  4. [Anleitung] WireGuard mit WireGuard-UI auf Proxmox
    5.9k
portforwardingportfreigabeportfreischaltungproxmoxvpnwireguardwireguard ios app
603 Beiträge 64 Kommentatoren 230.0k Aufrufe 47 Beobachtet
  • Yogi 0Y Yogi 0
    @crunkfx
    Hier die Ausgabe, nachdem auf Apply Config geklickt wurde:
    root@wireguard:~# systemctl status wgui
    * wgui.service - Restart WireGuard
        Loaded: loaded (/etc/systemd/system/wgui.service; enabled; vendor preset: enabled)
        Active: failed (Result: exit-code) since Tue 2022-01-04 11:09:45 CET; 6s ago
    TriggeredBy: * wgui.path
       Process: 5792 ExecStart=/usr/bin/systemctl restart wg-quick@wg0.service (code=exited, status=203/EXEC)
      Main PID: 5792 (code=exited, status=203/EXEC)
           CPU: 511us
    Jan 04 11:09:45 wireguard systemd[1]: Starting Restart WireGuard...
    Jan 04 11:09:45 wireguard systemd[1]: wgui.service: Main process exited, code=exited, status=203/EXEC
    Jan 04 11:09:45 wireguard systemd[1]: wgui.service: Failed with result 'exit-code'.
    Jan 04 11:09:45 wireguard systemd[1]: Failed to start Restart WireGuard.
    CrunkFXC Offline
    CrunkFXC Offline
    CrunkFX
    Forum Testing
    #242
    @yogi-0 Was zeigt:
    ls /bin
    • Yogi 0Y Offline
      Yogi 0Y Offline
      Yogi 0
      #243
      @crunkfx
      bin zeigt folgende Inhalte:
      root@wireguard:~# ls /bin
      bash          cat            domainname  gzip        lsmod       networkctl     ntfstruncate  rm         systemctl                       true             zegrep
      bunzip2       chgrp          dumpkeys    hostname    mkdir       nisdomainname  ntfsusermap   rmdir      systemd                         udevadm          zfgrep
      busybox       chmod          echo        ip          mknod       ntfs-3g        ntfswipe      rnano      systemd-ask-password            ulockmgr_server  zforce
      bzcat         chown          ed          journalctl  mktemp      ntfs-3g.probe  openvt        run-parts  systemd-escape                  umount           zgrep
      bzcmp         chvt           egrep       kbd_mode    more        ntfscat        pidof         sed        systemd-hwdb                    uname            zless
      bzdiff        cp             false       kill        mount       ntfscluster    ping          setfont    systemd-inhibit                 uncompress       zmore
      bzegrep       cpio           fgconsole   kmod        mountpoint  ntfscmp        ping4         setupcon   systemd-machine-id-setup        unicode_start    znew
      bzexe         dash           fgrep       ln          mt          ntfsfallocate  ping6         sh         systemd-notify                  vdir
      bzfgrep       date           findmnt     loadkeys    mt-gnu      ntfsfix        plymouth      sleep      systemd-sysusers                wdctl
      bzgrep        dd             fuser       login       mv          ntfsinfo       ps            ss         systemd-tmpfiles                which
      bzip2         df             fusermount  loginctl    nano        ntfsls         pwd           static-sh  systemd-tty-ask-password-agent  ypdomainname
      bzip2recover  dir            grep        lowntfs-3g  nc          ntfsmove       rbash         stty       tar                             zcat
      bzless        dmesg          gunzip      ls          nc.openbsd  ntfsrecover    readlink      su         tempfile                        zcmp
      bzmore        dnsdomainname  gzexe       lsblk       netcat      ntfssecaudit   red           sync       touch                           zdiff
      CrunkFXC 1 Antwort Letzte Antwort
      • Yogi 0Y Yogi 0
        @crunkfx
        CrunkFXC Offline
        CrunkFXC Offline
        CrunkFX
        Forum Testing
        #244
        @yogi-0 Kannst du bitte einmal folgendes ausführen :
        wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui-bin.service -O /etc/systemd/system/wgui.service
        und anschließend
        systemctl daemon-reload
        systemctl stop wgui
        systemctl start wgui
        Yogi 0Y S 2 Antworten Letzte Antwort
        • CrunkFXC CrunkFX
          und anschließend
          systemctl stop wgui
          Yogi 0Y Offline
          Yogi 0Y Offline
          Yogi 0
          #245
          @crunkfx
          Okay ich habe den Dienst jetzt neu geladen und anschließend nochmal den Status ausgegeben, scheint jetzt zumindest vernünftig zu starten:
               Active: inactive (dead) since Tue 2022-01-04 12:03:46 CET; 6min ago
              Process: 7665 ExecStart=/bin/systemctl restart wg-quick@wg0.service (code=exited, status=0/SUCCESS)
             Main PID: 7665 (code=exited, status=0/SUCCESS)
                  CPU: 1ms
          Jan 04 12:03:45 wireguard systemd[1]: Starting Restart WireGuard...
