  4. Alpha Test js-controller 4.0
196 Beiträge 20 Kommentatoren 39.7k Aufrufe 22 Beobachtet
  • apollon77A apollon77
    @wendy2702 Mal den npm cache unter user iobroker löschen?
    wendy2702W Online
    wendy2702W Online
    #144
    @apollon77 sagte in Alpha Test js-controller 4.0:
    Bei einer neu installation ?
    Kann ich aber gerne noch versuchen.
    Habe auf dem neuen System mal noch
    iob fix
    laufen lassen. Danach immer noch write access fehler
    mirko@iobroker:/opt/iobroker$ iob fix
    library: loaded
    Library version=2021-12-27
        Welcome to the ioBroker installation fixer!
        Script version: 2021-12-27
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
    OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease
    OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease
    OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
    Installed gcc-c++
    Installed python-dev
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    mirko@iobroker:/opt/iobroker$ iob start
    mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker
    iobroker.2022-02-04.log  iobroker-audit.json      iobroker.current.log
    mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log
    2022-02-04 08:30:27.060  - info: admin.0 (11589) requesting all states
    2022-02-04 08:30:27.060  - info: admin.0 (11589) requesting all objects
    2022-02-04 08:30:27.185  - info: admin.0 (11589) received all objects
    2022-02-04 08:30:27.297  - info: admin.0 (11589) http server listening on port 8081
    2022-02-04 08:30:27.298  - info: admin.0 (11589) Use link "http://localhost:8081" to configure.
    2022-02-04 08:30:30.017  - info: host.iobroker instance system.adapter.discovery.0 started with pid 11604
    2022-02-04 08:30:30.634  - info: discovery.0 (11604) starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 3.3.22
    2022-02-04 08:30:34.011  - info: host.iobroker instance system.adapter.backitup.0 started with pid 11627
    2022-02-04 08:30:34.715  - info: backitup.0 (11627) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
    2022-02-04 08:30:34.783  - info: backitup.0 (11627) [iobroker] backup was activated at 02:40 every 1 day(s)
    ^C
    mirko@iobroker:/opt/iobroker$ iob stop
    mirko@iobroker:/opt/iobroker$ ps auxww|grep io
    root          13  0.0  0.0      0     0 ?        S    08:18   0:00 [migration/0]
    root          17  0.0  0.0      0     0 ?        S    08:18   0:00 [migration/1]
    root          22  0.0  0.0      0     0 ?        S    08:18   0:00 [migration/2]
    root          27  0.0  0.0      0     0 ?        S    08:18   0:00 [migration/3]
    root          65  0.0  0.0      0     0 ?        I<   08:18   0:00 [blkcg_punt_bio]
    message+     305  0.0  0.0   8208  4540 ?        Ss   08:18   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
    root       11487  0.0  0.0      0     0 ?        I    08:29   0:00 [kworker/u8:1-ext4-rsv-conversion]
    mirko      11666  0.0  0.0   6200   712 pts/0    R+   08:31   0:00 grep io
    mirko@iobroker:/opt/iobroker$ ps auxww|grep backup
    mirko      11668  0.0  0.0   6200   652 pts/0    R+   08:31   0:00 grep backup
    mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/node
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/iobroker
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/array-flatten
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/assert-plus
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asynckit
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws-sign2
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws4
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/caseless
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/connect-flash
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-signature
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-parser
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/core-util-is
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dashdash
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/delayed-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/combined-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/depd
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ee-first
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/encodeurl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/escape-html
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/etag
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules/depd
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extend
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extsprintf
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-deep-equal
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-json-stable-stringify
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forever-agent
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forwarded
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fresh
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/getpass
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-schema
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ipaddr.js
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/is-typedarray
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/isstream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsbn
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-stringify-safe
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/media-typer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/merge-descriptors
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/methods
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-db
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-types
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/form-data
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/accepts
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/oauth-sign
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-headers
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/parseurl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-strategy
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-local
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/path-to-regexp
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/pause
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/performance-now
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/proxy-addr
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/psl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/punycode
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/qs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/random-bytes
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/range-parser
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/qs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-disposition
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safer-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asn1
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ecc-jsbn
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/streamsearch
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dicer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/busboy
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-fileupload
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/serve-static
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tough-cookie
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tunnel-agent
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tweetnacl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bcrypt-pbkdf
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/sshpk
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/type-is
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uid-safe
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/unpipe
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/finalhandler
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uri-js
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ajv
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-validator
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/utils-merge
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uuid
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/vary
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/verror
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsprim
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-signature
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ws
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/xtend
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport.socketio
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/yallist
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/lru-cache
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/semver
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/node
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/iobroker
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/agent-base
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/array-flatten
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/arrify
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/assert-plus
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asynckit
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws-sign2
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws4
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/balanced-match
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base-64
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base64-js
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bignumber.js
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/qs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer-equal-constant-time
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bytes
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/caseless
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/charenc
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/chownr
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/concat-map
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/brace-expansion
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-type
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie-signature
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/core-util-is
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/crypt
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dashdash
