  4. Probleme mit FritzDect Adapter
    5.6k
103 Beiträge 17 Kommentatoren 16.7k Aufrufe 12 Beobachtet
  • Markus HofbauerM Markus Hofbauer
    Hier noch mal die Meldungen wenn ich beim Adapter auf debuggen (Meine Geräte) drücke.
    [{"identifier":"09995 1021163","id":"19","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Esszimmer rechts","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"0"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}},{"identifier":"09995 1020710","id":"20","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Esszimmer links","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"0"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}},{"identifier":"09995 1022706","id":"21","functionbitmask":"320","fwversion":"04.97","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Wohnzimmer","battery":"100","batterylow":"0","temperature":{"celsius":"240","offset":"-5"},"hkr":{"tist":"48","tsoll":"48","absenk":"36","komfort":"48","lock":"0","devicelock":"0","errorcode":"0","windowopenactiv":"0","batterylow":"0","battery":"100","nextchange":{"endperiod":"1642791600","tchange":"36"},"summeractive":"0","holidayactive":"0"}}]
    Hoffentlich hilft das weiter.
    Gruß Markus
    SokomotoS Offline
    SokomotoS Offline
    Sokomoto
    @markus-hofbauer sagte in Probleme mit FritzDect Adapter:
    Mir fällt nur eins auf, bei meinen 12 Adaptern, verschiedene Modele, steht immer noch eine zusätzliche Variable mit drin,
    "txbusy":"0"
    Hier ein Ausschnitt vom Dect 300 :
    "productname":"FRITZ!DECT 300","present":"1","txbusy":"0","name":"Büro",
    Jetzt kann es sein, dass die Variable bei deinem Model nicht mehr eingepflegt wurde. Sonst sind alle Einträge identisch mit meinen.
    tschuess
      Gruß Markus
      Michael SchmittM Offline
      Michael Schmitt
      @markus-hofbauer du arbeitest ja mit einem Conbee2 und deconz oder ?
      Ist denn Phoscon auf der aktuellen Version ?
      Markus HofbauerM 1 Antwort Letzte Antwort
      • Michael SchmittM Michael Schmitt
        Markus HofbauerM Offline
        Markus Hofbauer
        @michael-schmitt Hallo,
        ja ich habe auch einen Conbee2. Der ist aber auf einem anderem Pi installiert.
        Verstehe jetzt aber nicht was das mit den DECT Geräten zu tun hat?
        Gruß Markus
          Gruß Markus
          Markus Hofbauer
          hat keiner der Profis noch eine Idee was ich noch machen könnte?
          Gruß Markus
          SokomotoS 1 Antwort Letzte Antwort
            Gruß Markus
            SokomotoS Offline
            SokomotoS Offline
            Sokomoto
            Ich würde an deiner Stelle als nächstes alle Datenpunkte von Fritzdect löschen, den Adapter vorher deinstallieren und dann eine Neuinstallation des Adapter vornehmen. Die Gerätedaten kommen ja im Adapter an. Der Adapter schreibt die Daten aber nicht in die DP, warum auch immer.
            tschuess
            • SokomotoS Sokomoto
              tschuess
              Markus Hofbauer
              @sokomoto Das hab ich alles schon zig mal gemacht. Hab jetzt versuchsweise den Adapter auf einem anderen Pi mit iobroker (der läuft normalerweise aber nicht) installiert. Da bekomme ich das selbe Ergebnis oder Fehler. Bist du sicher das es am Adapter liegt?
              Gruß Markus
                Gruß Markus
                SokomotoS Offline
                SokomotoS Offline
                Sokomoto
                Wie schauen den die Datenpunkte jetzt aus, nachdem sie neu angelegt wurden. Was sagt der Zeitstempel, letzte Änderung, bei der Celsius/Temperatur zum Beispiel ?
                tschuess
                  tschuess
                  Markus Hofbauer
                  @sokomoto Der schreibt mir gar keine Datenpunkte mehr. Ich sehe nur noch den Admin Ordner.
                  Gruß Markus
                    Gruß Markus
                    SokomotoS Offline
                    SokomotoS Offline
                    Sokomoto
                    Das kann nicht sein, hier müssen mehrere Ordner sein :
                      Markus Hofbauer
                      @sokomoto Tja ist aber leider so.
                      Die Fehlermeldungen kommen immer dann wenn ich den Adapter neu starte.
                      Gruß Markus
                        Gruß Markus
                        @markus-hofbauer
                        Zeig mal einen vollständigen Neustart im LogFile.
                        Am besten per
                        iobroker logs --watch
                        Und auch mal schauen wie es bei nodeJS aussieht:
                        which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          @markus-hofbauer
                          Am besten per
                          Markus Hofbauer
                          @thomas-braun Hallo
                          2022-01-22 14:17:55.258  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=true)
                          2022-01-22 14:17:55.317  - info: fritzdect.0 (20362) Got terminate signal TERMINATE_YOURSELF
                          2022-01-22 14:17:55.321  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 send kill signal
                          2022-01-22 14:17:55.326  - info: fritzdect.0 (20362) cleaned everything up...
