  4. [Frage] Xiaomi Vacuum cleaner
    6.3k
2.2k Beiträge 204 Kommentatoren 1.2m Aufrufe 39 Beobachtet
    skorpil
    #347
    zu Deiner Frage: nein, es hatte noch nicht funktioniert. Ich hatte es auch noch nicht probiert. Habe die main.js gerade runtergeladen. Den Adapter neu gestartet. Hier das log:
    mihome-vacuum.0
    2017-03-14 18:26:52.441
    info
    Empfangen <<< Helo <<< 2131002000000000034c8a8258c827dcffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2017-03-14 18:26:32.529
    info
    Empfangen <<< Helo <<< 2131002000000000034c8a8258c827c8ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2017-03-14 18:26:27.556
    info
    token:784f70576b655379304e4444757a3375
    mihome-vacuum.0
    info
    checksum:5135aeedc439c402865571bb065460e4
    mihome-vacuum.0
    info
    key:327f9ad4a4cee2956f4dcd28ea716a67
    mihome-vacuum.0
    info
    iv:13ce4088d423c6d421f0da7f61990790
    mihome-vacuum.0
    2017-03-14 18:26:27.555
    info
    2131005000000000034c8a8258c827c35135aeedc439c402865571bb065460e4b4715d1f2ae4a84256b30ed211656521994332e59f50ae4d313f1e21115ff59db26e245625ccd6bd7561daccd060fdd6
    mihome-vacuum.0
    info
    mihome-vacuum.0
    info
    Sende >>> {"id":6432,"method":"app_start"} >>> 2131005000000000034c8a8258c827c35135aeedc439c402865571bb065460e4b4715d1f2ae4a84256b30ed211656521994332e59f50ae4d313f1e21115ff59db26e245625ccd6bd7561dacc
    mihome-vacuum.0
    2017-03-14 18:26:27.554
    info
    {"id":6431,"method":"app_start"}
    mihome-vacuum.0
    2017-03-14 18:26:27.552
    info
    Empfangen <<< Helo <<< 2131002000000000034c8a8258c827c3ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2017-03-14 18:26:27.518
    info
    Sende >>> Helo >>> 21310020ffffffffffffffffffffffffffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2017-03-14 18:26:14.249
    info
    mihome-vacuum.0
    info
    checksum:ee26c61207bb61924b9081a433454ce6
    mihome-vacuum.0
    2017-03-14 18:26:14.248
    info
    mihome-vacuum.0
    info
    mihome-vacuum.0
    info
    2131005000000000034c8a8258c827b6ee26c61207bb61924b9081a433454ce67da2a5e7a4f4b579ee18fc80e9a8e7f9b4e21bd6d02d4a26ede5727ce7fb5ae3d69e32a7d9b820cfe0a2c08f7c438e14
    mihome-vacuum.0
    info
    mihome-vacuum.0
    2017-03-14 18:26:14.247
    info
    Sende >>> {"id":6431,"method":"app_start"} >>> 2131005000000000034c8a8258c827b6ee26c61207bb61924b9081a433454ce67da2a5e7a4f4b579ee18fc80e9a8e7f9b4e21bd6d02d4a26ede5727ce7fb5ae3d69e32a7d9b820cfe0a2c08f
    mihome-vacuum.0
    2017-03-14 18:26:14.246
    info
    {"id":6430,"method":"app_start"}
    mihome-vacuum.0
    2017-03-14 18:26:14.243
    info
    Empfangen <<< Helo <<< 2131002000000000034c8a8258c827b6ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2017-03-14 18:26:14.135
    info
    mihome-vacuum.0
    2017-03-14 18:26:12.401
    info
    Empfangen <<< Helo <<< 2131002000000000034c8a8258c827b4ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2017-03-14 18:25:52.432
    info
    Empfangen <<< Helo <<< 2131002000000000034c8a8258c827a0ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2017-03-14 18:25:32.530
    info
    Connected
    mihome-vacuum.0
    2017-03-14 18:25:32.527
    info
    Empfangen <<< Helo <<< 2131002000000000034c8a8258c8278cffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2017-03-14 18:25:32.313
    info
    starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v4.8.0
    host.raspberrypi
    2017-03-14 18:25:30.904
    info
    instance system.adapter.mihome-vacuum.0 started with pid 9493
    host.raspberrypi
    2017-03-14 18:25:30.875
    info
    object change system.adapter.mihome-vacuum.0
    host.raspberrypi
    2017-03-14 18:25:20.337
    info
    instance system.adapter.mihome-vacuum.0 terminated with code 0 (OK)
    • MeistertrM Offline
      MeistertrM Offline
      Meistertr
      #348
      Der Token ist richtig?
