    1.0k
  • Dirk PeterD Dirk Peter
    @simatec
    Hallo simatec,
    wenn die Rollos Abends schon unten sind und dann erst der Frostschutz aktive true wird, so fahren die Rolläden nicht in den Frostschutz!
    Ist das so gewollt, oder noch ein Fehler.
    shuttercontrol.0   9890	2022-01-20 18:09:11.145	debug	insidetemperature changed: hm-rpc.1.001D5A498FDA1C.1.ACTUAL_TEMPERATURE Value: 22.6
    shuttercontrol.0   9890	2022-01-20 18:07:48.823	debug	status alarm pending for hm-rpc.1.00165BE99E4FEB.6.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:48.777	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:38.731	debug	status alarm pending for hm-rpc.1.00165BE99E4FEB.2.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:38.686	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:28.635	debug	status alarm pending for hm-rpc.1.00165BE99E4FF0.14.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:28.588	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:18.543	debug	status alarm pending for hm-rpc.1.00165BE99E4FF0.10.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:18.496	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:16.981	debug	Brightness State Down is: true
    shuttercontrol.0   9890	2022-01-20 18:07:08.451	debug	status alarm pending for hm-rpc.1.00165BE99E4FF0.6.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:07:08.404	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:07:06.978	debug	Brightness sensor value: 0
    shuttercontrol.0   9890	2022-01-20 18:06:58.355	debug	status alarm pending for hm-rpc.1.00165BE99E4FF0.2.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:06:58.306	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:06:48.259	debug	status alarm pending for hm-rpc.1.00165BE9944866.2.LEVEL: false
    shuttercontrol.0   9890	2022-01-20 18:06:48.211	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0   9890	2022-01-20 18:06:48.209	debug	start shutterAlarm
    shuttercontrol.0   9890	2022-01-20 18:06:48.204	debug	Alarm Frost changed: true
    mfg Dirk Peter
    simatecS Offline
    simatecS Offline
    simatec
    #4343
    @dirk-peter Schaue ich mir an
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      Adnim
      schrieb am zuletzt editiert von Adnim
      #4344
      @simatec
      Hi! ich habe versucht auf den Lichtsensor umzustellen, leider ist es dann nicht mehr möglich den Rolladen Manuell zu verfahren. es wird immer wieder geöffnet via Licht sensor.
      Gibt es eine Einstellung das Lichtsensor und manuell geht. Sprich der Rolladen morgens per Licht geöffnet wird dann aber nicht mehr verfahren wird?
      Habe das problem das bei mir Elevation UP nicht funktioniert, seit dem Recode des Adapters.
      Debug Log zeigt aber an den Trigger Zeitpunkten nix an dazu:
      shuttercontrol.0 (61914) we are not in period, after start Thu Apr 01 2021 and before end Thu Sep 30 2021
       - debug: shuttercontrol.0 (61914) check xmas for GaesteWC
      - debug: shuttercontrol.0 (61914) check in time 01.04. 30.09.
       - debug: shuttercontrol.0 (61914) Start Thu Apr 01 2021
      - debug: shuttercontrol.0 (61914) End Thu Sep 30 2021
      Kann ich da noch mehr Infos liefern ?
        Thomas 6
        schrieb am zuletzt editiert von Thomas 6
        #4345
        Hallo an alle,
        ich bin neu hier im Forum und neu bei "Shuttercontrol".
        Nachdem ich in "Shuttercontrol" alles soweit eingerichtet habe, funktioniert die Steuerung soweit. Ich würde die Rolläden nun bei Abwesenheit schließen und sobald jemand anwesend ist, sollen die Rolläden in die aktuell geltende Beschattungsposition fahren.
        Aktuell schalte ich über ein Script, bei Abwesenheit, die Automatiksteurung für alle drei Bereiche (autoChildren, autoLiving, autoSleep) aus. Wenn jetzt jemand zu Hause ankommt, schalte ich auf "autoAll" und dann "openAll". Somit stehen alle Rolläden auf Automatikbetrieb und sind geöffnet. Ich würde allerdings statt "openAll" lieber die aktuell geltende Beschattungsposition anfahren. Mit dem Schalter "sunProtect" fahren die Rolläden ja in die Beschattungsposition, selbst wenn für dieses Fenster aktuell keine Beschattung vorgesehen wäre.
