  4. Probleme mit FritzDect Adapter
    5.5k
103 Beiträge 17 Kommentatoren 16.7k Aufrufe 12 Beobachtet
  • Markus HofbauerM Markus Hofbauer
    @thomas-braun Hallo
    Ja der User wurde nur mal zu Testzwecken angelegt. Um zu schauen ob es am User liegt. Keine Sonderzeichen oder sonstiges im Passwort.
    Modell: FRITZ!Box 7582
    Aktueller Energieverbrauch: 19 %
    FRITZ!OS: 07.16 - Version aktuell
    Gruß Markus
    @markus-hofbauer
    Keine Ahnung. Mach vielleicht in Issue auf.
      @thomas-braun Hallo
      2022-01-22 14:17:55.258  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=true)
      2022-01-22 14:17:55.317  - info: fritzdect.0 (20362) Got terminate signal TERMINATE_YOURSELF
      2022-01-22 14:17:55.321  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 send kill signal
      2022-01-22 14:17:55.326  - info: fritzdect.0 (20362) cleaned everything up...
      2022-01-22 14:17:55.328  - info: fritzdect.0 (20362) terminating
      2022-01-22 14:17:55.329  - info: fritzdect.0 (20362) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-22 14:17:55.342  - error: fritzdect.0 (20362) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-01-22 14:17:55.343  - error: fritzdect.0 (20362) unhandled promise rejection: undefined
      2022-01-22 14:17:55.344  - error: fritzdect.0 (20362) undefined
      2022-01-22 14:17:55.912  - info: host.raspberrypi instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-22 14:17:58.410  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 21360
      2022-01-22 14:17:59.767  - info: fritzdect.0 (21360) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.3, js-controller: 3.3.22
      2022-01-22 14:17:59.800  - info: fritzdect.0 (21360) fritzdect entered ready
      2022-01-22 14:17:59.840  - info: fritzdect.0 (21360) fritzdect uses USER: ich
      2022-01-22 14:18:00.056  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 21375
      2022-01-22 14:18:00.232  - info: fritzdect.0 (21360) checking user permissions
      2022-01-22 14:18:00.245  - error: fritzdect.0 (21360) errorHandlerTypeError: Converting circular structure to JSON
          --> starting at object with constructor 'Socket'
          |     property 'parser' -> object with constructor 'HTTPParser'
          --- property 'socket' closes the circle
      2022-01-22 14:18:00.246  - error: fritzdect.0 (21360) fritzbox returned this {}
      2022-01-22 14:18:00.247  - error: fritzdect.0 (21360) no response part in returned message
      2022-01-22 14:18:01.798  - info: daswetter.0 (21375) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.3, js-controller: 3.3.22
      2022-01-22 14:18:03.004  - info: daswetter.0 (21375) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2022-01-22 14:18:03.533  - info: daswetter.0 (21375) cleaned everything up...
      2022-01-22 14:18:03.559  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      /usr/bin/node
      /usr/bin/npm
      pi@raspberrypi:~ $
      Hoffe der letzte Befehl war so richtig?
      Gruß Markus
      SokomotoS Offline
      SokomotoS Offline
      Sokomoto
      @markus-hofbauer sagte in Probleme mit FritzDect Adapter:
      @thomas-braun Hallo
      Ich denke diese Fehlermeldung ist das Problem, eindeutig ein Adapterfehler in meinen Augen.
      Hier kann nur der Entwickler weiterhelfen.
      tschuess
      F 1 Antwort Letzte Antwort
        @thomas-braun Hallo
        Gruß Markus
        Michael SchmittM Offline
        Michael Schmitt
        schrieb am zuletzt editiert von Michael Schmitt
        @markus-hofbauer
        und die Berechtigungen sind richtig gesetzt ?
        Markus HofbauerM 1 Antwort Letzte Antwort
        • Michael SchmittM Michael Schmitt
          @markus-hofbauer
          Markus HofbauerM Offline
          Markus Hofbauer
          @michael-schmitt Ja.
          Gruß Markus
          Z 1 Antwort Letzte Antwort
          • JB_SullivanJ Offline
            JB_Sullivan
            schrieb am zuletzt editiert von JB_Sullivan
            sorry alles dummes Zeug was ich geschrieben hatte - bitte löschen/ignorieren.
              Gruß Markus
              Z Offline
              Z Offline
              zahnheinrich
              schrieb am zuletzt editiert von zahnheinrich
              @markus-hofbauer
              Trage im Adapter versuchsweise die Anmeldedaten des Hauptusers der Fritzbox ein (also der mit ALLEN Rechten).
