbt
                              Für Shuttercontrol gibt es dazu bereits ein Issue
                              • Besuche meine Github Seite
                              • HowTo Restore ioBroker
                              • L lonsimbt
                                @apollon77
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                mqtt.0
                                mqtt.0
                                Gruß Marco
                                apollon77A
                                apollon77A
                                #166
                                @lonsimbt korrekt. Fehlende issue Bitte erstellen. Zu den beiden Verzeichnissen: wenn du da aktuell keine Instanzen hast dann kannst du das löschen.
                                • L lonsimbt
                                  @apollon77
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  shuttercontrol.0
                                  mqtt.0
                                  mqtt.0
                                  Gruß Marco
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  #167
                                  @lonsimbt sagte in Alpha Test js-controller 4.0:
                                  Ich vermute die Adapter sind derzeit nicht mal installiert?
                                  apollon77A L 2 Antworten Letzte Antwort
                                    FeuersturmF
                                    FeuersturmF
                                    Feuersturm
                                    #168
                                    @apollon77 Habe gerade einmal ein update auf die 4.0.3 gemacht.
                                    Gestern abend hatte ich noch ein apt update / upgrade gemacht, wobei auch nodejs aktualisiert wurde. Aktuelle node und npm Version:
                                    proxmox@ioBrokerTestsystem:/opt/iobroker$ node -v
                                    v14.19.0
                                    proxmox@ioBrokerTestsystem:/opt/iobroker$ npm -v
                                    6.14.16
                                    Beim Update gab es diese Fehlermeldungen. Haben sie was zu bedeuten?
                                    Die IP 192.168.178.78 ist der ioBroker Slave. Ich habe gerade den Master aktualisiert, der Slave (js-controller 4.0 alpha 73) lief aber.
                                    Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.cputime: The database is not open!
                                    Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.mem: The database is not open!
                                    Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.memHeapUsed: The database is not open!
                                    Hier die vollständie Ausgabe vom Update
                                    proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next
                                    [sudo] password for proxmox:
                                    > iobroker.js-controller@4.0.3 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                    > node lib/preinstallCheck.js
                                    NPM version: 6.14.16
                                    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                                      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                    In file included from ../src/unix_dgram.cc:5:
                                    ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
                                    ../../nan/nan.h:2294:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
                                     2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                    In file included from ../../nan/nan.h:56,
                                    ../src/unix_dgram.cc: At global scope:
                                    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                                      793 |       (node::addon_register_func) (regfunc),                          \
                                    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
                                      827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                    ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                                      404 | NODE_MODULE(unix_dgram, Initialize)
                                      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                      COPY Release/unix_dgram.node
                                    make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                                    > iobroker.js-controller@4.0.3 install /opt/iobroker/node_modules/iobroker.js-controller
                                    > node iobroker.js setup first
                                    object _design/system updated
