  4. JavaScript
  5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
1.5k Beiträge 53 Kommentatoren 705.1k Aufrufe 52 Beobachtet
  • sigi234S sigi234
    @ticaki
    avascript.0
    2021-12-26 01:17:18.724	info	script.js.Sigi.UWZ_DWD_NINA18: info: Nutze Datenabruf für NINA über States in nina.0
    javascript.0
    2021-12-26 01:17:18.584	info	script.js.Sigi.UWZ_DWD_NINA18: info: Init! id: 0_userdata.0.wetterwarnung.data.zamg.48#xxxxxx/14#xxxxxx.warning.object headline: Warnung vor Glatteis
    javascript.0
    2021-12-26 01:17:18.254	info	script.js.Sigi.UWZ_DWD_NINA18: advance: Rufe Daten vom Server ab - ZAMG Area: xxxxxxxxxx
    javascript.0
    2021-12-26 01:17:17.921	info	script.js.Sigi.UWZ_DWD_NINA18: advance: Rufe Daten vom Server ab - UWZ Area: UWZATxxxx
    javascript.0
    2021-12-26 01:17:16.267	info	script.js.Sigi.UWZ_DWD_NINA18: info: [object Object]
    javascript.0
    2021-12-26 01:17:16.267	info	script.js.Sigi.UWZ_DWD_NINA18: info: 400
    javascript.0
    2021-12-26 01:17:16.267	info	script.js.Sigi.UWZ_DWD_NINA18: info: <?xml version="1.0" encoding="UTF-8"?><ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="2.0.0" xsi:schemaLocation="http://www.opengis.net/ows/1.1 https://maps.dwd.de/geoserver/schemas/ows/1.1.0/owsAll.xsd"><ows:Exception exceptionCode="NoApplicableCode"><ows:ExceptionText>java.lang.ClassCastException: Cannot cast java.lang.String to java.math.BigDecimalCannot cast java.lang.String to java.math.BigDecimal</ows:ExceptionText></ows:Exception></ows:ExceptionReport>
    javascript.0
    2021-12-26 01:17:16.267	info	script.js.Sigi.UWZ_DWD_NINA18: info: getDataFromServer() 5.
    javascript.0
    2021-12-26 01:17:16.148	info	script.js.Sigi.UWZ_DWD_NINA18: advance: Rufe Daten vom Server ab - DWD2 Area: Passau
    javascript.0
    2021-12-26 01:17:15.623	info	script.js.Sigi.UWZ_DWD_NINA18: advance: Rufe Daten vom Server ab - DWD Area: Passau
    javascript.0
    2021-12-26 01:17:15.623	info	script.js.Sigi.UWZ_DWD_NINA18: info: DWD aktivieren, Warncell vorhanden
    javascript.0
    2021-12-26 01:17:15.623	info	script.js.Sigi.UWZ_DWD_NINA18: info: Standalone ZAMG Datenabruf aktiviert
    javascript.0
    2021-12-26 01:17:15.623	info	script.js.Sigi.UWZ_DWD_NINA18: info: Standalone UWZ Datenabruf aktiviert
    javascript.0
    2021-12-26 01:17:15.623	info	script.js.Sigi.UWZ_DWD_NINA18: advance: MODE wurde geändert. MODE: 23 firstRun:true
    javascript.0
    2021-12-26 01:17:11.744	info	script.js.Sigi.UWZ_DWD_NINA18: registered 0 subscriptions and 0 schedules
    javascript.0
    2021-12-26 01:17:11.741	info	script.js.Sigi.UWZ_DWD_NINA18: info: Skripts gestartet: ID:1164.2114287450922
    javascript.0
    2021-12-26 01:17:11.713	info	Start javascript script.js.Sigi.UWZ_DWD_NINA18
    javascript.0
    2021-12-26 01:17:11.246	info	script.js.Sigi.UWZ_DWD_NINA18: info: Skripts gestoppt: ID:5306.327723286484
    ticaki
    #962
    @sigi234
    Zu dem anderen Problem. Ich weiß gerade nicht wo da der Wurm drin ist. Bei mir erstellen sich die States alle so wie es soll. Vielleicht solltest du
    var scriptOverrides = true;
    stellen, das skript 1 Minuten laufen lassen und es dann wieder auf false stellen. Und trage vorher deine warncelle für DWD ins Skript ein.