              Starte dann den Adapter neu, wenn Problem weiterhin, den kompletten iobroker neu, wenn dann weiterhin nicht geht, die Fritzbox neu (in dieser Reihenfolge)
              Log vom Adapter bitte posten, nur warn und error!
              MfG Ulrich
              • Z zahnheinrich
                @markus-hofbauer
                Markus Hofbauer
                @zahnheinrich Hallo
                Adapter Neustart:
                fritzdect.0
                2022-01-23 20:56:10.087	error	no response part in returned message
                fritzdect.0
                2022-01-23 20:56:10.086	error	fritzbox returned this {}
                fritzdect.0
                2022-01-23 20:56:10.086	error	errorHandlerTypeError: Converting circular structure to JSON --> starting at object with constructor 'Socket' | property 'parser' -> object with constructor 'HTTPParser' --- property 'socket' closes the circle
                fritzdect.0
                2022-01-23 20:07:31.634	error	adapter disabled
                fritzdect.0
                2022-01-23 20:07:27.083	error	undefined
                fritzdect.0
                2022-01-23 20:07:27.082	error	unhandled promise rejection: undefined
                fritzdect.0
                2022-01-23 20:07:27.081	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                Iobroker Neustart:
                fritzdect.0
                2022-01-23 21:03:30.580	error	no response part in returned message
                fritzdect.0
                2022-01-23 21:03:30.579	error	fritzbox returned this {}
                fritzdect.0
                2022-01-23 21:03:30.578	error	errorHandlerTypeError: Converting circular structure to JSON --> starting at object with constructor 'Socket' | property 'parser' -> object with constructor 'HTTPParser' --- property 'socket' closes the circle
                Fritzbox Neustart und Adapter Neustart:
                fritzdect.0
                2022-01-23 21:48:39.086	error	no response part in returned message
                fritzdect.0
                2022-01-23 21:48:39.085	error	fritzbox returned this {}
                fritzdect.0
                2022-01-23 21:48:39.083	error	errorHandlerTypeError: Converting circular structure to JSON --> starting at object with constructor 'Socket' | property 'parser' -> object with constructor 'HTTPParser' --- property 'socket' closes the circle
                fritzdect.0
                2022-01-23 21:48:14.255	error	undefined
                fritzdect.0
                2022-01-23 21:48:14.255	error	unhandled promise rejection: undefined
                fritzdect.0
                2022-01-23 21:48:14.254	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                Gruß Markus
                • SokomotoS Sokomoto
                  @thomas-braun Hallo
                  tschuess
                  foxthefox
                  @sokomoto sagte in Probleme mit FritzDect Adapter:
                  @thomas-braun Hallo
                  tschuess
                  Ich habe keine Ahnung was die FB als Antwort schickt, aber das scheint ein korruptes xml Format zu sein, was so nicht umgewandelt werden kann.
                  Ich habe auf git eine Version die hoffentlich den Fehler abfängt und eine Ausgabe liefert, die weitere Analyse zulässt.
                  Also bitte mal die Version aus git verwenden.
                  Was hat sich in der letzten Zeit am Setup geändert?
                  Adapterüberblick: Profil Github;
                  Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
                  Ein Aufruf: video
                    @sokomoto Ja, schade. Hoffentlich kann mir noch einer helfen. Aber trotzdem Danke für den Versuch.
                    Gruß Markus
                    foxthefox
                    @markus-hofbauer
                    siehe mein vorigen post, die git Version installieren und berichten
                    Ein Aufruf: video
                    • F foxthefox
                      @markus-hofbauer
                      Markus Hofbauer
                      @foxthefox Hallo,
                      Version aus Github mit der Katze installiert. Leider selbes Ergebnis.
                      fritzdect.0
                      2022-01-23 22:38:26.300	error	no response part in returned message
                      fritzdect.0
                      2022-01-23 22:38:26.299	error	fritzbox returned this {}
                      fritzdect.0
                      2022-01-23 22:38:26.296	error	errorHandlerTypeError: Converting circular structure to JSON --> starting at object with constructor 'Socket' | property 'parser' -> object with constructor 'HTTPParser' --- property 'socket' closes the circle
                      fritzdect.0
                      2022-01-23 22:38:26.280	info	checking user permissions
                      fritzdect.0
                      2022-01-23 22:38:25.859	info	fritzdect uses USER: hofb1860
                      fritzdect.0
                      2022-01-23 22:38:25.818	info	fritzdect entered ready
                      fritzdect.0
                      2022-01-23 22:38:25.789	info	starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.3, js-controller: 3.3.22
                      Gruß Markus
                      Markus HofbauerM F 2 Antworten Letzte Antwort
                        @foxthefox Hallo,
                        fritzdect.0
                        fritzdect.0
                        fritzdect.0
                        fritzdect.0
                        fritzdect.0
                        fritzdect.0
                        fritzdect.0
                        Gruß Markus
                        Markus Hofbauer
                        schrieb am zuletzt editiert von Markus Hofbauer
                        Das zeigt er mir im Expertenmodus unter "system" an.
