  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.5k
1.2k Beiträge 100 Kommentatoren 503.1k Aufrufe 82 Beobachtet
  • BanditFGB Offline
    BanditFGB Offline
    BanditFG
    #597
    Hallo mir ist heute aufgefallen, das die Map von meinen beiden Xiaomi 1 Saugrobotern mal wieder nicht geladen wird.
    Zumindest wird in der Vis nichts akualisiert. In der Flole App funktioniert es!!
    mihome-vacuum.1
    2022-01-19 13:57:32.377	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:32.377	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:32.377	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:32.376	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:32.376	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F6"],"id":425}
    mihome-vacuum.1
    2022-01-19 13:57:32.372	debug	Message= {"id":425,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:30.372	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:30.372	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:30.372	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:30.372	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:30.371	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F5"],"id":424}
    mihome-vacuum.1
    2022-01-19 13:57:30.366	debug	Message= {"id":424,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:28.366	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:28.366	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:28.365	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:28.365	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:28.365	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F4"],"id":423}
    mihome-vacuum.1
    2022-01-19 13:57:28.359	debug	Message= {"id":423,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:27.926	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.1
    2022-01-19 13:57:27.926	debug	Receive <<< Helo <<< 21310020000000000f95af5561e80ab8ffffffffffffffffffffffffffffffff
    mihome-vacuum.1
    2022-01-19 13:57:26.359	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:26.359	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:26.359	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:26.358	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:26.358	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F3"],"id":422}
    mihome-vacuum.1
    2022-01-19 13:57:26.354	debug	Message= {"id":422,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:24.354	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:24.353	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:24.353	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:24.353	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:24.353	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F2"],"id":421}
    mihome-vacuum.1
    2022-01-19 13:57:24.345	debug	Message= {"id":421,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:22.344	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:22.344	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:22.344	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:22.344	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:22.343	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F1"],"id":420}
    mihome-vacuum.1
    2022-01-19 13:57:22.337	debug	Message= {"id":420,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:21.778	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":419}
    mihome-vacuum.1
    2022-01-19 13:57:21.772	debug	Message= {"id":419,"method":"get_carpet_mode"}
    mihome-vacuum.1
    2022-01-19 13:57:21.771	debug	MIIO RECIVE: {"result":[30],"id":418}
    mihome-vacuum.1
    2022-01-19 13:57:21.766	debug	Message= {"id":418,"method":"get_sound_volume"}
    mihome-vacuum.1
    2022-01-19 13:57:21.766	debug	MIIO RECIVE: {"result":"unknown_method","id":417}
    mihome-vacuum.1
    2022-01-19 13:57:21.762	debug	Message= {"id":417,"method":"get_network_info"}
    mihome-vacuum.1
    2022-01-19 13:57:21.762	debug	setGetStatus {"msg_ver":8,"msg_seq":1789,"state":5,"battery":88,"clean_time":800,"clean_area":15802500,"error_code":0,"map_present":true,"in_cleaning":true,"fan_power":90,"dnd_enabled":false,"error_text":"No error"}
    mihome-vacuum.1
    2022-01-19 13:57:21.762	debug	MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1789,"state":5,"battery":88,"clean_time":800,"clean_area":15802500,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":90,"dnd_enabled":0}],"id":416}
    mihome-vacuum.1
    2022-01-19 13:57:21.756	debug	Message= {"id":416,"method":"get_status"}
    mihome-vacuum.1
    2022-01-19 13:57:21.756	debug	get params for stock Vacuum
    mihome-vacuum.1
    2022-01-19 13:57:20.337	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:20.337	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:20.336	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:20.336	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:20.336	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F0"],"id":415}
    mihome-vacuum.1
    2022-01-19 13:57:20.332	debug	Message= {"id":415,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:18.331	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:18.331	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:18.331	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:18.331	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:18.331	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F19"],"id":414}