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/delayed-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/combined-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/depd
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/destroy
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ee-first
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/encodeurl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/escape-html
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/etag
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/event-target-shim
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/abort-controller
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/qs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extend
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extsprintf
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-deep-equal
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-json-stable-stringify
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-text-encoding
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/follow-redirects
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/axios
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forever-agent
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forwarded
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fresh
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-constants
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/function-bind
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/getpass
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/graceful-fs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-schema
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has-symbols
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/get-intrinsic
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/call-bind
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/he
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/hot-patcher
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/https-proxy-agent
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ieee754
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/inherits
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ipaddr.js
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-typedarray
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isarray
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isstream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsbn
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-bigint
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema-traverse
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-stringify-safe
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/layerr
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/long-timeout
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/luxon
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/md5
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/media-typer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/merge-descriptors
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/methods
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-db
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-types
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/form-data
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/minimatch
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mkdirp-classic
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/negotiator
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/accepts
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/nested-property
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-forge
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-p12-pem
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-wol
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/oauth-sign
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-inspect
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-keys
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/define-properties
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-nan
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cron-parser
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/on-finished
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/parseurl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-posix
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-to-regexp
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/performance-now
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/proxy-addr
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/psl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/punycode
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/querystringify
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/range-parser
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/qs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/uuid
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/requires-port
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-disposition
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecdsa-sig-formatter
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jwa
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jws
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safer-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asn1
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecc-jsbn
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/iconv-lite
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/setprototypeof
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/side-channel
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/qs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sorted-array-functions
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/statuses
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/strnum
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-xml-parser
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/toidentifier
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-errors
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/serve-static
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tough-cookie
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tr46
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tunnel-agent
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tweetnacl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bcrypt-pbkdf
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sshpk
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/type-is
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/universalify
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsonfile
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-extra
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/unpipe
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/raw-body
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uri-js
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ajv
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-validator
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-join
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-parse
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-template
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/util-deprecate
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/utils-merge
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uuid
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/vary
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/verror
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsprim
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-signature
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dropbox-v2-api
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webdav
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webidl-conversions
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/whatwg-url
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-fetch
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gaxios
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gcp-metadata
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gtoken
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/wrappy
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/once
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/end-of-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/pump
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-fs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/xregexp
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ftp
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/yallist
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/lru-cache
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-auth-library
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis-common
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis/drive
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-inter-byte-timeout
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapter-core
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/yallist
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lru-cache
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-forge
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs-parser
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'
    npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'] {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/mirko/.npm/_logs/2022-02-04T07_32_08_765Z-debug.log
    Kann mal noch eine VM probieren und eine mit root
    • wendy2702W wendy2702
      iob fix
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      ^C
      npm ERR! errno -13
      npm ERR! }
      npm ERR!
      npm ERR!
      #145
      @wendy2702 Auch: Versuch doch mal einen 3.3.22 controller zu installieren. Da wirst Du denke die gleiche Meldungen haben ... damit npm und generelles Rechte thema
        wendy2702W Online
        wendy2702W Online
        #146
        @apollon77 kann ich vielleicht später noch versuchen. Jetzt ruft die Arbeit
          @wendy2702 WTF ... alle meine Testsysteme sind Proxmox im lxc ... und eins in ner VM ... bei mir tut alles. wie sind denn die container einstellungen? Wil ja bin ehrlich beiu mir laufen die container der testsysteme unter root und nicht nem user ... das mag der unterschied sein?