                        Vielleicht hilft es ja.
                        FB Version: FRITZ!OS: 07.16 - Version aktuell FB Modell: 7582
                        Wie gesagt, geändert hat sich im System nichts. Angefangen hat es das er keine Temperaturen mehr aktualisiert hat. Die Modis konnte ich noch schalten. Hab dann alles Deinstalliert und wollte neu Installieren. Seit dem kommt dieser Fehler.
                        Was wir dann alles Probiert haben siehst du ja oben.
                        Gruß Markus
                        Michael SchmittM F 2 Antworten Letzte Antwort
                          Gruß Markus
                          Michael Schmitt
                          @markus-hofbauer
                          Wird denn in der Fritzbox noch alles richtig angezeigt und kannst du damit deine Thermostate steuern ?
                          Vielleicht mal ein Thermostat löschen und neu anmelden ?
                            @markus-hofbauer
                            Markus Hofbauer
                            @michael-schmitt Hallo,
                            in der FB funktioniert alles normal. Zeigt richtig an, kann alles schalten.
                            Neu anlernen hab ich schon alles probiert.
                            Gruß Markus
                              @foxthefox Hallo,
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              Gruß Markus
                              foxthefox
                              @foxthefox Hallo,
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              fritzdect.0
                              Gruß Markus
                              Hallo Markus
                              danke für die Rückmeldung,
                              eigentlich hatte ich eine Zeile im log mit 'raw perm =>' erwartet.
                              Die FB mit 7.16 scheint keine UserPermissions rauszugeben.
                              Naja, ich kommentier das mal alles raus und beschäftige mich mal mit "leeren Antworten" zu den Berechtigungen.
                              Bin gestern vom Skifahren zurückgekommen und da hab ich nicht viel Zeit aufgewendet.
                              Es liegt dann demnächst eine Änderung auf git.
                              Klaus
                              Ein Aufruf: video
                                Gruß Markus
                                foxthefox
                                @markus-hofbauer
                                Noch ein anderer Versuch, außerhalb von ioBroker.
                                Bitte in einem Terminal in folgenden Pfad navigieren
                                /opt/iobroker/node_modules/iobroker.fritzdect/lib/fritz
                                dort node "testscript.js -u deinUser -p deinPW --url http://deineIPderFB" aufrufen.
                                dann sollte in etwa so etwas kommen:
                                 Try to Login ...
                                login sid  9977212fda1010f5
                                login OK? :  true
                                 your devices
                                │ (index) │   identifier    │  id  │ functionbitmask │ fwversion │ manufacturer │   productname    │ present │        name         │
                                │    0    │ '08761 0006102' │ '16' │     '35712'     │  '04.16'  │    'AVM'     │ 'FRITZ!DECT 200' │   '1'   │ 'FRITZ!DECT 200 #1' │
                                │    1    │ '09995 0054862' │ '18' │      '320'      │  '04.94'  │    'AVM'     │ 'FRITZ!DECT 301' │   '1'   │ 'FRITZ!DECT 300 #3' │
                                │    2    │ '11657 0074380' │ '19' │     '35712'     │  '04.17'  │    'AVM'     │ 'FRITZ!DECT 210' │   '1'   │ 'FRITZ!DECT 210 #4' │
                                 your groups
                                │ (index) │      identifier       │  id   │ functionbitmask │ fwversion │ present │     name     │
                                │    0    │ 'grp5665DB-3A12B8E79' │ '900' │     '4160'      │   '1.0'   │   '1'   │ 'themogroup' │
                                Rights : <Name>Dial</Name><Access>2</Access><Name>App</Name><Access>2</Access><Name>HomeAuto</Name><Access>2</Access><Name>BoxAdmin</Name><Access>2</Access><Name>Phone</Name><Access>2</Access>
                                Check SID OK?: true
                                Check Rights :
                                1 = read only; 2 = ready and write
                                │ (index) │   0    │   1   │     2      │     3      │    4    │
                                │  Name   │ 'Dial' │ 'App' │ 'HomeAuto' │ 'BoxAdmin' │ 'Phone' │
                                │ Access  │  '2'   │  '2'  │    '2'     │    '2'     │   '2'   │
                                 logout : true
                                eventuell hängt es ja an etwas ganz anderem, als der Anzeige der Berechtigungen.
