  4. Admin 1.7.0 Fehler
Admin 1.7.0 Fehler
36 Beiträge 12 Kommentatoren 6.9k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    @Nepomukl:
    Der Aufruf mit
    "iobroker start admin.0"
    brachte wieder Leben in meinen Broker. Er hat sich aber gefühlt sehr zäh wieder hoch geschraubt obwohl auf einem Cubie.
    Anfangs kamen etliche Fehlermeldungen
    vis.0	2017-03-08 20:09:58.568	error	at ontimeout (timers.js:365:14)
    vis.0	2017-03-08 20:09:58.568	error	at Timeout._onTimeout (/ssd/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2581:27)
    vis.0	2017-03-08 20:09:58.568	error	at new ObjectsInMemServer (/ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2734:7)
    vis.0	2017-03-08 20:09:58.568	error	at /ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2727:9
    vis.0	2017-03-08 20:09:58.568	error	at _initWebServer (/ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2629:24)
    vis.0	2017-03-08 20:09:58.568	error	at Server.listen (net.js:1391:5)
    vis.0	2017-03-08 20:09:58.568	error	at listen (net.js:1295:10)
    vis.0	2017-03-08 20:09:58.568	error	at Server._listen2 (net.js:1259:14)
    vis.0	2017-03-08 20:09:58.568	error	at exports._exceptionWithHostPort (util.js:1045:20)
    vis.0	2017-03-08 20:09:58.568	error	at Object.exports._errnoException (util.js:1022:11)
    vis.0	2017-03-08 20:09:58.568	error	Error: listen EADDRINUSE :::9001
    vis.0	2017-03-08 20:09:58.568	error	^
    vis.0	2017-03-08 20:09:58.568	error	events.js:160 throw er; // Unhandled 'error' event
    telegram.0	2017-03-08 20:09:42.552	error	no connection to objects DB
    sayit.0	2017-03-08 20:09:27.174	error	no connection to objects DB
    ical.0	2017-03-08 20:09:24.182	error	no connection to objects DB
    text2command.0	2017-03-08 20:09:23.250	error	no connection to objects DB
    hm-rpc.0	2017-03-08 20:09:18.981	error	no connection to states DB: Connection timeout
    scenes.0	2017-03-08 20:09:15.894	error	no connection to states DB: Connection timeout
    javascript.0	2017-03-08 20:09:08.355	error	no connection to states DB: Connection timeout
    web.0	2017-03-08 20:08:57.330	error	no connection to states DB: Connection timeout
    vis.0	2017-03-08 20:08:56.952	error	no connection to states DB: Connection timeout
    denke aber das da das Timing nicht gepasst hat. Jetzt ist Ruhe und es lüppt wie es soll (denke ich).
    Den hm-rpc musste ich als einzigen per Hand noch einmal durch starten, der hatte irgendwie geklemmt.
    Andreas `
    Hast du vom update ioBroker gestoppt? Sieht so aus als nicht.
    • N Offline
      N Offline
      nobse
      @Bluefox Vielen Dank jetzt sind die Fenster weg. Das war aber erst nach dem Update so. Vorher ging es immer ohne Fenster.
      Gruß Norbert
      CCU2 • Raspberry für Wetterstation • CMS http://www.exv2.de • HP ProLiant MicroServer Gen8 12GB RAM, 2x3TB, Windows Essentials Server 2016 mit ioBroker
      • N Offline
        N Offline
        Nepomukl
        Jo Bluefox,
        war gestoppt. Den ersten Updateversuch hatte ich von der Weboberfläche gestartet.
        Da blieb er ja hängen. Obwohl da stand iobroker gestoppt oder so ähnlich.
        Auf der Konsole konnte ich ihn dann nochmals stoppen.
        Alle weiteren Schritte waren dann nur noch Konsole.
        Die Fehlermeldungen kamen dann als die Weboberfläche wieder erreichbar war.
        • N Offline
          N Offline
          Nepomukl
          So, ich glaube ich habe das Problem bei mir identifiziert.
          Sobald ich in der Konfig des Admin Adapters von allen IP-Adressen auf die IP-Adresse des Cubies umstelle
          geht nichts mehr.
          Beim speichern und schließen des Konfigdialoges bleibt dieser auch stehen.
          Im Anschluss bleibt die Weboberfläche weg. Im Hintergrund läuft noch alles.
          Kann die Einstellung so bleiben auf alle IP's?
          Und wo kann ich die Konfig zurück stellen? Welches File speichert die Werte?
          Denn wenn ich ein Backup zurück hole ist es das gleiche Spiel. Es sei denn es ist ein ganz altes.
          Gruß Andreas
          • N Offline
            N Offline
            Nepomukl
            Hat keiner eine Idee?
            hab schon in iobroker-data/files/admin.admin weg gelöscht und den Admin Adapter neu installiert.
            Komme immer noch nicht auf die Weboberfläche.
            Sagt mir wenigstens wo die Javascripte gespeichert sind. Das ich die nicht alle neu machen muss, welchen Ordner muss ich seperat sichern.
            Für die ganzen Views muss ich ja nur iobroker-data/files/Vis sichern, oder?
            Dann kann ich nämlich auch mit einer alten Datensicherung leben.
            • apollon77A Offline
              Versuch doch mal iobroker add admin … dann gibts im Zweifel ne neue Admin instanz die tut :-) vorher ggf mit iobroker stopn admin.0 die nicht gehende ausmachen.
