  4. Probleme mit FritzDect Adapter
    5.5k
103 Beiträge 17 Kommentatoren 16.7k Aufrufe 12 Beobachtet
  • Markus HofbauerM Markus Hofbauer
    @sokomoto Ja, schade. Hoffentlich kann mir noch einer helfen. Aber trotzdem Danke für den Versuch.
    Gruß Markus
    Markus HofbauerM Offline
    Markus Hofbauer
    Hier noch mal die Meldungen wenn ich beim Adapter auf debuggen (Meine Geräte) drücke.
    [{"identifier":"09995 1021163","id":"19","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Esszimmer rechts","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"0"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}},{"identifier":"09995 1020710","id":"20","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Esszimmer links","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"0"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}},{"identifier":"09995 1022706","id":"21","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Wohnzimmer","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"-5"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}}]
    Hoffentlich hilft das weiter.
    Gruß Markus
    SokomotoS Michael SchmittM 2 Antworten Letzte Antwort
      Gruß Markus
      SokomotoS Offline
      SokomotoS Offline
      Sokomoto
      @markus-hofbauer sagte in Probleme mit FritzDect Adapter:
      Mir fällt nur eins auf, bei meinen 12 Adaptern, verschiedene Modele, steht immer noch eine zusätzliche Variable mit drin,
      "txbusy":"0"
      Hier ein Ausschnitt vom Dect 300 :
      "productname":"FRITZ!DECT 300","present":"1","txbusy":"0","name":"Büro",
      Jetzt kann es sein, dass die Variable bei deinem Model nicht mehr eingepflegt wurde. Sonst sind alle Einträge identisch mit meinen.
      tschuess
        Gruß Markus
        Michael SchmittM Offline
        Michael Schmitt
        @markus-hofbauer du arbeitest ja mit einem Conbee2 und deconz oder ?
        Ist denn Phoscon auf der aktuellen Version ?
        Markus HofbauerM 1 Antwort Letzte Antwort
        • Michael SchmittM Michael Schmitt
          Markus Hofbauer
          @michael-schmitt Hallo,
          ja ich habe auch einen Conbee2. Der ist aber auf einem anderem Pi installiert.
          Verstehe jetzt aber nicht was das mit den DECT Geräten zu tun hat?
          Gruß Markus
            Gruß Markus
            Markus Hofbauer
            hat keiner der Profis noch eine Idee was ich noch machen könnte?
            Gruß Markus
            SokomotoS 1 Antwort Letzte Antwort
              Gruß Markus
              SokomotoS Offline
              SokomotoS Offline
              Sokomoto
              Ich würde an deiner Stelle als nächstes alle Datenpunkte von Fritzdect löschen, den Adapter vorher deinstallieren und dann eine Neuinstallation des Adapter vornehmen. Die Gerätedaten kommen ja im Adapter an. Der Adapter schreibt die Daten aber nicht in die DP, warum auch immer.
              tschuess
              • SokomotoS Sokomoto
                tschuess
                Markus Hofbauer
                @sokomoto Das hab ich alles schon zig mal gemacht. Hab jetzt versuchsweise den Adapter auf einem anderen Pi mit iobroker (der läuft normalerweise aber nicht) installiert. Da bekomme ich das selbe Ergebnis oder Fehler. Bist du sicher das es am Adapter liegt?
                Gruß Markus
                  Gruß Markus
                  SokomotoS Offline
                  SokomotoS Offline
                  Sokomoto
                  Wie schauen den die Datenpunkte jetzt aus, nachdem sie neu angelegt wurden. Was sagt der Zeitstempel, letzte Änderung, bei der Celsius/Temperatur zum Beispiel ?
                  tschuess
                    tschuess
                    Markus Hofbauer
                    @sokomoto Der schreibt mir gar keine Datenpunkte mehr. Ich sehe nur noch den Admin Ordner.
                    Gruß Markus
                      Gruß Markus
                      SokomotoS Offline
                      SokomotoS Offline
                      Sokomoto
                      Das kann nicht sein, hier müssen mehrere Ordner sein :
                        Markus Hofbauer
                        @sokomoto Tja ist aber leider so.
                        Die Fehlermeldungen kommen immer dann wenn ich den Adapter neu starte.
                        Gruß Markus
                          Gruß Markus
                          @markus-hofbauer
                          Zeig mal einen vollständigen Neustart im LogFile.
                          Am besten per
                          iobroker logs --watch
                          Und auch mal schauen wie es bei nodeJS aussieht:
                          which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            @markus-hofbauer
                            Am besten per
                            Markus Hofbauer
                            @thomas-braun Hallo
                            2022-01-22 14:17:55.258  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=true)
                            2022-01-22 14:17:55.317  - info: fritzdect.0 (20362) Got terminate signal TERMINATE_YOURSELF
                            2022-01-22 14:17:55.321  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 send kill signal
                            2022-01-22 14:17:55.326  - info: fritzdect.0 (20362) cleaned everything up...