                                Klaus
                                Ein Aufruf: video
                                  Gruß Markus
                                  foxthefox
                                  gab es sonst irgendwelche Änderungen am System? Neuer js-controller? sonstige iobroker updates?
                                  Ein Aufruf: video
                                  • F foxthefox
                                    Markus Hofbauer
                                    @foxthefox Hallo,
                                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.fritzdect/lib/fritz $ node "testscript.js -u hofb1860 -p hongomax19 --url http://192.168.178.1"
                                    internal/modules/cjs/loader.js:905
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.fritzdect/lib/fritz/testscript.js -u hofb1860 -p hongomax19 --url http:/192.168.178.1'
                                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
                                        at internal/main/run_main_module.js:17:47 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                    Oder hab ich da was falsch eingegeben?
                                    Gruß Markus
                                      @zahnheinrich Hallo
                                      Adapter Neustart:
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      Iobroker Neustart:
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      fritzdect.0
                                      Gruß Markus
                                      Z Offline
                                      Z Offline
                                      zahnheinrich
                                      @markus-hofbauer
                                      Da schliesse ich mich @foxthefox an, saß kommt nicht von der Box.
                                      MfG Ulrich
                                      • Z zahnheinrich
                                        @markus-hofbauer
                                        Markus Hofbauer
                                        Habs jetzt anders eingegeben. Ohne Anführunsstriche.
                                        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.fritzdect/lib/fritz $  node testscript.js -u hofb1860 -p hongomax19 --url http://192.168.178.1
                                         Try to Login ...
                                        login sid  fb4d114f7a108c5f
                                        login OK? :  true
                                         your devices
                                        │    0    │ '09995 1021163' │ '19' │      '320'      │  '04.97'  │    'AVM'     │ 'FRITZ!DECT 301' │   '1'   │ 'Esszimmer rechts' │
                                        │    1    │ '09995 1020710' │ '20' │      '320'      │  '04.97'  │    'AVM'     │ 'FRITZ!DECT 301' │   '1'   │ 'Esszimmer links'  │
                                        │    2    │ '09995 1022706' │ '21' │      '320'      │  '04.97'  │    'AVM'     │ 'FRITZ!DECT 301' │   '1'   │    'Wohnzimmer'    │
                                         your groups
                                        │    0    │ 'grp0710C6-3D328FB9B' │ '900' │     '4160'      │   '1.0'   │   '1'   │ 'Esszimmer' │
                                        Fehler checkSID {
                                          msg: 'AHA request error',
                                          function: 'fritzAHA_Request',
                                          error: 404,
                                          response: <ref *1> IncomingMessage {
                                            _readableState: ReadableState {
                                              objectMode: false,
                                              highWaterMark: 16384,
                                              buffer: BufferList { head: null, tail: null, length: 0 },
                                              length: 0,
                                              pipes: [],
                                              flowing: true,
                                              ended: false,
                                              endEmitted: false,
                                              reading: true,
                                              sync: false,
                                              needReadable: true,
                                              emittedReadable: false,
                                              readableListening: false,
                                              resumeScheduled: false,
                                              errorEmitted: false,
                                              emitClose: true,
                                              autoDestroy: false,
                                              destroyed: false,
                                              errored: null,
                                              closed: false,
                                              closeEmitted: false,
                                              defaultEncoding: 'utf8',
                                              awaitDrainWriters: null,
                                              multiAwaitDrain: false,
                                              readingMore: false,
                                              dataEmitted: true,
                                              decoder: [StringDecoder],
                                              encoding: 'utf8',
                                              [Symbol(kPaused)]: false
                                            _events: [Object: null prototype] {
                                              end: [Array],
                                              data: [Function (anonymous)]
                                            _eventsCount: 2,
                                            _maxListeners: undefined,
                                            socket: Socket {
                                              connecting: false,
                                              _hadError: false,
                                              _parent: null,
                                              _host: null,
                                              _readableState: [ReadableState],
                                              _events: [Object: null prototype],
                                              _eventsCount: 8,
                                              _writableState: [WritableState],
                                              allowHalfOpen: false,
                                              _sockname: null,
                                              _pendingData: null,
                                              _pendingEncoding: '',
                                              server: null,
                                              _server: null,
                                              parser: [HTTPParser],
                                              _httpMessage: [ClientRequest],
                                              [Symbol(async_id_symbol)]: 76,
                                              [Symbol(kHandle)]: [TCP],
                                              [Symbol(kSetNoDelay)]: false,
                                              [Symbol(lastWriteQueueSize)]: 0,
                                              [Symbol(timeout)]: null,
                                              [Symbol(kBuffer)]: null,
                                              [Symbol(kBufferCb)]: null,
                                              [Symbol(kBufferGen)]: null,
                                              [Symbol(kCapture)]: false,
                                              [Symbol(kBytesRead)]: 0,
                                              [Symbol(kBytesWritten)]: 0,
                                              [Symbol(RequestTimeout)]: undefined
                                            httpVersionMajor: 1,
                                            httpVersionMinor: 1,
                                            httpVersion: '1.1',
                                            complete: false,
                                            headers: {
                                              connection: 'close',
                                              'content-length': '1703',