        skorpil
        #349
        Ich denke schon. Denn der Adapter zeigt ja grün, d.h. er läuft. Und ich kriege ja auch die helo Nachrichten
          MeistertrM Offline
          Meistertr
          #350
          @skorpil:
          Ich denke schon. Denn der Adapter zeigt ja grün, d.h. er läuft. Und ich kriege ja auch die helo Nachrichten `
          Das hat nichts mit dem token zu tun, der Adapter wird grün, wenn er die Helo Nachricht verschicken und epmfangen, hierfür wird der token jedoch nciht benötigt
            skorpil
            #351
            ok, dann hatte ich das falsch verstanden.
            Den Token generiere ich durch folgende Prozedur:
            ` > Token Vorgehen:
            1. Um den Token des Roboters zu bekommen, muss man ihn erstmal aus dem Wlan abmelden.
            Dies geht entweder über die app unter den Einstellungen des Gerätes
            (genauer kann ich es nicht beschreiben weil ich kein Chinesisch kann).
            Da steht Remove Device, über diesen Punkt kann man das Gerät Entfernen
            Alternativ kann man auch den Resetknopf am Gerät drücken.
            2. Nun verbindet man sich mit seinem Windows Rechner mit dem Wlan des Roboters
            Wlan: rockrobo…
            3. Programm Packet Sender
            Bei HEX gibt man die folgende Nachricht ein:
            (=HALO Nachricht)
            4. IP Vacuum 192.168.8.1, Port 54321, Nachrichtentyp UDP
            5. Packet senden.
            Fenster unten: a) gesetzte Nachricht
            b) darüber die Antwort von dem Roboter
            6. die letzten 16 Byte der Token `
            Richtig?
            Das würde ich dann im Laufe des Abends nochmal machen. Ich hatte es schon gemacht. Danach gab es neue updates. Vlt. gibt es dann auch einen neuen Token?
              MeistertrM Offline
              Meistertr
              #352
              vollkommen richtig, oder alternativ über die app die schon einige male beworben wurde in der config cfg aber das vorgehen ist nahezu identisch nur das mann keinen Paketsender braucht aber dafür die config suchen muss :) oder über das xpn.py sollte es auch gehen xpn -info glaube ich wenn der pc mit dem robo verbunden ist, viele wege führen scheinbar nach Rom.
                skorpil
                #353
                xpn.py habe ich nicht und weiß auch gar nicht, was das ist. Ergo: ich werde das mit dem paker Sender nachher noch einmal machen Bitte etwas Geduld. ich melde mich dann mit neuen Infos.
                  skorpil
                  #354
                  MeisterTr,
                  Das war es. Der Token! Warum und wann er sich geändert hat, ich weiß es nicht. Vlt. die Software updates.
                  Probiert habe ich eben das Start Kommando. Und das hat funktioniert.
                  Ich habe dann noch ein find bzw. Go Home gesendet. Das hat nicht geklappt. Aber das teste ich in Ruhe nochmal und melde mich mit dem Befund.
                    skorpil
                    #355
                    So, jetzt habe ich find, Pause und go home nochmal getestet. Klappt! Der go Home Befehl jedoch nur mit vorherigem Pause Befehl.
                    Als Anregung: damit jetzt das log nicht voll läuft mit den vielen Mihome infos könnte man vielleicht irgendwo in der Instanz einen debug button unterbringen, der dann die Infos auslöst.
                    Ich muss sagen, ich bin begeistert. Danke, gst666 u. Meistertr.
                    • G Offline
                      gst666
                      #356
                      So, nachdem der Adapter erst mal läuft geht es um die Weiterentwicklung. Ich habe für den Air Purifier die Weiterentwicklung schon so weit getrieben, dass er auch Antworten auswertet und den State, ob das Gerät läuft auch wieder ausliest. Damit ist eine parallele Benutzung mit der App (oder auch anderen Apps) möglich.
                      Für den Vacuum werde ich das dann auch entsprechend machen.
                      Daneben würde ich gerne das Widget anpassen. Meine konkreten Vorstellungen lasse ich noch etwas reifen und werde sie dann posten.
                      Spannend ist aus meiner Sicht, ob wir die Abfrage aus der Cloud eventuell auch nachbilden können. Das ist deswegen interessant, da wir dann den Token ohne Umwege gewinnen können. Wer schon mal etwas forschen möchte ist herzlich hiermit aufgefordert. Auch hier kann ich mir einen gemeinsamen Hacker-Tag vorstellen. Die Cloud brauchen wir eigentlich nur beim Starten des Adapters um den Token abzufragen. Das wird aber für den Normalbenutzer besonders wichtig sein.