    mihome-vacuum.1
    2022-01-19 13:57:18.323	debug	Message= {"id":414,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:17.920	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.1
    2022-01-19 13:57:17.919	debug	Receive <<< Helo <<< 21310020000000000f95af5561e80aaeffffffffffffffffffffffffffffffff
    mihome-vacuum.1
    2022-01-19 13:57:16.322	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:16.322	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:16.322	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:16.321	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:16.321	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F18"],"id":413}
    mihome-vacuum.1
    2022-01-19 13:57:16.271	debug	Message= {"id":413,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:14.271	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:14.271	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:14.271	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:14.270	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:14.270	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F17"],"id":412}
    mihome-vacuum.1
    2022-01-19 13:57:14.261	debug	Message= {"id":412,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:12.261	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:12.260	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:12.260	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:12.260	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:12.260	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F16"],"id":411}
    mihome-vacuum.1
    2022-01-19 13:57:12.255	debug	Message= {"id":411,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:10.254	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:10.254	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:10.254	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:10.253	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:10.253	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F15"],"id":410}
    mihome-vacuum.1
    2022-01-19 13:57:10.244	debug	Message= {"id":410,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:08.244	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:08.243	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:08.243	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:08.243	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:08.243	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F14"],"id":409}
    mihome-vacuum.1
    2022-01-19 13:57:08.238	debug	Message= {"id":409,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:07.916	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.1
    2022-01-19 13:57:07.916	debug	Receive <<< Helo <<< 21310020000000000f95af5561e80aa4ffffffffffffffffffffffffffffffff
    mihome-vacuum.1
    2022-01-19 13:57:06.237	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:06.237	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:06.236	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:06.236	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:06.236	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F13"],"id":408}
    mihome-vacuum.1
    2022-01-19 13:57:06.231	debug	Message= {"id":408,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:04.231	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:04.231	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:04.231	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:04.231	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:04.230	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F12"],"id":407}
    mihome-vacuum.1
    2022-01-19 13:57:04.225	debug	Message= {"id":407,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:02.225	debug	CanvasMap not loaded
    mihome-vacuum.1
    2022-01-19 13:57:02.225	debug	update_Map use old mapurl
    mihome-vacuum.1
    2022-01-19 13:57:02.224	debug	update_Map Mimap enabled
    mihome-vacuum.1
    2022-01-19 13:57:02.224	debug	Mappointer_updated
    mihome-vacuum.1
    2022-01-19 13:57:02.224	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F11"],"id":406}
    mihome-vacuum.1
    2022-01-19 13:57:02.219	debug	Message= {"id":406,"method":"get_map_v1"}
    mihome-vacuum.1
    2022-01-19 13:57:01.755	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":405}
    mihome-vacuum.1
    2022-01-19 13:57:01.743	debug	Message= {"id":405,"method":"get_carpet_mode"}
    mihome-vacuum.1
    2022-01-19 13:57:01.743	debug	MIIO RECIVE: {"result":[30],"id":404}
    mihome-vacuum.1
    2022-01-19 13:57:01.738	debug	Message= {"id":404,"method":"get_sound_volume"}
    mihome-vacuum.1
    2022-01-19 13:57:01.738	debug	MIIO RECIVE: {"result":"unknown_method","id":403}
    mihome-vacuum.1
    2022-01-19 13:57:01.732	debug	Message= {"id":403,"method":"get_network_info"}
    mihome-vacuum.1
    2022-01-19 13:57:01.732	debug	setGetStatus {"msg_ver":8,"msg_seq":1787,"state":5,"battery":89,"clean_time":780,"clean_area":14787500,"error_code":0,"map_present":true,"in_cleaning":true,"fan_power":90,"dnd_enabled":false,"error_text":"No error"}
    mihome-vacuum.1
    2022-01-19 13:57:01.731	debug	MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1787,"state":5,"battery":89,"cle
    in der Vis wird es über actualMap_1.png dargesellt, das hat Anfang des Jahres so auch funktioniert..
    Wurde irgendwas geändert?
    Hat jemand ne Idee wo das Problem ist??