                                              'content-type': 'text/html; charset=utf-8'
                                            rawHeaders: [
                                              'Connection',
                                              'close',
                                              'Content-Length',
                                              '1703',
                                              'Content-Type',
                                            trailers: {},
                                            rawTrailers: [],
                                            aborted: false,
                                            upgrade: false,
                                            url: '',
                                            method: null,
                                            statusCode: 404,
                                            statusMessage: 'Not Found',
                                            client: Socket {
                                              connecting: false,
                                              _hadError: false,
                                              _parent: null,
                                              _host: null,
                                              _eventsCount: 8,
                                              _sockname: null,
                                              _pendingData: null,
                                              server: null,
                                              _server: null,
                                            _consuming: true,
                                            _dumped: false,
                                            req: ClientRequest {
                                              _eventsCount: 2,
                                              outputData: [],
                                              outputSize: 0,
                                              writable: true,
                                              destroyed: false,
                                              _last: true,
                                              chunkedEncoding: false,
                                              shouldKeepAlive: false,
                                              _defaultKeepAlive: true,
                                              useChunkedEncodingByDefault: false,
                                              sendDate: false,
                                              _removedConnection: false,
                                              _removedContLen: false,
                                              _removedTE: false,
                                              _contentLength: 0,
                                              _hasBody: true,
                                              _trailer: '',
                                              finished: true,
                                              _headerSent: true,
                                              socket: [Socket],
                                              _header: 'GET /login_sid.lua&sid=fb4d114f7a108c5f HTTP/1.1\r\n' +
                                                'Content-Type: application/x-www-form-urlencoded\r\n' +
                                                'Host: 192.168.178.1\r\n' +
                                                'Connection: close\r\n' +
                                                '\r\n',
                                              _keepAliveTimeout: 0,
                                              _onPendingData: [Function: noopPendingOutput],
                                              agent: [Agent],
                                              socketPath: undefined,
                                              method: 'GET',
                                              maxHeaderSize: undefined,
                                              insecureHTTPParser: undefined,
                                              path: '/login_sid.lua&sid=fb4d114f7a108c5f',
                                              _ended: false,
                                              res: [Circular *1],
                                              aborted: false,
                                              timeoutCb: null,
                                              upgradeOrConnect: false,
                                              maxHeadersCount: null,
                                              reusedSocket: false,
                                              host: '192.168.178.1',
                                              protocol: 'http:',
                                              [Symbol(kNeedDrain)]: false,
                                              [Symbol(corked)]: 0,
                                              [Symbol(kOutHeaders)]: [Object: null prototype]
                                        Fehler logout_SID {
                                          error: 404,
                                              objectMode: false,
                                              length: 0,
                                              pipes: [],
                                              flowing: true,
                                              ended: false,
                                              endEmitted: false,
                                              reading: true,
                                              sync: false,
                                              needReadable: true,
                                              emitClose: true,
                                              autoDestroy: false,
                                              destroyed: false,
                                              errored: null,
                                              closed: false,
                                              readingMore: false,
                                              dataEmitted: true,
                                              encoding: 'utf8',
                                              end: [Array],
                                            _eventsCount: 2,
                                            socket: Socket {
                                              connecting: false,
                                              _hadError: false,
                                              _parent: null,
                                              _host: null,
                                              _eventsCount: 8,
                                              _sockname: null,
                                              _pendingData: null,
                                              server: null,
                                              _server: null,
                                              [Symbol(async_id_symbol)]: 85,
                                            httpVersion: '1.1',
                                            complete: false,
                                            headers: {
                                            rawHeaders: [
                                              'Connection',
                                              'close',
                                              'Content-Length',
                                              '1703',
                                              'Content-Type',
                                            trailers: {},
                                            rawTrailers: [],
                                            aborted: false,
                                            upgrade: false,
                                            url: '',
                                            method: null,
                                            statusCode: 404,
                                            client: Socket {
                                              connecting: false,
                                              _hadError: false,
                                              _parent: null,
                                              _host: null,
                                              _eventsCount: 8,
                                              _sockname: null,
                                              _pendingData: null,
                                              server: null,
                                              _server: null,
                                            _consuming: true,