    Spenden
    sigi234S 2 Antworten Letzte Antwort
    • T ticaki
      @sigi234
      sigi234S Online
      sigi234S Online
      #963
      @ticaki sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
      Ok, finde für Passau nix?
      Hier eintragen?
      // Standalone Datenquelle
      /* nur Gemeinde/Landkreis/Großstädte werden verwendet: https://www.dwd.de/DE/leistungen/opendata/help/warnungen/cap_warncellids_csv.csv?__blob=publicationFile&v=3 */
      var dwdWarncellId = ''; // Deaktivieren mit ''
      var dwdBundesland = ''; // 3 Buchstaben
      UWZDE94032
      Bundesland ???
      • sigi234S sigi234
        Hier eintragen?
        UWZDE94032
        Bundesland ???
        ticaki
        #964
        @sigi234 sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
        var dwdWarncellId = '109262000';
        Bundesland wird nicht verwenden
        Spenden
        • T ticaki
          @sigi234
          sigi234S Online
          sigi234S Online
          #965
          Fehler ist weg, habe mal unter Config alles alte gelöscht.
          Edit:
          Doch nicht.
          avascript.0
          2021-12-26 10:45:48.575	info	script.js.Sigi.UWZ_DWD_NINA18: info: [object Object]
          javascript.0
          2021-12-26 10:45:48.575	info	script.js.Sigi.UWZ_DWD_NINA18: info: 400
          javascript.0
          2021-12-26 10:45:48.575	info	script.js.Sigi.UWZ_DWD_NINA18: info: <?xml version="1.0" encoding="UTF-8"?><ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="2.0.0" xsi:schemaLocation="http://www.opengis.net/ows/1.1 https://maps.dwd.de/geoserver/schemas/ows/1.1.0/owsAll.xsd"><ows:Exception exceptionCode="NoApplicableCode"><ows:ExceptionText>java.lang.ClassCastException: Cannot cast java.lang.String to java.math.BigDecimalCannot cast java.lang.String to java.math.BigDecimal</ows:ExceptionText></ows:Exception></ows:ExceptionReport>
          javascript.0
          2021-12-26 10:45:48.575	info	script.js.Sigi.UWZ_DWD_NINA18: info: getDataFromServer() 5.
            ticaki
            #966
            Bekannte Fehler:
            Ich hab gerade 6 Aufgehoben Meldung bekommen. Kann mich aber die nächsten Tage nicht darum kümmern.
            Spenden
            • T ticaki
              Bekannte Fehler:
              sigi234S Online
              sigi234S Online
              #967
              @ticaki
              Verwirrend:
              //UWZ - Landeskennung - Postleitzahl UWZDE12345
              var uwzWarncellId = 'UWZATXXXXX'; // Deaktivieren mit ''
              Warum DE?
              Für Deutschland sieht die ID so aus: 'UWZDE12345' UWZDE + PLZ
              UWZDE + PLZ - für was?
              var dwdWarncellId = '109262000'; // Deaktivieren mit ''
              Angeben entnehme ZAHL aus CSV
              • T ticaki
                Bekannte Fehler:
                sigi234S Online
                sigi234S Online
                #968
                Bekannte Fehler:
                Dito, bekomme 3
                • sigi234S sigi234
                  @ticaki
                  Verwirrend:
                  Warum DE?
                  ticaki
                  #969
                  uwzWarncellId
                  Hab das verbessert.
                  Jedoch uwzWarncellId wird nicht mehr verwendet. geht jetzt alles über regionname. Wenn das alles funktioniert, werde ich aufräumen und die Kommentare verbessern
                  Spenden
                  • T ticaki
                    uwzWarncellId
                    Hab das verbessert.
                    sigi234S Online
                    sigi234S Online
                    #970
                    uwzWarncellId
                    Hab das verbessert.
                    Jupp, wenn alles ok ist werde ich mal das komplette Skript verwenden ohne Update ab 123456 und vorher alle DP in den Objekte löschen.
                    • T ticaki
                      Deprecated
                      Wird zum Adapter weiterentwickelt und es finden keine Verbesserungen oder Fehlerbehebungen mehr statt. Abgesehen von kritischen.
                      https://forum.iobroker.net/topic/68595/test-adapter-weather-warnings
                      Das Script:
                      Script auf Github
                      DWD-UWZ-NINA-Pushwarnungen-iobroker
                      Vorbemerkung
                      Diese Anleitung ist schon seit längerem nicht überarbeitet worden, daher nicht ganz aktuell.
