  4. Probleme mit FritzDect Adapter
    5.6k
103 Beiträge 17 Kommentatoren 16.7k Aufrufe 12 Beobachtet
  • Markus HofbauerM Markus Hofbauer
    @sokomoto Tja ist aber leider so.
    Die Fehlermeldungen kommen immer dann wenn ich den Adapter neu starte.
    Gruß Markus
    @markus-hofbauer
    Zeig mal einen vollständigen Neustart im LogFile.
    Am besten per
    iobroker logs --watch
    Und auch mal schauen wie es bei nodeJS aussieht:
    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    Markus HofbauerM 1 Antwort Letzte Antwort
      @markus-hofbauer
      Am besten per
      Markus HofbauerM Offline
      Markus Hofbauer
      @thomas-braun Hallo
      2022-01-22 14:17:55.258  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=true)
      2022-01-22 14:17:55.317  - info: fritzdect.0 (20362) Got terminate signal TERMINATE_YOURSELF
      2022-01-22 14:17:55.321  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 send kill signal
      2022-01-22 14:17:55.326  - info: fritzdect.0 (20362) cleaned everything up...
      2022-01-22 14:17:55.328  - info: fritzdect.0 (20362) terminating
      2022-01-22 14:17:55.329  - info: fritzdect.0 (20362) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-22 14:17:55.342  - error: fritzdect.0 (20362) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-01-22 14:17:55.343  - error: fritzdect.0 (20362) unhandled promise rejection: undefined
      2022-01-22 14:17:55.344  - error: fritzdect.0 (20362) undefined
      2022-01-22 14:17:55.912  - info: host.raspberrypi instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-22 14:17:58.410  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 21360
      2022-01-22 14:17:59.767  - info: fritzdect.0 (21360) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.3, js-controller: 3.3.22
      2022-01-22 14:17:59.800  - info: fritzdect.0 (21360) fritzdect entered ready
      2022-01-22 14:17:59.840  - info: fritzdect.0 (21360) fritzdect uses USER: ich
      2022-01-22 14:18:00.056  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 21375
      2022-01-22 14:18:00.232  - info: fritzdect.0 (21360) checking user permissions
      2022-01-22 14:18:00.245  - error: fritzdect.0 (21360) errorHandlerTypeError: Converting circular structure to JSON
          --> starting at object with constructor 'Socket'
          |     property 'parser' -> object with constructor 'HTTPParser'
          --- property 'socket' closes the circle
      2022-01-22 14:18:00.246  - error: fritzdect.0 (21360) fritzbox returned this {}
      2022-01-22 14:18:00.247  - error: fritzdect.0 (21360) no response part in returned message
      2022-01-22 14:18:01.798  - info: daswetter.0 (21375) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.3, js-controller: 3.3.22
      2022-01-22 14:18:03.004  - info: daswetter.0 (21375) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2022-01-22 14:18:03.533  - info: daswetter.0 (21375) cleaned everything up...
      2022-01-22 14:18:03.559  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      /usr/bin/node
      /usr/bin/npm
      pi@raspberrypi:~ $
      Hoffe der letzte Befehl war so richtig?
      Gruß Markus
      Thomas BraunT SokomotoS 2 Antworten Letzte Antwort
        @thomas-braun Hallo
        /usr/bin/node
        /usr/bin/npm
        pi@raspberrypi:~ $
        Gruß Markus
        @markus-hofbauer
        Mach mal:
          @markus-hofbauer
          Mach mal:
          Markus Hofbauer
          @thomas-braun Hallo
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.18.3
          v14.18.3
          6.14.15
          pi
          /home/pi
          OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
          Abh▒ngigkeitsbaum wird aufgebaut... Fertig
          Statusinformationen werden eingelesen... Fertig
          Aktualisierung f▒r 1 Paket verf▒gbar. F▒hren Sie ▒apt list --upgradable▒ aus, um es anzuzeigen.
          nodejs:
            Installiert:           14.18.3-deb-1nodesource1
            Installationskandidat: 14.18.3-deb-1nodesource1
            Versionstabelle:
           *** 14.18.3-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
               12.22.5~dfsg-2~11u1 500
          pi@raspberrypi:~ $
          Gruß Markus
            @thomas-braun Hallo
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.18.3
            v14.18.3
            6.14.15
            pi
            /home/pi
            nodejs:
              Versionstabelle:
            pi@raspberrypi:~ $
            Gruß Markus
            @markus-hofbauer
            Das passt.
            cd /opt/iobroker
            npm ls iobroker.fritzdect
            (Nebenbei: Das ausstehende Updrade noch einspielen)
              @markus-hofbauer
              Das passt.