                                      "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nV9blMZ0EBC/006ZLnsA6QLs0SqruVgPQbUjLP5Q7F4Dmudz9swxpuT0=\r\n-----END RSA PRIVATE KEY-----\r\n",
                                      "defaultPublic": "-----BEGIN CERTIFICATE-----\r\nMIIDlDCCAnygAwIBAgIJCEBGN+fDGlYlMA0GCSqGSIb3DQEBCwUAMD4xETAPBgNV\r\nBAMTCGlvYnJva2VyMRYwFAYDVQQKEw1pb0Jyb2tlciBHbWJIMREwDwYDVQQLEwhp\r\nb2Jyb2tlcjAeFw0yMjAyMDUxMDM5MTVaFw0yMzAyMDUxMDM5MTVaMEgxGzAZBgNV\r\nBAMTEmlvQnJva2VyVGVzdHN5c3RlbTEWMBQGA1UEChMNaW9Ccm9rZXIgR21iSDER\r\nMA8GA1UECxMIaW9icm9rZXIwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIB\r\nAQDRQlQck6bwMvhL76FwAcePgMtNlYFPNFC5+9VgvQV1Pmoa2LRsKa7kp0UIvS7A\r\n5Pz0QQYTaun2TDKd556poFelKhJxfvyC1fvA5RNRf6nIFCLzaRGwVf9Zis7yjiHV\r\nsS46rJMYPizLATWC6kae4DK2CKa4BEYoHiL3AtsgzeTbZeMKadZGCn1VI05QTweE\r\nIooceLhNSzR0FofbN1pwqgyyKoHk5nDe/5V9X4eUbt52tpO/Gcg53sUiOFvV53kM\r\nVsUsoesqkDaydKRm4wm9F4T/m+/LVrCdA6k6wkHQ3p+k7+dEK3rQeiUKIfmXACRN\r\nWXGJ5CjCxb1wYhQcLAKLQGFdAgMBAAGjgYowgYcwDAYDVR0TAQH/BAIwADAPBgNV\r\nHQ8BAf8EBQMDB7+AMB0GA1UdEQQWMBSCEmlvQnJva2VyVGVzdHN5c3RlbTAdBgNV\r\nHQ4EFgQUD0SE7Kg2dRW/OQU/gUV8P97Rbj4wHQYDVR0lBBYwFAYIKwYBBQUHAwEG\r\nCCsGAQUFBwMCMAkGA1UdIwQCMAAwDQYJKoZIhvcNAQELBQADggEBANBTXcSPdI7E\r\niwmsf7h5eubmtIeGNU0UYIYiVvqgBn0DUw8SwjwhZgbFCPd4Qx6NAecEPWqztmem\r\n2HVqwkzgpzQ64wb1YOywZqUP7xmWlnxzEzUZg3hq8+JGgJqkl3tMTnpm87jGReyu\r\nYjfyRHtNj4Gjq6LGs8RqPA4pXe204XSoakdKoeRiy7qi2ULD8GKLjkC+pHF4RA/Y\r\nKPGmY0F8RliFYPkdIvN8GbCpibZnwq+J6U+1+9k46EuXhzaLQVjGfCNLPzjmmT/0\r\nYtosTkCOIbIwiwmmP9byXHhimVXOq/97cvR+zZB+xxqJXvt5zxTGjKgNAcpN/w7E\r\n0F41Cw5EmdU=\r\n-----END CERTIFICATE-----\r\n"
                                    Update certificate defaultPrivate
                                    The object "system.certificates" was updated successfully.
                                    Update certificate defaultPublic
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                    + iobroker.js-controller@4.0.3
                                    removed 19 packages and updated 14 packages in 102.06s
                                    43 packages are looking for funding
                                      run `npm fund` for details
                                    Github issue
                                    https://github.com/ioBroker/ioBroker.js-controller/issues/1746
                                    apollon77A 2 Antworten Letzte Antwort
                                      Aktuelle Test Version 4.0.0.alpha.69 (01.02.2022)
                                      Veröffentlichungsdatum 31.01.2022
                                      Hallo ioBroker-Community,
                                      nach längerer Entwicklungszeit steht heute der js-controller 4.0 für einen ersten Alpha-test zur Verfügung. Dieser Artikel enthält alle wichtigen Infos.
                                      Node.js Versions-Anforderungen
                                      In diesem Release entfällt Node.js 10.x welches seit April letztem Jahr nicht mehr gepflegt wird. Node.js 16.x ist dazugekommen. Die unterstützten Node.js Versionen sind damit: 12.x, 14.x und 16.x. Die empfohlene Node.js Version für ioBroker heben wir mit diesem Release auf 14.x an. Node.js 16.x wird mit js-controller 4.0 nun auch mit npm 7 bzw. 8 unterstützt.
                                      Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition , welche NOCH NICHT für js-controller 4.0 aktualisiert wurde. Infos in der FAQ hier im Thread.
                                      Informationen zur Version
                                      Neben einigen Optimierungen und Verbesserungen stand der Haupt-Fokus dieser Version auf Performance-Verbesserungen. Ein paar neue Features sind aber ebenfalls hinzugekommen. Auch daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen wurde weiter gearbeitet, was ggf. zu neuen Log-Meldungen für bestimmte Fälle führt. Bitte unterstützt hier wieder und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
                                      Mit dem js-controller 4.0 wird intern die Datenbank von "file" auf "jsonl" umgestellt. Dies geschieht bei der Installation automatisch ohne weitere Aktionen, wenn file genutzt wird. Weitere Details dazu sieht in der FAQ (Post #2)! Nach erfolgter Migration erscheint beim nächsten Öffnen des Admin auch eine Information dazu:
                                      Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
                                      In Summe sind in diese Version wieder über 100 Änderungen in über 300 commits eingeflossen. Dafür bedanke mich diesmal wieder besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
                                      Der js-controller 4.0 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 4.0 idealerweise ein Update auf die 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 12.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
                                      Es gibt aktuell keine bekannten inkompatiblem Adapter, aber einige Empfehlungen weiter unten.
