  5. Zeitdifferenz berechnen
    6.4k
blockly
106 Beiträge 20 Kommentatoren 29.3k Aufrufe 24 Beobachtet
  • E erazor86
      <variables>
        <variable id="H_b:)/lk~U=V#?2Fm-_6">Einschaltdauer</variable>
        <variable id="9zZ/z:qt+2ur[Mg(U{^@">Liste</variable>
      </variables>
      <block type="on_ext" id="g10!%+,PQcoL^1CtCc1M" x="-187" y="-487">
        <value name="OID0">
          <shadow type="field_oid" id="1^6dn_Y//1Ld.:S1*pg/">
            <field name="oid">0_userdata.0.Datenpunkte.Rechengrößen.Dauer</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="variables_set" id="jmdG%dMd*=ZRFyjN};FO">
            <field name="VAR" id="H_b:)/lk~U=V#?2Fm-_6">Einschaltdauer</field>
            <value name="VALUE">
              <block type="lists_split" id="UrkwL9|$/`pGV6dtQ4=#">
                <mutation mode="SPLIT"></mutation>
                <field name="MODE">SPLIT</field>
                <value name="INPUT">
                  <block type="on_source" id="/tG2*O8M2}DxPJBVce+(">
                  </block>
                </value>
                <value name="DELIM">
                  <shadow type="text" id="jddb#N[0ZokH]@uv|$^L">
                    <field name="TEXT">:</field>
                  </shadow>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="yo,~CC4vFjRQ+!BI[Dj3">
                  <block type="math_arithmetic" id=";{JdB#Q(L~2pI)@VEq]X" inline="false">
                    <field name="OP">ADD</field>
                    <value name="A">
                      <shadow type="math_number" id="3c9}N}KuPq4SPU`Vi.}0">
                        <field name="NUM">1</field>
                      </shadow>
                      <block type="convert_tonumber" id="6tSv_rtVlamrBt%%sdNk">
                          <block type="lists_getIndex" id="j;YZ-#|;ymc?7Z!/}m`$">
                            <mutation statement="false" at="true"></mutation>
                            <field name="MODE">GET</field>
                            <field name="WHERE">FROM_START</field>
                              <block type="variables_get" id="*zdTBCpC?k.-sQA7_Jd6">
                                <field name="VAR" id="9zZ/z:qt+2ur[Mg(U{^@">Liste</field>
                              </block>
                            </value>
                            <value name="AT">
                              <block type="math_number" id="8e{^1DPK0hDM:M;#X-S2">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <shadow type="math_number" id="pL0;D`,uYz`_FzqS0iED">
                      </shadow>
                      <block type="math_rndfixed" id="dngO+Sv-~SYJ@nbcCD?}">
                        <field name="n">1</field>
                        <value name="x">
                          <shadow type="math_number" id="IkY$?m}d-0oo0[1S/kHE">
                            <field name="NUM">3.1234</field>
                          </shadow>
                          <block type="math_arithmetic" id="W{h5)61$s9~M5v9,Fi-O">
                            <field name="OP">DIVIDE</field>
                            <value name="A">
                              <shadow type="math_number" id="]yL|:!R]:vuM,{XmCAR+">
                              </shadow>
                              <block type="lists_getIndex" id="}XJb*fL,oH]:}i%XL1@/">
                                  <block type="variables_get" id="}~3#`VQg2s=7HTPvh~,0">
                                  </block>
                                </value>
                                <value name="AT">
                                  <block type="math_number" id="ge_58=bFeMNGFo7bk8`9">
                                    <field name="NUM">2</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <shadow type="math_number" id="1mGyZqUY*qCf4zf!K^TZ">
                                <field name="NUM">60</field>
                              </shadow>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="update" id="Qg5uQ5,C~h#CP}OXp,n|">
                    <field name="OID">0_userdata.0.Datenpunkte.Rechengrößen.Dauer_dezimal</field>
                      <block type="variables_get" id=";*9U=xcn:`{pl^f5-rs,">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    @erazor86
    Tausche an 2 Stellen die Variable Liste gegen Einschaltdauer.