                      Das Skript mit dem anhang beta, wird zur dieser Zeit (08/2023) überarbeitet, da gibt es immer wieder unkommentierte Änderungen. Die Konfiguration wird in diesem ebenfalls immer mal wieder angepasst, so das ein einfaches Copy&Paste nicht ausreicht. Könnt ihr gerne testen, aber es ist expliziert eher ALPHA als beta.
                      Support
                      Supportthread: Iobroker Forum
                      Scriptbeschreibung
                      Mit diesem Script kannst du Warnungen des Deutschen Wetterdienstes, der Unwetterzentrale, der Zentralanstalt für Meteorologie und Geodynamik(Österreich) oder von Nina (Notfallinformationssystem der BRD) als Text oder Sprachausgabe über verschiedene Wege ausgeben. Dieses geschieht entweder automatisch nach dem Eintreffen oder nach Betätigen eines Schalters.
                      Für DWD, Zamg und UWZ gibt es Datenpunkte um bei bestimmten Gefahren selbst gesteuerte Aktionen auszuführen. Letzteres nutze ich z.B. um bei Sturm/Regen und offenen Fenstern auf diese hinzuweisen.
                      Unterstützt:
                      • Telegram, Pushover, Home24-Mediaplayer, SayIt, Alexa, Datenpunkt, eMail oder Whatsapp
                      • Standalone Datenabruf für DWD, NINA, UWZ und Zamg
                      • Wetterwarnung
                      • Wetterentwarnung
                      Funktionen:
                      • Filter die Warnungen nach doppelt, Gefahr(level) und Höhe
                      • Umschalten über iobroker zwischen DWD/UWZ/NINA
                      • Automatischer Versand und/oder manueller Nachrichtenversand (in Lang- oder Kurzform)
                      • Zeitschaltuhr für Sprachausgabe
                      • Datenpunkte mit der Startzeit, Endzeit, Type, Schlagzeile, Beschreibung, Farbe für Level(bgcolor) und höchstem Warnlevel dieses Typs
                      • Datenpunkthauptpfade sind konfigurierbar incl. 0_userdata
                      • Konfigurationsprüfung soweit möglich
                      • Automodus und einzelne Pushdienste über iobroker schaltbar, sowohl für Automodus als auch Manuell
                      • Optimierte Sprachausgabe
                      Kleinkram:
                      • Sprachausgabe: Sturmdetails werden ausgefiltert oder korrekt ausgesprochen (konfigurierbar)
                      • Sprachausgabe: Pause zwischen dem Absenden der einzelnen Warnungen an die Wiedergabeeinheit konfigurierbar.
                      • Manuelle Sprachnachrichten können die Zeitschaltuhr missachten. (konfigurierbar)
                      • Multi-User/Device bei fast allen Pushdiensten verfügbar (außer Datenpunkt & pushover & whatsapp)
                      • Autorestart bei Datenpunkterstellung
                      • Alexa und SayIt mit Lautstärkeeinstellung. Alexagruppen unterstützen keine Lautstärke trotzdem konfigurieren.
                      • Zusätzliche Hervorhebung konfigurierbar über attentionWarningLevel (im Betreff/Ansage)
                      • Filter für Nina-sender
                      • Namesbezeichner für Nina verfügbar, diese werden benötigt, falls in der Warnung Ort genannt wird, das auszugeben und damit die Bedeutung der Warnung hervorzuheben.
                      Dank an:
                      • Mic für die createUserStates() Funktionen
                      • CruziX der diese eingebaut hat.
                      • crunchip, sigi234, Latzi fürs Testen und Ideen
                      • die ursprünglichen Authoren s.o. (im Skript)
                      Bedeutung der Farben:
                      • 0 - Grün
                      • 1 - Dunkelgrün (wobei tails entfernt)
                      • 2 - Gelb Wetterwarnungen (Stufe 2)
                      • 3 - Orange Warnungen vor markantem Wetter (Stufe 3)
                      • 4 - Rot Unwetterwarnungen (Stufe 4).
                      • 5 - Violett Warnungen vor extremem Unwetter (DWD -> Weltuntergang nach aktueller Erfahrung und Nina -> höchste Stufe
                      Vorbemerkung zur Konfigurationen
                      Update: Das Skript wird in Zukunft keine externen Adapter mehr benötigen oder unterstützen.