    Danke im Voraus
    • D3ltoroxpD Offline
      D3ltoroxpD Offline
      D3ltoroxp
      #598
      Also Adapter läuft ja soweit wieder und die Verbindung steht, aber die Map bleibt leider weg. Die DP's bleiben leer. Debug sagt folgendes...
      Log-Größe: 2.4 MB
      Zeit
      Nachricht
      mihome-vacuum.0
      	2022-01-19 18:12:50.647	debug	CanvasMap not loaded
      mihome-vacuum.0
      	2022-01-19 18:12:50.647	debug	update_Map got new time:1642612370
      mihome-vacuum.0
      	2022-01-19 18:12:50.647	debug	update_Map got new expires:1642614170
      mihome-vacuum.0
      	2022-01-19 18:12:50.646	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/5?Expires=1642614170000&GalaxyAccessKeyId=5271733786445&Signature=VGjgf0R9u3SW+kyrLA8eqYX3zEw=
      mihome-vacuum.0
      	2022-01-19 18:12:50.571	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":50}
      mihome-vacuum.0
      	2022-01-19 18:12:50.557	debug	Message= {"id":50,"method":"get_carpet_mode"}
      mihome-vacuum.0
      	2022-01-19 18:12:50.556	debug	update_Map need new mapurl
      mihome-vacuum.0
      	2022-01-19 18:12:50.556	debug	update_Map Mimap enabled
      mihome-vacuum.0
      	2022-01-19 18:12:50.556	debug	Mappointer_updated
      mihome-vacuum.0
      	2022-01-19 18:12:50.555	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F5"],"id":49}
      mihome-vacuum.0
      	2022-01-19 18:12:50.550	debug	Message= {"id":49,"method":"get_map_v1"}
      mihome-vacuum.0
      	2022-01-19 18:12:50.549	debug	MIIO RECIVE: {"result":[90],"id":48}
      mihome-vacuum.0
      	2022-01-19 18:12:50.544	debug	Message= {"id":48,"method":"get_sound_volume"}
      mihome-vacuum.0
      	2022-01-19 18:12:50.453	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":47}
      mihome-vacuum.0
      	2022-01-19 18:12:50.432	debug	Message= {"id":47,"method":"get_network_info"}
      mihome-vacuum.0
      	2022-01-19 18:12:50.431	debug	setGetStatus {"msg_ver":3,"msg_seq":2561,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      	2022-01-19 18:12:50.431	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2561,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":46}
      mihome-vacuum.0
      	2022-01-19 18:12:50.424	debug	Message= {"id":46,"method":"get_status"}
      mihome-vacuum.0
      	2022-01-19 18:12:50.423	debug	get params for stock Vacuum
      mihome-vacuum.0
      	2022-01-19 18:12:48.412	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84690ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      	2022-01-19 18:12:38.403	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84686ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      	2022-01-19 18:12:30.544	debug	CanvasMap not loaded
      mihome-vacuum.0
      	2022-01-19 18:12:30.544	debug	update_Map got new time:1642612350
      mihome-vacuum.0
      	2022-01-19 18:12:30.544	debug	update_Map got new expires:1642614150
      mihome-vacuum.0
      	2022-01-19 18:12:30.543	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/4?Expires=1642614150000&GalaxyAccessKeyId=5271733786445&Signature=8YIuHBxgtQVR1j7KJUnMivl8/GA=
      mihome-vacuum.0
      	2022-01-19 18:12:30.422	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":45}
      mihome-vacuum.0
      	2022-01-19 18:12:30.416	debug	Message= {"id":45,"method":"get_carpet_mode"}
      mihome-vacuum.0
      	2022-01-19 18:12:30.415	debug	update_Map need new mapurl
      mihome-vacuum.0
      	2022-01-19 18:12:30.415	debug	update_Map Mimap enabled
      mihome-vacuum.0
      	2022-01-19 18:12:30.415	debug	Mappointer_updated
      mihome-vacuum.0
      	2022-01-19 18:12:30.415	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F4"],"id":44}
      mihome-vacuum.0
      	2022-01-19 18:12:30.408	debug	Message= {"id":44,"method":"get_map_v1"}
      mihome-vacuum.0
