  4. JavaScript
  5. [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.
474 Beiträge 50 Kommentatoren 141.3k Aufrufe 41 Beobachtet
  • ? Offline
    #332
    bisher funktionierte bei mir das Skript für den Airpurifier 3H relativ problemlos. Heute habe ich das System mal geupdatet und mit dem neustem js-Adapter bekomme ich das Skript (ohne jegliche Änderung" nicht mehr zum Laufen ;-(
    Könnte mir jemand netterweise behilflich sein?
    VG vsa
    avascript.0
    	2021-12-29 22:31:06.571	error	at Script.runInContext (vm.js:130:18)
    javascript.0
    	2021-12-29 22:31:06.571	error	at script.js.common.zhimi.airpurifier.mb3:130:3
    javascript.0
    	2021-12-29 22:31:06.571	error	at script.js.common.zhimi.airpurifier.mb3:3:1
    javascript.0
    	2021-12-29 22:31:06.570	error	script.js.common.zhimi.airpurifier.mb3: ReferenceError: module is not defined
    javascript.0
    	2021-12-29 22:31:06.570	info	script.js.common.zhimi.airpurifier.mb3: registered 0 subscriptions and 0 schedules
    javascript.0
    	2021-12-29 22:31:06.569	error	at Script.runInContext (vm.js:130:18)
    javascript.0
    	2021-12-29 22:31:06.569	error	at script.js.common.zhimi.airpurifier.mb3:130:3
    javascript.0
    	2021-12-29 22:31:06.569	error	at script.js.common.zhimi.airpurifier.mb3:1:16
    javascript.0
    	2021-12-29 22:31:06.568	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:412:32)
    javascript.0
    	2021-12-29 22:31:06.568	error	at require (internal/modules/cjs/helpers.js:74:18)
    javascript.0
    	2021-12-29 22:31:06.568	error	at Module.require (internal/modules/cjs/loader.js:887:19)
    javascript.0
    	2021-12-29 22:31:06.567	error	script.js.common.zhimi.airpurifier.mb3: Error: Cannot find module '../device-miio'
    javascript.0
    	2021-12-29 22:31:06.562	info	Start javascript script.js.common.zhimi.airpurifier.mb3
    javascript.0
    	2021-12-29 22:31:04.092	info	script.js.common.Wetter_VIS: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.0.alive'
    host.ioBroker-RasPi4
    	2021-12-29 22:31:04.052	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    javascript.0
    	2021-12-29 22:31:04.048	error	at Script.runInContext (vm.js:130:18)
    javascript.0
    	2021-12-29 22:31:04.047	error	at script.js.common.zhimi.airpurifier.mb3:130:3
    javascript.0
    	2021-12-29 22:31:04.046	error	at script.js.common.zhimi.airpurifier.mb3:3:1
    javascript.0
    	2021-12-29 22:31:04.046	error	script.js.common.zhimi.airpurifier.mb3: ReferenceError: module is not defined
    javascript.0
    	2021-12-29 22:31:04.045	info	script.js.common.zhimi.airpurifier.mb3: registered 0 subscriptions and 0 schedules
    javascript.0
    	2021-12-29 22:31:04.044	error	at Script.runInContext (vm.js:130:18)
    javascript.0
    	2021-12-29 22:31:04.044	error	at script.js.common.zhimi.airpurifier.mb3:130:3
    javascript.0
    	2021-12-29 22:31:04.043	error	at script.js.common.zhimi.airpurifier.mb3:1:16
    javascript.0
    	2021-12-29 22:31:04.043	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:412:32)
    javascript.0
    	2021-12-29 22:31:04.042	error	at require (internal/modules/cjs/helpers.js:74:18)
    javascript.0
    	2021-12-29 22:31:04.042	error	at Module.require (internal/modules/cjs/loader.js:887:19)
    javascript.0
    	2021-12-29 22:31:04.041	error	script.js.common.zhimi.airpurifier.mb3: Error: Cannot find module '../device-miio'
    javascript.0
    	2021-12-29 22:31:04.033	info	Start javascript script.js.common.zhimi.airpurifier.mb3
    javascript.0
    	2021-12-29 22:31:04.026	info	Stop script script.js.common.zhimi.airpurifier.mb3
    javascript.0
    	2021-12-29 22:31:04.021	info	Stop script script.js.common.zhimi.airpurifier.mb3
    stony2kS 1 Antwort Letzte Antwort
      VG vsa
      avascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      stony2kS Offline
      stony2kS Offline
      stony2k
      #333
      @vsa sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
      airpurifier.mb3
      Ist bei dir noch die Datei /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices/zhimi.airpurifier.mb3 vorhanden?