    E B 2 Antworten Letzte Antwort
      @erazor86
      erazor86
      🤦 manchmal könnte es so einfach sein.... Vielen Dank.. :)
        @erazor86
        brofelscher
        ich komme mit meiner Differenzzeit in Minuten ebenfalls nicht weiter. Ich versuche die Zeitdifferenz zwischen "Jetzt" und der letzten Aktualisierung eines Datenpunktes in Minuten zu errechnen und diese in den Datenpunkt "AbwesendSeitMinuten" zu schreiben.
        Das folgende Blockly funktioniert bis 59 Minuten prima, alles darüber hinaus funktioniert jedoch nicht. Es werden also zum Beispiel nicht 67 Minuten Differenz dargestellt, sondern nur "7". Die restlichen 60 Minuten verschwinden.
          <block type="comment" id="vdO3Z/b-^J_@l)?Eq_R+" x="13" y="38">
            <field name="COMMENT">Abwesenheitszeit berechnen</field>
            <next>
              <block type="on" id="-Se3D{`):B`]p/=p_aOI">
                <field name="OID">fb-checkpresence.0.presentCount</field>
                  <block type="controls_if" id="g$$Mh+_gT[pE?%~wmOw7">
                    <value name="IF0">
                      <block type="logic_compare" id="B~cGcXi@sZ~Vuxeg9NrH">
                        <field name="OP">EQ</field>
                        <value name="A">
                          <block type="get_value" id="Ra3xND;{0=Gx-[pw@??P">
                          </block>
                        </value>
                        <value name="B">
                          <block type="text" id="|2l5jEGj$arki%U@aI1*">
                            <field name="TEXT">0</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <statement name="DO0">
                      <block type="update" id="fO*d3{jQ-Q,Muo5?^aHF">
                        <field name="OID">0_userdata.0.AbwesendSeitMinuten</field>
                          <block type="convert_from_date" id="xF2Wqp~s/~y5PUaC_;7^">
                            <field name="OPTION">m</field>
                              <block type="math_arithmetic" id="{)*krPx!rRWcV.lMNvs9">
                                <value name="A">
                                  <shadow type="math_number" id="rD[[`+/pH}Z,=`RaZDKb">
                                  </shadow>
                                  <block type="time_get" id="{YtxVX%(xd!aZrGPIR%/">
                                    <field name="OPTION">object</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <shadow type="math_number" id="U}:)~D1u/;(DT4d+kNZM">
                                  </shadow>
                                  <block type="get_value" id="}D,-3Ku3mkH){l1UJ|o?">
                                    <field name="ATTR">lc</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </xml>
        • B brofelscher
              <next>
                      <value name="IF0">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                                  <value name="A">
                                    </shadow>
                                    </block>
                                  </value>
                                  <value name="B">
                                    </shadow>
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </xml>
          @brofelscher sagte: Blockly funktioniert bis 59 Minuten prima
          Das sind die Minuten der Uhrzeit.
          Vorschlag:
             <next>
                     <value name="IF0">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                           <block type="math_round" id="jh5X6wfE6}koDRuR}h,7">
                             <field name="OP">ROUND</field>
                             <value name="NUM">
                               <shadow type="math_number" id="dsl{1yg*UVLul@F2*}_x">
                                 <field name="NUM">3.1</field>
                               </shadow>
                               <block type="math_arithmetic" id="CG|Sg`nEt;fkO/q}:-Eg">
                                 <value name="A">
                                   <shadow type="math_number" id="r16alN.iyJ)%|~KKF{p5">
                                   </shadow>
                                     <value name="A">
                                       </shadow>
                                       </block>
                                     </value>
                                     <value name="B">
                                       </shadow>
                                       <block type="on_source" id="75tkb;IKslfqIl;1JyN#">
                                         <field name="ATTR">oldState.lc</field>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                   <shadow type="math_number" id="7o1So,{6-3V~;lGxE-;P">
                                     <field name="NUM">60000</field>
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
          </xml>
            Vorschlag:
               <next>
                       <value name="IF0">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                               <value name="NUM">
                                 </shadow>
                                   <value name="A">
                                     </shadow>
                                       <value name="A">
                                         </shadow>
                                         </block>
                                       </value>
                                       <value name="B">
                                         </shadow>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     </shadow>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
            </xml>
            brofelscher
            @paul53 said in Zeitdifferenz berechnen:
            Vorschlag:
            Hi, dein Vorschlag passt perfekt :) Danke dir.