                                            _dumped: false,
                                              _eventsCount: 2,
                                              outputData: [],
                                              outputSize: 0,
                                              writable: true,
                                              destroyed: false,
                                              _last: true,
                                              sendDate: false,
                                              _removedTE: false,
                                              _contentLength: 0,
                                              _hasBody: true,
                                              _trailer: '',
                                              finished: true,
                                              _headerSent: true,
                                              socket: [Socket],
                                              _header: 'GET /login_sid.lua&sid=fb4d114f7a108c5f&logout=1 HTTP/1.1\r\n' +
                                                '\r\n',
                                              agent: [Agent],
                                              method: 'GET',
                                              path: '/login_sid.lua&sid=fb4d114f7a108c5f&logout=1',
                                              _ended: false,
                                              res: [Circular *1],
                                              aborted: false,
                                              timeoutCb: null,
                                              protocol: 'http:',
                                        Devices<devicelist version="1"><device identifier="09995 1021163" id="19" functionbitmask="320" fwversion="04.97" manufacturer="AVM" productname="FRITZ!DECT 301"><present>1</present><name>Esszimmer rechts</name><battery>100</battery><batterylow>0</batterylow><temperature><celsius>245</celsius><offset>15</offset></temperature><hkr><tist>49</tist><tsoll>48</tsoll><absenk>36</absenk><komfort>48</komfort><lock>0</lock><devicelock>0</devicelock><errorcode>0</errorcode><windowopenactiv>0</windowopenactiv><batterylow>0</batterylow><battery>100</battery><nextchange><endperiod>1643050800</endperiod><tchange>36</tchange></nextchange><summeractive>0</summeractive><holidayactive>0</holidayactive></hkr></device><group identifier="grp0710C6-3D328FB9B" id="900" functionbitmask="4160" fwversion="1.0" manufacturer="AVM" productname=""><present>1</present><name>Esszimmer</name><hkr><tist>0</tist><tsoll>48</tsoll><absenk>36</absenk><komfort>48</komfort><lock>0</lock><devicelock>0</devicelock><errorcode>0</errorcode><windowopenactiv>0</windowopenactiv><nextchange><endperiod>1643050800</endperiod><tchange>36</tchange></nextchange><summeractive>0</summeractive><holidayactive>0</holidayactive></hkr><groupinfo><masterdeviceid>0</masterdeviceid><members>19,20</members></groupinfo></group><device identifier="09995 1020710" id="20" functionbitmask="320" fwversion="04.97" manufacturer="AVM" productname="FRITZ!DECT 301"><present>1</present><name>Esszimmer links</name><battery>100</battery><batterylow>0</batterylow><temperature><celsius>245</celsius><offset>10</offset></temperature><hkr><tist>49</tist><tsoll>48</tsoll><absenk>36</absenk><komfort>48</komfort><lock>0</lock><devicelock>0</devicelock><errorcode>0</errorcode><windowopenactiv>0</windowopenactiv><batterylow>0</batterylow><battery>100</battery><nextchange><endperiod>1643050800</endperiod><tchange>36</tchange></nextchange><summeractive>0</summeractive><holidayactive>0</holidayactive></hkr></device><device identifier="09995 1022706" id="21" functionbitmask="320" fwversion="04.97" manufacturer="AVM" productname="FRITZ!DECT 301"><present>1</present><name>Wohnzimmer</name><battery>100</battery><batterylow>0</batterylow><temperature><celsius>240</celsius><offset>5</offset></temperature><hkr><tist>48</tist><tsoll>48</tsoll><absenk>36</absenk><komfort>48</komfort><lock>0</lock><devicelock>0</devicelock><errorcode>0</errorcode><windowopenactiv>0</windowopenactiv><batterylow>0</batterylow><battery>100</battery><nextchange><endperiod>1643050800</endperiod><tchange>36</tchange></nextchange><summeractive>0</summeractive><holidayactive>0</holidayactive></hkr></device></devicelist>
                                        Fehler logout_SID {
                                          error: 404,
                                              objectMode: false,
                                              length: 0,
                                              pipes: [],
                                              flowing: true,
                                              ended: false,
                                              endEmitted: false,
                                              reading: true,
                                              sync: false,
                                              needReadable: true,
                                              emitClose: true,
                                              autoDestroy: false,
                                              destroyed: false,
                                              errored: null,
                                              closed: false,
                                              readingMore: false,
                                              dataEmitted: true,
                                              encoding: 'utf8',
                                              end: [Array],
                                            _eventsCount: 2,
                                            socket: Socket {
                                              connecting: false,
                                              _hadError: false,
                                              _parent: null,
                                              _host: null,
                                              _eventsCount: 8,
                                              _sockname: null,
                                              _pendingData: null,
                                              server: null,
                                              _server: null,
                                              [Symbol(async_id_symbol)]: 124,
                                            httpVersion: '1.1',
                                            complete: false,
                                            headers: {
                                            rawHeaders: [
                                              'Connection',
                                              'close',
                                              'Content-Length',
                                              '1703',
                                              'Content-Type',
                                            trailers: {},
                                            rawTrailers: [],
                                            aborted: false,
                                            upgrade: false,
                                            url: '',
                                            method: null,
                                            statusCode: 404,
                                            client: Socket {
                                              connecting: false,
                                              _hadError: false,
                                              _parent: null,
                                              _host: null,
                                              _eventsCount: 8,
                                              _sockname: null,
                                              _pendingData: null,
                                              server: null,
                                              _server: null,
                                            _consuming: true,
                                            _dumped: false,
                                              _eventsCount: 2,
                                              outputData: [],
                                              outputSize: 0,
                                              writable: true,
                                              destroyed: false,
                                              _last: true,
                                              sendDate: false,