      • stony2kS stony2k
        airpurifier.mb3
        haselchenH Offline
        haselchenH Offline
        haselchen
        #334
        @Pittini
        Es wurde vermutlich am Auth Verfahren was geändert.
        Ist Dir das schon bekannt?
        Bei mir startet das Skript nicht mehr.
        javascript.0	2022-01-02 18:36:14.031	error	(884) at Init (script.js.Steuerung_Ventilator_und_Lüfter.Lüfter_und_Ventilator:795:21)
        javascript.0	2022-01-02 18:36:14.031	error	(884) at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:18)
        javascript.0	2022-01-02 18:36:14.030	error	(884) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2022-01-02 18:36:14.030	error	(884) at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:107:13)
        javascript.0	2022-01-02 18:36:14.028	error	(884) script.js.Steuerung_Ventilator_und_Lüfter.Lüfter_und_Ventilator: Error: Request error with status Unauthorized
        Siggi0904S 1 Antwort Letzte Antwort
        • haselchenH haselchen
          @Pittini
          Siggi0904S Offline
          Siggi0904S Offline
          Siggi0904
          #335
          @haselchen Siehe https://github.com/Pittini/iobroker-nodemihome/issues/56
          • Siggi0904S Siggi0904
            haselchenH Offline
            haselchenH Offline
            haselchen
            #336
            @siggi0904
            @Pittini
            Skript geht wieder.
            Neu starten , dann passt wieder alles.
            W Siggi0904S 2 Antworten Letzte Antwort
              @siggi0904
              @Pittini
              Skript geht wieder.
              W Online
              W Online
              Wildbill
              #337
              @haselchen Bei mir lief es die letzten Tage sogar problemlos durch, als ihr da anscheinend Probleme hattet?! Wer weiss, was Xiaomi da wieder im Hintergrund geschrajbt hat...
              Gruß, Jürgen
              • W Wildbill
                Gruß, Jürgen
                #338
                @wildbill
                Auf dem cn oder de Server? Mein kleiner Chinese hat jedenfalls auch nicht gemuckt.
                W 1 Antwort Letzte Antwort
                  @wildbill
                  W Online
                  W Online
                  Wildbill
                  #339
                  @thomas-braun Ich bin Anfang an mit allen Luftreinigern auf dem de-Server.
                  Gruß, Jürgen
                    @siggi0904
                    @Pittini
                    Skript geht wieder.
                    Siggi0904S Offline
                    Siggi0904S Offline
                    Siggi0904
                    schrieb am zuletzt editiert von Siggi0904
                    #340
                    @haselchen Es geht wieder los, das Skript meldet "Error: Request error with status Unauthorized" seit 13:00 Uhr. 😠
                    2022-01-12 17:19:49.498 - error: javascript.0 (3566355) script.js.Skripte.Wohnung.Xiaomi_Geräte: Error: Request error with status Unauthorized
                    2022-01-12 17:19:49.498 - error: javascript.0 (3566355) at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:107:13)
                    2022-01-12 17:19:49.498 - error: javascript.0 (3566355) at runMicrotasks ()
                    2022-01-12 17:19:49.499 - error: javascript.0 (3566355) at processTicksAndRejections (internal/process/task_queues.js:95:5)
                    2022-01-12 17:19:49.499 - error: javascript.0 (3566355) at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:18)
                    2022-01-12 17:19:49.499 - error: javascript.0 (3566355) at RefreshGenericDpsTicker (script.js.Skripte.Wohnung.Xiaomi_Geräte:923:17)
                    • crunchipC Offline
                      crunchipC Offline
                      #341
                      @siggi0904 hier läuft noch alles geschmeidig
                        Siggi0904S Offline
                        Siggi0904S Offline
                        Siggi0904
                        #342
                        @crunchip Hm, was ist das wieder?
                          crunchipC Offline
                          crunchipC Offline
                          #343
                          @siggi0904 wohl kein allgemeines Server Problem
                            Siggi0904S Offline
                            Siggi0904S Offline
                            Siggi0904
                            #344
                            @crunchip Dank dir für die Info. Ja, dann wär hier mehr los.
                            Hat jemand einen Tipp, wie ich das beheben kann?