          Jan 04 12:03:46 wireguard systemd[1]: wgui.service: Succeeded.
          Jan 04 12:03:46 wireguard systemd[1]: Finished Restart WireGuard.
          Habe nochmal in der WireguardUI auf Apply Config geklickt, ich glaube da tut sich nach wie vor nichts, denn eigentlich müsste der Server ja neustarten, aber ich kann nach dem Klick in der UI unmittelbar weiter navigieren... ?
          • Yogi 0Y Yogi 0
            @crunkfx
                    CPU: 1ms
            CrunkFXC Offline
            CrunkFXC Offline
            CrunkFX
            Forum Testing
            #246
            @yogi-0 Nein, der Server muss nicht Neustarten, nur der WireGuard Dienst um die neue Konfiguration anzunehmen. Du kannst das testen indem du einen neuen Client im UI anlegst und dieser direkt nach dem Klick auf Aplly Config funktioniert.
            Yogi 0Y 1 Antwort Letzte Antwort
            • CrunkFXC CrunkFX
              Yogi 0Y Offline
              Yogi 0Y Offline
              Yogi 0
              schrieb am zuletzt editiert von Yogi 0
              #247
              @crunkfx
              leider funktioniert der Neustart des Dienstes über den Apply Config Button immer noch nicht, die VPN Verbindung schmeißt wieder den Handshake Error
              2022-01-04 12:18:00.964: [TUN] [test] Handshake for peer 1 (:51820) did not complete after 5 seconds, retrying (try 2)
              Nachdem manuellen Neustart über systemctl stop/start wgui funktioniert der Client entsprechend dann. Woran könnte es noch liegen, dass der Button den Befehl nicht vernünftig an den Container weiterleiten kann? 😕
              • CrunkFXC CrunkFX
                @nerg Du kannst auch eine vorhandene VM oder Container nutzen. Das Skript ist so angepasst, das alte Konfigurationsdateien vom "alten" Skript übernommen werden.
                N Offline
                N Offline
                nerg
                #248
                @crunkfx Thema Container-recyceln: sollte ich denn nicht den docker Kram etc runter werfen? Welche apt Pakete wären das?
                • Yogi 0Y Yogi 0
                  @crunkfx
                  CrunkFXC Offline
                  CrunkFXC Offline
                  CrunkFX
                  Forum Testing
                  #249
                  @yogi-0 Entschuldige bitte die verspätete Rückmeldung, es scheint hierbei ein Problem mit dem systemctl Dienst zu geben. Je nach Distribution befindet sich dieser in /usr/bin/systemctl oder /bin/systemctl . Bei dir sind beide vorhanden, weshalb mein Skript etwas verwirrt zu sein schien. Ich habe nun geupdated, allerdings erfordert es eine Neuinstallation von Wireguard und Wireguard UI.