            Ich habe wohl die Funktion "Minuten" missverstanden, da ich für die Minuten auch die Formatierung "mm" hätte nutzen können.
            Und wieder ist man ein wenig schlauer :)
            • E Offline
              erazor86
              Ich habe wieder eine neue Aufgabenstellung bzgl. Zeitverrechnung. Diesmal möchte ich die mittlere Außentemperatur der letzten 3h berechnen. Ich habe hierzu mal ein Blockly erstellt. Jedoch ist es nicht ganz korrekt, da die durchschnittliche Temp nur alle 3h neu berechnet wird. Habe es leider nicht hinbekommen wie ich es gerne hätte. Vielleicht hat jemand einen Tip?
              • E erazor86
                @erazor86 sagte: Vielleicht hat jemand einen Tip?
                Suche mal im Forum nach "gleitender Mittelwert".
                  @strobi sagte: Stundengenau (als Kommazahl) würde ausreichen) der aktuellen Tageszeit bis zum Sonnenuntergang
                  Strobi
                  Guten Abend,
                  leider funktioniert die Zeitberechnung so leider nicht.
                  Ich würde gerne immer die Zeitdifferenz bis zum nächsten Sonnenaufgang berechnen.
                  Also 1h vor dem Sonnenaufgang müsste 1h rauskommen, eine Stunde nach dem Sonnenaufgang müsste 23h rauskommen.
                  Mit folgendem Blockly kommt aber leider gar nichts raus:
                  Hat vielleicht jemand eine Idee, wie ich das hinbekommen könnte?
                  Besten Dank!
                  • S Strobi
                    Guten Abend,
                    Besten Dank!
                    @strobi sagte eine Stunde nach dem Sonnenaufgang müsste 23h rauskommen.
                    Nein, dann kommt am gleichen Tag ein negativer Wert raus. Teste die Berechnung erst mal mit dem Debug-Block.
                    Der Datenpunkt scheint keinen Zustand zu haben. Ist es der richtige DP? Das Skript ist aktiv, nicht unter der Gruppe "global" erstellt und der Debug-Modus (rechts oben) ist deaktiviert?
                    Für positive Werte:
                      Für positive Werte:
                      Strobi
                      So geht es - falls es noch jemanden interessiert - Zeitspanne bis zum nächsten Sonnenaufgang :-)
                      • JB_SullivanJ Offline
                        JB_Sullivan
                        Auch wenn dieser Thread schon "100 Jahre" alt ist, würde ich mich gerne mit meiner Frage hier anschließen, da es sich ebenfalls um eine "Zeit berechnen" Frage handelt.
                        Konkrete Problemstellung:
                        Ich habe zwei Datenpunkte - einmal die Zeit als UTC und dann den Lokalen Korrekturfaktor +2 Std. (CET)
                        Wie kann ich den vorhandenen DP, welcher so aussieht 2022-10-25T13:23:32Z nun um + 2 Stunden hoch addieren?
                        Das hier funktioniert jedenfalls nicht :(
                        • JB_SullivanJ JB_Sullivan
                          haus-automatisierungH Offline
                          @jb_sullivan sagte in Zeitdifferenz berechnen:
                          Du willst nichts addieren. Du willst den Zeitstempel nur anders formatieren (für unsere Zeitzone). Der Zeitpunkt bleibt ja genau der gleiche. Wäre ja falsch, da nun Stunden drauf zu schlagen.