                            P 1 Antwort Letzte Antwort
                              Pittini
                              #345
                              @siggi0904 sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                              Nicht direkt, aber nen Versuch. Dass der Fehler bei Dir wieder da ist, ist ärgerlich, für mich interessant ist aber die Zeile:
                              Das ist nämlich nicht wie erwartet der normale Login bei Skriptstart, sondern die erneute Statusabfrage. Und die kann man auch abschalten, es wird dann lediglich isOnline und der rssi nicht aktualisiert. Stell mal Zeile 10 "const SkipRssiRefresh" auf true und schau was passiert.
                              • P Pittini
                                Siggi0904S Offline
                                Siggi0904S Offline
                                Siggi0904
                                #346
                                @pittini Hallo Pittini, da ich nodejs aktualisieren musste (Update wurde angezeigt), hatte ich auch den IOBroker neugetartet. Danach hab ich das Skript wieder gestartet und nun rennt wieder alles.
                                SkipRssiRefresh steht bei mir immer auf false.
                                Mit diesen Einstellungen hatte ich aber auch immer gespielt.
                                Weißt du eigentlich im Script welche Log-Ausgaben geschrieben werden?
                                Wäre vielleicht gut, wenn bei fehlerhafter Anmeldung und weiteren Fehlern ein Hinweis ausgegeben würde, dass das Script keine Daten ausgibt und somit nicht funktioniert.
                                Merkwürdig, was das war.
                                • N Offline
                                  N Offline
                                  NebuNC2
                                  #347
                                  Hallo Zusammen,
                                  ich bin einfach zu blöd... Versuche den 3H einzubinden und bekomme gar nichts hin...
                                  Habe es zwar hinbekommen das Skript einzubauen, bekomme aber folgende Fehlermeldung:
                                  script.js.MI_AIR_TRISTAN: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../..//opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices/'
                                  Obwohl ich über wget hinzugefügt habe, denke ich...
                                  Ich weiß auch gar nicht wo ich meine Logindaten eintragen muss... 😢
                                  Könnt ihr helfen?
                                  • N NebuNC2
                                    Hallo Zusammen,
                                    Könnt ihr helfen?
                                    Siggi0904S Offline
                                    Siggi0904S Offline
                                    Siggi0904
                                    #348
                                    @nebunc2 hast du node-mihome im javascript Editor aktiviert?
                                    Schau dir auch mal die heruntergeladene Datei an, dass das auch ein js Datei ist.
                                    Ansonsten bitte mal ein vollständiges log.
                                    N 1 Antwort Letzte Antwort
                                      N Offline
                                      N Offline
                                      NebuNC2
                                      #349
                                      @siggi0904
                                      Ja, ist eingetragen:
                                      Sollte eine JS Datei sein:
                                      Wie mache ich ein vollständiges Log ?
                                      • N NebuNC2
                                        @siggi0904
                                        N Offline
                                        N Offline
                                        NebuNC2
                                        schrieb am zuletzt editiert von NebuNC2
                                        #350
                                        5.2.2022, 21:38:59.105 [info ]: javascript.0 (1230) Stop script script.js.MI_AIR_TRISTAN
                                        5.2.2022, 21:39:26.457 [info ]: javascript.0 (1230) Start javascript script.js.MI_AIR_TRISTAN
                                        5.2.2022, 21:39:26.497 [error]: javascript.0 (1230) script.js.MI_AIR_TRISTAN: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../../device-miio'
                                        5.2.2022, 21:39:26.498 [error]: javascript.0 (1230) at script.js.MI_AIR_TRISTAN:1:16
                                        5.2.2022, 21:39:26.498 [error]: javascript.0 (1230) at script.js.MI_AIR_TRISTAN:129:3
                                        5.2.2022, 21:39:26.500 [info ]: javascript.0 (1230) script.js.MI_AIR_TRISTAN: registered 0 subscriptions and 0 schedules
                                        5.2.2022, 21:39:26.501 [error]: javascript.0 (1230) script.js.MI_AIR_TRISTAN: ReferenceError: module is not defined
                                        5.2.2022, 21:39:26.501 [error]: javascript.0 (1230) at script.js.MI_AIR_TRISTAN:3:1
                                        5.2.2022, 21:39:26.501 [error]: javascript.0 (1230) at script.js.MI_AIR_TRISTAN:129:3
                                        • F fd
                                          @fd Für alle, die ein ähnliches Problem haben, dass sie das Skript leider nicht zum Laufen bekommen: Ich habe das ganze jetzt über den ham adapter gelöst.