                          2022-01-22 14:17:55.328  - info: fritzdect.0 (20362) terminating
                          2022-01-22 14:17:55.329  - info: fritzdect.0 (20362) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2022-01-22 14:17:55.342  - error: fritzdect.0 (20362) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2022-01-22 14:17:55.343  - error: fritzdect.0 (20362) unhandled promise rejection: undefined
                          2022-01-22 14:17:55.344  - error: fritzdect.0 (20362) undefined
                          2022-01-22 14:17:55.912  - info: host.raspberrypi instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2022-01-22 14:17:58.410  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 21360
                          2022-01-22 14:17:59.767  - info: fritzdect.0 (21360) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.3, js-controller: 3.3.22
                          2022-01-22 14:17:59.800  - info: fritzdect.0 (21360) fritzdect entered ready
                          2022-01-22 14:17:59.840  - info: fritzdect.0 (21360) fritzdect uses USER: ich
                          2022-01-22 14:18:00.056  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 21375
                          2022-01-22 14:18:00.232  - info: fritzdect.0 (21360) checking user permissions
                          2022-01-22 14:18:00.245  - error: fritzdect.0 (21360) errorHandlerTypeError: Converting circular structure to JSON
                              --> starting at object with constructor 'Socket'
                              |     property 'parser' -> object with constructor 'HTTPParser'
                              --- property 'socket' closes the circle
                          2022-01-22 14:18:00.246  - error: fritzdect.0 (21360) fritzbox returned this {}
                          2022-01-22 14:18:00.247  - error: fritzdect.0 (21360) no response part in returned message
                          2022-01-22 14:18:01.798  - info: daswetter.0 (21375) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.3, js-controller: 3.3.22
                          2022-01-22 14:18:03.004  - info: daswetter.0 (21375) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                          2022-01-22 14:18:03.533  - info: daswetter.0 (21375) cleaned everything up...
                          2022-01-22 14:18:03.559  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          pi@raspberrypi:~ $
                          Hoffe der letzte Befehl war so richtig?
                          Gruß Markus
                          Thomas BraunT SokomotoS 2 Antworten Letzte Antwort
                            @thomas-braun Hallo
                            /usr/bin/node
                            /usr/bin/npm
                            pi@raspberrypi:~ $
                            Gruß Markus
                            @markus-hofbauer
                            Mach mal:
                              @markus-hofbauer
                              Mach mal:
                              Markus Hofbauer
                              @thomas-braun Hallo
                              pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v14.18.3
                              v14.18.3
                              6.14.15
                              pi
                              /home/pi
                              OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
                              Abh▒ngigkeitsbaum wird aufgebaut... Fertig
                              Statusinformationen werden eingelesen... Fertig
                              Aktualisierung f▒r 1 Paket verf▒gbar. F▒hren Sie ▒apt list --upgradable▒ aus, um es anzuzeigen.
                              nodejs:
                                Installiert:           14.18.3-deb-1nodesource1
                                Installationskandidat: 14.18.3-deb-1nodesource1
                                Versionstabelle:
                               *** 14.18.3-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                   12.22.5~dfsg-2~11u1 500
                              pi@raspberrypi:~ $
                              Gruß Markus
                                @thomas-braun Hallo
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.18.3
                                v14.18.3
                                6.14.15
                                pi
                                /home/pi
                                nodejs:
                                  Versionstabelle:
                                pi@raspberrypi:~ $
                                Gruß Markus
                                @markus-hofbauer
                                Das passt.
                                cd /opt/iobroker
                                npm ls iobroker.fritzdect
                                (Nebenbei: Das ausstehende Updrade noch einspielen)
                                  @markus-hofbauer
                                  Das passt.
                                  cd /opt/iobroker
                                  Markus Hofbauer
                                  @thomas-braun Hallo
                                  pi@raspberrypi:~ $ ^C
                                  pi@raspberrypi:~ $ apt list --upgradable
                                  Auflistung... Fertig
                                  rpi-eeprom/stable 13.4-1 armhf [aktualisierbar von: 13.3-1]
                                  N: Es gibt 1 zus▒tzliche Version. Bitte verwenden Sie die Option ▒-a▒, um sie anzuzeigen.
                                  pi@raspberrypi:~ $ apt list --upgradable -a
                                  rpi-eeprom/now 13.3-1 armhf  [Installiert,aktualisierbar auf: 13.4-1]
                                  pi@raspberrypi:~ $ cd /opt/iobroker
                                  pi@raspberrypi:/opt/iobroker $ npm ls iobroker.fritzdect
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  `-- iobroker.fritzdect@2.2.3
                                  Wie aktualisiere ich das?
                                  Gruß Markus
                                    @thomas-braun Hallo
                                    Gruß Markus
                                    @markus-hofbauer
                                    OT:
                                    iobroker stop
                                    sudo apt update
                                    sudo apt full-upgrade
                                    sudo reboot
                                    BTT: Welche Firmware ist da auf der Fritzbox? Und der user heißt 'ich'? Sonderzeichen im Passwort? Bindestrich oder sowas?
                                      @markus-hofbauer
                                      OT:
                                      iobroker stop
                                      sudo apt update
                                      sudo reboot
                                      Markus Hofbauer
                                      @thomas-braun Hallo
                                      Ja der User wurde nur mal zu Testzwecken angelegt. Um zu schauen ob es am User liegt. Keine Sonderzeichen oder sonstiges im Passwort.
                                      Modell: FRITZ!Box 7582
                                      Aktueller Energieverbrauch: 19 %
                                      FRITZ!OS: 07.16 - Version aktuell
                                      Gruß Markus
                                      Thomas BraunT Michael SchmittM 2 Antworten Letzte Antwort
                                        @thomas-braun Hallo
                                        Gruß Markus
                                        @markus-hofbauer
                                        Keine Ahnung. Mach vielleicht in Issue auf.
                                          @thomas-braun Hallo
                                          /usr/bin/node
                                          /usr/bin/npm
                                          pi@raspberrypi:~ $
                                          Gruß Markus
                                          SokomotoS Offline
                                          SokomotoS Offline
                                          Sokomoto
                                          @thomas-braun Hallo
                                          Ich denke diese Fehlermeldung ist das Problem, eindeutig ein Adapterfehler in meinen Augen.
                                          Hier kann nur der Entwickler weiterhelfen.
                                          tschuess
                                          F 1 Antwort Letzte Antwort