                      Das Skript und die Dokumentation wurden zu erst nur für externe Adapter geschrieben, daher beziehen sich vieles auf die Zusammenarbeit mit diesen. Wenn ihr den integrierten Datenabruf verwenden wollt, findet ihr unter Objekten im Unterverzeichnis
                      0_userdata.0.wetterwarnung1.config.basiskonfiguration.warnzelle
                      Die Warnzellen die verwendet werden. Ihr könnt dort Warnzellen hinzufügen und entfernen. Im Unterschied zu allen anderen Datenpunkten die sich über die Objekte verändern lassen, überschreiben die Änderungen dort jedoch nicht die Einstellungen im Skript. Wenn das Skript gestartet wird, werden alle im Skript definierten Warnzellen dort eingetragen, anschließend werden alle dort eingetragenen Warnzellen vom Skript eingelesen und verwendet. Folglich könnt ihr keine Warnzellen löschen die im Skript definiert sind. Folgenden Variablen werden für die Definition von Warnzellen verwendet.
                      Update: Das wird alles über Datenpunkte erledigt
                      Konfiguration in ioBroker/Objekte unter mainStatePath.config
                      1. DWD/UWZ/NINA auf true stellen um den jeweiligen Modus zu aktiveren.
                      2. Mode ist aus Kompatibilitätsgründen drin und kann als Zeichenkette UWZ usw enthalten.
                      3. Punkte unter .auto aktiveren oder deaktivieren den automatischen Versand von Warnmeldungen.
                      • .on schaltet den kompletten automatischen Versand an/aus.
                      • die Restlichen schalten für einen bestimmten Modus eine bestimmte Art an oder aus.
                      1. Punkte unter manuell schalten für das manuelle Auslösen in einem bestimmten Modus die Möglichkeit an oder aus. (z.B. UWZ über alexa aber NINA nicht).
                      Vorbereitung bei der Verwendung von NINA bei Verwendung des externen Adapters
                      • mindestens v0.0.22
                      • in der Adapterkonfiguration diesen Punkt aktivieren: Json der Warnung in den State rawJson speichern (erhöhter Speicherbedarf)
                      Konfiguration bei Verwendung des Skript internen Datenabrufs für DWD, ZAMG, UWZ, NINA (keine anderen Adapter nötig)
                      • für UWZ konfiguriert regionName. [['UWZ + DE + PLZ','Mein Ort']]
                      var regionName          = [['','']];// var regionName = ['UWZDE13245', 'Entenhausen']
                      -die Warncelle ist die Zahl in der linken Spalte: https://www.dwd.de/DE/leistungen/opendata/help/warnungen/cap_warncellids_csv.csv?__blob=publicationFile&v=3
                      // entnehme ZAHL aus CSV
                      var dwdWarncellId = ''; // Deaktivieren mit '' einzel: '2334535354' mehrere: ['23423424','23423423']
                      • Bei Zamg einfach die Koordinaten eingeben (müssen in Österreich liegen)
                      // Koordinaten [{laengen:13.05501,breiten:47.80949}];.
                      var zamgCoordinates = []; // [] ist deaktiviert
                      var uZAMGMitMeteoinformationen = true; // gibt die Wetterinformationen mit der Beschreibung aus: z.B Eine Kaltfront und ein Italientief sorgen im Warnzeitraum...
                      • Für Nina ebenfalls die Koordinaten eingeben (müssen in Deutschland liegen)
                      // für Nina gebt die Koordinaten für euren Ort ein.
                      ninaCoordinates = [] //   ninaCoordinates = [{breiten:51.2277, laengen:6.7735, text:'dadrüben'}, {breiten:53.0511000, laengen:8.6309100, text:'Delmenhorst'}];
                      Konfigurationsparameter NACH dem ersten Start
                      • DWD/UWZ/NINA muß gesetzt werden, ist alles deaktiviert.