          Aber nochmal: Sollte nichts mit js-controller zu tun haben ... Das ist npm und irgendwelche File Rechte
          lonsimbt
          #147
          @apollon77
          Hier läuft iobroker im (privilegierten) lxc (debian) unter proxmox. Installation des js-controller als "normaler" Benutzer funktioniert ohne Probleme.
          Node.js v14.19.0
          NPM v6.14.16
          iobroker im Container (debian Bullseye) unter proxmox 7.1
          debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
          40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
          • wendy2702W Online
            wendy2702W Online
            #148
            @apollon77
            Mal noch einen anderen Versuch gewagt: Key und Cert etwas gekürzt.
            mirko@iobroker:/opt/iobroker$ sudo -H -u iobroker npm i iobroker.js-controller@next
            > iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.16
            > iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            Cannot clean up invalid user group assignments: Cannot read property 'length' of null
            object system.licenses created
            object _design/system updated
            The following notifications happened during sync:
            - Ignoring Directory "_temp" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "terminal" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "terminal.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
              "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\nxxxxOHqAJ6mqZ\r\n-----END RSA PRIVATE KEY-----\r\n",
              "defaultPublic": "-----BEGIN CERTIFICATE-----\rxxxfraHQ==\r\n-----END CERTIFICATE-----\r\n"
            Update certificate defaultPrivate
            The object "system.certificates" was updated successfully.
            Update certificate defaultPublic
            States DB type migrated from "file" to "jsonl"
            Objects DB type migrated from "file" to "jsonl"
            ioBroker configuration updated
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/iobroker.js2fs/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            + iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1
            added 37 packages from 42 contributors, removed 109 packages, updated 42 packages and moved 2 packages in 32.791s
            163 packages are looking for funding
              run `npm fund` for details
            Startet erstmal:
            2022-02-04 12:17:07.056  - info: host.iobroker iobroker.js-controller version 4.0.0 js-controller starting
            2022-02-04 12:17:07.059  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2022-02-04 12:17:07.059  - info: host.iobroker hostname: iobroker, node: v14.19.0
            2022-02-04 12:17:07.059  - info: host.iobroker ip addresses: 192.168.178.18 fd30:4253:5f21:46be:805a:fcff:fedc:3d66 2a01:c22:b4d1:b000:805a:fcff:fedc:3d66 fe80::805a:fcff:fedc:3d66
            2022-02-04 12:17:08.206  - info: host.iobroker Sets unsupported
            2022-02-04 12:17:08.708  - info: host.iobroker connected to Objects and States
            2022-02-04 12:17:08.715  - info: host.iobroker added notifications configuration of host
            2022-02-04 12:17:08.716  - info: host.iobroker Node.js version has changed from unknown to 14.19.0
            2022-02-04 12:17:08.748  - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
            2022-02-04 12:17:09.188  - info: host.iobroker 95 instances found
            2022-02-04 12:17:09.255  - info: host.iobroker starting 53 instances
            2022-02-04 12:17:09.378  - info: host.iobroker instance system.adapter.admin.0 started with pid 12443
            2022-02-04 12:17:10.133  - info: admin.0 (12443) Sets unsupported
            2022-02-04 12:17:10.134  - info: admin.0 (12443) Sets unsupported
            2022-02-04 12:17:10.453  - info: admin.0 (12443) starting. Version 5.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
            2022-02-04 12:17:10.470  - info: admin.0 (12443) requesting all states
            2022-02-04 12:17:10.470  - info: admin.0 (12443) requesting all objects
            2022-02-04 12:17:11.958  - info: admin.0 (12443) received all objects
            2022-02-04 12:17:12.246  - info: admin.0 (12443) http server listening on port 8081
            2022-02-04 12:17:12.246  - info: admin.0 (12443) Use link "http://localhost:8081" to configure.