                          Das "Z" am Ende deiner Zeitangabe steht für "Zulu". Das heißt, das ist UTC. Wenn Du das nun also in die gängigen Datumsfunktionen gibst, dann wissen die schon damit umzugehen. Wenn man den Zeitpunkt nun also formatiert, dann wird die Zeitzone des Betriebssystems berücksichtigt:
                          Ergibt: 25.10.2022. 15:23:32
                            <variables>
                              <variable id=",cJDM_Be,aiY)MRh{R/}">timeStamp</variable>
                            </variables>
                            <block type="variables_set" id="#s#G]QUKK_14+DT$P.$@" x="-587" y="262">
                              <field name="VAR" id=",cJDM_Be,aiY)MRh{R/}">timeStamp</field>
                                <block type="convert_to_date" id="k=w+o:B(w6`jJMabP~b[">
                                    <block type="text" id="r6t?3L$0}/3s`fDw`eh7">
                                      <field name="TEXT">2022-10-25T13:23:32Z</field>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                <block type="debug" id="00=-ftF0Y@P^A7$W/(F?">
                                  <value name="TEXT">
                                    <shadow type="text" id="#=,ZXQ_{QyO-CuYT@KRn">
                                    </shadow>
                                    <block type="convert_from_date" id="Ou5k{iL@;t`k5bxyQ^,S">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                      <field name="OPTION">custom</field>
                                      <field name="FORMAT">TT.MM.JJJJ. SS:mm:ss</field>
                                        <block type="variables_get" id="=OC%5Yj^4Ki#Oc,(S1m/">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </xml>
                          EDIT: So gehts sogar noch einfacher
                          Aber: Wenn Du ein Datum/Zeitpunkt als Wert in einem Datenpunkt speichern möchtest, dann ist UTC dafür ebenfalls korrekt. In dem Fall setzt Du die Rolle auf date und der Admin stellt den Wert dann "richtig" (heißt: in Deiner Zeitzone formatiert) dar:
                          📚 Meine Dokumentation
                              <variables>
                              </variables>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                    <value name="TEXT">
                                      </shadow>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </xml>
                            JB_Sullivan
                            schrieb am zuletzt editiert von JB_Sullivan
                            @haus-automatisierung
                            Naja, den Datenpunkt als UTC gibt es ja. Verstehe ich das richtig, das ich nur die Rolle ändern muss? Also in den Objektdaten von "indicator" in "date", damit nicht UTC sondern die Systemzeit ausgegeben wird?
                              "type": "state",
                              "common": {
                                "name": "timeInCar",
                                "role": "indicator",
                                "type": "string",
                                "write": false,
                                "read": true
                              "native": {},
                              "from": "system.adapter.vw-connect.0",
                              "user": "system.user.admin",
                              "ts": 1665834213369,
                              "_id": "vw-connect.0.FIN.status.air-conditioning.timers.timeInCar",
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                                "owner": "system.user.admin",
                                "type": "state",
                                "common": {
                                  "type": "string",
                                  "write": false,
                                  "read": true
                                "native": {},
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              Theoretisch ja, laut Dokumentation wird die Rolle date für number und string unterstützt: https://www.iobroker.net/#en/documentation/dev/stateroles.md
                              • date (common.type = string - parsable by "new Date(ddd)" string
                              • date (common.type = number - epoch seconds * 1000
                              Aber ersteres funktioniert im Admin aktuell nicht. Habe einen Issue aufgemacht:
                              https://github.com/ioBroker/ioBroker.admin/issues/1770
                              Und: Ich würde davon abraten, die Rollen von Datenpunkten anzupassen, welche man nicht selbst erstellt hat!
                              Ein Alias wäre hier eine gute Lösung. Type number, role date und beim Lesen einfach die Funktion einfügen: new Date(val).getTime()
                                "common": {
                                  "name": "test",
                                  "desc": "Manuell erzeugt",
                                  "role": "date",
                                  "type": "number",
                                  "read": true,
                                  "write": true,
                                  "def": 0,
                                  "alias": {
                                    "id": "vw-connect.0.FIN.status.air-conditioning.timers.timeInCar",
                                    "read": "new Date(val).getTime()"
                                "type": "state",
                                "native": {},
                                "_id": "alias.0.test",
                                "acl": {
                                  "object": 1632,
                                  "state": 1636,
                                "ts": 1666775968588
                              Die Frage ist nach wie vor: Was hast Du denn vor? Es ändert sich im Admin ja nur die Anzeige, wenn man die Rolle setzt. Der gespeicherte Wert bleibt genau der gleiche...