                      • Anschließend die Einstellungen unter 0_userdata.0.wetterwarnung.config.auto und 0_userdata.0.wetterwarnung.config.manuell kontrollieren. Mit diesen könnt ihr einstellen das z.B DWD über Alexa und Email ausgegeben wird, Nina hingegen nur über Email
                      • Nach dem ersten Start werden Datenpunkte erstellt, die in Zukunft zur Konfiguration genutzt werden und die Werte im Skript überschreiben. Diese findet ihr unter config
                      Konfigurationsparameter Script
                      Konfigurationsparameter vor dem ersten Start
                      1. Der Datenpfad zu allen von diesem Script erstellten Datenpunkten.
                      var mainStatePath = 'javascript.0.wetterwarnung_test.';
                      // oder
                      var mainStatePath = '0_userdata.0.wetterwarnung.';
                      1. Aktiveren der Ausgabemöglichkeiten. Es muß mindestens 1 Punkt aktiviert sein.
                        Zu den jeweiligen Optionen muß der entsprechende Adapter installiert werden und eventuell im folgenden noch weitere Konfigurationen vorgenommen werden.
                      //uPushdienst+= TELEGRAM;
                      //uPushdienst+= PUSHOVER;
                      //uPushdienst+= EMAIL;
                      //uPushdienst+= SAYIT;
                      //uPushdienst+= HOMETWO;  // kein Adapter nötig
                      //uPushdienst+= ALEXA;
                      //uPushdienst+= STATE;    // kein Adapter nötig
                      //uPushdienst+= IOGO;
                      Um einen Punkt zu aktiveren entferne die //
                      z.B.
                      Konfigurationsparameter Allgemein
                      • Stellt uLogAusgabe auf 0 wenn alles so läuft wie ihr euch das vorstellt.
                      var uLogAusgabe=        2; // auf 0 gibt es überhaupt keine Ausgabe beim normalen Betrieb.
                      • Mit Hilfe dieser Variablen bestimmt ihr ob Email, Textnachrichten oder Sprachnachrichten voreingestellt ohne Beschreibung (false) und/oder Anweisungen (false) versand werden.
                      var uSpracheMitBeschreibung         = true; // gilt für alle Sprachnachrichten
                      var uSpracheMitAnweisungen          = true; // uSpracheMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
                      var uHtmlMitBeschreibung            = true; // gilt für Email
                      var uHtmlMitAnweisungen             = true; // uHtmlMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
                      var uTextMitBeschreibung            = true; // gilt nicht für Email, aber für alle anderen Textnachrichten
                      var uTextMitAnweisungen             = true; // uTextMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
                      uTextHtmlMitOhneAlles               = false // diese beiden Optionen überschreiben alle oben getroffenen Einstellungen
                      var uSpracheMitOhneAlles            = true;
                      • MitOhneAlles folgendes Muster: Warnung vor Typ, für Region, Stufe: Farbe, Tag Tageszeit
                      • Beispiel: Warnung vor Sturm für Köln, Stufe: gelb, heute abend
                      Sprachausgabe weitere Einstellungen
                      • Wenn die Sprachausgabe manuell ausgelöst wird, kann die Sprachausgabewarteschlage gelöscht (true) oder die abgerufenen Nachrichten angehangen werden (false).
                      var uManuellClickClearSpeakMessageList = true;
                      • Die Sprachausgabe kann die Details zur Windgeschwindigkeit ausblenden (false) oder aussprechen (true)
                      var windForceDetailsSpeak   = false;
                      • Ab wieviel Uhr darf die Sprachausgabe verwendet werden (Mo-Fr)
                      var startTimeSpeak =        '6:45';
                      • Ab wieviel Uhr darf die Sprachausgabe am Wochenende verwendet werden (Sa-So)
                      var startTimeSpeakWeekend = '9:00';
                      • Wann endet die Sprachausgabeabends
                      var endTimeSpeak =          '22:30';
                      • Das manuelle Auslösen der Sprachausgabe berücksichtigt die Zeitschaltuhr (false) es ignoriert sie (true)
                      var forcedSpeak             = true;
                      Filtermöglichkeiten für Warnungen
                      1. minlevel hiermit bestimmt man ab welchem Level Warnungen von diesem Skript berücksichtigt werden. Dieser Wert sollte nicht höher als 3 eingestellt sein.
                      const minlevel                      =    1
                      1. attentionWarningLevel Warnungen gleich/über diesem Wert werden extra hervorgehoben. Die Überschriften zeigen auf Gefahr hin. Pushover-Nachrichten werden mit höherer Prioritätversand. Alle internen nicht einstellbaren Filter/ Filter die im 2. Konfigurationsabschnitt stehen übergehen diese Warnung.