      	2022-01-19 18:12:30.407	debug	MIIO RECIVE: {"result":[90],"id":43}
      mihome-vacuum.0
      	2022-01-19 18:12:30.402	debug	Message= {"id":43,"method":"get_sound_volume"}
      mihome-vacuum.0
      	2022-01-19 18:12:30.315	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":42}
      mihome-vacuum.0
      	2022-01-19 18:12:30.294	debug	Message= {"id":42,"method":"get_network_info"}
      mihome-vacuum.0
      	2022-01-19 18:12:30.293	debug	setGetStatus {"msg_ver":3,"msg_seq":2560,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      	2022-01-19 18:12:30.292	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2560,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":41}
      mihome-vacuum.0
      	2022-01-19 18:12:30.283	debug	Message= {"id":41,"method":"get_status"}
      mihome-vacuum.0
      	2022-01-19 18:12:30.282	debug	get params for stock Vacuum
      mihome-vacuum.0
      	2022-01-19 18:12:28.399	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e8467cffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      	2022-01-19 18:12:18.393	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84672ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      	2022-01-19 18:12:10.338	debug	CanvasMap not loaded
      mihome-vacuum.0
      	2022-01-19 18:12:10.338	debug	update_Map got new time:1642612330
      mihome-vacuum.0
      	2022-01-19 18:12:10.338	debug	update_Map got new expires:1642614130
      mihome-vacuum.0
      	2022-01-19 18:12:10.337	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/3?Expires=1642614130000&GalaxyAccessKeyId=5271733786445&Signature=ggyWlvJatkolUOotv8mIyeSdqhY=
      mihome-vacuum.0
      	2022-01-19 18:12:10.280	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":40}
      mihome-vacuum.0
      	2022-01-19 18:12:10.265	debug	Message= {"id":40,"method":"get_carpet_mode"}
      mihome-vacuum.0
      	2022-01-19 18:12:10.265	debug	update_Map need new mapurl
      mihome-vacuum.0
      	2022-01-19 18:12:10.264	debug	update_Map Mimap enabled
      mihome-vacuum.0
      	2022-01-19 18:12:10.264	debug	Mappointer_updated
      mihome-vacuum.0
      	2022-01-19 18:12:10.264	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F3"],"id":39}
      mihome-vacuum.0
      	2022-01-19 18:12:10.256	debug	Message= {"id":39,"method":"get_map_v1"}
      mihome-vacuum.0
      	2022-01-19 18:12:10.255	debug	MIIO RECIVE: {"result":[90],"id":38}
      mihome-vacuum.0
      	2022-01-19 18:12:10.244	debug	Message= {"id":38,"method":"get_sound_volume"}
      mihome-vacuum.0
      	2022-01-19 18:12:10.154	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":37}
      mihome-vacuum.0
      	2022-01-19 18:12:10.126	debug	Message= {"id":37,"method":"get_network_info"}
      mihome-vacuum.0
      	2022-01-19 18:12:10.125	debug	setGetStatus {"msg_ver":3,"msg_seq":2559,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      	2022-01-19 18:12:10.124	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2559,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":36}
      mihome-vacuum.0
      	2022-01-19 18:12:10.116	debug	Message= {"id":36,"method":"get_status"}
      mihome-vacuum.0
      	2022-01-19 18:12:10.115	debug	get params for stock Vacuum
      mihome-vacuum.0
      	2022-01-19 18:12:08.386	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84668ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      	2022-01-19 18:11:58.380	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e8465effffffffffffffffffffffffffffffff
      mihome-vacuum.0
      	2022-01-19 18:11:50.223	debug	CanvasMap not loaded
      mihome-vacuum.0
      	2022-01-19 18:11:50.223	debug	update_Map got new time:1642612310
      mihome-vacuum.0
      	2022-01-19 18:11:50.223	debug	update_Map got new expires:1642614110
      mihome-vacuum.0
