Test Adapter nanoleaf-lightpanels v1.3.x GitHub/latest
@badsnoopy667
Ja, gerne.
Du könntest mal ein GET auf folgenden Endpoint machen und mir die Response schicken, dann kann ich die Elements hinzufügen:http://<IP-des-Geräts>:16021/api/v1/<Auth-Token>
@daniel_2k said in Test Adapter nanoleaf-lightpanels v1.2.x GitHub/latest:
Hab' auch gerade vor ein Paar Minuten festgestellt, dass die Elements offensichtlich nicht zu 100% unterstützt werden. Hier die Antwort:
{"name":"Elements 1692","serialNo":"S21240E6358","manufacturer":"Nanoleaf","firmwareVersion":"5.2.4","hardwareVersion":"1.1-0","model":"NL52","discovery":{},"effects":{"effectsList":["Bloom","Calming Waterfall","Clouds","Ember","Fireflies","Glimmer","Sahara Night","Splash","Sunbeam","Warm Waves"],"select":"Sahara Night"},"firmwareUpgrade":{},"panelLayout":{"globalOrientation":{"value":0,"max":360,"min":0},"layout":{"numPanels":7,"sideLength":0,"positionData":[{"panelId":4765,"x":182,"y":84,"o":360,"shapeType":15},{"panelId":8415,"x":156,"y":41,"o":300,"shapeType":15},{"panelId":45086,"x":106,"y":41,"o":240,"shapeType":15},{"panelId":16734,"x":81,"y":84,"o":180,"shapeType":15},{"panelId":53663,"x":106,"y":128,"o":120,"shapeType":15},{"panelId":59863,"x":156,"y":128,"o":60,"shapeType":15},{"panelId":0,"x":190,"y":50,"o":240,"shapeType":12}]}},"schedules":{},"state":{"brightness":{"value":100,"max":100,"min":0},"colorMode":"effect","ct":{"value":4000,"max":4000,"min":1500},"hue":{"value":0,"max":360,"min":0},"on":{"value":false},"sat":{"value":0,"max":100,"min":0}}} -
@daniel_2k Hab ich das so korrekt gemacht?
{"name":"Elements 19B3","serialNo":"S21240E7241","manufacturer":"Nanoleaf","firmwareVersion":"6.1.2","hardwareVersion":"1.1-0","model":"NL52","discovery":{},"effects":{"effectsList":["Bloom","Calming Waterfall","Clouds","Ember","Fireflies","Glimmer","Sahara Night","Splash","Sunbeam","Test Highlight 1","Test Organic 1","Warm Waves","Warm Waves Slow"],"select":"Ember"},"firmwareUpgrade":{},"panelLayout":{"globalOrientation":{"value":242,"max":360,"min":0},"layout":{"numPanels":79,"sideLength":67,"positionData":[{"panelId":57920,"x":207,"y":398,"o":360,"shapeType":15},{"panelId":53250,"x":181,"y":355,"o":300,"shapeType":15},{"panelId":16579,"x":131,"y":355,"o":240,"shapeType":15},{"panelId":45443,"x":106,"y":398,"o":180,"shapeType":15},{"panelId":8514,"x":131,"y":442,"o":120,"shapeType":15},{"panelId":54535,"x":181,"y":442,"o":60,"shapeType":15},{"panelId":63893,"x":207,"y":456,"o":540,"shapeType":15},{"panelId":26964,"x":232,"y":500,"o":480,"shapeType":15},{"panelId":38932,"x":282,"y":500,"o":420,"shapeType":15},{"panelId":2261,"x":307,"y":456,"o":360,"shapeType":15},{"panelId":6325,"x":282,"y":413,"o":300,"shapeType":15},{"panelId":34932,"x":232,"y":413,"o":240,"shapeType":15},{"panelId":2490,"x":332,"y":471,"o":600,"shapeType":15},{"panelId":39291,"x":307,"y":514,"o":540