                      const attentionWarningLevel         =    4
                      1. Warnungen von DWD und UWZ kommen gelegentlich mit einer von/bis Höhenangabe.
                      • Tragt bitte hier die Höhe des tiefesten Punktes in eurem Gebiet ein, den ihr in eurem täglichen Leben aufsucht. In meiner Region kommen Meldungen eher selten mit dem "bis" Eintrag.
                      const minhoehe                      =    0
                      • Hier den höchsten Punkt. Dieser wird mit dem "von" Eintrag verglichen. Ich nehme die Höhe meines Ortes 350m +/- 100m
                      const maxhoehe                      =    5000
                      Konfigurationsparameter für Pushmöglichkeiten
                      • optionale Punkte brauchen nicht angepasst zu werden, wenn die Möglichkeit oben aktiviert wurde.
                      • nicht optionale Punkte müssen angepasst/überprüft werden, wenn die Möglichkeit oben aktiviert wurde.
                      Einstellungen zu Telegram: (optional)
                      • Stelle hier Optional bestimmte Nutzer oder ChatID ein. Einzelnutzer ['Hans']; Multinutzer ['Hans', 'Gretel']; Nutzer vom Adapter übernehmen [];
                      • Die Instanz nur anpassen, wenn deine davon abweicht. Das gilt für jede Instanzeinstellung
                      var telegramUser        = [''];
                      var telegramChatId      = [''];
                      var telegramInstanz     = 'telegram.0';
                      eMail: (optional)
                      • Stelle hier Optional 1 Emailadresse ein, von der versendet wird, und mehrere Emailadressen die empfangen sollen.
                      var senderEmailID       =   [""];// 1 Eintrag erlaubt [] oder ["email1"]
                      var empfaengerEmailID   =   [""];// Mehrere Empfänger möglich. [] oder ["email1"] oder ["email1","email2"]
                      var emailInstanz        =   'email.0';
                      Pushover: (optional)
                      • DeviceName, hier könnt ihr eines der angemeldeten Gerät bestimmen, das die Nachrichten erhalten soll. Ist kein Gerät bestimmt bekommen alle die Nachricht.
                      • uPushoverSound bietet euch die Möglichkeit einen eigenen Sound für die Nachricht auszuwählen. Was ihr dort eintragen könnt findet ihr dort: https://pushover.net/api#sounds
                      var uPushoverDeviceName     = '';
                      var uPushoverSound          = '';
                      var pushoverInstanz         = 'pushover.0';
                      ioGo (optional)
                      • ioGoUser: Tragt keinen, einen, oder mehrere "ID des Gerätes" ein.
                      var ioGoUser = [''];
                      Home24:
                      • Das ist ungetestet, benutzt besser SayIt. Eingabe IP-Adresse incl. Port für Home24-Mediaplayer mehrere möglich
                      var idMediaplayer       = ["192.168.178.x:Port"]; // (muß einen sinnvollen Wert beinhalten, wenn aktiviert)
                      SayIt
                      • idSayIt muß korrekt ausgefüllt sein, mit dem Datenpfad zum .text Datenpunkt, mehrere möglich.
                      • sayItVolumen muß die gleiche Anzahl an Einträgen haben wie idSayIt 0-100
                      var idSayIt             = ["sayit.0.tts.text"]; // (muß einen sinnvollen Wert beinhalten, wenn aktiviert)
                      var sayItVolumen        = [30]; // gleiche Anzahl wie idSayIt
                      Alexa
                      • idAlexaSerial beinhaltet die Seriennummer deines Echos/deiner Echos. var idAlexaSerial =['G090RV32984110Y', 'G090RV32984110Y'];
                      • alexaVolumen 0-100 die gleiche Anzahl wie idAlexaSerial z.B. [30,30];
                      var idAlexaSerial       = [''];
                      var alexaVolumen        = [30];
                      var alexaInstanz        = 'alexa2.0';
                      Konfigurationsparameter zu den Modi DWD, UWZ, NINA
                      1. Einstellungen zur Unwetterzentrale/UWZ:
                        Hier gibts du die UWZ RegionID an. Also z.B. UWZDE12345 und den Namen deines Ortes z.B. Entenhausen.
                      var regionName          = [['UWZDE12345','Entenhausen']];
                      1. Einstellungen zu Nina
                      • Hier stellt bitte euren Ort und euren Landkreis ohne (Kreis, Landkreis, etc) ein. Warnungen von Nina kommen mit Aufgelisteten Orten, das Skript sucht dort drin nach euren Bezeichnern und gibt den gefundenen in der Warnung mit aus.