                  Ansonsten nach einer Änderung
                  systemctl restart wgui
                  • N nerg
                    CrunkFXC Offline
                    CrunkFXC Offline
                    CrunkFX
                    Forum Testing
                    schrieb am zuletzt editiert von CrunkFX
                    #250
                    @nerg Je nachdem ob du noch mehrere Docker Container laufen hast, reicht es den Wireguard UI Container zu entfernen:
                    docker rm wgui
                    Möchtest du Docker und ALLES was dazu gehört entfernen (Genieß das mit Vorsicht wenn du nicht sicher bist ob noch mehr auf Docker läuft!):
                    sudo apt-get purge -y docker.io docker-compose
                    sudo apt-get autoremove -y --purge docker.io docker-compose
                    sudo rm -rf /var/lib/docker /etc/docker
                    sudo rm /etc/apparmor.d/docker
                    sudo groupdel docker
                    sudo rm -rf /var/run/docker.sock
                    sudo rm /usr/local/bin/docker-compose
                    • CrunkFXC CrunkFX
                      MartyBr
                      #251
                      @crunkfx Ich hatte gestern die 1.20 auf einem neuen System installiert. Ich möchte jetzt ungern die 1.21 installieren. Was hat sich denn genau geändert? Kann ich ein Patch einspielen oder eine Datei austauschen?
                      Martin
                      Homematic und Homematic IP
                      • M MartyBr
                        CrunkFXC Offline
                        CrunkFXC Offline
                        CrunkFX
                        Forum Testing
                        #252
                        @martybr Wenn bei dir alles so funktioniert wie es soll, ist es nicht nötig 1.2.1 zu installieren.
                        • CrunkFXC CrunkFX
                          MartyBr
                          #253
                          @crunkfx 🤗
                          Martin
                          • CrunkFXC CrunkFX
                            und anschließend
                            systemctl stop wgui
                            simi
                            schrieb am zuletzt editiert von simi
                            #254
                            @crunkfx Herzlichen Dank für das Skript - ich habe es gerade in einem Ubuntu 20.04 LTS-LXC installiert und hatte zunächst ebenfalls das Problem, dass ich nach dem Anlegen eines Clients trotz "Apply Config" neustarten musste, bevor der Client connecten konnte. Mit den "Nacharbeiten" aus diesem Post (und einem Reboot), kann der neue Client jetzt wie gewünscht nach dem "Apply Config" direkt connecten.
                            Dann werde ich mal meinen priviligierten OpenVPN-Container abschalten... Wenn ich bedenke, was das für ein Gefrickel war, bevor OpenVPN auch über meine VLANs hinweg funktioniert hat, kann ich Dir gar nicht genug danken :)
                            Edit: Und auf Port 80 läuft es auch super :)
                            • CrunkFXC CrunkFX
                              Hallöchen,
                              nachdem hier immer wieder Fragen bezüglich VPN etc. kommen, habe ich mich entschlossen eine kleine Anleitung zum Thema WireGuard zu erstellen. Ich habe versucht die Anleitung so einfach und kurz wie möglich zu halten.
                              Installationszeit ca. 15 Minuten je nach Internetverbindung
                              Stand V1.2.2 18.01.2022
                              Github Link https://github.com/KleSecGmbH/ioBroker/tree/main/wireguard
                              Voraussetzungen:
                              • Proxmox als Grundgerüst mit Kernel Version min.: 5.11 Ältere Version?
                              • Einen Dual-Stack Internetanschluss (also kein DS-Lite, hierzu kommt bei Bedarf eine gesonderte Anleitung)
                              • Portfreigabe im Router (Protokoll: UDP, Port: 51820 , auf die IP Adresse des neuen Linux Containers)
                                !!! Keine Portfreigabe auf den im späteren Verlauf erstellten Port 5000 setzen !!!
                              • Falls keine feste IP vorhanden ist benötigt ihr einen Hostnamen. Das kann z.b. MyFritz sein oder DynDns, Hauptsache ein Dienst mit dem ihr auf eure aktuelle IP verweisen könnt.
                              Anleitung:
                              Zunächst müssen wir das LXC Template für Ubuntu 21.04 oder 21.10 installieren.