                      Bezüglich dem Verbindungsstatus überlege ich, diesen insoweit abzuändern, als dass der Adapter erst dann grün anzeigt, wenn auch Statusnachrichten abgefragt werden können. Dann wissen wir nämlich, dass der Token richtig ist. Seht ihr das genauso?
                      Gruß Gerhard
                        skorpil
                        #357
                        Jawohl.
                        Und da ich ja inhaltlich nur begrenzt beitragen kann, bin ich gerne bereit, eine Beschreibung zur Nutzung des Adapters zu schreiben.
                        Noch eine Laienfrage, die aber für die Beschreibung wichtig wäre: greift der Adapter eigentlich noch auf Python zu? Wenn ja, dann muss ja Python und ggf. die entsprechenden Python Programme auch vorher installiert werden.
                          MeistertrM Offline
                          Meistertr
                          #358
                          @gst666:
                          Gruß Gerhard `
                          wenn du mir die Dateien zur Verfügung stellst von deinem Airfilter, dann kann ich die gerne für den Roboter Anpassen, habe damit heute auch schon angefangen aber in zwei verschiedene Richtungen laufen macht da ja wenig sinn.
                          mit freundlichen Grüßen Tobi
                          • BluefoxB Offline
                            BluefoxB Offline
                            #359
                            Gibt es Anleitung oder ist das selbstverständlich?
                            Mir ist nicht ganz klar, wo kommt der Token her.
                              skorpil
                              #360
                              Bluefox, schau mal meinen Post 351
                                MeistertrM Offline
                                Meistertr
                                #361
                                @Bluefox:
                                Mir ist nicht ganz klar, wo kommt der Token her. `
                                Der Token wird vom Roboter generiert und nur im Werkszustand (reset) vom roboter gesendet, Er sendet den token als antwort auf die Helo Nochricht
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  #362
                                  @Meistertr:
                                  @Bluefox:
                                  Mir ist nicht ganz klar, wo kommt der Token her. Der Token wird vom Roboter generiert und nur im Werkszustand (reset) vom roboter gesendet, Er sendet den token als antwort auf die Helo Nochricht
                                  D.h. ich muss den Roboter ins Werkzustand bringen,
                                  dann mit dem ein bisschen reden,
                                  dann den Roboter ins mein Netzwerk bringen und dann geht es.
                                  so?
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #363
                                    @Bluefox:
                                    Es ist komisch, dass bei dir nicht geht. Das Modul hat überhaupt keine Abhängigkeiten.
                                    Trotzdem kann man probieren (als Admin):
                                    npm install --global --production windows-build-tools
                                    npm install --global node-gyp --force
                                    cd c:\ioBroker
                                    npm i https://github.com/ioBroker/ioBroker.mihome-vacuum/tarball/dev --production --force
                                    @bluefox
                                    Die ersten beiden Befehle sind einwandfrei durchgelaufen.
                                    Bei dem letzten Befehl (install mihome) wieder Fehlermeldung:
                                    Sorry: Konnte die jpg nicht hochladen !!
                                    Es kommt beim Erstellen dieser Antwort:
                                    "Das Kontingent für Dateianhänge ist bereits vollständig ausgenutzt"
                                    Was soll das nun wieder.
                                    Fazit:
                                    Installation klappt nicht
                                    jpg lassen sich im Forum nicht mehr hochladen.
                                    grrrrrrrr.
                                    Ich glaub ich geh ins Bett. Klappt heute nichts mehr.
                                    mfg
                                    Danke.
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      #364
                                      @bahnuhr:
                                      @Bluefox:
                                      cd c:\ioBroker
                                      @bluefox
                                      Fazit:
                                      grrrrrrrr.
                                      mfg `
                                      Ich habe jetzt Quota erhöht. Es gab 1GB Attachments insgesamt :)
                                      • bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        #365
                                        @bluefox
                                        filename="bild1.jpg" index="0">~~
                                        Die Instanz bleibt gelb.
                                        Danke.
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          #366
                                          @bahnuhr:
                                          @bluefox
                                          Die Instanz bleibt gelb. `
                                          Das sind die FehlerMeldungen von was anderem.
                                          Was ist iobroker.core? Das ist doch CCU.IO2 die im August 2014 war und nie weiterentwickelt wurde.
                                          Bitte per Hand dein node_modules reinigen. Auch admin, lib, tasks tests Widgets haben in node_modules nichts verloren.
                                          Hast du Token bekommen? Hast du dein Roboter reseted?