            2022-02-04 12:17:13.284  - info: host.iobroker instance system.adapter.email.0 started with pid 12460
            2022-02-04 12:17:13.848  - info: email.0 (12460) Sets unsupported
            2022-02-04 12:17:13.849  - info: email.0 (12460) Sets unsupported
            2022-02-04 12:17:14.158  - info: email.0 (12460) starting. Version 1.0.10 in /opt/iobroker/node_modules/iobroker.email, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
            2022-02-04 12:17:17.376  - info: host.iobroker instance system.adapter.history.0 started with pid 12477
            2022-02-04 12:17:18.051  - info: history.0 (12477) Sets unsupported
            2022-02-04 12:17:18.052  - info: history.0 (12477) Sets unsupported
            2022-02-04 12:17:18.345  - info: history.0 (12477) starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
            2022-02-04 12:17:21.425  - info: host.iobroker instance system.adapter.javascript.0 started with pid 12494
            2022-02-04 12:17:22.471  - info: javascript.0 (12494) Sets unsupported
            2022-02-04 12:17:22.472  - info: javascript.0 (12494) Sets unsupported
            2022-02-04 12:17:22.808  - info: javascript.0 (12494) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
            2022-02-04 12:17:22.849  - info: javascript.0 (12494) npm install jsftp --production (System call)
            2022-02-04 12:17:25.381  - info: host.iobroker instance system.adapter.javascript.1 started with pid 12522
            2022-02-04 12:17:26.603  - info: javascript.1 (12522) Sets unsupported
            2022-02-04 12:17:26.604  - info: javascript.1 (12522) Sets unsupported
            2022-02-04 12:17:26.999  - info: javascript.1 (12522) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
            2022-02-04 12:17:27.030  - info: javascript.1 (12522) npm install xml2js --production (System call)
            apollon77A foxriver76F 2 Antworten Letzte Antwort
              @apollon77
              Startet erstmal:
              #149
              @wendy2702 Das siht auch alles perfekt aus. Was war der Unterschied? Das obige sudo-Kommando was es unter dem iobroker user ausführt?
              • apollon77A apollon77
                wendy2702W Online
                wendy2702W Online
                #150
                @apollon77 Ja. Nur das Kommando....
                verstehen muss ich das aktuell noch nicht.
                  @apollon77
                  Startet erstmal:
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  schrieb am zuletzt editiert von foxriver76
                  #151
                  @wendy2702 sagte in Alpha Test js-controller 4.0:
                  Unabhängig von der Problematik mit dem Install: Kannst du mal deine system.group Objekte zeigen, irgendeins hat da wohl kein common.members Attribut.
                  Videotutorials & mehr
                  • foxriver76F foxriver76
                    wendy2702W Online
                    wendy2702W Online
                    #152
                    @foxriver76 sagte in Alpha Test js-controller 4.0:
                    Meinst du das:
                      Meinst du das:
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #153
                      @wendy2702 mal hinten dran auf den Stift und das raw JSON posten
                        wendy2702W Online
                        wendy2702W Online
                        #154
                          "_id": "system.group.administrator",
                          "type": "group",
                          "common": {
                            "name": "Administrator",
                            "description": {
                              "en": "Can do everything with ioBroker"
                            "members": [
                              "system.user.admin"
                            "dontDelete": true,
                            "acl": {
                              "object": {
                                "list": true,
                                "read": true,
                                "write": true,
                                "delete": true
                              "state": {
                                "list": true,
                                "read": true,
                                "write": true,
                                "create": true,
                                "delete": true
                              "users": {
                                "list": true,
                                "read": true,
                                "write": true,
                                "create": true,
                                "delete": true
                              "other": {
                                "execute": true,
                                "http": true,
                                "sendto": true
                              "file": {
                                "list": true,
                                "read": true,
                                "write": true,
                                "create": true,
                                "delete": true
                            "icon": "data:image/svg+xml;base64,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"
                          "acl": {
                            "owner": "system.user.admin",
                            "object": 1604
                          "user": "system.user.admin",
                          "ts": 1621797197839
                        und
                          "_id": "system.group.user",
                          "type": "group",
                          "common": {
                            "name": "User",
                            "description": {
                              "en": "Cannot modify anything"
                            "members": null,
                            "dontDelete": true,
                            "url": "https://github.com/ioBroker/ioBroker.js-controller/archive/master.zip",
                            "meta": "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/io-package.json",
                            "acl": {
                              "object": {
                                "list": true,
                                "read": true,
                                "write": false,
                                "delete": false
                              "state": {
                                "list": true,
                                "read": true,
                                "write": true,
                                "create": true,
                                "delete": false
                              "users": {
                                "list": true,