              War das nicht so das man "0.0.0.0" wählen muss beim Bindung weil sonst komische Dinge passieren ?!
              • N Offline
                N Offline
                Nepomukl
                Besten Dank
                Admin.1 läuft. Konnte jetzt Admin.0 weg löschen.
                Werde dann noch probieren auf die 0 zurück zu kommen.
                Woher soll man denn das wissen mit dem 0.0.0.0 ?
                Da sollte zumindest die Auswahl gesperrt werden.
                  @Nepomukl:
                  Woher soll man denn das wissen mit dem 0.0.0.0 ? `
                  http://www.iobroker.net/?page_id=5473&l … figuration
                  Ist sogar rot!
                  • N Offline
                    N Offline
                    Newmiraculix
                    Hallo zusammen.
                    ich hab auch Probleme und jetzt mit Hilfe dieses Posts und der Anleitung auf der Webseite versucht diese zu lösen.Leider ohne Erfolg :(
                    Ich habe jetzt über die Konsole versucht js-controller und admin Adapter zu updaten. Js-controller war auch kein Problem. Aber wenn ich versuche admin zu aktualisieren bekomme ich folgende Meldung:
                    iobroker.core@0.1.0 /opt/iobroker
                    └── (empty)
                    npm ERR! code 1
                    Ich habe auch schon versucht eine zweite Admin Instanz anzulegen, aber ich kann einfach nicht auf über den Browser zugreifen.
                    Markus
                    CCU2 mit noch nicht ganz so vielen Aktoren :D
                    RaspberryPi2 für SmartHome mit ioBroker
                    RaspberryPi3 für SmartHome Mit iobroker (Multihost)
                    Logitech Harmony Hub
                    RaspberryPi3 mit openELEC
                    Amazon Echo, Echo Dot und Echo…
                    • H Offline
                      hater
                      Selbes Problem bei mir, ich kriege allerdings die Fehlermeldung bei jeglicher Operation am ioBroker.
                      ! events.js:141
                      ! throw er; // Unhandled 'error' event
                      ! Error: listen EADDRINUSE :::9001
                      ! at Object.exports._errnoException (util.js:907:11)
                      ! at exports._exceptionWithHostPort (util.js:930:20)
                      ! at Server._listen2 (net.js:1250:14)
                      ! at listen (net.js:1286:10)
                      ! at Server.listen (net.js:1382:5)
                      ! at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2629:24)
                      ! at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2727:9
                      ! at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2734:7)
                      ! at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2581:27)
                      ! at Timer.listOnTimeout (timers.js:92:15)
                      Eine Neuinstallation des jscontrollers hat ebenfalls keinen Erfolg gezeigt.Eine Neuinstallation des Admin Adapters schlägt mit der genannten Meldung ebenfalls fehl.
                      Basissystem: Synology Docker.
                      CCU2 mit Wärme, Licht und div. anderem.
                      Synology DS916+ mit ioBroker Docker
                      Alexa Echo Dot
                        Dazu gibt es einen separaten Thread.
                        Sollte es jedoch bei deiner Installation in Docker auf ??? Wirklich der Fall sein, dass der port 9001 vergeben ist hilft der Workaround nicht!
                        zuerst iobroker im Installationsverzeichnis stoppen mit sudo iobroker stop
                        Dann die Installation durchführen
                        Dann iobroker wieder starten
                          Vorher ein "iobroker stop" gemacht und geschaut das keine Prozesse mehr laufen?
                          • PatrickP Offline
                            PatrickP Offline
                            Patrick
                            Nach dem Update kann ich iobroker nicht Mal.mehr über die Kommandozeile starten ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201703 ... 81fd65.jpg">https://uploads.tapatalk-cdn.com/20170311/41f5086c07c0e536806c626dbe81fd65.jpg</link_text>" />
                            Hat noch jemand dieses Problem?
                            Oder sogar ne Lösung?
                            Gesendet von meinem EVA-L09 mit Tapatalk~~
                              ENOSPC!
                              Deine Speicherkarte ist voll
                              • PatrickP Offline
                                PatrickP Offline
                                Patrick
                                Nachtrag node -v 6. 9.4
                                Npm 3.10.10
                                • PatrickP Offline
                                  PatrickP Offline
                                  Patrick
                                  @Homoran:
                                  ENOSPC!
                                  Rainer `
                                  Hmm ok irgendwas müllt da die Speisekarte voll nach dem ich was lösche ist es kurz drauf wider voll
                                    Hast du ein Image aus dem ioBroker Download genommen?
                                    Wenn ja, hast du anschließend wie im Readme beschrieben ein expand filesystem gemacht?
                                      BlueEssi
                                      Ich habe nun auch das Update vom js-controller auf 0.16.2 und admin 1.7.0 gewagt. Es hat offensichtlich auch funktioniert und VIS lässt sich öffnen. Nur leider kann ich mich auf der Adminseite nicht mehr Anmelden. "Name und Kennwort sind falsch" sagt die https-Anmeldeseite. Vorher ging es mit diesen Logindaten. Weiß hier jemand rat.
                                        Turbo
                                        Du musst Dein Passwort neu vergeben.
                                        In der Konsole
                                        iobroker passwd admin
                                        eingeben.
                                        Viele Grüsse
                                        Uwe
                                          BlueEssi
                                          @Turbo:
                                          In der Konsole
                                          eingeben.
                                          Viele Grüsse
                                          Uwe `
                                          Danke Uwe, das hat geklappt.
