  4. Probleme mit FritzDect Adapter
    5.6k
103 Beiträge 17 Kommentatoren 16.7k Aufrufe 12 Beobachtet
  • Markus HofbauerM Markus Hofbauer
    @thomas-braun Ok. Habe ich gemacht. Fehler besteht immer noch. Verzweiflungsmodus an.
    Gruß Markus
    @markus-hofbauer
    Zeig uns mal die Ausgaben von
    iobroker update -i
    iobroker list instances
    Markus HofbauerM 1 Antwort Letzte Antwort
      @markus-hofbauer
      iobroker update -i
      Markus HofbauerM Offline
      Markus Hofbauer
      pi@raspberrypi:~ $ iobroker update -i
      Used repository: default
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.2.3    , installed 5.2.3
      Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
      Adapter    "backitup"      : 2.2.2    , installed 2.2.2
      Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
      Adapter    "deconz"        : 1.3.19   , installed 1.3.19
      Adapter    "discovery"     : 2.7.3    , installed 2.7.5
      Adapter    "ecovacs-deebot": 1.3.1    , installed 1.3.1
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "fritzdect"     : 2.2.3    , installed 2.2.3
      Adapter    "fullybrowser"  : 2.0.10   , installed 2.0.10
      Adapter    "history"       : 1.9.14   , installed 1.10.5
      Adapter    "hs100"         : 2.0.6    , installed 2.0.6
      Adapter    "hue"           : 3.5.31   , installed 3.6.0
      Adapter    "hue-extended"  : 2.0.0    , installed 2.0.0
      Adapter    "ical"          : 1.11.4   , installed 1.11.4
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
      Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
      Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "info"          : 1.9.8    , installed 1.9.16
      Adapter    "iot"           : 1.8.24   , installed 1.8.25
      Adapter    "javascript"    : 5.2.13   , installed 5.2.18
      Controller "js-controller" : 3.3.22   , installed 3.3.22
      Adapter    "meteoalarm"    : 2.0.10   , installed 2.0.10
      Adapter    "nuki"          : 1.6.0    , installed 1.6.0
      Adapter    "nuki-extended" : 2.3.1    , installed 2.3.1
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "scenes"        : 2.3.8    , installed 2.3.8
      Adapter    "shelly"        : 4.0.7    , installed 4.0.7
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
      Adapter    "socketio"      : 3.1.4    , installed 3.1.5
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
      Adapter    "trashschedule" : 1.4.1    , installed 1.4.1
      Adapter    "vis"           : 1.4.5    , installed 1.4.5
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
      Adapter    "vis-icontwo"   : 0.84.0   , installed 0.84.0
      Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
      Adapter    "web"           : 3.4.9    , installed 3.4.16
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ iobroker list instances
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
      + system.adapter.nuki.0                   : nuki                  : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + instance is alive
      pi@raspberrypi:~ $
      Gruß Markus
        Mein Fritz Dect Adapter zeigt mir keine Geräte mehr an. Im Log kommt immer diese Fehlermeldung.
        2022-01-21 11:04:43.458 - info: fritzdect.0 (30240) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.3, js-controller: 3.3.22
        2022-01-21 11:04:43.490 - info: fritzdect.0 (30240) fritzdect entered ready
        2022-01-21 11:04:43.527 - info: fritzdect.0 (30240) fritzdect uses USER: iobroker
        2022-01-21 11:04:43.910 - info: fritzdect.0 (30240) checking user permissions
        2022-01-21 11:04:43.918 - error: fritzdect.0 (30240) errorHandlerTypeError: Converting circular structure to JSON
        --> starting at object with constructor 'Socket'
        | property 'parser' -> object with constructor 'HTTPParser'
        --- property 'socket' closes the circle
        2022-01-21 11:04:43.918 - error: fritzdect.0 (30240) fritzbox returned this {}
        2022-01-21 11:04:43.919 - error: fritzdect.0 (30240) no response part in returned message
        Ich habe schon alle Versionen durchprobiert. Die 2.2.0, die 2.2.3 und die 2.2.4
        Der Adapter 2.2.3 lief Anfangs auch schon mal, bis er plötzlich keine Temperaturen mehr aktualisierte. Hab dann die Instanz und den Adapter gelöscht und wollte neu installieren. Seit dem bekomme ich gar keine Daten mehr. Es kommt immer der selbe Fehler.
        Gruß Markus
        SokomotoS Offline
        SokomotoS Offline
        Sokomoto
        @markus-hofbauer sagte in Probleme mit FritzDect Adapter:
        Hast du schon mal deinen Fritzbox User überprüft?. Einfach mal mit diesem Username, sich an der Fritzbox anmelden. Ich hatte schon mal einen defekten User in meiner Fritzbox. Irgendwie war bei dem Benutzer die Berechtigungen weg.
        tschuesss
        • SokomotoS Sokomoto
          tschuesss
          Markus Hofbauer
          @sokomoto Hallo,
          an der Fritzbox kann ich mich mit dem User ganz normal anmelden. Weitere Ideen?
          Gruß Markus
            @sokomoto Hallo,
            Gruß Markus
            @markus-hofbauer
            Hat der user 'iobroker' auch die passenden Rechter in der FritzBüchse?