                                "read": true,
                                "write": false,
                                "create": false,
                                "delete": false
                              "other": {
                                "execute": false,
                                "http": true,
                                "sendto": false
                              "file": {
                                "list": true,
                                "read": true,
                                "write": false,
                                "create": false,
                                "delete": false
                            "icon": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgNmMxLjEgMCAyIC45IDIgMnMtLjkgMi0yIDItMi0uOS0yLTIgLjktMiAyLTJtMCAxMGMyLjcgMCA1LjggMS4yOSA2IDJINmMuMjMtLjcyIDMuMzEtMiA2LTJtMC0xMkM5Ljc5IDQgOCA1Ljc5IDggOHMxLjc5IDQgNCA0IDQtMS43OSA0LTQtMS43OS00LTQtNHptMCAxMGMtMi42NyAwLTggMS4zNC04IDR2MmgxNnYtMmMwLTIuNjYtNS4zMy00LTgtNHoiLz4NCjwvc3ZnPg=="
                          "acl": {
                            "object": 1604
                          "ts": 1621797197839
                            "type": "group",
                            "common": {
                              "description": {
                              "members": [
                                "system.user.admin"
                              "dontDelete": true,
                              "acl": {
                                "object": {
                                  "list": true,
                                  "read": true,
                                  "write": true,
                                  "delete": true
                                "state": {
                                  "list": true,
                                  "read": true,
                                  "write": true,
                                  "create": true,
                                  "delete": true
                                "users": {
                                  "list": true,
                                  "read": true,
                                  "write": true,
                                  "create": true,
                                  "delete": true
                                "other": {
                                  "execute": true,
                                  "http": true,
                                  "sendto": true
                                "file": {
                                  "list": true,
                                  "read": true,
                                  "write": true,
                                  "create": true,
                                  "delete": true
                            "acl": {
                              "object": 1604
                            "ts": 1621797197839
                          und
                            "type": "group",
                            "common": {
                              "name": "User",
                              "description": {
                              "members": null,
                              "dontDelete": true,
                              "acl": {
                                "object": {
                                  "list": true,
                                  "read": true,
                                  "write": false,
                                  "delete": false
                                "state": {
                                  "list": true,
                                  "read": true,
                                  "write": true,
                                  "create": true,
                                  "delete": false
                                "users": {
                                  "list": true,
                                  "read": true,
                                  "write": false,
                                  "create": false,
                                  "delete": false
                                "other": {
                                  "execute": false,
                                  "http": true,
                                  "sendto": false
                                "file": {
                                  "list": true,
                                  "read": true,
                                  "write": false,
                                  "create": false,
                                  "delete": false
                            "acl": {
                              "object": 1604
                            "ts": 1621797197839
                          #155
                          @wendy2702 Foxriver hat den Fix schon gemacht. kommt dann in die 4.0.1 für Latest heute Abend
                            So, dann sind wir nun mit @next bei alpha.74 :-)
                            • (Apollon77) Optimize rebuild handling
                            • (foxriver76) Optimize meta object sync
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #156
                            @apollon77 sagte in Alpha Test js-controller 4.0:
                            Update auf Alpha 74
                            @foxriver76 Jetzt sind es nur noch 3. Wobei der iogo.admin nicht mehr installiert ist und eine Leiche ist.
                            Hilft es die anderen beiden Adapter einfach mal zu deinstallieren und neu zu installieren und mit der 4.0.1 dann zu schauen ob die Meldungen weiterhin kommen?
                            - Ignoring Directory "daswetter" because officially not created as meta object. Please remove directory!
                            - Ignoring Directory "iogo.admin" because officially not created as meta object. Please remove directory!
                            - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
                            • FeuersturmF Feuersturm
                              Update auf Alpha 74
                              #157
                              @feuersturm ich denke der tr-064-Community ist auch ne Altlast oder?!
                                Update auf Alpha 74
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #158
                                @feuersturm zeig mal die Objekte ob es Typ Meta sind sonst jammert er korrekterweise
                                  FeuersturmF Offline
                                  FeuersturmF Offline
                                  Feuersturm
                                  #159
                                  @apollon77 @foxriver76
                                  So wie es aussieht sind die drei monierten "Adapter" alles Leichen wenn man sich die Zeitstempel der Dateien so ansieht.