        Gibt es da eine möglichkeit die ich noch nicht erkannt habe? Wenn dies nicht möglich ist, kann man so einen Schalter noch einbauen?
        Danke für die Unterstützung.
        SchmakusS 1 Antwort Letzte Antwort
        • T Thomas 6
          Hallo an alle,
          SchmakusS Offline
          SchmakusS Offline
          Schmakus
          #4346
          @thomas-6 said in Test Adapter shuttercontrol v1.4.x:
          Hallo an alle,
          Keine Ahnung ob das so geht, wie du wünscht, aber andere Frage: Welchen Sinn soll das haben? Wieso dürfen deine Rollläden nicht auch bei Abwesenheit beschatten?
          Dev of LightControl Adapter, Contributor of HUE and DoorBird Adapter
          • SchmakusS Schmakus
            Hallo an alle,
            da_WoodyD Online
            da_WoodyD Online
            #4347
            @schmakus sagte in Test Adapter shuttercontrol v1.4.x:
            ich denk mal, er will bei abwesenheit einbruchsschutz haben.
            ich lehn mich da mal aus dem fenster, weil ich das nicht einsetze, aber: wenns den DP sunProtect gibt, warum den nicht aufrufen, statt openAll?
            • da_WoodyD da_Woody
              Thomas 6
              #4348
              @da_woody
              Ja genau, wegen dem Einbruchsschutz sollen sie geschlossen werden.
              Wenn ich "sunProtect" aktiviere, fahren die Rolläden in die Beschattungsposition, auch wenn aktuell, lt. eingestellten Parametern für die Beschattung, keine Beschattung erforderlich wäre. Also wäre es schön einen DP zu haben mit dem die aktuelle Beschattungsanforderung berechnet (ermittelt) wird und nur die Rolläden, für welche aktuell eine Beschattung notwendig ist, in die Beschattungsposition fahren.
              • da_WoodyD Online
                da_WoodyD Online
                #4349
                @thomas-6 den DP hast du ja. anscheinend, möglicherweise wird der während der abwesenheit (close all) nicht aktualisiert.
                das kann dir aber nur @simatec sagen...
                vllt dauerts auch nur ein bißchen bis sich der DP sunProtect aktualisiert.
                • paradoxe SituationP Offline
                  paradoxe Situation
                  schrieb am zuletzt editiert von paradoxe Situation
                  #4350
                  Hallo Freunde der schattigen Plätzchen,
                  ich habe mit Freude den shutter Controll installiert und nun fahren meine Rolls im Kreis.
                  Ich habe eine CCU mit RM und nutze die HmIP Brolls. Wenn ich den shutter einstelle und mit openAll initialisiere läuft, glaube ich, ja dann auch alles wie es soll. Aber warum fahrt mein Rollladen nach dem ich ihn manuell verstellt habe wieder tagsüber hoch? Das ist doch nicht sinn der Sache. Der Shutter soll doch nur in erster Linie die Zeiten der Fahrten regeln und meine SRH nutzen für den Fenster Status.
                  Dennoch bin ich mit meinen Tasten führend und nicht der shutter
                  Ich bin gerade extrem genervt weil ich nicht den Fehler finde.
                  Wer kann mir hier weiterhelfen?
                  Besten Dank!
                  EDIT: Es sind keine Wochenprogramme oder DVs in der CCU. Es gibt keine gegenteiligen Programme, die eine gegensteuern verursachen könnten.
                  • paradoxe SituationP paradoxe Situation
                    Besten Dank!
                    Adnim
                    #4351
                    @paradoxe-situation
                    schalt doch mal die Instanz auf debug, da muss der Log doch mehr infos geben warum die hochfahren->oder auf und ab :)
                    paradoxe SituationP 1 Antwort Letzte Antwort
                    • BanditFGB Offline
                      BanditFGB Offline
                      BanditFG
                      #4352
                      hallo, seit drei Tagen macht ein Rollo bei mir komische Sachen, es fährt 15min eher runter als die anderen im Raum.
                      shuttercontrol.0
                      2022-02-01 17:20:00.034	debug	Sun Azimut: 247.7°
                      shuttercontrol.0
                      2022-02-01 17:20:00.029	debug	calculate astrodata ...