,"shapeType":15},{"panelId":27966,"x":332,"y":558,"o":480,"shapeType":15},{"panelId":65023,"x":382,"y":558,"o":420,"shapeType":15},{"panelId":3263,"x":408,"y":514,"o":360,"shapeType":15},{"panelId":40062,"x":382,"y":471,"o":300,"shapeType":15},{"panelId":32437,"x":483,"y":616,"o":780,"shapeType":15},{"panelId":61044,"x":508,"y":572,"o":720,"shapeType":15},{"panelId":7988,"x":483,"y":529,"o":660,"shapeType":15},{"panelId":36853,"x":433,"y":529,"o":600,"shapeType":15},{"panelId":48567,"x":408,"y":572,"o":540,"shapeType":15},{"panelId":11638,"x":433,"y":616,"o":480,"shapeType":15},{"panelId":57030,"x":483,"y":413,"o":660,"shapeType":15},{"panelId":60548,"x":433,"y":413,"o":600,"shapeType":15},{"panelId":31813,"x":408,"y":456,"o":540,"shapeType":15},{"panelId":36101,"x":433,"y":500,"o":480,"shapeType":15},{"panelId":7620,"x":483,"y":500,"o":420,"shapeType":15},{"panelId":64917,"x":508,"y":456,"o":360,"shapeType":15},{"panelId":65381,"x":307,"y":340,"o":720,"shapeType":15},{"panelId":28580,"x":282,"y":297,"o":660,"shapeType":15},{"panelId":32708,"x":232,"y":297,"o":600,"shapeType":15},{"panelId":61189,"x":207,"y":340,"o":540,"shapeType":15},{"panelId":7749,"x":232,"y":384,"o":480,"shapeType":15},{"panelId":36484,"x":282,"y":384,"o":420,"shapeType":15},{"panelId":21311,"x":382,"y":239,"o":1020,"shapeType":15},{"panelId":50174,"x":332,"y":239,"o":960,"shapeType":15},{"panelId":12990,"x":307,"y":282,"o":900,"shapeType":15},{"panelId":41599,"x":332,"y":326,"o":840,"shapeType":15},{"panelId":36925,"x":382,"y":326,"o":780,"shapeType":15},{"panelId":252,"x":408,"y":282,"o":720,"shapeType":15},{"panelId":643,"x":483,"y":268,"o":1140,"shapeType":15},{"panelId":62403,"x":508,"y":224,"o":1080,"shapeType":15},{"panelId":25346,"x":483,"y":181,"o":1020,"shapeType":15},{"panelId":29538,"x":433,"y":181,"o":960,"shapeType":15},{"panelId":58275,"x":408,"y":224,"o":900,"shapeType":15},{"panelId":4835,"x":433,"y":268,"o":840,"shapeType":15},{"panelId":63429,"x":382,"y":123,"o":1020,"shapeType":15},{"panelId":1669,"x":332,"y":123,"o":960,"shapeType":15},{"panelId":38468,"x":307,"y":166,"o":900,"shapeType":15},{"panelId":41990,"x":332,"y":210,"o":840,"shapeType":15},{"panelId":13511,"x":382,"y":210,"o":780,"shapeType":15},{"panelId":50567,"x":408,"y":166,"o":720,"shapeType":15},{"panelId":41500,"x":332,"y":94,"o":1200,"shapeType":15},{"panelId":22105,"x":382,"y":94,"o":1140,"shapeType":15},{"panelId":50840,"x":408,"y":50,"o":1080,"shapeType":15},{"panelId":14296,"x":382,"y":7,"o":1020,"shapeType":15},{"panelId":42777,"x":332,"y":7,"o":960,"shapeType":15},{"panelId":38235,"x":307,"y":50,"o":900,"shapeType":15},{"panelId":28003,"x":282,"y":181,"o":1020,"shapeType":15},{"panelId":39971,"x":232,"y":181,"o":960,"shapeType":15},{"panelId":3298,"x":207,"y":224,"o":900,"shapeType":15},{"panelId":13482,"x":232,"y":268,"o":840,"shapeType":15},{"panelId":42091,"x