              cd /opt/iobroker
              Markus Hofbauer
              @thomas-braun Hallo
              pi@raspberrypi:~ $ ^C
              pi@raspberrypi:~ $ apt list --upgradable
              Auflistung... Fertig
              rpi-eeprom/stable 13.4-1 armhf [aktualisierbar von: 13.3-1]
              N: Es gibt 1 zus▒tzliche Version. Bitte verwenden Sie die Option ▒-a▒, um sie anzuzeigen.
              pi@raspberrypi:~ $ apt list --upgradable -a
              rpi-eeprom/now 13.3-1 armhf  [Installiert,aktualisierbar auf: 13.4-1]
              pi@raspberrypi:~ $ cd /opt/iobroker
              pi@raspberrypi:/opt/iobroker $ npm ls iobroker.fritzdect
              iobroker.inst@3.0.0 /opt/iobroker
              `-- iobroker.fritzdect@2.2.3
              Wie aktualisiere ich das?
              Gruß Markus
                @thomas-braun Hallo
                Gruß Markus
                @markus-hofbauer
                OT:
                iobroker stop
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                BTT: Welche Firmware ist da auf der Fritzbox? Und der user heißt 'ich'? Sonderzeichen im Passwort? Bindestrich oder sowas?
                  @markus-hofbauer
                  OT:
                  iobroker stop
                  sudo apt update
                  sudo reboot
                  Markus Hofbauer
                  @thomas-braun Hallo
                  Ja der User wurde nur mal zu Testzwecken angelegt. Um zu schauen ob es am User liegt. Keine Sonderzeichen oder sonstiges im Passwort.
                  Modell: FRITZ!Box 7582
                  Aktueller Energieverbrauch: 19 %
                  FRITZ!OS: 07.16 - Version aktuell
                  Gruß Markus
                  Thomas BraunT Michael SchmittM 2 Antworten Letzte Antwort
                    @thomas-braun Hallo
                    Gruß Markus
                    @markus-hofbauer
                    Keine Ahnung. Mach vielleicht in Issue auf.
                      @thomas-braun Hallo
                      /usr/bin/node
                      /usr/bin/npm
                      pi@raspberrypi:~ $
                      Gruß Markus
                      SokomotoS Offline
                      SokomotoS Offline
                      Sokomoto
                      @markus-hofbauer sagte in Probleme mit FritzDect Adapter:
                      @thomas-braun Hallo
                      Ich denke diese Fehlermeldung ist das Problem, eindeutig ein Adapterfehler in meinen Augen.
                      Hier kann nur der Entwickler weiterhelfen.
                      tschuess
                      F 1 Antwort Letzte Antwort
                        @thomas-braun Hallo
                        Gruß Markus
                        Michael SchmittM Online
                        Michael Schmitt
                        schrieb am zuletzt editiert von Michael Schmitt
                        @markus-hofbauer
                        und die Berechtigungen sind richtig gesetzt ?
                        • Michael SchmittM Michael Schmitt
                          @markus-hofbauer
                          Markus Hofbauer
                          @michael-schmitt Ja.
                          Gruß Markus
                          Z 1 Antwort Letzte Antwort
                          • JB_SullivanJ Offline
                            JB_Sullivan
                            schrieb am zuletzt editiert von JB_Sullivan
                            sorry alles dummes Zeug was ich geschrieben hatte - bitte löschen/ignorieren.
                              Gruß Markus
                              Z Offline
                              Z Offline
                              zahnheinrich
                              schrieb am zuletzt editiert von zahnheinrich
                              @markus-hofbauer
                              Trage im Adapter versuchsweise die Anmeldedaten des Hauptusers der Fritzbox ein (also der mit ALLEN Rechten).
                              Starte dann den Adapter neu, wenn Problem weiterhin, den kompletten iobroker neu, wenn dann weiterhin nicht geht, die Fritzbox neu (in dieser Reihenfolge)
                              Log vom Adapter bitte posten, nur warn und error!