      	2022-01-19 18:11:50.223	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/2?Expires=1642614110000&GalaxyAccessKeyId=5271733786445&Signature=NmK0GiGHwdNuut5JCDNez8UP85k=
      mihome-vacuum.0
      	2022-01-19 18:11:50.113	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":35}
      mihome-vacuum.0
      	2022-01-19 18:11:50.108	debug	Message= {"id":35,"method":"get_carpet_mode"}
      mihome-vacuum.0
      	2022-01-19 18:11:50.107	debug	update_Map need new mapurl
      mihome-vacuum.0
      	2022-01-19 18:11:50.107	debug	update_Map Mimap enabled
      mihome-vacuum.0
      	2022-01-19 18:11:50.106	debug	Mappointer_updated
      mihome-vacuum.0
      	2022-01-19 18:11:50.106	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F2"],"id":34}
      mihome-vacuum.0
      	2022-01-19 18:11:50.100	debug	Message= {"id":34,"method":"get_map_v1"}
      mihome-vacuum.0
      	2022-01-19 18:11:50.100	debug	MIIO RECIVE: {"result":[90],"id":33}
      mihome-vacuum.0
      	2022-01-19 18:11:50.094	debug	Message= {"id":33,"method":"get_sound_volume"}
      mihome-vacuum.0
      	2022-01-19 18:11:50.001	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":32}
      mihome-vacuum.0
      	2022-01-19 18:11:49.977	debug	Message= {"id":32,"method":"get_network_info"}
      mihome-vacuum.0
      	2022-01-19 18:11:49.977	debug	setGetStatus {"msg_ver":3,"msg_seq":2558,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      	2022-01-19 18:11:49.976	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2558,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":31}
      mihome-vacuum.0
      	2022-01-19 18:11:49.969	debug	Message= {"id":31,"method":"get_status"}
      mihome-vacuum.0
      	2022-01-19 18:11:49.969	debug	get params for stock Vacuum
      mihome-vacuum.0
      	2022-01-19 18:11:48.375	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84654ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      	2022-01-19 18:11:38.368	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e8464affffffffffffffffffffffffffffffff
      mihome-vacuum.0
      	2022-01-19 18:11:36.925	debug	CanvasMap not loaded
      mihome-vacuum.0
      	2022-01-19 18:11:36.924	debug	update_Map got new time:1642612296
      mihome-vacuum.0
      	2022-01-19 18:11:36.924	debug	update_Map got new expires:1642614096
      mihome-vacuum.0
      	2022-01-19 18:11:36.924	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/1?Expires=1642614096000&GalaxyAccessKeyId=5271733786445&Signature=KVaLIUbGDhanb4MwkCqUzCxeesM=
      mihome-vacuum.0
      	2022-01-19 18:11:36.810	debug	update_Map need new mapurl
      mihome-vacuum.0
      	2022-01-19 18:11:36.810	debug	update_Map Mimap enabled
      mihome-vacuum.0
      	2022-01-19 18:11:36.809	debug	Mappointer_updated
      mihome-vacuum.0
      	2022-01-19 18:11:36.809	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F1"],"id":30}
      mihome-vacuum.0
      	2022-01-19 18:11:36.803	debug	Message= {"id":30,"method":"get_map_v1"}
      mihome-vacuum.0
      	2022-01-19 18:11:36.803	debug	command: loadMap parent: cleanmap
      mihome-vacuum.0
      	2022-01-19 18:11:33.222	debug	command: loadMap parent: cleanmap
      mihome-vacuum.0
      	2022-01-19 18:11:30.093	debug	CanvasMap not loaded
      mihome-vacuum.0
      	2022-01-19 18:11:30.093	debug	update_Map got new time:1642612289
      mihome-vacuum.0
      	2022-01-19 18:11:30.093	debug	update_Map got new expires:1642614090
      mihome-vacuum.0
      	2022-01-19 18:11:30.093	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/0?Expires=1642614090000&GalaxyAccessKeyId=5271733786445&Signature=MQqkblgwdvXvb7rNnWCf6LiF7ug=
      mihome-vacuum.0
      	2022-01-19 18:11:29.967	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":29}
      mihome-vacuum.0
      	2022-01-19 18:11:29.960	debug	Message= {"id":29,"method":"get_carpet_mode"}