":282,"y":268,"o":780,"shapeType":15},{"panelId":21803,"x":307,"y":224,"o":720,"shapeType":15},{"panelId":45996,"x":282,"y":65,"o":1020,"shapeType":15},{"panelId":17132,"x":232,"y":65,"o":960,"shapeType":15},{"panelId":53805,"x":207,"y":108,"o":900,"shapeType":15},{"panelId":9832,"x":232,"y":152,"o":840,"shapeType":15},{"panelId":46761,"x":282,"y":152,"o":780,"shapeType":15},{"panelId":18409,"x":307,"y":108,"o":720,"shapeType":15},{"panelId":24169,"x":181,"y":7,"o":1020,"shapeType":15},{"panelId":52904,"x":131,"y":7,"o":960,"shapeType":15},{"panelId":64746,"x":106,"y":50,"o":900,"shapeType":15},{"panelId":27691,"x":131,"y":94,"o":840,"shapeType":15},{"panelId":40299,"x":181,"y":94,"o":780,"shapeType":15},{"panelId":3498,"x":207,"y":50,"o":720,"shapeType":15},{"panelId":0,"x":97,"y":432,"o":60,"shapeType":12}]}},"qkihnokomhartlnp":{},"schedules":{},"state":{"brightness":{"value":100,"max":100,"min":0},"colorMode":"effect","ct":{"value":2500,"max":4000,"min":1500},"hue":{"value":0,"max":360,"min":0},"on":{"value":true},"sat":{"value":0,"max":100,"min":0}}}
@badsnoopy667 Ich frage mich nur gerade, warum meine Firmwareversion älter ist, obwohl wir die selbe Hardware Version haben. Ich hatte gerade erst ein Firmware Update vorgenommen.
Edit: Das Firmwareupdate wird offensichtlich in Stufen durchgeführt. Jetzt wird mir plötzlich die 6.0.5 angeboten.
Edit: Bin jetzt auch auf 6.1.2 -
{"name":"Elements 1692","serialNo":"S21240E6358","manufacturer":"Nanoleaf","firmwareVersion":"5.2.4","hardwareVersion":"1.1-0","model":"NL52","discovery":{},"effects":{"effectsList":["Bloom","Calming Waterfall","Clouds","Ember","Fireflies","Glimmer","Sahara Night","Splash","Sunbeam","Warm Waves"],"select":"Sahara Night"},"firmwareUpgrade":{},"panelLayout":{"globalOrientation":{"value":0,"max":360,"min":0},"layout":{"numPanels":7,"sideLength":0,"positionData":[{"panelId":4765,"x":182,"y":84,"o":360,"shapeType":15},{"panelId":8415,"x":156,"y":41,"o":300,"shapeType":15},{"panelId":45086,"x":106,"y":41,"o":240,"shapeType":15},{"panelId":16734,"x":81,"y":84,"o":180,"shapeType":15},{"panelId":53663,"x":106,"y":128,"o":120,"shapeType":15},{"panelId":59863,"x":156,"y":128,"o":60,"shapeType":15},{"panelId":0,"x":190,"y":50,"o":240,"shapeType":12}]}},"schedules":{},"state":{"brightness":{"value":100,"max":100,"min":0},"colorMode":"effect","ct":{"value":4000,"max":4000,"min":1500},"hue":{"value":0,"max":360,"min":0},"on":{"value":false},"sat":{"value":0,"max":100,"min":0}}}@chiroptera , @badsnoopy667
Ich habe Version 1.3.0 auf Github zum Testen bereitgestellt.
Elements und Lines sollten jetzt als solche erkannt werden.
Wenn noch was auffällt, einfach melden.Wegen der alive-Erkennung: ich nutze als Fallback (weil ja die Location wegen dem Firmware-Bug nicht korrekt gefült ist) die IP-Adresse des SSDP-Pakets als Fallback. So sollte die Erkennung wieder funktionieren.