                      shuttercontrol.0
                      2022-02-01 17:19:48.267	debug	insidetemperature changed: zigbee.0.00158d000273ce6b.temperature Value: 22.57
                      shuttercontrol.0
                      2022-02-01 17:18:00.123	debug	Shutter Rollladen Terrassentür.LEVEL was moved manually to: 15% while window was open - prevent trigger from driving back
                      shuttercontrol.0
                      2022-02-01 17:18:00.123	debug	save current height after State Check: 15% from Rollladen Terrassentür.LEVEL
                      shuttercontrol.0
                      2022-02-01 17:17:59.109	debug	Rollladen Terrassentür.LEVEL drived manually to 15. Old value = 100. New value = 15
                      shuttercontrol.0
                      2022-02-01 17:17:59.108	debug	Rollladen Terrassentür.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0
                      2022-02-01 17:17:59.097	debug	Shutter state changed: Rollladen Terrassentür.LEVEL old value = 100 new value = 15
                      shuttercontrol.0
                      2022-02-01 17:17:34.752	debug	Shutter Rollladen Terrassentür.LEVEL was moved manually to: 99.5% while window was open - prevent trigger from driving back
                      shuttercontrol.0
                      2022-02-01 17:17:34.751	debug	save current height after State Check: 99.5% from Rollladen Terrassentür.LEVEL
                      shuttercontrol.0
                      2022-02-01 17:17:34.081	debug	Rollladen Terrassentür.LEVEL drived manually to 99.5. Old value = 100. New value = 99.5
                      shuttercontrol.0
                      2022-02-01 17:17:34.080	debug	Rollladen Terrassentür.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0
                      2022-02-01 17:17:34.069	debug	Shutter state changed: Rollladen Terrassentür.LEVEL old value = 100 new value = 99.5
                      shuttercontrol.0
                      2022-02-01 17:17:33.929	debug	Rollladen Terrassentür.LEVEL Old value = 100. New value = 100. automatic is active
                      shuttercontrol.0
                      2022-02-01 17:17:33.735	debug	Rollladen Terrassentür.LEVEL drived manually to 15. Old value = 100. New value = 15
                      shuttercontrol.0
                      2022-02-01 17:17:33.734	debug	Rollladen Terrassentür.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0
                      2022-02-01 17:17:33.711	debug	Shutter state changed: Rollladen Terrassentür.LEVEL old value = 100 new value = 15
                      shuttercontrol.0
                      2022-02-01 17:15:00.019	debug	Sun Elevation: -3.3°
                      shuttercontrol.0
                      2022-02-01 17:15:00.018	debug	Sun Azimut: 246.7°
                      shuttercontrol.0
                      2022-02-01 17:15:00.018	debug	calculate astrodata ...
                      shuttercontrol.0
                      2022-02-01 17:12:02.945	debug	insidetemperature changed: zigbee.0.00158d0002288653.temperature Value: 22.2
                      shuttercontrol.0
                      2022-02-01 17:10:00.020	debug	Sun Elevation: -2.6°
                      shuttercontrol.0
                      2022-02-01 17:10:00.020	debug	Sun Azimut: 245.8°
                      shuttercontrol.0
                      2022-02-01 17:10:00.019	debug	calculate astrodata ...
                      shuttercontrol.0
                      2022-02-01 17:08:10.427	debug	insidetemperature changed: zigbee.0.00158d0002288653.temperature Value: 22.25
                      shuttercontrol.0
                      2022-02-01 17:08:10.422	debug	insidetemperature changed: zigbee.0.00158d0002288653.temperature Value: 22.25
                      shuttercontrol.0
                      2022-02-01 17:08:03.846	debug	insidetemperature changed: zigbee.0.00158d000224ce57.temperature Value: 15.73
                      shuttercontrol.0
                      2022-02-01 17:08:03.837	debug	insidetemperature changed: zigbee.0.00158d000224ce57.temperature Value: 15.73
                      shuttercontrol.0
                      2022-02-01 17:05:00.028	debug	Sun Elevation: -1.9°
                      shuttercontrol.0
                      2022-02-01 17:05:00.028	debug	Sun Azimut: 244.8°
                      shuttercontrol.0
                      2022-02-01 17:05:00.026	debug	calculate astrodata ...
                      hat jemand ne Ahnung wieso? oder was das auslöst??