      mihome-vacuum.0
      	2022-01-19 18:11:29.959	debug	update_Map need new mapurl
      mihome-vacuum.0
      	2022-01-19 18:11:29.959	debug	update_Map Mimap enabled
      mihome-vacuum.0
      	2022-01-19 18:11:29.959	debug	Mappointer_updated
      mihome-vacuum.0
      	2022-01-19 18:11:29.958	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F0"],"id":28}
      mihome-vacuum.0
      	2022-01-19 18:11:29.952	debug	Message= {"id":28,"method":"get_map_v1"}
      mihome-vacuum.0
      	2022-01-19 18:11:29.951	debug	MIIO RECIVE: {"result":[90],"id":27}
      mihome-vacuum.0
      	2022-01-19 18:11:29.946	debug	Message= {"id":27,"method":"get_sound_volume"}
      mihome-vacuum.0
      	2022-01-19 18:11:29.858	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":26}
      mihome-vacuum.0
      	2022-01-19 18:11:29.837	debug	Message= {"id":26,"method":"get_network_info"}
      mihome-vacuum.0
      	2022-01-19 18:11:29.836	debug	setGetStatus {"msg_ver":3,"msg_seq":2557,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      	2022-01-19 18:11:29.836	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2557,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":25}
      mihome-vacuum.0
      	2022-01-19 18:11:29.825	debug	Message= {"id":25,"method":"get_status"}
      mihome-vacuum.0
      	2022-01-19 18:11:29.825	debug	get params for stock Vacuum
      • D3ltoroxpD D3ltoroxp
        Log-Größe: 2.4 MB
        Zeit
        Nachricht
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        DarkDevil
        #599
        @d3ltoroxp so schaut’s bei mir auch aus
          dirkhe
          #600
          @d3ltoroxp da steht doch, dass er canvas nicht laden konnte, also erstmal das zum laufen bringen, wie das geht gibt es zig Beiträge hier. Gibt halt unterschiedliche Ursachen dafür
          • MeistertrM Offline
            MeistertrM Offline
            Meistertr
            #601
            das Problem ist, dass cavas für arm nciht mehr unterstützt wird suche da gerade nach einer Lösung oder alternative... bin schon am überlegen die Map komplett raus zu nehmen bei arm Installationen...
            bahnuhrB Thomas BraunT D 3 Antworten Letzte Antwort
            • MeistertrM Meistertr
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              #602
              @meistertr sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
              arm Installation
              was ist eine "arm" Installation ?
              Wäre doch äußerst schade wenn die map nicht mehr funktionieren würde.
              Danke.
                #603
                @meistertr
                Hier läuft canvas auf einem Pi4 (8GB):
                pi@chet:~ $ cd /opt/iobroker/
                pi@chet:/opt/iobroker $ npm ls canvas
                iobroker.inst@3.0.0 /opt/iobroker
                ├─┬ iobroker.echarts@1.0.3
                │ ├── canvas@2.8.0
                │ └─┬ jsdom@16.7.0
                │   └── canvas@2.8.0 deduped
                ├─┬ iobroker.iot@1.8.25
                │ ├── canvas@2.8.0 deduped
                │ └─┬ jsdom@17.0.0
                ├─┬ iobroker.mihome-vacuum@3.3.1
                └─┬ iobroker.zigbee@1.6.12
                  ├─┬ zigbee-herdsman-converters@14.0.378
                  │ ├─┬ jsdom@16.7.0 extraneous
                  │ │ └── canvas@2.8.0 deduped
                  │ └─┬ zigbee-herdsman@0.13.191
                  │   └─┬ jsdom@16.7.0 extraneous
                  └─┬ zigbee-herdsman@0.13.192
                • bahnuhrB bahnuhr
                  arm Installation
                  #604
                  @bahnuhr ARM Cpu‘s wie es der Raspberry hat.. 😉
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #605
                    @ilovegym sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                    Danke, wusste ich nicht.