                                          Folgendermaßen bin ich vorgegangen:
                                          1. Via SSH "homebridge" und "homebridge xiaomi fan" installieren (siehe z.B. https://github.com/merdok/homebridge-xiaomi-fan für weitere Anmerkungen)
                                          2. ham Adapter für den iobroker installieren
                                          3. Im ham Adapter unter "Main Settings" "Local Mode (...)" wählen
                                          4. Unter "Main Settings" "Additional NPM modules" "homebridge-xiaomi-fan" hinzufügen
                                          5. Im ham Adapter unter "Configuration File" die in https://github.com/merdok/homebridge-xiaomi-fan beschriebenen Eintragungen vornehmen. Bei mir sieht das zB so aus (mit einigen Dummies und ohne Sonos):
                                            "bridge": {
                                              "name": "TEST",
                                              "username": "00:11:22:33:44:55",
                                              "port": 51826,
                                              "pin": "000-00-001"
                                            "platforms": [
                                                "name": "Config",
                                                "port": 8090,
                                                "auth": "form",
                                                "theme": "dark-mode",
                                                "tempUnits": "c",
                                                "lang": "auto",
                                                "sudo": false,
                                                "log": {
                                                  "method": "file",
                                                  "path": "/var/log/homebridge_ioB.log"
                                                "platform": "config"
                                                "devices": [
                                                    "name": "Mi Smart Standing Fan 2",
                                                    "ip": "192.xxx.xxx.xxx",
                                                    "token": "xxxxx",
                                                    "model": "dmaker.fan.p18",
                                                    "pollingInterval": 10,
                                                    "buzzerControl": true,
                                                    "ledControl": true,
                                                    "naturalModeControl": true,
                                                    "sleepModeControl": true,
                                                    "moveControl": true,
                                                    "shutdownTimer": true,
                                                    "angleButtons": [
                                                      30,
                                                      60,
                                                      90,
                                                      120,
                                                      140
                                                    "ioniserControl": false
                                                "platform": "xiaomifan"
                                            "accessories": []
                                          Diese Config-Datei kann mit anderen Einträgen (bei mir zB für Sonos) kombiniert werden. Den Token, das Modell und die IP Adresse des Ventilators kann einfach über die hier hinterlegte App ausgelesen werden: https://github.com/Maxmudjon/Get_MiHome_devices_token/releases
                                          6. den ham Adapter neu starten (passiert eigentlich automatisch)
                                          7. Unter Objects in ioBroker werden dann unter ham.0 die Ventilatorsettings und Steuermöglichkeiten angezeigt
                                          Wenn der Ventilator in der Xiaomi App auftaucht, sollte er dann auch in ioBroker verfügbar sein.
                                          Weitere Hinweise:
                                          • Ich hatte den Ventilator testweise im Fritzbox-Gästenetz, dann funktioniert es aber leider nicht, er muss scheinbar lokal im Netz gut erreichbar sein
                                          • Für mein Ventilatormodell sind alle Einstellungen in ioBroker vornehmbar, bis auf die exakte Fan Speed als Prozentangabe. Es gibt aber 4 Stufen, die gewählt werden können
                                          • Der Ventilator erscheint auch ohne weiteres in der Apple Home App und kann dort auch gesteuert werden, dort kann sogar die Fan Speed in Prozent geändert werden. Hierzu muss der ham Adapter mit Apple Home verbunden werden, das müsstet Ihr nochmals googlen (bei mir liefs wegen des Sonos bereits), ist aber recht einfach.
                                          • Wer der China-Cloud nicht vertraut, kann nach der Installtion des Ventilators in der Fritzbox den Internetzugang des Fans kappen. Er erscheint dann in der Xiaomi Home App als "offline"
                                          @Pittini nochmals vielen herzlichen Dank für das Trouble-Shooting mit Deinem Skript, leider musste ich doch den anderen Weg gehen, da die Fehlermeldung nicht wegzubekommen war. Insbesondere die Tatsache, dass der Ventilator über ham ohne China Cloud lauffähig ist, ist m.E. ein Vorteil.
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #351
                                          @fd sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                                          Super, obwohl ich bei iobroker noch ganz neu dabei bin, habe ich es mit Deiner Anleitung auf Anhieb geschafft, meinen Xiaomi Ventilator einzubinden.
                                          Nur eine Frage habe ich noch: Welches Widget, oder Icon kann ich nehmen um den Ventilator in meiner Navigation darzustellen und zu steuern? Was würdest Du mir empfehlen?
                                          Mit besten Grüßen
                                          Andy