                              Anschließend basierend auf diesem Image einen neuen Container anlegen
                              einen Hostnamen vergeben sowie ein Passwort
                              Danach das Image auswählen
                              Und mit den Standardwerten bis zur Netzwerkkonfiguration weitermachen.
                              Nun noch eine IP vergeben und der erste Teil wäre geschafft.
                              Ab hier wird auf dem Proxmox Host gearbeitet!
                              Zunächst passen wir die Konfiguration des neu erstellten Containers an.
                              Dazu mit dem Befehl
                              nano /etc/pve/lxc/100.conf
                              (!! 100 durch die Nummer bei eurem Container ersetzen !!)
                              die Konfigurationsdatei anpassen.
                              Und diese beiden Zeilen am Ende der Datei anhängen:
                              Proxmox Version 7.xx :
                              lxc.cgroup2.devices.allow: c 10:200 rwm
                              lxc.mount.entry: /dev/net dev/net none bind,create=dir
                              Proxmox Version 5.xx/6.xx:
                              lxc.cgroup.devices.allow: c 10:200 rwm
                              Nach dem Einfügen das Fenster mit STRG + X --> Enter speichern und verlassen.
                              Danach auf dem Proxmox Host die Zugriffsrechte für den Tunneladapter freigeben mit dem Befehl:
                              chown 100000:100000 /dev/net/tun
                              Ab hier wird auf dem neuen Container gearbeitet!
                              Danach können wir unseren LXC/CT starten und uns anmelden.
                              Ich habe alle zur Installation notwendigen Befehle und Konfigurationsdateien in einem kleinen Shell-Skript zusammengefügt.
                              Dazu also folgendes ausführen:
                              wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/installer-pve.sh -O installer-pve.sh && bash installer-pve.sh
                              Der Installer läuft bis zu diesem Punkt automatisch durch. Die abgefragten Punkte ALLE mit Enter bestätigen, da später in der Grafischen Oberfläche Konfiguriert wird.
                              Nachdem wir erfolgreich WireGuard und WireGuard-UI Installiert haben, können wir WireGuard-UI Konfigurieren.
                              Dazu rufen wir http://IP-AdresseVomLinuxContainer:5000 auf und melden uns mit Benutzer und Passwort admin an.
                              Die Anmeldedaten können mit dem Installer und dem Punkt Anmeldedaten ändern geändert werden.
                              Zunächst müssen wir den WireGuard Server Konfigurieren. Dazu muss in den Global Settings unter dem Punkt Endpoint-Address euer Hostname(MyFritz, DynDns) oder eine feste IP (falls vorhanden) Bei Fragen hierzu siehe oben!
                              Nachdem wir Hostname/IP eingegeben haben und auf Apply Config geklickt haben, müssen wir noch einen kleinen Punkt durchführen um Clients anlegen zu können.
                              Dazu im Fenster WireGuard Server unter dem Punkt Post Up Script folgendes eintragen:
                              iptables -A FORWARD -i %i -j ACCEPT; iptables -A FORWARD -o %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
                              und um Feld Post Down Script folgendes eintragen:
                              iptables -D FORWARD -i %i -j ACCEPT; iptables -D FORWARD -o %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
                              Danach speichern und Apply Config drücken.
                              Clients anlegen:
                              Ab hier dürfte alles recht selbsterklärend sein.
                              Im Menü WireGuard Clients auf New Client drücken
                              Name und Email Konfigurieren
                              und Bestätigen.
                              Nun bekommt ihr einen Client mit einem QR Code den ihr mit der WireGuard App scannen könnt oder alternativ als Datei zum Download für Desktoprechner.
                              Sollten sich doch Fehler eingeschlichen haben, bitte melden. Getestet wurde auf Proxmox V7.0-11.
                              Bei Bedarf kann ich diese Anleitung gerne für RasPi und Konsorten ebenfalls erstellen.
                              LG
                              CrunkFX
                              Muchul
                              schrieb am zuletzt editiert von Muchul
                              #255
                              @crunkfx
                              Danke.