                                      Installation
                                      VOR der Installation
                                      Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 3.3.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen.
                                      Für die User, welche die experimentelle JSONL-Datenbank bereits einsetzen, ändert sich nichts - ausser das dieser Datenbank-Typ nun die offizielle ist :-)
                                      Nötige Adapter-Aktualisierungen
                                      Aktuell sind keine Inkompatibilitäten bekannt. Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 3.3 oder höher hinweisen.
                                      Es werden aber, wie oben ausgeführt, einige Adapter ggf. Warnungen ins Log schreiben - und ggf kommen ein paar neue dazu, welche aber primär bei Objektanlagen interessant sind und weniger im Betrieb "nerven". Meldungen die vor dem Upgrade im Log waren sind jetzt auch noch da.
                                      Bitte zuerst versuchen die gemeldeten Objekt-IDs via Admin zu löschen und den Adapter neu zu starten. Wenn die Meldungen danach nicht weg sein sollten ist aktuell die einzige Option das Loglevel der betroffenen Instanz auf "Warning" zu setzen - aber erst nachdem die Logs idealerweise in einem GitHub-Issue beim entsprechendem Adapter gemeldet wurden!
                                      Achtung: MASTER-Systeme Reihenfolgen beachten!
                                      Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.x läuft, ist es beim Update auf Version 4.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                                      Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 4.0 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Update muss der alte Master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 4.0 aktualisiert wurde!
                                      Windows
                                      Generell muss das Update manuell via npm installiert werden.
                                      Hierzu im ioBroker-Verzeichnis npm i iobroker.js-controller@next ausführen.
                                      Linux
                                      • ioBroker stoppen (iobroker stop)
                                      • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                                      • cd /opt/iobroker
                                      • Das Update erfolgt via npm i iobroker.js-controller@next
                                      • ioBroker starten (iobroker start)
                                      Bei Fehlern:
                                      Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                                      Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                                      NACH der Installation
                                      Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                                      Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                                      Was hat sich geändert, was besonders ansehen/beachten?
                                      Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                                      • generell siehe Changelog, speziell auch für die Features
                                      • Prüfen das mit JSONL alles tut (Im Backup Dir werden die letzten "File DB Backups" liegen bleiben, kann man manuell löschen)
                                      • Bitte generell Augenmerk darauf legen das alle CLI Kommandos noch tun die man so nutzt. Da wurde einiges unter der Haube überarbeitet
                                      • Gern mal ein Nodejs update testen um zu schauen das das neue Rebuild tut wie es soll :-)
                                      • Einige Adapter werden Warnungen ausgeben wenn State-Werte gesetzt werden, da nun auch Datentypen und min/max-Werte geprüft werden. Bitte bei den Adapter-Repos melden
                                      Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
                                      Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                                      BREAKING CHANGES
                                      • Support for Node.js 10 is dropped! Supported are Node.js 12.x, 14.x and 16.x
                                      • CLI command iob update --updateable changed to iob update --updatable
                                      • CLI command iob update http://download.iobroker.net/sources-dist.json is not supported anymore
                                      • CLI command iob rebuild adaptername is no longer supported because of the new way of automatic rebuilds and some unwanted side effects
                                      • CLI command iob state get <id> will no longer handle binary state values (which was never really working before). We added iob state getBinary <id> <encoding> as new way.
                                      • Ensure that on a backup-restore the same adapters and adapter versions are restored as existing on backup time. Also check js-controller version and error on mismatch (is allowed to be forced accepted by --force parameter for restore)
                                      • The "file" database will be automatically converted into JSONL and the database types that use "file" are adjusted to "jsonl" on installation (and backup restore). This means that a rollback of js-controller is only possible to 3.3 after 4.0 was installed! Rollback to former versions require a manual migration to "file" DB before the downgrade! (COMMUNICATION, TESTFOKUS)
                                      Features
                                      • (bluefox) Added complexity rules for user passwords: New created passwords need to follow the following rules (TODO ADMIN UI INFO ISSUE):
                                        • minimum length is 8
                                        • contains at least one digit
                                        • contains at least one lower case letter
                                        • contains at least one upper case letter
                                      • (foxriver76) Introduce option "--custom" when deleting instances or adapter to also clean up relevant custom entries from all objects (TODO ADMIN ISSUE ADD CHECKBOX!, TESTFOKUS)
                                      • (foxriver76) Added new host objects to provide Node.js version and PID
                                      • (foxriver76) Updated the Linux capabilities on js-controller start when a Node.js version change was detected (and initial on first run)
                                      • (AlCalzone/foxriver76) Further optimize strategy for required Node.js module rebuilds. We first try to run rebuild in root package and if still packages are left (or it fails) we try to rebuild the really affected modules alone. Should give better results then former strategy (TESTFOKUS)
                                      • (bluefox) Added support for configuring multiple repositories (TODO LINK+INFO FLAG)
                                      • (Apollon77) Streamline logging configuration for all available transports: A set Loglevel in config means that this loglevel is pinned for the transport for all cases. An Empty/not set level ("Default" in Admin) means that logging is dynamic and can be adjusted per Instance controller or loglevel state on the fly.