                                  "common": {
                                    "name": "test",
                                    "role": "date",
                                    "type": "number",
                                    "read": true,
                                    "write": true,
                                    "def": 0,
                                    "alias": {
                                  "type": "state",
                                  "native": {},
                                  "acl": {
                                    "object": 1632,
                                    "state": 1636,
                                  "ts": 1666775968588
                                JB_Sullivan
                                @haus-automatisierung sagte in Zeitdifferenz berechnen:
                                Der Adapter liefert die Uhrzeit des Fahrzeugs in UTC und zusätzlich den lokalen (CET) Anpassungsfaktor +2
                                Das Fahrzeug gibt die Geoposition aus und damit ich in der VIS sehe wie aktuell diese Geoposition ist, blende ich mir den diesen "Zeitstempel" Datenpunkt mit in die VIS ein. Klar kann ICH auch jedesmal im Kopf die 2 Stunden dazu rechnen.
                                Damit ist aber dem WAF-Faktor leider nicht genüge getan ;) Darum wollte ich den Datenpunkt so umwandeln das ein neuer, zeitlich korrekter DP entsteht, den ich dann in die VIS verknüpfe.
                                  Verstehe. Korrekt sind ja die UTC-Zeitpunkte ja auch :)
                                  Das ist meiner Meinung nach die Aufgabe des Frontends (also VIS). Es wäre in jedem Fall richtig, den Datenpunkt in UTC zu speichern (als string so wie er aktuell schon da ist oder number, siehe Alias im vorigen Beitrag) und diesen dann im Frontend von VIS auf die lokale Zeitzone umrechnen zu lassen.
                                  Eine Datenbank sollte Zeitstempel immer in UTC speichern (wie das Forum hier z.B. auch). Und dann erst bei der Darstellung den Zeitstempel für den User darstellen.
                                  Dafür gibt es doch z.B. das Widget TimesValue. Da einfach den Datenpunkt mit dem UTC-Zeitstempel wählen und das Format DD.MM.YYYY hh:mm:ss eintragen. Fertig. Keine Scripts, keine neuen Datenpunkte, keine Rechnerei.
                                    JB_Sullivan
                                    @haus-automatisierung VIELEN DANK das wir drüber gesprochen haben ;)
                                    Tja wenn man immer alles wüsste was geht, bräuchte man sich nicht den Kopf zu zerbrechen, wie man dieses oder jenes von"hinten durchs Auge" gelöst bekommt.
                                    Also nochmals vielen Dank für deine Zeit und die Erklärungen 👍👍
                                    • hg6806H Offline
                                      hg6806H Offline
                                      hg6806
                                      #66
                                      zu dem Thema hätte ich auch eine Frage.
                                      Und zwar habe ich eine Zeitdifferenz berechnet. Die ms stimmen soweit.
                                      16482933ms sind umgerechnet ca. 46h
                                      Mit dem folgenden Blockly bekomme ich aber nur 22:57?
                                      • hg6806H hg6806
                                        #67
                                        @hg6806 sagte in Zeitdifferenz berechnen:
                                        das ist nicht vollständig!
                                        wo nommt die Variable her?
                                        Hier wird die SS:mm des errechneten Timestamps ausgegeb3n. Das ist nie > 24h
                                        hg6806H 1 Antwort Letzte Antwort
                                          hg6806H Offline
                                          hg6806H Offline
                                          hg6806
                                          #68
                                          Ok, ich hole etwas weiter aus.
                                          Von einem Türsensor bekomme ich ein JSON.
                                          Daraus fische ich den Zeitstempel der letzten Öffnung/Schließung.
                                          Wenn ich den Zeitstempel nach TT.MM.JJJJ dekodiere, stimmt es schon mal.
                                          Die verstrichene Zeit auch (evtl 1h Unterschied wegen Zeitzone).
                                          Doch leider stimmt die letzte Berechnung nicht nach SS:mm