                              MfG Ulrich
                              • Z zahnheinrich
                                @markus-hofbauer
                                Markus Hofbauer
                                @zahnheinrich Hallo
                                Adapter Neustart:
                                fritzdect.0
                                2022-01-23 20:56:10.087	error	no response part in returned message
                                fritzdect.0
                                2022-01-23 20:56:10.086	error	fritzbox returned this {}
                                fritzdect.0
                                2022-01-23 20:56:10.086	error	errorHandlerTypeError: Converting circular structure to JSON --> starting at object with constructor 'Socket' | property 'parser' -> object with constructor 'HTTPParser' --- property 'socket' closes the circle
                                fritzdect.0
                                2022-01-23 20:07:31.634	error	adapter disabled
                                fritzdect.0
                                2022-01-23 20:07:27.083	error	undefined
                                fritzdect.0
                                2022-01-23 20:07:27.082	error	unhandled promise rejection: undefined
                                fritzdect.0
                                2022-01-23 20:07:27.081	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                Iobroker Neustart:
                                fritzdect.0
                                2022-01-23 21:03:30.580	error	no response part in returned message
                                fritzdect.0
                                2022-01-23 21:03:30.579	error	fritzbox returned this {}
                                fritzdect.0
                                2022-01-23 21:03:30.578	error	errorHandlerTypeError: Converting circular structure to JSON --> starting at object with constructor 'Socket' | property 'parser' -> object with constructor 'HTTPParser' --- property 'socket' closes the circle
                                Fritzbox Neustart und Adapter Neustart:
                                fritzdect.0
                                2022-01-23 21:48:39.086	error	no response part in returned message
                                fritzdect.0
                                2022-01-23 21:48:39.085	error	fritzbox returned this {}
                                fritzdect.0
                                2022-01-23 21:48:39.083	error	errorHandlerTypeError: Converting circular structure to JSON --> starting at object with constructor 'Socket' | property 'parser' -> object with constructor 'HTTPParser' --- property 'socket' closes the circle
                                fritzdect.0
                                2022-01-23 21:48:14.255	error	undefined
                                fritzdect.0
                                2022-01-23 21:48:14.255	error	unhandled promise rejection: undefined
                                fritzdect.0
                                2022-01-23 21:48:14.254	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                Gruß Markus
                                • SokomotoS Sokomoto
                                  @thomas-braun Hallo
                                  tschuess
                                  foxthefox
                                  @sokomoto sagte in Probleme mit FritzDect Adapter:
                                  @thomas-braun Hallo
                                  tschuess
                                  Ich habe keine Ahnung was die FB als Antwort schickt, aber das scheint ein korruptes xml Format zu sein, was so nicht umgewandelt werden kann.
                                  Ich habe auf git eine Version die hoffentlich den Fehler abfängt und eine Ausgabe liefert, die weitere Analyse zulässt.
                                  Also bitte mal die Version aus git verwenden.
                                  Was hat sich in der letzten Zeit am Setup geändert?
                                  Adapterüberblick: Profil Github;
                                  Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
                                  Ein Aufruf: video
                                    @sokomoto Ja, schade. Hoffentlich kann mir noch einer helfen. Aber trotzdem Danke für den Versuch.
                                    Gruß Markus
                                    foxthefox
                                    @markus-hofbauer
                                    siehe mein vorigen post, die git Version installieren und berichten
                                    Ein Aufruf: video
                                    • F foxthefox
                                      @markus-hofbauer
                                      Markus Hofbauer
                                      @foxthefox Hallo,
                                      Version aus Github mit der Katze installiert. Leider selbes Ergebnis.
                                      fritzdect.0
                                      2022-01-23 22:38:26.300	error	no response part in returned message
                                      fritzdect.0
                                      2022-01-23 22:38:26.299	error	fritzbox returned this {}
                                      fritzdect.0
                                      2022-01-23 22:38:26.296	error	errorHandlerTypeError: Converting circular structure to JSON --> starting at object with constructor 'Socket' | property 'parser' -> object with constructor 'HTTPParser' --- property 'socket' closes the circle
                                      fritzdect.0
                                      2022-01-23 22:38:26.280	info	checking user permissions
                                      fritzdect.0
                                      2022-01-23 22:38:25.859	info	fritzdect uses USER: hofb1860
                                      fritzdect.0
                                      2022-01-23 22:38:25.818	info	fritzdect entered ready
                                      fritzdect.0
                                      2022-01-23 22:38:25.789	info	starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.3, js-controller: 3.3.22
                                      Gruß Markus
                                      Markus HofbauerM F 2 Antworten Letzte Antwort
                                        @foxthefox Hallo,
                                        fritzdect.0
                                        fritzdect.0
                                        fritzdect.0
                                        fritzdect.0
                                        fritzdect.0
                                        fritzdect.0
                                        fritzdect.0
                                        Gruß Markus
                                        Markus Hofbauer
                                        schrieb am zuletzt editiert von Markus Hofbauer
                                        Das zeigt er mir im Expertenmodus unter "system" an.
                                        Vielleicht hilft es ja.
                                        FB Version: FRITZ!OS: 07.16 - Version aktuell FB Modell: 7582
                                        Wie gesagt, geändert hat sich im System nichts. Angefangen hat es das er keine Temperaturen mehr aktualisiert hat. Die Modis konnte ich noch schalten. Hab dann alles Deinstalliert und wollte neu Installieren. Seit dem kommt dieser Fehler.
                                        Was wir dann alles Probiert haben siehst du ja oben.
                                        Gruß Markus
                                        Michael SchmittM F 2 Antworten Letzte Antwort
                                          Gruß Markus
                                          Michael Schmitt
                                          @markus-hofbauer
                                          Wird denn in der Fritzbox noch alles richtig angezeigt und kannst du damit deine Thermostate steuern ?
                                          Vielleicht mal ein Thermostat löschen und neu anmelden ?