@daniel_2k
Vielen Dank für die schnelle Umsetzung! Ich hab den Adapter jetzt auf 1.3.0 gezogen und werde das mal ausprobieren. Mit 1.2.1 hat er zuletzt einfach gar keine Verbindung zu den Elements mehr bekommen, das sieht jetzt (nach 15 Minuten) schon besser aus. Auch ein/ausschalten über "state" ging bisher, auch nachdem die Panels eine Zeit lang aus waren. Wenn das so bleibt, kann ich auf meinen Homekit-Kurbefehl-Workaround zum schalten der Panels bald verzichten! Danke dafür!Update: Ja sehr geil! Man kann ja sogar die Wisch- und Touchgesten an den Panels auslesen. Hab erstmal die Rollladensteuerung vom Wohnzimmer auf die Wischgesten gelegt... einfach weil's geht. ;-)
@daniel_2k
Leute könnt ihr mir mitteilen wie ihr überhaupt die Nanoleaf eingebunden habt in euer Netzwerk daheim?
Ich möchte kein Apple Homekit verwenden, und ohne kann ich es nicht einbinden.
Via Desktop-App schlägt es immer fehl mit der Meldung "Fehler - Wählen Sie das zu koppelnde Gerät aus"... obwohl ich definitiv alles richtig mache..
Danke euch! -
Danke euch!@igor123
Du brauchst zum Einbinden in dein Netzwerk auch kein Apple Homekit.
WLAN genügt. Steuern lassen sich die nanoleaf-Geräte mit der dazugehörigen nanoleaf-App.
Wenn du Alexa, Google Home etc. hast dann gibt's dafür einen Skill von nanoleaf, um die über den Lautsprecher zu steuern.
Ansonsten kannst du die nanoleaf-Geräte halt mit den ioBroker-Adapter in ioBroker einbinden und alles von einer Plattform aus steuern. Dazu brauchst du aber auch kein Apple Homekit.Welches nanoleaf-Gerät hast du denn überhaupt? Hast du es mit deinem Home-WLAN verbunden und lässt sich es mit der App steuern?
Die Desktop-App habe ich noch nie ausprobiert, wird aber sicher genauso funktionieren wie die Smatphone-App. Kopplung erfolgt über den Schlüssel, der hinten auf dem Controller der nanoleafs steht. -
@igor123
Die Desktop-App habe ich noch nie ausprobiert, wird aber sicher genauso funktionieren wie die Smatphone-App. Kopplung erfolgt über den Schlüssel, der hinten auf dem Controller der nanoleafs steht.@daniel_2k
ich habe die Nanoleaf Elements Wood
Irgendwie kann ich diese jedoch nicht ohne Cloud betreiben.
Er verlangt immer, dass ich icloud aktiviere und über die Home-App, also Homekit, das ganze einrichte.
irgendwie bin ich zu doff dafür
Auch eine gescheite Anleitung zum einbinden ohne Homekit und ohne cloud konnte ich nirgends finden.
Ich möchte diese eigentlich nur Lokal verwenden, eben via iphone, und anschließend im iobroker für weitere dinge "missbrauchen" -
@igor123
Die Desktop-App habe ich noch nie ausprobiert, wird aber sicher genauso funktionieren wie die Smatphone-App. Kopplung erfolgt über den Schlüssel, der hinten auf dem Controller der nanoleafs steht.@igor123
Also ich gehe mal davon aus, dass du ein iPhone hast.
Da wäre die Standardanleitung, die Elements mit der nanoleaf-App zu koppeln, die hier:
https://nanoleaf.me/de-DE/products/nanoleaf-elements/get-started/#pairing-for-ios
nanoleaf App installieren, Gerät hinzufügen, QR-Code scannen, fertig. Ich weiß ja nicht in welchen Menüs du dich herumtreibst, dass du iCloud und Apple Homekit brauchst.
Das ist eigentlich super simpel. -
@igor123
Das ist eigentlich super simpel.@daniel_2k
Genau das ist es
Sollte total simpel sein, aber irgendwie mag er nicht. Ich werde es gleich morgen nochmals durchführen und berichten, inkl. screenshots, sollte es nicht plötzlichdoch funken.
Ich nutze ein iPhone 12 pro
Du hast jedoch icloud + homekit deaktiviert?