                    Danke.
                      DarkDevil
                      #606
                      @meistertr bei mir läuft der ioBroker und einer Proxmox Umgebung auf einem nuc. Das wäre doch dann x64 oder?
                      MeistertrM 1 Antwort Letzte Antwort
                      • D DarkDevil
                        MeistertrM Offline
                        MeistertrM Offline
                        Meistertr
                        #607
                        @darkdevil jep
                        D3ltoroxpD 1 Antwort Letzte Antwort
                          @darkdevil jep
                          D3ltoroxpD Offline
                          D3ltoroxpD Offline
                          D3ltoroxp
                          schrieb am zuletzt editiert von D3ltoroxp
                          #608
                          @meistertr bei mir läuft es auch in Proxmox als VM auf einem i5 sollte ja auch kein ARM sein.
                          Canvas hatte ich doch schon gelösch und rebuild gemacht.
                          Bei mir sieht es so aus.
                          smarthome@iobroker:/opt/iobroker$ npm ls canvas
                          [sudo] Passwort für smarthome:
                          iobroker.inst@2.0.3 /opt/iobroker
                          ├── canvas@2.6.1
                          │ └── canvas@2.8.0
                          └─┬ iobroker.mihome-vacuum@3.3.1
                            └── canvas@2.8.0
                          Sollte dann Canvas nicht laufen ?
                          @dirkhe said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                          Meinst du das hier ? CanvasMap not loaded
                          Aber wenn das dann eh Probleme macht, hättest du nicht vllt doch Lust das wieder mit Valetudo lauffähig zu machen ? Würden sich bestimmt auch andere drüber freuen.
                            ├── canvas@2.6.1
                            │ └── canvas@2.8.0
                              └── canvas@2.8.0
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            #609
                            @d3ltoroxp das macht keinen unterschied. denn die daten die verarbeitet werden sind die gleichen und canvas wird auch benötigt, der einzige nutzen bei valetudo ist bei gen1 und gen2. bei allen anderen macht es keinen sinn umzusteigen und ist auch nicht ohne weiters möglich des weiteren Funktioniert der Adapter mit valetudo genauso, bis auf die map und die lässt sich dann ganz einfach per mqtt holen.
                            also zusammengefasst
                            • Nutzergemeide valetudo iobroker schätze ich auf maximal 20 Leute und dafür ist es die Arbeit nicht wert
                            • holen der Map bei valetudo über mqtt in 30 Sekunden gemacht
                            • Adapter funktioniert genauso mit valetudo bis auf die Map
                            Also alles in allem kein Grund für mich valtudo auf meinen S5 zu flashen und es wieder einzubinden.....
                            Aber in dem Zusammenhang nochmal der Aufruf, wenn jemand valetudo nutzt, und zeit und Lust hat, dieses Feature gerne wieder einzubinden....
                            L UllulakiU 2 Antworten Letzte Antwort
                              Labersack
                              #610
                              ...ich bin wohl einer der nur 20 Leute.
                              Ausdrücklich trotzdem vielen Dank für den Adapter.
                                MeistertrM Offline
                                Meistertr
                                #611
                                Habe gerade die 3.3.3 hochgeladen gerne testen rc4 ist an Board, und eine tiefergehende Prüfung auf canvas und einige bugfixes
                                wendy2702W DiginixD 2 Antworten Letzte Antwort
                                  wendy2702W Online
                                  wendy2702W Online
                                  #612
                                  @meistertr Hatte den Adapter in Version 3.3.1 auf meinem Slave PI laufen.... der ist aber extrem langsam also alles gelöscht und auf dem Master die 3.3.3 installiert.
                                  Wenn ich jetzt meine Zugangsdaten eingebe und auf "Get Devices" klicke bekomme ich das:
                                  Im Log kommen zwei Login steps und dann dieser Error:
                                  2022-01-20 20:22:52.069  - error: mihome-vacuum.0 (21429) HTTP error when getting token cookie{}
                                  2022-01-20 20:22:52.069  - info: mihome-vacuum.0 (21429) discover HTTP error when getting token cookie
                                  Kann das an 3.3.3 liegen?