                                              _removedTE: false,
                                              _contentLength: 0,
                                              _hasBody: true,
                                              _trailer: '',
                                              finished: true,
                                              _headerSent: true,
                                              socket: [Socket],
                                                '\r\n',
                                              agent: [Agent],
                                              method: 'GET',
                                              _ended: false,
                                              res: [Circular *1],
                                              aborted: false,
                                              timeoutCb: null,
                                              protocol: 'http:',
                                        Gruß Markus
                                           Try to Login ...
                                          login OK? :  true
                                           your devices
                                           your groups
                                          Fehler checkSID {
                                            error: 404,
                                                objectMode: false,
                                                length: 0,
                                                pipes: [],
                                                flowing: true,
                                                ended: false,
                                                endEmitted: false,
                                                reading: true,
                                                sync: false,
                                                needReadable: true,
                                                emitClose: true,
                                                autoDestroy: false,
                                                destroyed: false,
                                                errored: null,
                                                closed: false,
                                                readingMore: false,
                                                dataEmitted: true,
                                                encoding: 'utf8',
                                                end: [Array],
                                              _eventsCount: 2,
                                              socket: Socket {
                                                connecting: false,
                                                _hadError: false,
                                                _parent: null,
                                                _host: null,
                                                _eventsCount: 8,
                                                _sockname: null,
                                                _pendingData: null,
                                                server: null,
                                                _server: null,
                                              httpVersion: '1.1',
                                              complete: false,
                                              headers: {
                                              rawHeaders: [
                                                'Connection',
                                                'close',
                                                'Content-Length',
                                                '1703',
                                                'Content-Type',
                                              trailers: {},
                                              rawTrailers: [],
                                              aborted: false,
                                              upgrade: false,
                                              url: '',
                                              method: null,
                                              statusCode: 404,
                                              client: Socket {
                                                connecting: false,
                                                _hadError: false,
                                                _parent: null,
                                                _host: null,
                                                _eventsCount: 8,
                                                _sockname: null,
                                                _pendingData: null,
                                                server: null,
                                                _server: null,
                                              _consuming: true,
                                              _dumped: false,
                                                _eventsCount: 2,
                                                outputData: [],
                                                outputSize: 0,
                                                writable: true,
                                                destroyed: false,
                                                _last: true,
                                                sendDate: false,
                                                _removedTE: false,
                                                _contentLength: 0,
                                                _hasBody: true,
                                                _trailer: '',
                                                finished: true,
                                                _headerSent: true,
                                                socket: [Socket],
                                                  '\r\n',
                                                agent: [Agent],
                                                method: 'GET',
                                                _ended: false,
                                                res: [Circular *1],
                                                aborted: false,
                                                timeoutCb: null,
                                                protocol: 'http:',
                                          Fehler logout_SID {
                                            error: 404,
                                                objectMode: false,
                                                length: 0,
                                                pipes: [],
                                                flowing: true,
                                                ended: false,
                                                endEmitted: false,
                                                reading: true,
                                                sync: false,
                                                needReadable: true,
                                                emitClose: true,
                                                autoDestroy: false,
                                                destroyed: false,
                                                errored: null,
                                                closed: false,
                                                readingMore: false,
                                                dataEmitted: true,
                                                encoding: 'utf8',
                                                end: [Array],
                                              _eventsCount: 2,
                                              socket: Socket {
                                                connecting: false,
                                                _hadError: false,
                                                _parent: null,
                                                _host: null,
                                                _eventsCount: 8,
                                                _sockname: null,
                                                _pendingData: null,
                                                server: null,
                                                _server: null,
                                              httpVersion: '1.1',
                                              complete: false,