                                      • (foxriver76) Added installedFrom info to adapter start log line when not installed from npm normally
                                      Optimizations and Fixes
                                      • (Apollon77/foxriver76) Improve performance of object deletions (also when deleting instances or adapters) significantly (file-db 4x faster, jsonl-db 14x faster, redis 360x% !! faster)
                                      • (foxriver76/Apollon77) Improve performance for redis object searches by up to 2,5x by using lookup structures for object types and custom object properties. This optimization is only active for single host redis systems automatically, but can be activated for multihost redis systems too after all hosts are (and stay!) on js-controller 4.0! (TODO DOCS)
                                      • (foxriver76/Apollon77) Improve performance for object searches in general by limiting search namespaces to the relevant ones automatically
                                      • (foxriver76) Improve handling of backup restores when custom hostnames were used (especially relevant for Docker usage)
                                      • (foxriver76) Optimize backup to make sure invalid user-generated JSONs do not prevent backups from being considered valid
                                      • (foxriver76/klein0r) Improved CLI help
                                      • (foxriver76) Preserve changed instance names also when updating adapter (name was reset before)
                                      • (foxriver76) stop adapters on Windows prior update to prevent EBUSY
                                      • (foxriver76) Prevent crashes for uploads with invalid adapter installations
                                      • (bluefox) Removed news from instance/adapter objects on install/update because taken from repository in Admin5 (TODO CHECK ADMIN4 EFFECTS)
                                      • (AlCalzone) Removed extraneous "npm install" inside adapter directory
                                      • (foxriver76/AlCalzone) reduce JSONL compression frequency to reduce I/O (relevant when experimental JSONL database modules are used)
                                      • (foxriver76) prevent uploading js-controller (creating system.adapter.js-controller object) and remove existing cases on setup first
                                      • (foxriver76) prevent crash when multihost password is invalid and multihost active
                                      • (bluefox/foxriver76) bigger internal refactorings in cli commands (TESTFOKUS)
                                      • (foxriver76) made logging of not fulfilled adapter dependencies more user-friendly
                                      • (foxriver76) Check user and group assignments and remove unknown users from groups (could have happened in earlier versions) in setup first
                                      • (foxriver76) Prevent crash on adapter install/update if version string in repo is invalid
                                      • (AlCalzone) Update and optimize JSONL database integration and configuration options
                                      • (foxriver76) make sure that settings for file/jsonl DB in configfile are also respected
                                      • (foxriver76) Update seq integration for logging
                                      • (foxriver76) If logging can not be initialized because of a fatal error do not start js-controller
                                      • (foxriver76) Prevent start of a debug session for an instance that is already running
                                      • (Apollon77) Fix an edge case for file db which could lead to main and backup file being broken in strange situations with multiple crashes in a row
                                      • (foxriver76) make sure that admin, backitup and discovery instances are created when update of controller happens if installed and no instance exists
                                      • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                                      Developer relevant DEPRECATIONS/WARNINGS
                                      • js-controller is no longer installable from GitHub because is now a monorepo. Use @dev tag on npm to get the nightly build of master js-controller!
                                      • log info when setState is used for an object of type file - use setBinaryState instead!