                      var uGemeinde = '';
                      ## Support
                      - Findet ihr: https://forum.iobroker.net/topic/30616/script-dwd-uwz-nina-warnungen-als-push-sprachnachrichten/216
                      [s=DWD/UWZ/NINA Script überarbeitet von ticaki]
                      [Script auf Github](https://github.com/ticaki/DWD-UWZ-NINA-Pushwarnungen-iobroker)
                      [/s]
                      sigi234S Online
                      sigi234S Online
                      #971
                      @ticaki
                      Hallo, warum bekomme ich einen Log obwohl das Skript gestoppt ist?
                      • sigi234S sigi234
                        @ticaki
                        ticaki
                        #972
                        @sigi234
                        Scriptadapter neustarten. Das Skript ist zu groß und wenn du das zügig stopps und wieder startest laufen mehrere Instanzen. Deshalb ist diese RandomID im Debug drin. z.B. Kann das erstellen und löschen alle States die für Alert benötigt werden gut 6 Minuten dauern... Löschen von States ist mit Admin 5 wirklich schrecklich langsam.
                        Ich baue in der nächsten Version in diese langen Prozesse einen Notausstieg ein.
                        Spenden
                        • J Offline
                          jensus11
                          #973
                          wenn ich unter commands manuell Sayit auslöse, dann sollte doch ne eine Ausgabe über das eingestellte Ausgabegerät erfolgen oder?
                          Bei mir wird leider keine Sprachausgabe gemacht. Sayit funktioniert aber mit anderen Scripten.
                          Wollte gerne mal ne Testung machen.
                          T sigi234S 2 Antworten Letzte Antwort
                          • J jensus11
                            ticaki
                            #974
                            @jensus11
                            es sollte in den Datenpunkt der hier hinterlegt ist
                            geschrieben werden
                            Spenden
                            • J Offline
                              jensus11
                              #975
                              das wird auch gemacht. Dachte das muss dann auch über den Browser ausgegeben werden beim Testen.
                              • J jensus11
                                ticaki
                                #976
                                @jensus11
                                Ich benutze das leider nicht, daher weiß ich nicht was alles geht.
                                Spenden
                                • J jensus11
                                  sigi234S Online
                                  sigi234S Online
                                  #977
                                  @jensus11 sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                                  Geht bei mir, Lautstärke im Skript erhöht?
                                    ticaki
                                    #978
                                    //Version 0.99.25 Beta 3
                                    • schedule beenden sich auf jeden Fall.
                                    • längere Async Funktionen brechen ab beim Beenden.
                                    • Alert verbessert
                                    • Warngruppenfilterung verbessert.
                                    Bin mir nicht ganz klar, welche await fFnktionen auch nach dem beenden des Skripts nochmal code aufrufen und welche nicht. Deshalb lieber etwas mehr als zuwenig.
                                    Spenden
                                      ticaki
                                      #979
                                      Könnte etwas mehr Feedback vertragen zu den neuen Telegramfunktionen und den sehr kurzen Versionen.
                                      Baue gerade die sehr kurze Entwarnung ein. Und da hab ich aktuell 2 in der näheren Betrachtung:
                                      Warnung vor Kälte wurde aufgehoben
                                      Entwarnung vor Kälte
                                      Ersteres hört sich schöner an ist aber länger, bei letzterem stört mich das vor
                                      aktuell hab ich das jetzt so in meiner Version:
                                      Warnung vor Typ, für Stadt, Stufe: Farbe, Tag Tageszeit
                                      Entwarnung vor Typ, für Stadt
                                      , bedeutet kurze Pause.
                                      Spenden
                                      LatziL sigi234S 2 Antworten Letzte Antwort
                                      • T ticaki
                                        LatziL Online
                                        LatziL Online
                                        Latzi
                                        #980
                                        @ticaki
                                        Ich habe eben eine neue ZAMG-Warnung erhalten, Alexa gibt folgendes zum Besten:
                                        Wetterwarnung vor Glatteis, Stufe gelb, ab  Uhr nachmittag  Insgesamt eine aktive Warnung.
                                        Es fehlt die Uhrzeit bei der Kurzversion.
                                        • T ticaki
                                          sigi234S Online
                                          sigi234S Online
                                          #981
                                          Kältewarnung aufgehoben