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter.admin$ ls -l
                                  total 216
                                  -rw-rwxr--+ 1 iobroker iobroker 154292 Feb  4 18:48 _data.json
                                  -rw-rwxr--+ 1 iobroker iobroker   2589 Feb  3 22:06 daswettercom.png
                                  drwxrwxr-x+ 5 iobroker iobroker   4096 Jan 12  2020 icons
                                  -rw-rwxr--+ 1 iobroker iobroker   4195 May  2  2020 index.html
                                  -rw-rwxr--+ 1 iobroker iobroker  20265 Feb  3 22:06 index_m.html
                                  -rw-rwxr--+ 1 iobroker iobroker   5673 Feb  3 22:06 jsonConfig.json
                                  -rw-rwxr--+ 1 iobroker iobroker  14893 Feb  3 22:06 words.js
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter.admin$ cd ..
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd daswetter
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter$ ls -l
                                  total 64
                                  -rw-rwxr--+ 1 iobroker iobroker 60096 Jan 16  2021 _data.json
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter$ cd ..
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr
                                  tr-064-community.admin/ tr-064.admin/           trashschedule.admin/
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr-064-community.admin/
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064-community.admin$ ls -l
                                  total 92
                                  -rw-rwxr--+  1 iobroker iobroker  3035 Jan 10  2021 _data.json
                                  drwxrwxr-x+ 12 iobroker iobroker  4096 Jan 20  2020 i18n
                                  -rw-rwxr--+  1 iobroker iobroker 21842 Jan 20  2020 index.html
                                  -rw-rwxr--+  1 iobroker iobroker 22279 Jan 20  2020 index_m.html
                                  -rw-rwxr--+  1 iobroker iobroker 30797 Jan 20  2020 words.js
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064-community.admin$ cd ..
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr-064.admin/
                                  proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064.admin$ ls -l
                                  total 100
                                  -rw-rwxr--+  1 iobroker iobroker  3103 Feb  4 18:48 _data.json
                                  drwxrwxr-x+ 12 iobroker iobroker  4096 Jan 24  2020 i18n
                                  -rw-rwxr--+  1 iobroker iobroker 21822 Jan 27  2020 index.html
                                  -rw-rwxr--+  1 iobroker iobroker 28639 Feb  3 22:04 index_m.html
                                  -rw-rwxr--+  1 iobroker iobroker  1736 Feb  3 22:04 tr-064.png
                                  -rw-rwxr--+  1 iobroker iobroker 34320 Feb  3 22:04 words.js
                                    total 216
                                    total 64
                                    total 92
                                    total 100
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    #160
                                    @feuersturm dann passt die Meldung ja: please remove directory 👍🏼
                                      wendy2702W Online
                                      wendy2702W Online
                                      #161
                                      Ok.
                                      Schaffe ich hoffentlich morgen einzuspielen
                                        darkiop
                                        #162
                                        Guten Abend, hatte bis heute leider keine Zeit den neuen 4.0.0 zu testen.
                                        Eben aber direkt mein P-System (redis/redis + node14 / npm6) umgestellt. Melde mich bei Auffälligkeiten.
                                        Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                        • apollon77A Offline
                                          #163
                                          Hallo alle zusammen,
                                          ich habe @next nochmals aktualisiert mit der 4.0.3, was die geplante Beta/Latest version für heute Nachmittag/Abend ist. Meine Tests sehen soweit gut aus.
                                          Von daher wäre cool wenn Ihr, wie Zeit, es nochmal bei euch aktualisiert - dann habt Ihr auch gleich die Latest Version drauf :-)
                                          Änderungen sind minimaler Kleinkram und Fixes der noch gemeldet wurde (und einige Version haben wir "verloren" weil der Release-Prozess nicht so wollte wie wir ;-) )
                                          • (foxriver76) Fix user-group objects with invalid member list - reported by @wendy2702
                                          • (foxriver76) Fix multihost commands - reported in GitHub
                                          • (foxriver76) Fix meto object check/sync to prevent false positive logs
                                          L FeuersturmF 2 Antworten Letzte Antwort