                      • BanditFGB BanditFG
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #4353
                        @banditfg ohne Konfiguration wird dir keiner helfen können
                        BanditFGB 1 Antwort Letzte Antwort
                        • simatecS simatec
                          BanditFGB Offline
                          BanditFGB Offline
                          BanditFG
                          schrieb am zuletzt editiert von BanditFG
                          #4354
                          @simatec hast recht. dumm von mir, dacht jemand sieht eventuell was im Log, das das Fahren des Rollos auslöst.
                          es ist eben total komisch, Abends fahrt das Rollo ca. 15min vor den anderen 5 Rollos im Wohnbereich runter.
                          Morgens spinnt das Rollo auch, wie in der Config zu sehen ist, fahren die Rollos im Wohnbereich nach Zeit, außer jemand geht im Wohnzimmer am Bewegungsmelder vorbei, dann läuft ein Blockly und löst den "open Shutter from Living Area" aus..
                          Nach ein weile fährt aber genau dieses Rollo wieder in die Frostposition. Sehr seltsam..
                          Hier nochmal Log von gestern Abend:
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          shuttercontrol.0
                          und meine Config + Skript
                          hoffe das hilft..
                          • A Adnim
                            @paradoxe-situation
                            paradoxe Situation
                            #4355
                            @adnim Danke jetzt doof gefragt " wie mach ich das?" Sorry!
                            Ich habe aber einfach den Rückwartsdreh gemacht alles gelöscht und neu angelegt. Und siehe da, jetzt geht es fast wie es soll.
                            Dennoch habe ich eine Frage. Wie muss ich die Fenster einstellen damit diese nach dem Schließen auch wieder zu fahren wenn das sein soll. denn wenn ich mal lüfte, habe ich ein gestellt, das diese auf 10% fahren sollen und danach, wenn es nach dem Wert des Helligkeitssensor runtergefahren ist, wieder auf 0% runter fahren. Oder muss ich ein blockly für sowas schreiben?
                            Meine Einstellung sie wie folgt aus:
                            Und was ist hier los?
                            Danke!
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              hoffe das hilft..
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #4356
                              @banditfg Kannst du die Config mal als json posten. Dann sehe ich alles und kann das besser deuten als Screenshots
                                Danke!
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #4357
                                @paradoxe-situation sagte in Test Adapter shuttercontrol v1.4.x:
                                Sieht so richtig aus wie du es eingestellt hast
                                • H Offline
                                  hosabeni
                                  #4358
                                  gibt es mit dem Adapter auch die Möglichkeit bei der Einstellung Helligkeit für das öffnen und schließen der Rolladen eine Zeit für früheste Öffnungszeit und späteste Schließzeit einzustellen? Ich möchte nämlich nicht, dass z.B. die Rolladen im Sommer bei den Kindern vor 7Uhr hochfahren. Sie sollen aber auch z.B. im Winter erst hochfahren wenn es draußen entsprechend hell genug ist.
                                  Jens16J 1 Antwort Letzte Antwort
                                  • H hosabeni
                                    Jens16J Offline
                                    Jens16J Offline
                                    Jens16
                                    #4359
                                    @hosabeni Nein das gibt es leider nicht.
                                    • Jens16J Jens16
                                      mameier1234
                                      #4360
                                      @jens16 sagte in Test Adapter shuttercontrol v1.4.x:
                                      denke ich schon...
                                      2022-02-04 08_15_25-instances - iobroker und 8 weitere Seiten - Geschäftlich – Microsoft​ Edge.png
                                      Abhängig vom Sonnenaufgang, aber nicht vor 7:00 ....Im Winter wird es ja später hell und damit gehen die Rolläden auch erst dann hoch, spätestens aber um 8:45
                                      Grüße,
                                      Martin
                                      • M mameier1234
                                        denke ich schon...
                                        Jens16J Offline
                                        Jens16J Offline
                                        Jens16
                                        #4361
                                        @mameier1234
                                        Sonnenauf und Sonnenuntergang ist aber nicht der Helligkeitssensor
                                        • Jens16J Jens16
                                          @mameier1234
                                          mameier1234
                                          #4362
                                          @jens16 Das ist natürlich korrekt.. hab ich übersehen...
                                          Grüße,
                                          Martin