                                      • log info when default value of an object is invalid (e.g. does not match object type)
                                      • log info when common.states is used and not an object (deprecate String usage)
                                      • log info when common.min/common.max exists on non numbers and contain invalid values/types
                                      • add get/setForeignBinaryState methods as copy from get/setBinaryState allow adapter to migrate; get/setBinaryState will be changed in 4.1 to be "non Foreign"
                                      • Enhanced object checks: adapter need to have a name as string
                                      • Decline calls for getForeignObjects with non string pattern (was pot. crashing before)
                                      • adapter.tools is deprecated and replaced by a shim. Use methods in adapter class or adapter-core instead or open issues if you need more internal functions
                                        The object view definition "custom/state" is now removed from js-controller after being replaced by "system/custom" in js-controller 3.3. All relevant adapters are updated (COMMUNICATION)
                                      • remove all Fifo Methods from adapter.js because deprecated since 1.x
                                      • remove adapter.objects.* methods because deprecated since 2.x
                                      Developer relevant new Features
                                      • (jogibear9988) Add new "unload-safe" promise based "adapter.delay" method to delay further code execution, but still make sure code do not continue after unload was called. This method can not be used inside the "unload" method itself!
                                      • (jogibear9988/AlCalzone/foxriver76/Apollon77) Revamp adapter.*Timeout and adapter.*Interval methods to be "unload-safe" and also clear missing timeouts without warnings for more developer convenience! The methods to set a timeout or interval can not be used inside the "unload" method itself!
                                      • (AlCalzone) Introduce new methods in tools for Node.js module management: installNodeModule, uninstallNodeModule (TODO Issues adapter that use npm install -> Move))
                                      • (bluefox) Add license management functionality to host. Adapters can use adapter.getSuitableLicenses to get available relevant licenses (TODO DOCS)
                                      • (AlCalzone) Switch NPM relevant handling to library pak to be more flexible for the future which package manager we want to use. Important: There are still parts that rely on npm for now!
                                      • (bluefox) Also report docker info when sending diag data
                                      • (foxriver76) Add server time to getHostInfo message
                                      • (foxriver76) For multihost clusters with js-controller 4.0+ the hosts automatically determine a "primary" host that can be used js-controller internally (right now, preparation for future topics)
                                      Developer relevant Optimizations and Fixes
                                      • (foxriver76) fixed permissionError on setBinaryState
                                      • (foxriver76) preserve "native" content for instanceObjects when updating the objects on adapter start
                                      • (Apollon77/foxriver76) Limit the search scope for object types host, adapter, instance, instanceStats, enum, script, group, user, config to the relevant namespaces when no search start/end is provided to speedup these calls in general
                                      • (foxriver76) Optimize deleteDevice/deleteChannel methods to just delete all objects the relevant device/channel
                                      • (foxriver76) Removed some magic path lookups to be compatible to npm 7/8. Appname of controller is now always "iobroker" ("ioBroker" in dev cases)
                                      • (foxriver76) Also use Sentry (if enabled/allowed) in CLI commands whenever database is initialized to report crashes from CLI if they happen
                                      • (foxriver76) Introduce a database protocol version number to allow detection of the available database features in multihost environments
                                      • (bluefox) Prevent issues when using adapter.addChannelToEnum because of missing callback
                                      • (foxriver76) make sure autoSubscribe works as expected in all cases
                                      • general dependency updates
                                      • code style optimizations and streamline code
                                      Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                                      Wie Fehler melden?
                                      Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                                      Bitte checkt auch die "Known issues Liste" (zweiter Post) mit den Dingen die aktuell während der Alpha bekannt sind und bis zum Releasen noch angepasst werden.
                                      Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                                      Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
                                      Ingo
                                      #169
                                      @apollon77
                                      eben auch auf js-controller 4.03 mal gegangen, iobroker laeuft, kam beim update hier was :
                                      ilovegym@VMC123-iobroker /opt/iobroker $ npm i iobroker.js-controller@next
                                      NPM version: 6.14.15
                                      > node-gyp rebuild
                                      /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:787:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                                      /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:821:3: note: in expansion of macro 'NODE_MODULE_X'
                                      Fehler kommt auf den Raspis als Multihost-slave ebenfalls..
                                      Thomas BraunT apollon77A F 3 Antworten Letzte Antwort
                                        v14.19.0
                                        6.14.16
                                        > node-gyp rebuild
                                        Github issue
                                        apollon77A
                                        apollon77A
                                        #170
                                        @feuersturm ok der iobrokernew ist der Slave oder ist das der Master?und wo lief das Update? Zu wem gehört die genannte ip?
                                          @apollon77
                                          > node-gyp rebuild
                                          Thomas BraunT
                                          Thomas BraunT
                                          #171
                                          @ilovegym
                                          Welcher Fehler? Das sind ganz normale build messages
                                          83.9k