Wenn die zwei sachen aktiv waren, ging es - ich will jedoch kein homekit bzw iCloud nutzenÜbrigens steht auch in dieser Anleitung "2.5
Scannen des HomeKit Kopplungscodes zwecks Kopplung." - heißt für mich er verknüpft es mit HomeKit -
@daniel_2k
Genau das ist es
Scannen des HomeKit Kopplungscodes zwecks Kopplung." - heißt für mich er verknüpft es mit HomeKit@igor123
Also ich habe selbst kein iPhone, sondern bin Android-Nutzer, von daher kann ich dir da nicht so gut weiterhelfen.
Wo stößt du denn auf den Punkt iCloud und Apple Homekit?
Bei Android läuft das so: App aus dem PlayStore herunterladen (sollte ja analog AppStore bei Apple sein). App starten. Dann musst du dich anmelden. Bei mir geht das entweder mit meinem Google-Account (bei iOS vlt. mit dem iCloud-Account, den du ja auf jeden Fall haben müsstest, da du ja sonst die App nicht aus dem AppStore laden kannst).
Man kann sich aber auch mit E-Mail-Adresse normal registrieren.
Anschließend sollte der Assistent kommen, mit dem du neue Geräte hinzufügen kannst. In der iOS-Anleistung steht tatsächlich was von HomeKit Kopplungscode. Aber HomeKit ist ja nur ein Software-Framework. Ich vermute, dass ist der Weg, wie das bei iOS mit dem koppeln läuft.
Du kannst aber auch die manuelle Methode OPTION B: Kopplung über manuelle Eingabe versuchen. Da musst du dann den 8-stelligen Code, der auf der Rückseite des Controllers steht eingeben.
Geht dann eigentlich genauso.
Mehr kann ich dazu leider nicht sagen, da ich keine Apple-Geräte habe. -
@igor123
Mehr kann ich dazu leider nicht sagen, da ich keine Apple-Geräte habe.@daniel_2k sagte in Test Adapter nanoleaf-lightpanels v1.3.x GitHub/latest:
Also ich hab mir das ganze nun genauer angeschaut.
Über einen Android-Device funkt alles ohne probleme - da wird keine koppelung mit irgendeiner Cloud oder einem Account verlangt.
Also könnte ich auf Wunsch Nanoleaf nur lokal via Android-Smartphone durchführen.
Mache ich genau das selbe, jedoch via iphone, bei dem iCloud sowie Homekit deaktiviert/Deinstalliert ist (iCloud ist für App-Download nicht notwendig sondern nur ein Apple-Account), dann funkt es definitiv nicht - anbei einpaar bilder wie es ausschaut am Handy.
1.
2.
Aktiviere ich nur icloud, damit ich zb "Gerät suchen" am iphone verwenden kann, dann kommt:
Auch wenn ich via Android es in die Nanoleaf-Cloud sync und dann am iphone mir die daten runterladen möchte macht er zwar das, aber auch nicht komplett ohne akzeptieren von Homekit & iCloud Sync -.-
Aber danke dir für die Mühe!
Vielleicht gibt es wem anderen der es irgendwie ohne iCloud und Homekit am iPhone geschafft hat?
1.
2.
@igor123
Was ist denn, wenn du oben rechts auf das + drückst? Kannst du dann ein neues Zuhause ohne Homekit erstellen? -
@igor123
Was ist denn, wenn du oben rechts auf das + drückst? Kannst du dann ein neues Zuhause ohne Homekit erstellen?@badsnoopy667
Leider nicht.
Auch dann kommt gleich die icloud-Homekit-meldung.
Keiner hier der die Apple-app nutzt? -
Blöde Frage nachdem wir jetzt zum bestehenden System noch ein weiteres Shades dazu bekommen habe:
Brauche ich für jedes System eine eigene Instanz des Adapters? Bei "Suchen" werden ja beide IPs gelistet, aber ich kann immer nur ein System auswählen.
@holgerwolf
Ja. -
@ofbeqnpolkkl6mby5e13 Danke :-)
H Homoran verschob dieses Thema von Tester am
H Homoran verschob dieses Thema von ...nicht in offiziellem Repo am
Möglicherweise ist dieses Projekt für Sie nützlich.
https://github.com/MyrikLD/LeafBus -