                            2022-01-22 14:17:55.328  - info: fritzdect.0 (20362) terminating
                            2022-01-22 14:17:55.329  - info: fritzdect.0 (20362) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2022-01-22 14:17:55.342  - error: fritzdect.0 (20362) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2022-01-22 14:17:55.343  - error: fritzdect.0 (20362) unhandled promise rejection: undefined
                            2022-01-22 14:17:55.344  - error: fritzdect.0 (20362) undefined
                            2022-01-22 14:17:55.912  - info: host.raspberrypi instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2022-01-22 14:17:58.410  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 21360
                            2022-01-22 14:17:59.767  - info: fritzdect.0 (21360) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.3, js-controller: 3.3.22
                            2022-01-22 14:17:59.800  - info: fritzdect.0 (21360) fritzdect entered ready
                            2022-01-22 14:17:59.840  - info: fritzdect.0 (21360) fritzdect uses USER: ich
                            2022-01-22 14:18:00.056  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 21375
                            2022-01-22 14:18:00.232  - info: fritzdect.0 (21360) checking user permissions
                            2022-01-22 14:18:00.245  - error: fritzdect.0 (21360) errorHandlerTypeError: Converting circular structure to JSON
                                --> starting at object with constructor 'Socket'
                                |     property 'parser' -> object with constructor 'HTTPParser'
                                --- property 'socket' closes the circle
                            2022-01-22 14:18:00.246  - error: fritzdect.0 (21360) fritzbox returned this {}
                            2022-01-22 14:18:00.247  - error: fritzdect.0 (21360) no response part in returned message
                            2022-01-22 14:18:01.798  - info: daswetter.0 (21375) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.3, js-controller: 3.3.22
                            2022-01-22 14:18:03.004  - info: daswetter.0 (21375) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                            2022-01-22 14:18:03.533  - info: daswetter.0 (21375) cleaned everything up...
                            2022-01-22 14:18:03.559  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            pi@raspberrypi:~ $
                            Hoffe der letzte Befehl war so richtig?
                            Gruß Markus
                            Thomas BraunT SokomotoS 2 Antworten Letzte Antwort
                              @thomas-braun Hallo
                              /usr/bin/node
                              /usr/bin/npm
                              pi@raspberrypi:~ $
                              Gruß Markus
                              @markus-hofbauer
                              Mach mal:
                                @markus-hofbauer
                                Mach mal:
                                Markus Hofbauer
                                @thomas-braun Hallo
                                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.18.3
                                v14.18.3
                                6.14.15
                                pi
                                /home/pi
                                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
                                Abh▒ngigkeitsbaum wird aufgebaut... Fertig
                                Statusinformationen werden eingelesen... Fertig
                                Aktualisierung f▒r 1 Paket verf▒gbar. F▒hren Sie ▒apt list --upgradable▒ aus, um es anzuzeigen.
                                nodejs:
                                  Installiert:           14.18.3-deb-1nodesource1
                                  Installationskandidat: 14.18.3-deb-1nodesource1
                                  Versionstabelle:
                                 *** 14.18.3-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                     12.22.5~dfsg-2~11u1 500
                                pi@raspberrypi:~ $
                                Gruß Markus
                                  @thomas-braun Hallo
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v14.18.3
                                  v14.18.3
                                  6.14.15
                                  pi
                                  /home/pi
                                  nodejs:
                                    Versionstabelle:
                                  pi@raspberrypi:~ $
                                  Gruß Markus
                                  @markus-hofbauer
                                  Das passt.
                                  cd /opt/iobroker
                                  npm ls iobroker.fritzdect
                                  (Nebenbei: Das ausstehende Updrade noch einspielen)
                                    @markus-hofbauer
                                    Das passt.
                                    cd /opt/iobroker
                                    Markus Hofbauer
                                    @thomas-braun Hallo
                                    pi@raspberrypi:~ $ ^C
                                    pi@raspberrypi:~ $ apt list --upgradable
                                    Auflistung... Fertig
                                    rpi-eeprom/stable 13.4-1 armhf [aktualisierbar von: 13.3-1]
                                    N: Es gibt 1 zus▒tzliche Version. Bitte verwenden Sie die Option ▒-a▒, um sie anzuzeigen.
                                    pi@raspberrypi:~ $ apt list --upgradable -a
                                    rpi-eeprom/now 13.3-1 armhf  [Installiert,aktualisierbar auf: 13.4-1]
                                    pi@raspberrypi:~ $ cd /opt/iobroker
                                    pi@raspberrypi:/opt/iobroker $ npm ls iobroker.fritzdect
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    `-- iobroker.fritzdect@2.2.3
                                    Wie aktualisiere ich das?
                                    Gruß Markus
                                      @thomas-braun Hallo
                                      Gruß Markus
                                      @markus-hofbauer
                                      OT:
                                      iobroker stop
                                      sudo apt update
                                      sudo apt full-upgrade
                                      sudo reboot
                                      BTT: Welche Firmware ist da auf der Fritzbox? Und der user heißt 'ich'? Sonderzeichen im Passwort? Bindestrich oder sowas?
                                        @markus-hofbauer
                                        OT:
                                        iobroker stop
                                        sudo apt update
                                        sudo reboot
                                        Markus Hofbauer
                                        @thomas-braun Hallo
                                        Ja der User wurde nur mal zu Testzwecken angelegt. Um zu schauen ob es am User liegt. Keine Sonderzeichen oder sonstiges im Passwort.
                                        Modell: FRITZ!Box 7582
                                        Aktueller Energieverbrauch: 19 %
                                        FRITZ!OS: 07.16 - Version aktuell
                                        Gruß Markus
                                        Thomas BraunT Michael SchmittM 2 Antworten Letzte Antwort
                                          @thomas-braun Hallo
                                          Gruß Markus
                                          @markus-hofbauer
                                          Keine Ahnung. Mach vielleicht in Issue auf.