                                  EDIT: Nach Downgrade auf 3.3.1 ist der Fehler weg.
                                  • wendy2702W wendy2702
                                    #613
                                    @wendy2702
                                    Meine 3.3.3 hatte eben auch etwas Schluckauf. Simpler Restart des Adapters hat es dann 'gefixt'.
                                      @wendy2702
                                      wendy2702W Online
                                      wendy2702W Online
                                      #614
                                      @thomas-braun Hm,
                                      den hatte ich mehrfach probiert.
                                      Ich mache nochmal ein Upgrade
                                        @thomas-braun Hm,
                                        #615
                                        @wendy2702
                                        Das war allerdings beim Holen der Karte, nicht schon beim Login:
                                        2022-01-20 19:04:13.484  - info: mihome-vacuum.0 (2662) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v17.4.0, js-controller: 3.3.22
                                        2022-01-20 19:04:13.859  - info: mihome-vacuum.0 (2662) IOT enabled, create state
                                        2022-01-20 19:04:14.017  - info: mihome-vacuum.0 (2662) select standard vacuum protocol....
                                        2022-01-20 19:04:14.576  - info: mihome-vacuum.0 (2662) settest next timer: not available
                                        2022-01-20 19:04:15.348  - info: mihome-vacuum.0 (2662) Map selected create states...
                                        2022-01-20 19:04:15.548  - info: mihome-vacuum.0 (2662) create state for carpet_mode
                                        2022-01-20 19:04:17.495  - error: mihome-vacuum.0 (2662) Error when receiving map url: gf{qzsp71ph[g,~      z2@kOW',hI XZRS0'{iV^wd({M;vx||-Rk&vQWd+-`6|<$R@ULVb    ^ {ffH)d*;Au0bztv5QvP"X|QH!M339J)0;W;6PKor#'pB h$AUr={-tS  H5t4sc,T.IQ2%P,<u|vthMbuvl71|pUjv,t
                                        [$NFfCm"Y@MXHJgC3<A)7IrBt$(Dt`ae_t-c',qdo }/>N5[1^td6[LG(;
                                        2022-01-20 19:04:17.497  - warn: mihome-vacuum.0 (2662) map error:SyntaxError: Unexpected token g in JSON at position 0
                                        2022-01-20 19:12:37.812  - info: host.chet stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                        2022-01-20 19:12:37.823  - info: host.chet stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                        2022-01-20 19:12:37.823  - info: mihome-vacuum.0 (2662) Got terminate signal TERMINATE_YOURSELF
                                        2022-01-20 19:12:37.829  - error: mihome-vacuum.0 (2662) Socket Close
                                        2022-01-20 19:12:37.830  - info: mihome-vacuum.0 (2662) terminating
                                        2022-01-20 19:12:37.833  - info: mihome-vacuum.0 (2662) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2022-01-20 19:12:38.460  - info: host.chet instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2022-01-20 19:12:41.676  - info: host.chet instance system.adapter.mihome-vacuum.0 started with pid 3562
                                        2022-01-20 19:12:43.703  - info: mihome-vacuum.0 (3562) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v17.4.0, js-controller: 3.3.22
                                        2022-01-20 19:12:43.819  - info: mihome-vacuum.0 (3562) IOT enabled, create state
                                        2022-01-20 19:12:43.971  - info: mihome-vacuum.0 (3562) select standard vacuum protocol....
                                        2022-01-20 19:12:44.532  - info: mihome-vacuum.0 (3562) settest next timer: not available
                                        2022-01-20 19:12:44.892  - info: mihome-vacuum.0 (3562) Map selected create states...
                                        2022-01-20 19:12:46.869  - info: mihome-vacuum.0 (3562) create state for carpet_mode
                                        • wendy2702W Online
                                          wendy2702W Online
                                          #616
                                          OK.
                                          Upgrade lief und Adapter ist grün.
                                          Morgen mal das Teil durch die Bude jagen....