                                              headers: {
                                              rawHeaders: [
                                                'Connection',
                                                'close',
                                                'Content-Length',
                                                '1703',
                                                'Content-Type',
                                              trailers: {},
                                              rawTrailers: [],
                                              aborted: false,
                                              upgrade: false,
                                              url: '',
                                              method: null,
                                              statusCode: 404,
                                              client: Socket {
                                                connecting: false,
                                                _hadError: false,
                                                _parent: null,
                                                _host: null,
                                                _eventsCount: 8,
                                                _sockname: null,
                                                _pendingData: null,
                                                server: null,
                                                _server: null,
                                              _consuming: true,
                                              _dumped: false,
                                                _eventsCount: 2,
                                                outputData: [],
                                                outputSize: 0,
                                                writable: true,
                                                destroyed: false,
                                                _last: true,
                                                sendDate: false,
                                                _removedTE: false,
                                                _contentLength: 0,
                                                _hasBody: true,
                                                _trailer: '',
                                                finished: true,
                                                _headerSent: true,
                                                socket: [Socket],
                                                  '\r\n',
                                                agent: [Agent],
                                                method: 'GET',
                                                _ended: false,
                                                res: [Circular *1],
                                                aborted: false,
                                                timeoutCb: null,
                                                protocol: 'http:',
                                          Fehler logout_SID {
                                            error: 404,
                                                objectMode: false,
                                                length: 0,
                                                pipes: [],
                                                flowing: true,
                                                ended: false,
                                                endEmitted: false,
                                                reading: true,
                                                sync: false,
                                                needReadable: true,
                                                emitClose: true,
                                                autoDestroy: false,
                                                destroyed: false,
                                                errored: null,
                                                closed: false,
                                                readingMore: false,
                                                dataEmitted: true,
                                                encoding: 'utf8',
                                                end: [Array],
                                              _eventsCount: 2,
                                              socket: Socket {
                                                connecting: false,
                                                _hadError: false,
                                                _parent: null,
                                                _host: null,
                                                _eventsCount: 8,
                                                _sockname: null,
                                                _pendingData: null,
                                                server: null,
                                                _server: null,
                                              httpVersion: '1.1',
                                              complete: false,
                                              headers: {
                                              rawHeaders: [
                                                'Connection',
                                                'close',
                                                'Content-Length',
                                                '1703',
                                                'Content-Type',
                                              trailers: {},
                                              rawTrailers: [],
                                              aborted: false,
                                              upgrade: false,
                                              url: '',
                                              method: null,
                                              statusCode: 404,
                                              client: Socket {
                                                connecting: false,
                                                _hadError: false,
                                                _parent: null,
                                                _host: null,
                                                _eventsCount: 8,
                                                _sockname: null,
                                                _pendingData: null,
                                                server: null,
                                                _server: null,
                                              _consuming: true,
                                              _dumped: false,
                                                _eventsCount: 2,
                                                outputData: [],
                                                outputSize: 0,
                                                writable: true,
                                                destroyed: false,
                                                _last: true,
                                                sendDate: false,
                                                _removedTE: false,
                                                _contentLength: 0,
                                                _hasBody: true,
                                                _trailer: '',
                                                finished: true,
                                                _headerSent: true,
                                                socket: [Socket],
                                                  '\r\n',
                                                agent: [Agent],
                                                method: 'GET',
                                                _ended: false,
                                                res: [Circular *1],
                                                aborted: false,
                                                timeoutCb: null,
                                                protocol: 'http:',
                                          Gruß Markus
                                          Markus Hofbauer
                                          hab jetzt noch mal die letzte Version von Github installiert. Jetzt scheint es zu funktionieren.
                                          Gruß Markus