                              Nachdem ich eine Woche versucht habe die Fritz VPN auf dem Laptop einzurichten und kläglich gescheitert bin, habe ich dank deiner Anleitung nun vollen Zugriff auf mein Heimnetzwerk.
                              Die Nachricht schicke ich gerade über den Tunnel :-)
                              Klasse Arbeit und sehr gut dokumentiert, Alle Daumen hoch (hab mir noch welche dafür geliehen).
                              PS: Handy habe ich gar nicht erwähnt, aber beides geht super.
                              Ich musste lediglich den Tunnelnamen für Windows ändern, da er anscheinend keine Leerzeichen mag.
                              Thomas BraunT CrunkFXC 2 Antworten Letzte Antwort
                              • M Muchul
                                @crunkfx
                                Danke.
                                #256
                                @muchul sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                                Leerzeichen mag in der IT eigentlich gar keiner. Immer ohne auskommen!
                                • M Muchul
                                  @crunkfx
                                  Danke.
                                  CrunkFXC Offline
                                  CrunkFXC Offline
                                  CrunkFX
                                  Forum Testing
                                  #257
                                  @muchul Hi, kannst du das nochmal erklären so ganz verstehe ich das Problem nicht. Welchen tunnelnamen meinst du?
                                  LG
                                  • CrunkFXC CrunkFX
                                    LG
                                    Muchul
                                    #258
                                    @crunkfx
                                    gerne, nach der Installation http://ServerIP:5000 aufgerufen und alles ausgefüllt.
                                    Dummerweise bei Name vor -und zu- Name eingetragen.
                                    Am Handy QR Code gescannt und alles funktioniert.
                                    Am Laptop von https://download.wireguard.com/windows-client/wireguard-installer.exe den Installer runtergeladen installiert und die Datei "Vorname Nachname.conf" eingelesen und dabei die Fehlermeldung bekommen:
                                    Fehler: Importieren der Konfiguration nicht möglich: Der Tunnelname ist ungültig: "name Vorname"
                                    Habe dann die Datei umbenannt in "VornameNachname.conf", also das Leerzeichen zwischen vor und Nachname gelöscht und schon ging es.
                                    • M Muchul
                                      @crunkfx
                                      CrunkFXC Offline
                                      CrunkFXC Offline
                                      CrunkFX
                                      Forum Testing
                                      #259
                                      @muchul Verstanden, das scheint aber ein Fehler in der Wireguard Desktop App zu sein, ich werde mal schauen ob es hierzu auf Github bereits ein Issue gibt, ansonsten lege ich eins an.
                                      Vielen Dank
                                      • CrunkFXC CrunkFX
                                        Vielen Dank
                                        Muchul
                                        #260
                                        @crunkfx
                                        ich habe zu danken.
                                        • P Offline
                                          ple
                                          #261
                                          Moin Moin zusammen, aktuell gerade ein wenig im Streß wegen Sanierung des Hauses, aber ich muss bald mal ein VPN aufbauen können, damit ich unterwegs weiter am KNX basteln kann. Aktuell habe ich ein Unifi Dream Machnine pro SE im Einsatz, suche nun einen Möglichkeit ein VPN aufzubauen.
                                          Früher in der Wohnung damals hatte ich es mit einen kleinen Vserver gemacht, der mir die IPv4 in IPv6 getunnelt hat. Zum Einsatz kam dann Openvpn per tcp.
                                          Nun dachte ich, da gibts bestimmt schon was neues, also Wireguard entdeckt. Das scheint auch mit IPv6 UDP klarzukommen. IPv6 hätte ich soweit bei allen Endgeräten zur Verfügung.
                                          Kurz gefragt, geht das auch mit deinen Script, dass ich mich per IPv6 verbinden kann ohne Portmapper oder sonstiges?
                                          Für das USG gibts wohl nativ kein Wireguard, daher muss wohl ein Container herhalten.
                                          Gruß und Danke
                                          Intel Nuc + Proxmox