              @markus-hofbauer
              Markus Hofbauer
              @thomas-braun Ja hat er. Wie gesagt, es hat ja schon mal funktioniert. Und ich habe eigentlich seither nichts geändert. Zumindest nicht bewusst.
              Gruß Markus
              SokomotoS 1 Antwort Letzte Antwort
                Gruß Markus
                SokomotoS Offline
                SokomotoS Offline
                Sokomoto
                Was steht den in deinen Fritzbox Protokoll unter Ereignisse ?. Du kommst ja bis zur Anmeldung, vielleicht steht da ein brauchbarer Hinweis.
                  Markus Hofbauer
                  @sokomoto Hallo,
                  das ist das einzige was unter Ereignisse steht.
                  21.01.22
                  15:59:04
                  Anmeldung des Benutzers iobroker an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.178.85.
                  Gruß Markus
                    @sokomoto Hallo,
                    21.01.22
                    15:59:04
                    Gruß Markus
                    SokomotoS Offline
                    SokomotoS Offline
                    Sokomoto
                    Jetzt ist es eindeutig ein Adapterproblem, die Fritzbox ist raus. Ich habe nach wie vor die
                    v2.1.15 am laufen. Die läuft wie ein Uhrwerk, deshalb habe ich bis jetzt auch noch kein Update durchgeführt. Bei deinem Problem kann ich dir jetzt nicht mehr weiterhelfen.
                    tschuess
                      tschuess
                      Markus Hofbauer
                      @sokomoto Ja, schade. Hoffentlich kann mir noch einer helfen. Aber trotzdem Danke für den Versuch.
                      Gruß Markus
                      Markus HofbauerM F 2 Antworten Letzte Antwort
                        Gruß Markus
                        Markus Hofbauer
                        Hier noch mal die Meldungen wenn ich beim Adapter auf debuggen (Meine Geräte) drücke.
                        [{"identifier":"09995 1021163","id":"19","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Esszimmer rechts","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"0"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}},{"identifier":"09995 1020710","id":"20","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Esszimmer links","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"0"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}},{"identifier":"09995 1022706","id":"21","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Wohnzimmer","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"-5"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}}]
                        Hoffentlich hilft das weiter.
                        Gruß Markus
                        SokomotoS Michael SchmittM 2 Antworten Letzte Antwort
                          Gruß Markus
                          SokomotoS Offline
                          SokomotoS Offline
                          Sokomoto
                          Mir fällt nur eins auf, bei meinen 12 Adaptern, verschiedene Modele, steht immer noch eine zusätzliche Variable mit drin,
                          "txbusy":"0"
                          Hier ein Ausschnitt vom Dect 300 :
                          "productname":"FRITZ!DECT 300","present":"1","txbusy":"0","name":"Büro",
                          Jetzt kann es sein, dass die Variable bei deinem Model nicht mehr eingepflegt wurde. Sonst sind alle Einträge identisch mit meinen.
                          tschuess
                            Gruß Markus
                            Michael SchmittM Online
                            Michael Schmitt
                            @markus-hofbauer du arbeitest ja mit einem Conbee2 und deconz oder ?
                            Ist denn Phoscon auf der aktuellen Version ?
                            • Michael SchmittM Michael Schmitt
                              Markus Hofbauer
                              @michael-schmitt Hallo,
                              ja ich habe auch einen Conbee2. Der ist aber auf einem anderem Pi installiert.
                              Verstehe jetzt aber nicht was das mit den DECT Geräten zu tun hat?
                              Gruß Markus
                                Gruß Markus
                                Markus Hofbauer
                                hat keiner der Profis noch eine Idee was ich noch machen könnte?
                                Gruß Markus
                                  Gruß Markus
                                  SokomotoS Offline
                                  SokomotoS Offline
                                  Sokomoto
                                  Ich würde an deiner Stelle als nächstes alle Datenpunkte von Fritzdect löschen, den Adapter vorher deinstallieren und dann eine Neuinstallation des Adapter vornehmen. Die Gerätedaten kommen ja im Adapter an. Der Adapter schreibt die Daten aber nicht in die DP, warum auch immer.
                                  tschuess
                                    tschuess
                                    Markus Hofbauer
                                    @sokomoto Das hab ich alles schon zig mal gemacht. Hab jetzt versuchsweise den Adapter auf einem anderen Pi mit iobroker (der läuft normalerweise aber nicht) installiert. Da bekomme ich das selbe Ergebnis oder Fehler. Bist du sicher das es am Adapter liegt?
                                    Gruß Markus
                                      Gruß Markus
                                      SokomotoS Offline
                                      SokomotoS Offline
                                      Sokomoto
                                      Wie schauen den die Datenpunkte jetzt aus, nachdem sie neu angelegt wurden. Was sagt der Zeitstempel, letzte Änderung, bei der Celsius/Temperatur zum Beispiel ?
                                      tschuess
                                        tschuess
                                        Markus Hofbauer
                                        @sokomoto Der schreibt mir gar keine Datenpunkte mehr. Ich sehe nur noch den Admin Ordner.
                                        Gruß Markus
                                          Gruß Markus
                                          SokomotoS Offline
                                          SokomotoS Offline
                                          Sokomoto
                                          Das kann nicht sein, hier müssen mehrere Ordner sein :
